WikiText: bc.. does not work? [message #480954] |
Wed, 19 August 2009 03:42  |
Originally posted by: anders.hessellund.gmail.com
I tried to render the following simple document in wikitext's preview
pane as well as in an Ant-generated HTML file, but for some reason the
"bc.."-tag does not work.
h1(#id). An HTML first-level heading
Textile syntax is really simple. You can _emphasize_ text or *emphasize
it even more*.
h2. An HTML third-level heading
p. Here is some code:
bc..
package org.eclipse.workflow;
public class Workflow {
p. Here is a plain old paragraph. It needs to start with "p." to mark
the end of the code block above.
The generated HTML for the blockquote looks like this:
<p>bc..<br/>package org.eclipse.workflow;</p><p>public class Workflow
{</p><p>}</p><p>Here is a plain old paragraph. It needs to start with
“p.” to mark the end of the code block above.</p>
I am using the Galileo-release of Eclipse.
Anders
Re: WikiText: bc.. does not work? [message #481421 is a reply to message #480959] |
Thu, 20 August 2009 17:53  |
Anders Hessellund wrote:
> Ups, I figured it out:
> The linebreak after bc.. should be removed.
Actually, a line break is okay, but the bc.. must be followed by one space character.
WikiText has some documentation on this topic:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .mylyn.wikitext.help.ui/help/Textile-Syntax.html
> BEFORE:
> bc..
> AFTER:
> bc.. package org.eclipse.workflow;
> Cheers,
> Anders
>> Hi,
>> *emphasize it even more*.
>> bc..
>> Cheers,
>> Anders
Re: WikiText: bc.. does not work? [message #598781 is a reply to message #480954] |
Wed, 19 August 2009 03:52  |
BEFORE:
bc..
AFTER:
Anders
> it even more*.
> bc..
> Cheers,
> Anders
Re: WikiText: bc.. does not work? [message #598806 is a reply to message #480959] |
> BEFORE:
> bc..
> AFTER:
> Cheers,
> Anders
>> Hi,
>> bc..
>> Cheers,
>> Anders
FUDForum. Page generated in 0.04488 seconds
