Loading Model from Enterprise architect [message #478181] |
Mon, 09 February 2009 23:28  |
Hello all,
Can you please help me in loading the model from EA.
I have created model using enterprise architect 6.5
After creating the model in Enterprise Architect I use the "Export to XMI"
function.
My XMI Output is correct according to UML2.1/XMI 2.1 and the files end
with *.xml suffix.
I changed the extension from .xml to .xmi and loaded the xmi file in
Eclipse using UML Editor.
I got the following exception with
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'pk_in' is not
legal.
Then, i read some newsgroup and corrected pk_in to in.
Then i got exception with
java.lang.IllegalArgumentException: The class 'ValueSpecification' is not
a valid classifier
I have read all the threads in this newsgroup and i am not able to find
the solution.
Please help me in getting loading the model in eclipse. I am facing this
problem from past 7 days and my customer is really need this solution.
Is Enterprise Architect generating incorrect files? Or does UML2 expect an
other kind of xml schema?
Please clarify how to go ahead with this.
Is there any transformation exist from EA Model to UML2 model.
I am using
Eclipse 3.3.0
EMF 2.3.0
UML2 2.1.0
Thanks and Regards,
Anand
Re: Loading Model from Enterprise architect [message #478238 is a reply to message #478219] |
Thu, 12 March 2009 23:58  |
Thanks Raphael for the information.
I used EA 7.1 UML 2.1 and tried loading the model but was unsuccessful
this time also.
I think we need to write our own XMICorrector to correct the XMI file
exported from EA.
I tried acceleo, even i was unsuccessful with that also.
Can you please let me know how to start with correcting XMI file exported
from EA as you have already stated in the above post.
Thanks in advance.
Anand
Re: Loading Model from Enterprise architect [message #627385 is a reply to message #478181] |
Tue, 10 February 2009 12:49  |
Hi Anand,
Is it possible to post the .xmi file you are trying to load?
- James.
"Anand" <anand.007@yahoo.com> wrote in message
news:621052e552fb19e65891815bbd340ddd$1@www.eclipse.org...
> Hello all,
> function. My XMI Output is correct according to UML2.1/XMI 2.1 and the
> files end with *.xml suffix. I changed the extension from .xml to .xmi and
> loaded the xmi file in Eclipse using UML Editor.
> legal.
> a valid classifier
> the solution.
> I am using
> Eclipse 3.3.0
> EMF 2.3.0
> UML2 2.1.0
> Thanks and Regards,
> Anand
Re: Loading Model from Enterprise architect [message #627386 is a reply to message #478185] |
Tue, 10 February 2009 23:27  |
Hello James,
Thanks for your reply.
Here is the XMI content. I could not find the way to attach the file.
I am getting the following error when i load xmi in UML Model editor.
Please help me in this. I am struck up with this problem.
a valid classifier
at
org.eclipse.uml2.uml.internal.impl.UMLFactoryImpl.create(UML FactoryImpl.java:681)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:871)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XM LHelperImpl.java:920)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2171)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFe atureType(XMLHandler.java:2144)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2020)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1799)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.uml2.uml.internal.resource.XMI2UMLHandler.proces sElement(XMI2UMLHandler.java:103)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod elGen(UMLEditor.java:926)
at
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod el(UMLEditor.java:971)
at
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createPag es(UMLEditor.java:1058)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
I am pasting the file contents here:
<?xml version="1.0" encoding="windows-1252"?>
<xmi:XMI xmi:version="2.1" xmlns:uml="http://schema.omg.org/spec/UML/2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:thecustomprofile="http://www.sparxsystems.com/profiles/thecustomprofile/1.0">
