Home » Eclipse Projects » SWTBot » Setting values in the Properties View
Setting values in the Properties View [message #480316] Fri, 14 August 2009 20:06 Go to next message
Originally posted by: jconlon.apache.org
Does anyone have an example on how to set values in a Properties View?
Not really sure how to get to a value column that has a combo box in it.
I can navigate the tree to the Property column like this
SWTBotTreeItem id = propTree.getTreeItem("Identification");
SWTBotTreeItem premNode = id.getNode("Premises");
but I am stumped on how to get to the pull down in the value column for
Premises.
Any suggestions?
thanks,
John
Re: Setting values in the Properties View [message #480400 is a reply to message #480316] Sun, 16 August 2009 15:48 Go to previous messageGo to next message
Hi John,
> Premises.
Try this to activate the cell editor:
premNode.click();
or
premNode.doubleClick();
Then try this to select the value
bot.comboBox().setSelection( "value" );
Then click to another node to finish
id.click();
HTH,
Stefan
Re: Setting values in the Properties View [message #480528 is a reply to message #480400] Mon, 17 August 2009 10:15 Go to previous message
Hi Stefan,
Yes that did it.
But I did need to change the comboBox() to
bot.ccomboBox().setSelection( "value" );
BTW your ContextMenuHelper was also a big help for selecting context menus.
thanks again!
John
Stefan Seelmann wrote:
> Hi John,
>> Premises.
> premNode.click();
> or
> id.click();
> HTH,
> Stefan
Previous Topic:autocomplete?
Next Topic:No SWTBotTreeItem recursive expand
Current Time: Sat Jul 19 12:50:51 EDT 2025
Powered by FUDForum. Page generated in 0.24929 seconds
