Home » Modeling » GMF (Graphical Modeling Framework) » set attribute on creation of node
set attribute on creation of node [message #479951] Thu, 13 August 2009 04:34 Go to next message
Hi all,
I need to set an atribute on the creation of a node
eg.
if node A... attribute ON/OFF = ON
if node B... attribute ON/OFF = OFF
A is always ON and B is always OFF!
I know that I need to do this in the nodes create command but I'm not sure
of the best way to do it.
- how do I access the nodes attribute and set it?
Just a brief example should help,
Thanks in advance,
Gary
Re: set attribute on creation of node [message #479958 is a reply to message #479951] Thu, 13 August 2009 05:02 Go to previous messageGo to next message
You should be able to set the attribute in your
XxxCreateCommand.doConfigure method.
Just call newElement.setYyy(...) there.
Regards, Peter
Re: set attribute on creation of node [message #480022 is a reply to message #479958] Thu, 13 August 2009 09:50 Go to previous messageGo to next message
Hi, I've realised that it is more complex than I first thought:
- I have a two nodes (A,B) that reference the same class (ClassName)
(seams as if the create command is for an instance of the class type since
the create command for node A has the name ...ClassNameCreateCommand
and the create command for node B has the name ...ClassNameCreateCommand2
-In these create command methods there is nothing called
XxxCreateCommand.doConfigure as you mentioned!
Am I looking in the right place?
(Xxx.diagram.edit.commands > ClassNameCreateCommand)
Thanks in advance,
Gary
Re: set attribute on creation of node [message #480023 is a reply to message #480022] Thu, 13 August 2009 09:59 Go to previous messageGo to next message
Hi Gary,
Yes, you are looking in the right place.
If you use a GMF version prior to 2.2, then the doConfigure method does
not exist. In this case, you can modify doExecuteWithResult.
You get your new element by "getNewElement()", cast it to Xxx.
Regards, Peter
Re: set attribute on creation of node [message #480030 is a reply to message #480023] Thu, 13 August 2009 10:11 Go to previous messageGo to next message
hi, the only methods in my create command are:
public ClassNameCreateCommand(CreateElementRequest req){ *** }
protected EObject getElementToEdit() { *** }
protected EClass getEClassToEdit() { *** }
_____________________________________________________
do I need to create my own method?
Gary
Re: set attribute on creation of node [message #480044 is a reply to message #480023] Thu, 13 August 2009 10:24 Go to previous messageGo to next message
my entire create command =
____________________________________________________________ _______________
public class SwitchReferenceCreateCommand extends CreateElementCommand {
public SwitchReferenceCreateCommand(CreateElementRequest req) {
super(req);
EObject container = ((CreateElementRequest) getRequest())
.getContainer();
if (container instanceof View) {
container = ((View) container).getElement();
return container;
return ViewManagement.ViewManagementPackage.eINSTANCE
.getSwitch();
As you can see there is no reference to the methods you suggested,
I'm not sure where I'm going wrong,
thanks,
Gary
Re: set attribute on creation of node [message #480045 is a reply to message #480044] Thu, 13 August 2009 10:45 Go to previous messageGo to next message
Not sure about when this method is generated. You can override it anyway:
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
CommandResult result = super.doExecuteWithResult(monitor, info);
((SwitchReference)getNewElement()).setXxx();
return result;
Or, maybe better:
protected EObject doDefaultElementCreation() {
SwitchReference newSwitchReference =
(SwitchReference)super.doDefaultElementCreation();
// newSwitchReference.setXxx();
return newSwitchReference;
Re: set attribute on creation of node [message #480055 is a reply to message #480045] Thu, 13 August 2009 11:31 Go to previous messageGo to next message
Thanks for your help, that works great!
Re: set attribute on creation of node [message #480569 is a reply to message #479951] Mon, 17 August 2009 12:31 Go to previous messageGo to next message
Hello Gary,
You can:
- create two node mappings one for node A, another for node B
- create two constraints for each of these mappings saying A => attribute
ON/OFF = ON, B => attribute ON/OFF = OFF
- create two FeatureSequenceInitializers for each A/B node mapping setting
attribute ON/OFF to ON/OFF on creation
See Ecore diagram editor example, link mappings for containment/non containment
references for more details.
Alex Shatalin
Re: set attribute on creation of node [message #480719 is a reply to message #480569] Tue, 18 August 2009 06:05 Go to previous messageGo to next message
Hi, Thanks for this info, do you have a link to the example you mentioned?
I can't find it, and I've never used OCL constraints before, also never
used Feature Seq Initializers before so I could do with as much help as I
can get.
Gary
Re: set attribute on creation of node [message #480775 is a reply to message #480719] Tue, 18 August 2009 08:53 Go to previous messageGo to next message
Hello Gary,
See http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.ecore.editor/?root=Modeling_Project
Alex Shatalin
Re: set attribute on creation of node [message #480975 is a reply to message #480775] Wed, 19 August 2009 04:48 Go to previous message
Thanks for that Alex, this is a much tidyer way of setting an attribute,
since you don't need to add code after generation!
Thank you all for your help and advice!
Previous Topic:How to automatically create a default node after generating a new diagram
Next Topic:Double EditPart.java files
Current Time: Sat Jul 19 05:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.04901 seconds