<xmi:Documentation exporter="Enterprise Architect" exporterVersion="6.5"/>
<uml:Model xmi:type="uml:Model" name="EA_Model" visibility="public">
<packagedElement xmi:type="uml:Package"
xmi:id="EAPK_CD825798_C93A_4035_82E5_AEC56D9DF236" name="Model"
xmi:id="EAPK_1F199D3E_F346_422d_9D3E_154CFAF09C77" name="Sample"
<packagedElement xmi:type="uml:Class"
xmi:id="EAID_1AE191F0_1502_475e_922B_0D92E48C0FBF" name="ABC.c"
<ownedAttribute xmi:type="uml:Property"
xmi:id="EAID_322327E9_C4CC_4941_AB10_AC127CA6DEC4" name="UB"
visibility="private" isStatic="true" isDerived="false">
<lowerValue xmi:type="uml:LiteralInteger"
xmi:id="EAID_LI000001_C4CC_4941_AB10_AC127CA6DEC4" value="1"/>
<upperValue xmi:type="uml:LiteralInteger"
xmi:id="EAID_LI000002_C4CC_4941_AB10_AC127CA6DEC4" value="1"/>
</ownedAttribute>
xmi:id="EAID_87E66664_4B01_4ecd_8EA4_A10DCB13CFCD" name="UL"
xmi:id="EAID_LI000003_4B01_4ecd_8EA4_A10DCB13CFCD" value="1"/>
xmi:id="EAID_LI000004_4B01_4ecd_8EA4_A10DCB13CFCD" value="1"/>
</ownedAttribute>
<ownedOperation xmi:id="EAID_07A8A26F_1436_4f35_8726_673CA5AAE937"
name="eV" visibility="public" concurrency="sequential"/>
<ownedOperation xmi:id="EAID_EAFA9516_8FA3_43cc_B12B_EED12E9A6442"
name="V" visibility="public" concurrency="sequential"/>
<ownedOperation xmi:id="EAID_FD8BC5FA_5BFD_48d1_8F30_EA5B172ABED4"
name="V2" visibility="public" concurrency="sequential"/>
</packagedElement>
<packagedElement xmi:type="uml:Dependency"
xmi:id="EAID_00761287_6260_4e76_8F06_E94E95866688" visibility="public"
supplier="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9"
client="EAID_1AE191F0_1502_475e_922B_0D92E48C0FBF"/>
xmi:id="EAID_828E1DD7_5321_4b7a_9EAC_09F1EA8FD65A" visibility="public"
supplier="EAID_0AEA91B6_60B8_4044_9552_123705B7C497"
xmi:id="EAID_889E9CB6_2B18_4794_BAD9_FAD0C2F9AE26" visibility="public"
supplier="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"
xmi:id="EAID_9F76A730_FCDB_45db_A6C2_3F46CB1AB37F" visibility="public"
supplier="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"
xmi:id="EAID_F7890F02_791A_48a3_8424_88EBE18E5AEC" visibility="public"
supplier="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92"
<packagedElement xmi:type="uml:Interface"
xmi:id="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B" name="CFG.h"
visibility="public" isAbstract="true">
xmi:id="EAID_8E79DFF3_E860_4f4e_9E82_80D4C809FFA5" name="a"
visibility="public" isStatic="true" isDerived="false">
xmi:id="EAID_LI000005_E860_4f4e_9E82_80D4C809FFA5" value="1"/>
xmi:id="EAID_LI000006_E860_4f4e_9E82_80D4C809FFA5" value="1"/>
</ownedAttribute>
xmi:id="EAID_2BD709F5_46CC_4ba7_BA2A_A390B4F2290E" name="b"
xmi:id="EAID_LI000007_46CC_4ba7_BA2A_A390B4F2290E" value="1"/>
xmi:id="EAID_LI000008_46CC_4ba7_BA2A_A390B4F2290E" value="1"/>
</ownedAttribute>
xmi:id="EAID_BBCF6B47_C248_49a1_9D2D_54A397102AE7" name="c"
xmi:id="EAID_LI000009_C248_49a1_9D2D_54A397102AE7" value="1"/>
xmi:id="EAID_LI000010_C248_49a1_9D2D_54A397102AE7" value="1"/>
</ownedAttribute>
xmi:id="EAID_6A209E19_BD07_4cc8_8EF1_ED22ED79CAE5" name="e"
xmi:id="EAID_LI000011_BD07_4cc8_8EF1_ED22ED79CAE5" value="1"/>
xmi:id="EAID_LI000012_BD07_4cc8_8EF1_ED22ED79CAE5" value="1"/>
</ownedAttribute>
xmi:id="EAID_8DD41F45_04A0_47e2_B70F_1393CC8D2CAF" name="f"
xmi:id="EAID_LI000013_04A0_47e2_B70F_1393CC8D2CAF" value="1"/>
xmi:id="EAID_LI000014_04A0_47e2_B70F_1393CC8D2CAF" value="1"/>
</ownedAttribute>
xmi:id="EAID_B843386C_4FBB_445b_A019_CE229198B1C4" name="g"
xmi:id="EAID_LI000015_4FBB_445b_A019_CE229198B1C4" value="1"/>
xmi:id="EAID_LI000016_4FBB_445b_A019_CE229198B1C4" value="1"/>
</ownedAttribute>
xmi:id="EAID_64D3FB86_C07A_411d_A177_5DA0C97B5A44" name="h"
xmi:id="EAID_LI000017_C07A_411d_A177_5DA0C97B5A44" value="1"/>
xmi:id="EAID_LI000018_C07A_411d_A177_5DA0C97B5A44" value="1"/>
</ownedAttribute>
xmi:id="EAID_0D9C4ABF_572C_47ce_BF3B_750590F4EFC2" name="i"
xmi:id="EAID_LI000019_572C_47ce_BF3B_750590F4EFC2" value="1"/>
xmi:id="EAID_LI000020_572C_47ce_BF3B_750590F4EFC2" value="1"/>
</ownedAttribute>
xmi:id="EAID_B5B0700B_E483_4f0a_AA77_3AFF7E9C10F9" name="j"
xmi:id="EAID_LI000021_E483_4f0a_AA77_3AFF7E9C10F9" value="1"/>
