Home » Eclipse Projects » Platform - User Assistance (UA) » Minimal standalone help system
Minimal standalone help system [message #479007] Fri, 07 August 2009 19:40 Go to next message
I tried installing a minimal stand-alone help system according to the Eclipse help ( http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_standalone.htm) with no luck. I tried from both the Eclipse Classic 3.5.0 for Windows download and the Eclipse for RCP/Plug-in Developers for Windows download.
First, export can't be done to the <location1>/eclipse folder, don't know why but nothing gets written. I tried directly to <location1> and moving the resulting folders and files into the <location1>/eclipse folder and got a bit further.
Second, I got the following message when starting with the recommended "java -classpath ..." command: "The Eclipse executable launcher was unable to locate its companion shared library." After searching the web, I found that the Equinox launcher doesn't seem to be included so that has to be copied manually. Okay, so I copied the equinox launcher jar file and folder.
Now I got the following error in a log: "java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter". Can't find a solution to that one.
Does anyone know what I'm doing wrong? Has anyone succeeded in this? How should I get it to work?
Andreas Ekstrand
Re: Minimal standalone help system [message #479149 is a reply to message #479007] Sun, 09 August 2009 16:20 Go to previous messageGo to next message
Hi Andreas,
In an earlier milestone for 3.5, I started with the "Eclipse Platform
SDK" package and managed to do it using those instructions. I haven't
tried it with the GA version of 3.5 yet.
I usually start with the Eclipse Platform SDK package on my machine,
because then I can do plug-in development in the PDE. Maybe the
instructions are specific to using the "Platform SDK" package, I don't know.
Hope this helps,
Lee Anne
Andreas Ekstrand wrote:
> Eclipse help
> file and folder.
> to that one.
> Regards,
> Andreas Ekstrand
Re: Minimal standalone help system [message #479155 is a reply to message #479149] Sun, 09 August 2009 17:47 Go to previous messageGo to next message
Hi Lee Anne,
Thank you for your reply. I tried with the Eclipse Platform SDK, but with the same problem. The launcher bug present in earlier versions probably was re-introduced after the milestone you tested.
I downgraded to Ganymede and that works fine - the drawback is a larger export (about 26MB instead of 11MB) but at least it's functioning.
/Andreas
Re: Minimal standalone help system [message #479157 is a reply to message #479149] Sun, 09 August 2009 17:51 Go to previous message
By the way, I had to edit the config.ini file in order for my help to be visible in the Ganymede export as well, just as you described on the News Portal, Lee Anne. Thanx for sharing!
/Andreas
Previous Topic:IHelpContentProvider is never called
Next Topic:Open drop down menu with cheat sheet
Current Time: Sat Jul 19 13:25:19 EDT 2025
Powered by FUDForum. Page generated in 0.04870 seconds
