Home » Modeling » EMF » Delete elements in a model?
Delete elements in a model? [message #479131] Sun, 09 August 2009 13:21 Go to next message
Originally posted by: formatzeh.gmx.de
How can I safely delete some elements in a model? I implemented some
transformations which, for example, generate new elements contained in a
specific root element. Therefore I want to delete all already existent
elements in the root element. Until now, I did it in that way:
public void generateServiceElements(ServiceAccessComponent sac){
sac.getOperation().clear();
//add some new operations
But once in a while I get the following exception when saving the file
after transformations:
DanglingHREFException: The object 'MetaModel.impl.OperationImpl@1885c3a
(name: myOperation)' is not contained in a resource.
Before I cleared the existing elements I didn't get this exception. So I
could imagine that the elements of the EList<Operation> (received with
sac.getOperation()) aren't deleted really but only the list is cleared.
That's why the elements haven't got a container and the exception is
thrown. How can I clear the list adequate that all elements will be
deleted right?
Re: Delete elements in a model? [message #479140 is a reply to message #479131] Sun, 09 August 2009 14:36 Go to previous messageGo to next message
Gilbert,
Probably you want to use EcoreUtil.delete(eObject, true) for each object
in the list (which will also remove it from the list).
> deleted right?
Re: Delete elements in a model? [message #479144 is a reply to message #479140] Sun, 09 August 2009 15:28 Go to previous messageGo to next message
I get an ConcurrentModificationException? But what is an concurrent
access? When the model is open in the generated editor?
Re: Delete elements in a model? [message #479147 is a reply to message #479144] Sun, 09 August 2009 15:51 Go to previous message
Gilbert,
Keep in mind that as each element in the list is deleted it's removed
from the list so if you are iterating over that very list and calling
delete on each element, you'll get an exception just like what you've
described. Either iterate over a copy of the list or use a counted loop
knowing that the list shrinks as a result of each delete call.
Previous Topic:Validation fails on required EAttribute (EEnum) with default literal value.
Next Topic:get EPackage from a EStructuralFeature
Current Time: Sun Jul 20 12:08:15 EDT 2025
Powered by FUDForum. Page generated in 0.02824 seconds