xmi:id="EAID_LI000022_E483_4f0a_AA77_3AFF7E9C10F9" value="1"/>
</ownedAttribute>
</packagedElement>
xmi:id="EAID_FE29440B_60A9_4b9e_921D_5859BC0DBF3F" visibility="public"
client="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"/>
xmi:id="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9" name="Gs.H"
xmi:id="EAID_CF61D5D9_0DC8_422e_B169_DD92BA2F731F" name="PST"
xmi:id="EAID_LI000023_0DC8_422e_B169_DD92BA2F731F" value="1"/>
xmi:id="EAID_LI000024_0DC8_422e_B169_DD92BA2F731F" value="1"/>
</ownedAttribute>
xmi:id="EAID_C4373B66_03F4_46e2_94EA_9DE519CC3AF4" name="ST"
xmi:id="EAID_LI000025_03F4_46e2_94EA_9DE519CC3AF4" value="1"/>
xmi:id="EAID_LI000026_03F4_46e2_94EA_9DE519CC3AF4" value="1"/>
</ownedAttribute>
</packagedElement>
xmi:id="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92" name="Ph.h"
xmi:id="EAID_D264A9F6_95E4_42ef_820D_68B9A65D82EE" name="C"
xmi:id="EAID_LI000027_95E4_42ef_820D_68B9A65D82EE" value="1"/>
xmi:id="EAID_LI000028_95E4_42ef_820D_68B9A65D82EE" value="1"/>
<defaultValue xmi:id="EAID_LI000029_95E4_42ef_820D_68B9A65D82EE"
value="0x04"/>
</ownedAttribute>
xmi:id="EAID_0D162A65_3032_40e9_A9BF_9D0CCF0E39D3" name="C_F"
xmi:id="EAID_LI000029_3032_40e9_A9BF_9D0CCF0E39D3" value="1"/>
xmi:id="EAID_LI000030_3032_40e9_A9BF_9D0CCF0E39D3" value="1"/>
<defaultValue xmi:id="EAID_LI000031_3032_40e9_A9BF_9D0CCF0E39D3"
value="0x4000"/>
</ownedAttribute>
xmi:id="EAID_450489B9_CC5D_4c1b_A14A_FE50FB0C3926" name="C_Fl"
xmi:id="EAID_LI000031_CC5D_4c1b_A14A_FE50FB0C3926" value="1"/>
xmi:id="EAID_LI000032_CC5D_4c1b_A14A_FE50FB0C3926" value="1"/>
<defaultValue xmi:id="EAID_LI000033_CC5D_4c1b_A14A_FE50FB0C3926"
value="0x2000"/>
</ownedAttribute>
xmi:id="EAID_8BD9C4EF_CBD0_44d6_AC38_2683599C8BA6" name="C_Fla"
xmi:id="EAID_LI000033_CBD0_44d6_AC38_2683599C8BA6" value="1"/>
xmi:id="EAID_LI000034_CBD0_44d6_AC38_2683599C8BA6" value="1"/>
<defaultValue xmi:id="EAID_LI000035_CBD0_44d6_AC38_2683599C8BA6"
value="0x02"/>
</ownedAttribute>
xmi:id="EAID_EE17AB8E_79F8_47d0_BCA4_D0622F1F62C3" name="C_Flas"
xmi:id="EAID_LI000035_79F8_47d0_BCA4_D0622F1F62C3" value="1"/>
xmi:id="EAID_LI000036_79F8_47d0_BCA4_D0622F1F62C3" value="1"/>
<defaultValue xmi:id="EAID_LI000037_79F8_47d0_BCA4_D0622F1F62C3"
value="0x1000"/>
</ownedAttribute>
xmi:id="EAID_3FA96802_48F5_4aca_BA74_6BD4A9DFE5F3" name="C_H"
xmi:id="EAID_LI000037_48F5_4aca_BA74_6BD4A9DFE5F3" value="1"/>
xmi:id="EAID_LI000038_48F5_4aca_BA74_6BD4A9DFE5F3" value="1"/>
<defaultValue xmi:id="EAID_LI000039_48F5_4aca_BA74_6BD4A9DFE5F3"
value="0x08"/>
</ownedAttribute>
xmi:id="EAID_40E00161_763B_420d_8C36_5B996C59CAC4" name="C_He"
xmi:id="EAID_LI000039_763B_420d_8C36_5B996C59CAC4" value="1"/>
xmi:id="EAID_LI000040_763B_420d_8C36_5B996C59CAC4" value="1"/>
<defaultValue xmi:id="EAID_LI000041_763B_420d_8C36_5B996C59CAC4"
value="0x20"/>
</ownedAttribute>
xmi:id="EAID_DC309A9C_1D4C_4505_9CCE_98658A9E7320" name="C_Het"
xmi:id="EAID_LI000041_1D4C_4505_9CCE_98658A9E7320" value="1"/>
xmi:id="EAID_LI000042_1D4C_4505_9CCE_98658A9E7320" value="1"/>
<defaultValue xmi:id="EAID_LI000043_1D4C_4505_9CCE_98658A9E7320"
value="0x10"/>
</ownedAttribute>
xmi:id="EAID_39A7934A_74CC_472b_A4D2_55DC246DB690" name="ID_UL"
xmi:id="EAID_LI000043_74CC_472b_A4D2_55DC246DB690" value="1"/>
xmi:id="EAID_LI000044_74CC_472b_A4D2_55DC246DB690" value="1"/>
<defaultValue xmi:id="EAID_LI000045_74CC_472b_A4D2_55DC246DB690"
value="0x40"/>
</ownedAttribute>
xmi:id="EAID_BED3FAE5_F0B1_4fb2_8D38_39EFE17E9C3B" name="ID_UL1"
xmi:id="EAID_LI000045_F0B1_4fb2_8D38_39EFE17E9C3B" value="1"/>
xmi:id="EAID_LI000046_F0B1_4fb2_8D38_39EFE17E9C3B" value="1"/>
<defaultValue xmi:id="EAID_LI000047_F0B1_4fb2_8D38_39EFE17E9C3B"
value="0x80"/>
</ownedAttribute>
xmi:id="EAID_03FEB6F4_23D0_4472_9B27_4088F062B269" name="UB"
xmi:id="EAID_LI000047_23D0_4472_9B27_4088F062B269" value="1"/>
xmi:id="EAID_LI000048_23D0_4472_9B27_4088F062B269" value="1"/>
</ownedAttribute>
xmi:id="EAID_F017B5A3_3859_4b4e_B53C_318B503B0D20" name="UL"
xmi:id="EAID_LI000049_3859_4b4e_B53C_318B503B0D20" value="1"/>
xmi:id="EAID_LI000050_3859_4b4e_B53C_318B503B0D20" value="1"/>
