Home » Modeling » Modeling (top-level project) » Help: Advice on GUI Designer to choose?
Help: Advice on GUI Designer to choose? [message #478806] Thu, 06 August 2009 22:10 Go to next message
I am starting the development of a database program using Java and Eclipse (Galileo). Having just started with Eclipse, I don't know what is available and useful as a GUI design plug in. Any suggestion?
Its probably best that the tool be free, ...and I don't want to develop any tools or plug-ins for Eclipse, I want to use one that has already been developed.
Re: Help: Advice on GUI Designer to choose? [message #478908 is a reply to message #478806] Fri, 07 August 2009 08:53 Go to previous messageGo to next message
Lou,
GMF lets you develop graphical editors. The Visual Editor Project
supports visual development of UI's based on SWT...
Re: Help: Advice on GUI Designer to choose? [message #478929 is a reply to message #478908] Fri, 07 August 2009 10:31 Go to previous messageGo to next message
I'm a bit confused by your response. I don't want to develop graphical editors. I want to use one that is already developed.
Did I ask in the wrong forum?
Is SWT appropriate if I move the project on to become a web application with jFaces, servlets and Tomcat?
Re: Help: Advice on GUI Designer to choose? [message #478935 is a reply to message #478929] Fri, 07 August 2009 10:44 Go to previous messageGo to next message
Lou,
Comments below.
> editors.
Then you won't be interested in GMF. :-P
Like VE.
Yes, I think so. :-P
Things like the RAP project support web access to an SWT-based
application. The Eclipse 4.0 (e4) work is also targeting the web...
Re: Help: Advice on GUI Designer to choose? [message #478936 is a reply to message #478935] Fri, 07 August 2009 11:03 Go to previous messageGo to next message
Haha, OK. Wrong forum. Thanks for helping, anyway. I guess we'll see about the RAP project later.
I just wanted to ask what to start the prototype with SWT or Swing to make migration easier. Perhaps if you can direct me to the proper forum, I'll ask there.
Re: Help: Advice on GUI Designer to choose? [message #478946 is a reply to message #478936] Fri, 07 August 2009 11:28 Go to previous messageGo to next message
--------------080208050205040802080505
Lou,
It really depends on what type of application you're trying to build.
Things like the Visual Editor Project or the Web Tools Project might be
useful. Also, you might well have a model for your data, e.g,. a schema
and could generate a complete application from that:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Lou,<br>
<br>
schema and could generate a complete application from that:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
<br>
LouArnold wrote:
<blockquote cite="mid:h5hfnq$5cm$1@build.eclipse.org" type="cite">Haha,
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------080208050205040802080505--
Re: Help: Advice on GUI Designer to choose? [message #478949 is a reply to message #478936] Fri, 07 August 2009 11:48 Go to previous messageGo to next message
You are not sure what technology you want to use, but want to create a
prototype? Sound like a case for http://www.eclipse.org/pmf/ But it is
"not there yet" and I don't think that you want it, but still it is
"modelling" newsgroup ;)
You can try to install http://www.eclipse.org/vep/
(http://wiki.eclipse.org/VE/Update) it support SWT and Swing.
VE news group: eclipse.tools.ve
Most likely you will have some problems (installation or usage), so you
would like to check commercials tools (both support SWT and Swing, there
are some free non-commercial versions):
http://www.instantiations.com/windowbuilder/
or http://www.cloudgarden.com/jigloo/
Actually if you are not sure what to use, probably
http://www.netbeans.org/kb/docs/java/gui-db.html fit your needs best.
Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #478951 is a reply to message #478949] Fri, 07 August 2009 11:58 Go to previous messageGo to next message
Krzysztof Kowalczyk wrote on Fri, 07 August 2009 11:48
"modelling" newsgroup Wink
Krzysztof Kowalczyk
I think this answered it. I will try VE, but if things get sticky then, perhaps Netbeans is better.
