Home » Modeling » GMF (Graphical Modeling Framework) » Child references
Child references [message #479209] Mon, 10 August 2009 05:45 Go to next message
I have a model
Role <-- Contract --> Role
Over here Roles are of type node
& Contract is a link between two Roles.
Now if the link is of complex type 'Contract' in XML schema & 'Contract'
has it's own sub-elements of complex type. e.g.
<Contract>
<Term />
<Clauses />
</Contract>
Can this be represented using GMF? I mean can a link has child references
as nodes? If not how this can be modeled?
Swapnil
Re: Child references [message #479222 is a reply to message #479209] Mon, 10 August 2009 06:12 Go to previous messageGo to next message
Swapnil,
It's also best not to cross post the same question to multiple
newsgroups with separate posts.
Swapnil wrote:
> I have a model
> 'Contract' has it's own sub-elements of complex type. e.g.
> <Contract>
> <Term />
> <Clauses />
> </Contract>
> references as nodes? If not how this can be modeled?
> Cheers,
> Swapnil
Re: Child references [message #479452 is a reply to message #479209] Tue, 11 August 2009 03:32 Go to previous messageGo to next message
I hope, I understand your problem correctly.
I think you only need to have a class for the contract in your meta-model.
So your ecore would look like this:
Role
> outgoingContracts : Contract (0 to * containment)
>> EOpposite would be source
> incommingContracts : Contract (0 to * reference)
>> EOpposite would be target
Contract
> source : Role (1 to 1 reference)
> target : Role (1 to 1 reference)
> terms : Term (0 to * containment)
> clauses : Clause (0 to * containment)
The rest should be set automatically.
Tobias
Swapnil wrote:
> I have a model
> <Contract>
> <Term />
> <Clauses />
> </Contract>
> Cheers,
> Swapnil
Re: Child references [message #479463 is a reply to message #479452] Tue, 11 August 2009 04:22 Go to previous messageGo to next message
Hi Tobias,
Thanks for the reply.
I tried that, but it gives errors when i generate the diagram editor code.
The method add(Contract) in the type List<Contract> is not applicable for
the arguments
(TermType) TermTypeCreateCommand.java /TEST.diagram/src/Smc11/diagram/edit/commands line
61 Java Problem
The method getTerm() is undefined for the type
SMCType Smc11DiagramUpdater.java /TEST.diagram/src/Smc11/diagram/part line
51 Java Problem
I think as i don't have Contract as a Top reference node its not allowing
Term's containment feature set as a Contract.
In my case Contract is of type link.
Please provide me some help on this.
Swapnil
Re: Child references [message #479467 is a reply to message #479463] Tue, 11 August 2009 04:59 Go to previous messageGo to next message
did you regenerate the *.genmodel and the model/edit-code?
I'm not so sure how you can dynamically add and delete elements to the
connection. I only used an enum-type initialized with the "Feature Seq
Initializer".
The enum in my case is no Top-Level-Node and changeable using the
properties tab (has to be set in the *.genmodel attributes to
'changeable').
If you have a more complex object that is attribut of you connection, you
might have to use diagram partitioning
(http://www.jevon.org/wiki/GMF_Diagram_Partitioning) or adopt the
properties tab.
Maybe you also can represent your attributes with a "Feature Label
Mapping" in the "Link Mapping".
Never the less, when I set the source- and target-features of my
Connections to changeable I get a list with all nodes, where I can change
the references.
I hope this helps.
Tobias
Re: Child references [message #480545 is a reply to message #479209] Mon, 17 August 2009 11:10 Go to previous message
Hello Swapnil,
Technically domain model element associated with link can contain child elements,
so if you don'd need to show there child elements somehow on a diagram it
can be done.
Alex Shatalin
Previous Topic:Traingle Figure
Next Topic:Obtain EditPart from View model od domain model element
Current Time: Sat Jul 19 17:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