</ownedAttribute>
xmi:id="EAID_04622168_3E1C_4458_9D9F_CED672472244" name="UL1"
xmi:id="EAID_LI000051_3E1C_4458_9D9F_CED672472244" value="1"/>
xmi:id="EAID_LI000052_3E1C_4458_9D9F_CED672472244" value="1"/>
<defaultValue xmi:id="EAID_LI000053_3E1C_4458_9D9F_CED672472244"
value="0x400"/>
</ownedAttribute>
xmi:id="EAID_5591BAA7_58CA_4574_921C_47439E3932F4" name="UL2"
xmi:id="EAID_LI000053_58CA_4574_921C_47439E3932F4" value="1"/>
xmi:id="EAID_LI000054_58CA_4574_921C_47439E3932F4" value="1"/>
<defaultValue xmi:id="EAID_LI000055_58CA_4574_921C_47439E3932F4"
value="0x800"/>
</ownedAttribute>
xmi:id="EAID_AB9C4001_57AC_4a04_86CC_23798A18A2DF" name="UL3"
xmi:id="EAID_LI000055_57AC_4a04_86CC_23798A18A2DF" value="1"/>
xmi:id="EAID_LI000056_57AC_4a04_86CC_23798A18A2DF" value="1"/>
<defaultValue xmi:id="EAID_LI000057_57AC_4a04_86CC_23798A18A2DF"
value="0x100"/>
</ownedAttribute>
xmi:id="EAID_0D819D4A_601F_4fd5_9F7C_029C060462DA" name="UL4"
xmi:id="EAID_LI000057_601F_4fd5_9F7C_029C060462DA" value="1"/>
xmi:id="EAID_LI000058_601F_4fd5_9F7C_029C060462DA" value="1"/>
<defaultValue xmi:id="EAID_LI000059_601F_4fd5_9F7C_029C060462DA"
value="0x200"/>
</ownedAttribute>
xmi:id="EAID_4BD757E9_F734_4267_B948_9F665BB6DF4B" name="UL5"
xmi:id="EAID_LI000059_F734_4267_B948_9F665BB6DF4B" value="1"/>
xmi:id="EAID_LI000060_F734_4267_B948_9F665BB6DF4B" value="1"/>
<defaultValue xmi:id="EAID_LI000061_F734_4267_B948_9F665BB6DF4B"
value="0x100"/>
</ownedAttribute>
<ownedOperation xmi:id="EAID_1FB5BA0A_817F_48d7_985C_8F4FD94706E4"
name="V" visibility="public" concurrency="sequential">
<ownedParameter xmi:id="EAID_7579BF43_7CBF_4e91_998F_6556D8EBB9B2"
name="l_ErrorId_UL" direction="pk_in"/>
</ownedOperation>
</packagedElement>
xmi:id="EAID_0AEA91B6_60B8_4044_9552_123705B7C497" name="XYZ.h"
xmi:id="EAID_54F9D7EC_4249_4242_AAC7_BB13190BD787" name="1_UL"
xmi:id="EAID_LI000061_4249_4242_AAC7_BB13190BD787" value="1"/>
xmi:id="EAID_LI000062_4249_4242_AAC7_BB13190BD787" value="1"/>
</ownedAttribute>
xmi:id="EAID_B1BCC9BF_09FA_439a_87F3_248201574F23" name="L"
xmi:id="EAID_LI000063_09FA_439a_87F3_248201574F23" value="1"/>
xmi:id="EAID_LI000064_09FA_439a_87F3_248201574F23" value="1"/>
</ownedAttribute>
xmi:id="EAID_DFC27553_2A02_442c_823C_43CD1D034A24" name="OFF"
xmi:id="EAID_LI000065_2A02_442c_823C_43CD1D034A24" value="1"/>
xmi:id="EAID_LI000066_2A02_442c_823C_43CD1D034A24" value="1"/>
</ownedAttribute>
xmi:id="EAID_EF03C6CD_51FA_46d2_8D0B_127BF90352A3" name="ON"
xmi:id="EAID_LI000067_51FA_46d2_8D0B_127BF90352A3" value="1"/>
xmi:id="EAID_LI000068_51FA_46d2_8D0B_127BF90352A3" value="1"/>
</ownedAttribute>
xmi:id="EAID_DF833404_8A71_4462_B1B3_9E529343A0C4" name="U"
xmi:id="EAID_LI000069_8A71_4462_B1B3_9E529343A0C4" value="1"/>
xmi:id="EAID_LI000070_8A71_4462_B1B3_9E529343A0C4" value="1"/>
</ownedAttribute>
xmi:id="EAID_3E289690_D9C4_4cb9_889F_53CA4DA9F62E" name="UL"
xmi:id="EAID_LI000071_D9C4_4cb9_889F_53CA4DA9F62E" value="1"/>
xmi:id="EAID_LI000072_D9C4_4cb9_889F_53CA4DA9F62E" value="1"/>
</ownedAttribute>
<ownedOperation xmi:id="EAID_C92674C6_05B9_445f_8037_20808961C579"
</packagedElement>
xmi:id="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B" name="in.h"
xmi:id="EAID_C0244F60_C580_48ad_98D5_0D2F6FF9F9CD" name="ED"
xmi:id="EAID_LI000073_C580_48ad_98D5_0D2F6FF9F9CD" value="1"/>
xmi:id="EAID_LI000074_C580_48ad_98D5_0D2F6FF9F9CD" value="1"/>
</ownedAttribute>
xmi:id="EAID_15E4E617_6E29_49e9_95E1_720EE56AEEA5" name="UL"
xmi:id="EAID_LI000075_6E29_49e9_95E1_720EE56AEEA5" value="1"/>
xmi:id="EAID_LI000076_6E29_49e9_95E1_720EE56AEEA5" value="1"/>
</ownedAttribute>
xmi:id="EAID_2539AD27_B179_4c7d_B307_DB9AC76856F6" name="UL1"
xmi:id="EAID_LI000077_B179_4c7d_B307_DB9AC76856F6" value="1"/>
xmi:id="EAID_LI000078_B179_4c7d_B307_DB9AC76856F6" value="1"/>
</ownedAttribute>
xmi:id="EAID_3C123386_221E_4b95_86DC_2FE29FED4C6C" name="UL2"
xmi:id="EAID_LI000079_221E_4b95_86DC_2FE29FED4C6C" value="1"/>
xmi:id="EAID_LI000080_221E_4b95_86DC_2FE29FED4C6C" value="1"/>
</ownedAttribute>
xmi:id="EAID_C6DABED3_63D4_4352_9A37_E73681B1FCF6" name="UL3"