Thanks very much.
Re: Help: Advice on GUI Designer to choose? [message #479094 is a reply to message #478951] Sun, 09 August 2009 00:14 Go to previous messageGo to next message
Netbeans means Swing and Matisse which may or may not be better. SWT is
cool (and better IMHO) though it is changing in e4 so who knows. They
are going declarative and CSS and Javascript and such things.
If you stay with SWT, forget VE, buy SWT Designer from instantiations.com.
My opinion.
Re: Help: Advice on GUI Designer to choose? [message #479159 is a reply to message #479094] Sun, 09 August 2009 18:16 Go to previous messageGo to next message
I mentioned Netbeans, as in database application one can use Swing
Application Framework https://appframework.dev.java.net/ and JPA and
Netbeans generate and handle such things well out of the box. In Eclipse
it would take much effort to gather proper knowledge about beans
binding, SWT, JFace, JPA and find good plugins to support that.
> SWT is cool (and better IMHO) though it is changing in e4 so who knows. They
It is not "changing", it is "growing". e4 allows for deklarative SWT
(XWT) and for styling controls with CSS. But you don't have to use it!
The old way works like always did.
I am (not yet ;) ) fun of XWT / XAML, but declarative UI has strong
advantages in many use cases IMO.
Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #496793 is a reply to message #479159] Wed, 11 November 2009 06:38 Go to previous message
Soyatec has published the first version of XWT Designer for technical
preview, and has decided to contribute it in eclipse. The integration of
this GUI Design in e4 is on going. If everything goes well, it will be in e4
1.0M3.
Definitively, PMF addresses the Modeling UI in large terms (not only UI ,
but also data binding and scenario),
So, keep turn.
Best regards
Yves YANG
"Krzysztof Kowalczyk" <kowalczyk.krzysztof@gmail.com> wrote in message
news:h5nhrf$s68$1@build.eclipse.org...
> it would take much effort to gather proper knowledge about beans binding,
>> They
> It is not "changing", it is "growing". e4 allows for deklarative SWT (XWT)
> and for styling controls with CSS. But you don't have to use it! The old
> Regards,
> Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #617747 is a reply to message #478908] Fri, 07 August 2009 10:31 Go to previous message
Re: Help: Advice on GUI Designer to choose? [message #617748 is a reply to message #617747] Fri, 07 August 2009 10:44 Go to previous message
Lou,
Comments below.
> editors.
Like VE.
Re: Help: Advice on GUI Designer to choose? [message #617749 is a reply to message #478935] Fri, 07 August 2009 11:03 Go to previous message
Re: Help: Advice on GUI Designer to choose? [message #617750 is a reply to message #617749] Fri, 07 August 2009 11:28 Go to previous message
Lou,
<html>
<head>
</head>
Lou,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: Help: Advice on GUI Designer to choose? [message #617751 is a reply to message #617749] Fri, 07 August 2009 11:48 Go to previous message
Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #617752 is a reply to message #478949] Fri, 07 August 2009 11:58 Go to previous message
> Regards,
> Krzysztof Kowalczyk
Thanks very much.
Re: Help: Advice on GUI Designer to choose? [message #617754 is a reply to message #617752] Sun, 09 August 2009 00:14 Go to previous message
My opinion.
Re: Help: Advice on GUI Designer to choose? [message #617757 is a reply to message #479094] Sun, 09 August 2009 18:16 Go to previous message
Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #618458 is a reply to message #479159] Wed, 11 November 2009 06:38 Go to previous message
1.0M3.
So, keep turn.
Best regards
Yves YANG
>> They
> Regards,
> Krzysztof Kowalczyk
Previous Topic:[Announce] Eclipse/OMG Symposium 2010
Next Topic:[Announce] PMF newsgroup is available
Current Time: Sat Jul 19 08:49:57 EDT 2025
Powered by FUDForum. Page generated in 0.06762 seconds
