Source Attach for EclipseLink [message #479348] |
Mon, 10 August 2009 13:54  |
Hello Everyone
I just started learning JPA (used plain Hibernate in a little project two years
ago) and I am using EclipseLink as persistence provider.
To complicate things a little bit, I am creating an RCP application :-)
I installed the RT EclipseLink plugins/features (including source) and now I am
wondering why I cant see the JavaDoc from the ContentAssistant. I also tried to
put the org.eclipse.persistence.core.source and
org.eclipse.persistence.jpa.source bundles into the depencies but it didnt work.
The problem is, that the Library Plugin-Dependencies does not allow modification
and this implies Source-Attachements (otherwise I could just attach the source
form the eclipselink downloads).
Is there a way to achieve this? I dont like to switch between a browser with an
documentation open and Eclipse since its much more convinient to read about
functionality where you need in (in code).
Thanks in advance
-- Marc
Re: Source Attach for EclipseLink [message #481037 is a reply to message #479348] |
Wed, 19 August 2009 08:01  |
Hm, i don't know about the installable feature, I downloaded the EL OSGi
Bundles form eclise.org/eclipselink and put all of them into my target
platform (including the source bundles), and that worked for me (means I
can see Javadoc and the sourcecode).
Which Version are you using. I used the latest stable bundles 1.1.2.
I remember that in older versions they forgot to put the line
Eclipse-SourceBundle:
bundle.name.for.which.this.bundle.isSourceBundle;version="version " in
the manifest.mf, which is used to discover the sources for a bundle.
If you use an older version have a look at the manifest.mf and check if
that line is there.
HTH
Tom
Marc Schlegel schrieb:
> Hello Everyone
> Thanks in advance
> -- Marc
FUDForum. Page generated in 0.03687 seconds