xmi:id="EAID_LI000081_63D4_4352_9A37_E73681B1FCF6" value="1"/>
xmi:id="EAID_LI000082_63D4_4352_9A37_E73681B1FCF6" value="1"/>
</ownedAttribute>
xmi:id="EAID_659CB829_BB94_45ed_B622_A9A98C22691F" name="UW"
xmi:id="EAID_LI000083_BB94_45ed_B622_A9A98C22691F" value="1"/>
xmi:id="EAID_LI000084_BB94_45ed_B622_A9A98C22691F" value="1"/>
</ownedAttribute>
<ownedOperation xmi:id="EAID_5948638B_00F1_486d_97EF_45D37AFB8103"
<ownedOperation xmi:id="EAID_D54988F3_C4DA_491a_B737_CDC8178A5E27"
name="V1" visibility="public" concurrency="sequential"/>
<ownedOperation xmi:id="EAID_7769A273_CD9C_4771_8C62_A0A9C4AE43E4"
<ownedOperation xmi:id="EAID_DA91EA8E_64A5_4ec7_95EB_EC87D9B76A1A"
name="V3" visibility="public" concurrency="sequential"/>
<ownedOperation xmi:id="EAID_C6A2A643_8219_48dc_A243_C3BF8CD3708F"
name="V4" visibility="public" concurrency="sequential"/>
</packagedElement>
xmi:id="EAID_8B33B2D3_7EBA_48c0_A0F5_80F745A825E0" visibility="public"
client="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"/>
<packagedElement xmi:type="uml:Component"
xmi:id="EAID_6BCFB871_6F81_4128_BF92_E0D5F12859B9" name="Sampl"
visibility="public"/>
<packagedElement xmi:type="uml:Realization"
xmi:id="EAID_AA01A369_87A1_4e30_BC64_1CD6D60ECDD5" visibility="public"
realizingClassifier="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B "
client="EAID_6BCFB871_6F81_4128_BF92_E0D5F12859B9"/>
xmi:id="EAID_48CFBEB8_378D_489b_AE67_B6FF4C9E776C" name="ESM09_COMMON :
ESM09_InterruptHandling" visibility="public"/>
xmi:id="EAID_52CE987F_1DF6_43db_9C3E_9E3F9818B125" name="ESM09_COMMON :
ESM09_Init" visibility="public"/>
xmi:id="EAID_687E4E47_19EC_4add_9178_7C827FAB68AA" name="internal ESM09
diagrams" visibility="public"/>
xmi:id="EAID_6C42D355_5696_472d_8E8C_8656CD760EC6" name="ESM09_COMMON"
xmi:id="EAID_7B83CA0A_706D_43d5_8ECB_A2ADA65C498C" name="Sample"
xmi:id="EAID_7F4D9478_93E7_4d17_9F30_D32664B86511" name="ESM09_COMMON"
xmi:id="EAID_8987A2AF_9FF0_4545_ACEA_8850C89D57EA" visibility="public"
client="EAID_7F4D9478_93E7_4d17_9F30_D32664B86511"/>
xmi:id="EAID_8F455C4F_A5FC_4ec4_8B3B_61B33A9155C0" name="ESM09_COMMON"
xmi:id="EAID_ACD3CC84_2F18_405d_B20D_C2C27640B6B7" name="ESM09_COMMON"
xmi:id="EAID_CBE4B06D_EC40_4acf_AA7A_276EC990DAF1" name="ESM09_COMMON :
ESM09_StartupTests" visibility="public"/>
</packagedElement>
</packagedElement>
<thecustomprofile:interface
base_Interface="EAID_90FD549A_5C50_4bb5_88C6_F7A80B3FDE2B"/ >
<thecustomprofile:Visibility
Visibility="ESM09_COMMON"/>
base_Interface="EAID_B9C9BA44_30FD_4b5d_AB3F_D4AD3936F1A9"/ >
<thecustomprofile:typedef_volatile_struct
base_Attribute="EAID_C4373B66_03F4_46e2_94EA_9DE519CC3AF4"
__EAStereoName="typedef volatile struct"/>
base_Interface="EAID_524570EC_00AA_48ce_9798_633F4D0FAF92"/ >
<thecustomprofile:extern
base_Attribute="EAID_03FEB6F4_23D0_4472_9B27_4088F062B269"/ >
base_Attribute="EAID_F017B5A3_3859_4b4e_B53C_318B503B0D20"/ >
base_Interface="EAID_0AEA91B6_60B8_4044_9552_123705B7C497"/ >
base_Attribute="EAID_54F9D7EC_4249_4242_AAC7_BB13190BD787"/ >
base_Attribute="EAID_B1BCC9BF_09FA_439a_87F3_248201574F23"/ >
base_Attribute="EAID_DF833404_8A71_4462_B1B3_9E529343A0C4"/ >
<thecustomprofile:extern_volatile
base_Attribute="EAID_3E289690_D9C4_4cb9_889F_53CA4DA9F62E"
__EAStereoName="extern volatile"/>
base_Interface="EAID_6C8CD667_59E4_42b6_98F4_85F460E6282B"/ >
Visibility="HSW"/>
base_Attribute="EAID_2539AD27_B179_4c7d_B307_DB9AC76856F6"
<thecustomprofile:inline
base_Operation="EAID_5948638B_00F1_486d_97EF_45D37AFB8103"/ >
base_Operation="EAID_D54988F3_C4DA_491a_B737_CDC8178A5E27"/ >
base_Operation="EAID_7769A273_CD9C_4771_8C62_A0A9C4AE43E4"/ >
base_Operation="EAID_DA91EA8E_64A5_4ec7_95EB_EC87D9B76A1A"/ >
base_Operation="EAID_C6A2A643_8219_48dc_A243_C3BF8CD3708F"/ >
<thecustomprofile:realize
base_Realisation="EAID_AA01A369_87A1_4e30_BC64_1CD6D60ECDD5 "/>
<uml:Profile xmi:version="2.1"
xmlns:uml="http://schema.omg.org/spec/UML/2.1/uml.xml"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmi:id="thecustomprofile"
nsPrefix="thecustomprofile" name="thecustomprofile"
metamodelReference="mmref01">
