Home » Archived » Buckminster » How to include component version with an action path
How to include component version with an action path [message #480867] Tue, 18 August 2009 13:55 Go to next message
I'm adding an action to a feature component, via a cspex, that generates a
product archive, much like the mailapp tutorial. I want the archive name to
include version and platform information. I've got the following so far
which adds the platform information.
<cs:public name="product.install.archive" actor="ant">
<cs:actorProperties>
<cs:property key="buildFile" value="build/product.ant"/>
<cs:property key="targets" value="product.install.archive"/>
</cs:actorProperties>
<cs:prerequisites alias="action.input">
<cs:attribute name="product.install"/>
</cs:prerequisites>
<cs:products alias="action.output"
base="${buckminster.output}/">
<cs:path
path="MailApp.${target.os}.${target.ws}.${target.arch}.zip"/ >
</cs:products>
</cs:public>
Is this a good approach? I've gotten stuck now because I can't find a
property for the version of the component. I want the complete version
number with substituted qualifier.
Tas
Re: How to include component version with an action path [message #480909 is a reply to message #480867] Tue, 18 August 2009 17:03 Go to previous messageGo to next message
Hi Tas,
The substituted qualifier is not available as a property since it is generated as part of the build. Ideally, the build
should have several phases. A first one that computes things like that and creates a set of advices in a context and
then the real build that have access to that context. This is a planned improvement but nothing that we have ready just
yet. But there are other solutions that you might want to try.
The build.xml that is bundled with our PDE support contains two ant macros that you might find useful. The
extractFeatureVersion and extractBundleVersion. Both takes two attributes. A 'file' from which to extract the version
and a 'property' that will receive the extracted version.
You can get access to these macros by adding this line to your ant script:
<import file="${buckminster.pdetasks}"/>
and then you can extract a version with:
<extractFeatureVersion file="${sp:manifest}" property="feature.version"/>
For this to work, your cspec must pass the feature.xml file that contains the calculated qualifier using a prerequisite
with alias="manifest".
HTH,
Thomas Hallgren
Re: How to include component version with an action path [message #480953 is a reply to message #480909] Wed, 19 August 2009 03:31 Go to previous messageGo to next message
Hi Thomas,
I did notice the extractFeatureVersion task but couldn't think of a way to
use as part of an action's products. My current understanding of actions is
that you need to pre-declare output paths and artifacts in the cspec/cspex,
which means I need to know it before the action runs. It looks like a
chicken and egg situation to me?
My end goal is to generate and publish multiple product zips during the
build. Is this the sort of thing you'd place in a high-level build script,
for example in a top-level releng component. If I had this component use the
buckminster task to invoke the product archive task for each target platform
would I be able to extract the version number (with qualifier) there as it
is after the build of the site?
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:h6f4u4$j0u$1@build.eclipse.org...
> Hi Tas,
> generated as part of the build. Ideally, the build should have several
> advices in a context and then the real build that have access to that
> that you might find useful. The extractFeatureVersion and
> extract the version and a 'property' that will receive the extracted
> version.
> the calculated qualifier using a prerequisite with alias="manifest".
> HTH,
> Thomas Hallgren
Re: How to include component version with an action path [message #480974 is a reply to message #480953] Wed, 19 August 2009 04:48 Go to previous messageGo to next message
Hi Tas,
On 08/19/2009 09:31 AM, Tas Frangoullides wrote:
> Hi Thomas,
> to use as part of an action's products. My current understanding of
> actions is that you need to pre-declare output paths and artifacts in
> the cspec/cspex, which means I need to know it before the action runs.
> It looks like a chicken and egg situation to me?
The way we solve that is to use a folder as the output path and then let the ant-script create the part of the name that
includes the version.
> script, for example in a top-level releng component. If I had this
> component use the buckminster task to invoke the product archive task
> for each target platform would I be able to extract the version number
> (with qualifier) there as it is after the build of the site?
We have some work in progress to make this kind of thing declarable (and of course runnable) in a cspec. I know it
doesn't help you much right now but it might be good to know that it's coming.
You can subscribe yourself to bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=286637 "Add ability to repeat actions
with different input".
Thomas Hallgren
Re: How to include component version with an action path [message #480978 is a reply to message #480974] Wed, 19 August 2009 04:57 Go to previous messageGo to next message
Thomas,
Thanks. Using a folder sounds like a reasonable way forward; I can produce
multiple archives and give them a version number.
So at present I cannot access the qualifier, even from within an ant script
that implements an action?
Tas
news:h6ge93$4c4$1@build.eclipse.org...
> Hi Tas,
>> Hi Thomas,
> the ant-script create the part of the name that includes the version.
> of course runnable) in a cspec. I know it doesn't help you much right now
> repeat actions with different input".
> Regards,
> Thomas Hallgren
Re: How to include component version with an action path [message #480987 is a reply to message #480978] Wed, 19 August 2009 05:26 Go to previous message
On 08/19/2009 10:57 AM, Tas Frangoullides wrote:
> Thomas,
> produce multiple archives and give them a version number.
> script that implements an action?
Not unless you pass the manifest.mf in which the qualifier resides.
- thomas
Previous Topic:New version of Buckminster Book available (rev 0.5)
Next Topic:Build fails after headless resolve using p2
Current Time: Sat Jul 19 11:23:06 EDT 2025
Powered by FUDForum. Page generated in 0.37378 seconds