<ownedComment xmi:type="uml:Comment" xmi:id="comment01"
annotatedElement="thecustomprofile">
<body> Version:1.0</body>
</ownedComment>
<packageImport xmi:id="mmref01">
<importedPackage href="http://schema.omg.org/spec/UML/2.1/uml.xml"/>
</packageImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="realize"
name="realize">
xmi:id="realize-base_Realisation" name="base_Realisation"
association="Realisation_realize">
<type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Realisation"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Realisation_realize"
name="A_Realisation_realize" memberEnd="extension_realize
realize-base_Realisation">
<ownedEnd xmi:id="extension_realize" name="extension_realize"
type="realize" isComposite="true" lower="0" upper="1"
memberEnd="extension_realize realize-base_Realisation"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="extern"
name="extern">
<ownedAttribute xmi:type="uml:Property" xmi:id="extern-base_Attribute"
name="base_Attribute" association="Attribute_extern">
<type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Attribute"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Attribute_extern"
name="A_Attribute_extern" memberEnd="extension_extern
extern-base_Attribute">
<ownedEnd xmi:id="extension_extern" name="extension_extern"
type="extern" isComposite="true" lower="0" upper="1"
memberEnd="extension_extern extern-base_Attribute"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="extern volatile"
name="extern volatile">
volatile-base_Attribute" name="base_Attribute"
association="Attribute_extern volatile">
</ownedAttribute>
</packagedElement>
volatile" name="A_Attribute_extern volatile" memberEnd="extension_extern
volatile extern volatile-base_Attribute">
<ownedEnd xmi:id="extension_extern volatile" name="extension_extern
volatile" type="extern volatile" isComposite="true" lower="0" upper="1"
memberEnd="extension_extern volatile extern volatile-base_Attribute"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="interface"
name="interface">
xmi:id="interface-base_Interface" name="base_Interface"
association="Interface_interface">
<type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Interface"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Interface_interface"
name="A_Interface_interface" memberEnd="extension_interface
interface-base_Interface">
<ownedEnd xmi:id="extension_interface" name="extension_interface"
type="interface" isComposite="true" lower="0" upper="1"
memberEnd="extension_interface interface-base_Interface"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="inline"
name="inline">
<ownedAttribute xmi:type="uml:Property" xmi:id="inline-base_Operation"
name="base_Operation" association="Operation_inline">
<type href="http://schema.omg.org/spec/UML/2.1/uml.xml#Operation"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Operation_inline"
name="A_Operation_inline" memberEnd="extension_inline
inline-base_Operation">
<ownedEnd xmi:id="extension_inline" name="extension_inline"
type="inline" isComposite="true" lower="0" upper="1"
memberEnd="extension_inline inline-base_Operation"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="Visibility"
name="Visibility">
xmi:id="Visibility-base_Interface" name="base_Interface"
association="Interface_Visibility">
</ownedAttribute>
<ownedAttribute xmi:type="uml:Property" xmi:id="Visibility-Visibility"
name="Visibility">
<type href="http://schema.omg.org/spec/UML/2.1/uml.xml#String"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Interface_Visibility"
name="A_Interface_Visibility" memberEnd="extension_Visibility
Visibility-base_Interface">
<ownedEnd xmi:id="extension_Visibility" name="extension_Visibility"
type="Visibility" isComposite="true" lower="0" upper="1"
memberEnd="extension_Visibility Visibility-base_Interface"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="typedef volatile
struct" name="typedef volatile struct">
<ownedAttribute xmi:type="uml:Property" xmi:id="typedef volatile
struct-base_Attribute" name="base_Attribute"
association="Attribute_typedef volatile struct">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Attribute_typedef
volatile struct" name="A_Attribute_typedef volatile struct"
memberEnd="extension_typedef volatile struct typedef volatile
struct-base_Attribute">
<ownedEnd xmi:id="extension_typedef volatile struct"
name="extension_typedef volatile struct" type="typedef volatile struct"
isComposite="true" lower="0" upper="1" memberEnd="extension_typedef
volatile struct typedef volatile struct-base_Attribute"/>
</packagedElement>
</uml:Profile>
</uml:Model>
<xmi:Extension extender="Enterprise Architect" extenderID="6.5">
<elements>
<element xmi:idref="EAPK_CD825798_C93A_4035_82E5_AEC56D9DF236">
<packageproperties/>
<paths/>
<times/>
<flags iscontrolled="FALSE" isprotected="FALSE" usedtd="FALSE"
logxml="FALSE" packageFlags="isModel=1;"/>
</element>
<element xmi:idref="EAPK_1F199D3E_F346_422d_9D3E_154CFAF09C77"
xmi:type="uml:Package" name="Sample" scope="public">
<model package2="EAID_1F199D3E_F346_422d_9D3E_154CFAF09C77"
package="EAPK_CD825798_C93A_4035_82E5_AEC56D9DF236" tpos="0"
ea_localid="2" ea_eleType="package"/>
<properties isSpecification="false" sType="Package" nType="0"
scope="public"/>
<project version="1.0" phase="1.0" created="2005-07-26 11:59:00"
modified="2009-02-11 05:02:22" complexity="1" status="Proposed"/>
<code gentype="C"/>
<style
appearance=" BackColor=-1;BorderColor=-1;BorderWidth=-1;FontColor=-1;VSwi mLanes=0;HSwimLanes=0;BorderStyle=0; "/>
<modelDocument/>
<tags/>
<xrefs/>
<extendedProperties tagged="0" package_name="Model"/>
<packageproperties version="1.0"/>
<paths/>
<times/>
<flags iscontrolled="FALSE" isprotected="FALSE" batchsave="0"
batchload="0" usedtd="FALSE" logxml="FALSE"/>
</element>
<element xmi:idref="EAID_1AE191F0_1502_475e_922B_0D92E48C0FBF"
xmi:type="uml:Class" name="ABC.c" scope="public">
<model package="EAPK_1F199D3E_F346_422d_9D3E_154CFAF09C77" tpos="0"
ea_localid="2" ea_eleType="element"/>
<properties isSpecification="false" sType="Class" nType="0"
scope="public" isRoot="false" isLeaf="false" isAbstract="false"
isActive="false"/>
<project version="1.0" phase="1.0" created="2007-08-24 10:33:09"
modified="2009-02-11 05:02:32" complexity="1" status="Proposed"/>
<code gentype="C"/>
<style
appearance=" BackColor=10080763;BorderColor=-1;BorderWidth=1;FontColor=-1 ;VSwimLanes=0;HSwimLanes=0;BorderStyle=0; "/>
<modelDocument/>
<tags/>
<xrefs
value=" $XREFPROP=$XID={AE0E4555-8F32-4373-BAAA-CFC0CE6C254B}$XID;$N AM=CustomProperties$NAM;$TYP=element
property$TYP;$VIS=Public$VIS;$DES=@PROP=@NAME=isActive@ENDNAME;@TYPE=Boolean@ENDTYPE ;@VALU=@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP;$DES;$CLT={1AE191F0- 1502-475e-922B-0D92E48C0FBF}$CLT;$SUP=<none>$S UP;$ENDXREF; "/>
<extendedProperties tagged="0" package_name="Sample"/>
<attributes>
<attribute xmi:idref="EAID_322327E9_C4CC_4941_AB10_AC127CA6DEC4"
name="UB" scope="Private">
<initial/>
<documentation/>
<model ea_localid="2"
ea_guid="{322327E9-C4CC-4941-AB10-AC127CA6DEC4}"/>
<properties type="UBYTE" derived="0" collection="false" static="1"
duplicates="0" changeability="changeable"/>
<coords ordered="0" scale="0"/>
<containment containment="Not Specified" position="0"/>
<stereotype/>
<bounds lower="1" upper="1"/>
<options/>
<style/>
<styleex value="volatile=0;"/>
<tags/>
<xrefs/>
</attribute>
<attribute xmi:idref="EAID_87E66664_4B01_4ecd_8EA4_A10DCB13CFCD"
name="UL" scope="Private">
<initial/>
<documentation/>
<model ea_localid="1"
ea_guid="{87E66664-4B01-4ecd-8EA4-A10DCB13CFCD}"/>
<properties type="ULONG" derived="0" collection="false" static="1"
<containment containment="Not Specified" position="1"/>
<stereotype/>
<options/>
<style/>
<tags/>
Re: Loading Model from Enterprise architect [message #627413 is a reply to message #478186] |
Thu, 05 March 2009 16:43  |
Anand,
There's a problem with the XMI you are trying to load - it has a number of
'defaultValue' elements with unspecified type. Since the type of
Property::defaultValue, ValueSpecification, is abstract, a specific type
must be specified; otherwise, an attempt it made to instantiate the abstract
type, hence the exception.
Kenn
"Anand Soddy" <anand.soddy@in.bosch.com> wrote in message
news:adb56c15888d466f4baf3b4ebd6e70c2$1@www.eclipse.org...
> Hello James,
> a valid classifier
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> value="0x04"/>
> </ownedAttribute>
> value="0x4000"/>
> </ownedAttribute>
> value="0x2000"/>
> </ownedAttribute>
> value="0x02"/>
> </ownedAttribute>
> value="0x1000"/>
> </ownedAttribute>
> value="0x08"/>
> </ownedAttribute>
> value="0x20"/>
> </ownedAttribute>
> value="0x10"/>
> </ownedAttribute>
> value="0x40"/>
> </ownedAttribute>
> value="0x80"/>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> value="0x400"/>
> </ownedAttribute>
> value="0x800"/>
> </ownedAttribute>
> value="0x100"/>
> </ownedAttribute>
> value="0x200"/>
> </ownedAttribute>
> value="0x100"/>
> </ownedAttribute>
> </ownedOperation>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> Visibility="HSW"/>
> </ownedComment>
> </packageImport>
> name="realize">
> <ownedAttribute xmi:type="uml:Property" xmi:id="realize-base_Realisation"
> name="base_Realisation" association="Realisation_realize">
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> <packagedElement xmi:type="uml:Stereotype" xmi:id="extern" name="extern">
> </ownedAttribute>
> </packagedElement>
> <ownedEnd xmi:id="extension_extern" name="extension_extern" type="extern"
> isComposite="true" lower="0" upper="1" memberEnd="extension_extern
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> name="interface">
> <ownedAttribute xmi:type="uml:Property" xmi:id="interface-base_Interface"
> name="base_Interface" association="Interface_interface">
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> <packagedElement xmi:type="uml:Stereotype" xmi:id="inline" name="inline">
> </ownedAttribute>
> </packagedElement>
> <ownedEnd xmi:id="extension_inline" name="extension_inline" type="inline"
> isComposite="true" lower="0" upper="1" memberEnd="extension_inline
> </packagedElement>
> name="Visibility">
> <ownedAttribute xmi:type="uml:Property" xmi:id="Visibility-base_Interface"
> name="base_Interface" association="Interface_Visibility">
> </ownedAttribute>
> name="Visibility">
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> </uml:Model>
> <elements>
> <paths/>
> <times/>
> </element>
> scope="public"/>
> <code gentype="C"/>
> <style
> <modelDocument/>
> <tags/>
> <xrefs/>
> <paths/>
> <times/>
> </element>
> ea_lo
Re: Loading Model from Enterprise architect [message #627414 is a reply to message #478218] |
Fri, 06 March 2009 08:34  |
Just my two cents on this item.
I have already done the exercice to load a UML model exported in XMI
from EA and I had to replace some keywords so that it can be accepted by
Eclipse UML2 editor.
Seems that EA is not really conformant to UML2 specification. Probably
because they have to deal with compatibility from 1.X relases for their
customers.
regards
raphaël
Kenn Hussey a écrit :
> Anand,
> Kenn
>> Hello James,
>> a valid classifier
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> value="0x04"/>
>> </ownedAttribute>
>> value="0x4000"/>
>> </ownedAttribute>
>> value="0x2000"/>
>> </ownedAttribute>
>> value="0x02"/>
>> </ownedAttribute>
>> value="0x1000"/>
>> </ownedAttribute>
>> value="0x08"/>
>> </ownedAttribute>
>> value="0x20"/>
>> </ownedAttribute>
>> value="0x10"/>
>> </ownedAttribute>
>> value="0x40"/>
>> </ownedAttribute>
>> value="0x80"/>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> value="0x400"/>
>> </ownedAttribute>
>> value="0x800"/>
>> </ownedAttribute>
>> value="0x100"/>
>> </ownedAttribute>
>> value="0x200"/>
>> </ownedAttribute>
>> value="0x100"/>
>> </ownedAttribute>
>> </ownedOperation>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </packagedElement>
>> Visibility="HSW"/>
>> </ownedComment>
>> </packageImport>
>> name="realize">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> name="interface">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> name="Visibility">
>> </ownedAttribute>
>> name="Visibility">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedE
Re: Loading Model from Enterprise architect [message #627432 is a reply to message #478219] |
this time also.
exported from EA.
Thanks in advance.
Anand
FUDForum. Page generated in 0.06500 seconds
