Home » Modeling » UML2 » Reusing package-element in UML Metamodel extension
Reusing package-element in UML Metamodel extension [message #478102] Sun, 04 January 2009 16:28 Go to next message
Is there any possibility to use uml:package in an extended UML-Metamodel ?
What I tried so far:
-Create new UML model (Model Object: Model)
-I add an UML Package element to the model and then I transform this
model to a metamodel (convert to->metamodel).
After that I generate EMF Model and let EMF create the code for the
model and editor.
When I run the editor there is no UML Package available in my instance
model.
Deepak
Re: Reusing package-element in UML Metamodel extension [message #478109 is a reply to message #478102] Tue, 06 January 2009 09:48 Go to previous messageGo to next message
Hi Deepak,
If you can see the corresponding EPackage in the EMF model then the EMF
codegenerator should create a package for you.
What does your EMF model look like?
- James.
"Deepak" <dee_n@gmx.de> wrote in message
news:gjr9lq$17g$1@build.eclipse.org...
> Hello,
> -I add an UML Package element to the model and then I transform this model
> After that I generate EMF Model and let EMF create the code for the model
> and editor.
> model.
> Regards,
> Deepak
Re: Reusing package-element in UML Metamodel extension [message #478110 is a reply to message #478109] Wed, 07 January 2009 08:17 Go to previous messageGo to next message
--------------060602050409040405070603
Hi James,
Yes, I can see the corresponding EPackage but if I run the generated
editor I can't insert any UML:Package element in my model. I just start
with the Activity element.
I attached a sample of my UML extended model and the derived Ecore file.
I want to create a specific activity diagram (no value pins, no
callbehavior action and some other unnecessary elements) which contains
OCL constraints.
The layout of my activity diagram should be:
uml:package
Activity
CallOperationAction
InputPin
OutputPin
ControlFlow
InitialNode
FinalNode....
Deepak
James Bruck schrieb:
> Hi Deepak,
> Cheers,
> - James.
>> Hello,
>> and editor.
>> model.
>> Regards,
>> Deepak
Content-Type: text/xml;
name="My.uml"
Content-Disposition: inline;
filename="My.uml"
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:Standard="http://www.eclipse.org/uml2/schemas/Standard/1" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Standard/1 pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w">
<uml:Model xmi:id="_0" name="TestMeta">
<packagedElement xmi:type="uml:Package" xmi:id="ActvityWithOCL" name="ActvityWithOCL">
<packagedElement xmi:type="uml:Activity" xmi:id="ActvityWithOCL-ExtActivity" name="ExtActivity" precondition="ActvityWithOCL-ExtActivity-OCL">
<ownedRule xmi:id="ActvityWithOCL-ExtActivity-OCL" name="OCL">
<specification xmi:type="uml:OpaqueExpression" xmi:id="ActvityWithOCL-ExtActivity-OCL-containsInputPin" name="containsInputPin">
<language>OCL</language>
</specification>
</ownedRule>
<generalization xmi:id="ActvityWithOCL-ExtActivity-_generalization.0">
<general xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Activity"/>
</generalization>
<node xmi:type="uml:CallBehaviorAction" xmi:id="ActvityWithOCL-ExtActivity-testGet" name="testGet"/>
</packagedElement>
</packagedElement>
<profileApplication xmi:id="_profileApplication.0">
<eAnnotations xmi:id=" _profileApplication.0-_http2F2Fwww.eclipse.org2Fuml22F2.0.02 FUML " source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
</profileApplication>
</uml:Model>
<Standard:Metamodel xmi:id="_mORn4L--Ed2_NN0Jjs2C1w" base_Model="_0"/>
<Standard:Metaclass xmi:id="_mOax0L--Ed2_NN0Jjs2C1w" base_Class="ActvityWithOCL-ExtActivity"/>
</xmi:XMI>
name="testMeta.ecore"
filename="testMeta.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="testMeta"
nsURI="http:///testMeta.ecore" nsPrefix="testMeta">
<eSubpackages name="actvityWithOcl" nsURI="http:///testMeta/actvityWithOcl.ecore"
nsPrefix="testMeta.actvityWithOcl">
<eClassifiers xsi:type="ecore:EClass" name="ExtActivity" eSuperTypes=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Acti vity ">
<eOperations name="ocl" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean">
<eParameters name="diagnostics" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDiagnosticChain">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="The chain of diagnostics to which problems are to be appended."/>
</eAnnotations>
</eParameters>
<eParameters name="context">
<details key="documentation" value="The cache of context-specific information."/>
</eAnnotations>
<eGenericType eClassifier="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EMap">
<eTypeArguments eClassifier="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EJavaObject"/>
</eGenericType>
</eParameters>
</eOperations>
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
--------------060602050409040405070603--
Re: Reusing package-element in UML Metamodel extension [message #478113 is a reply to message #478110] Wed, 07 January 2009 13:37 Go to previous messageGo to next message
Hi Deepak,
I think you might want something like in the attachment.
Try adding the attached .ecore, reloading you .genmodel, then regenerate
all.
Let me know if that is what you were looking for.
-James.
news:gk2a1s$15v$1@build.eclipse.org...
> Hi James,
> OCL constraints.
> uml:package
> Activity
> CallOperationAction
> InputPin
> OutputPin
> ControlFlow
> InitialNode
> FinalNode....
> Regards,
> Deepak
>> Hi Deepak,
>> Cheers,
>> - James.
>>> Hello,
>>> model
>>> model
>>> and editor.
>>> model.
>>> Regards,
>>> Deepak
> </specification>
> </ownedRule>
> <generalization
> </generalization>
> </packagedElement>
> </packagedElement>
> <eAnnotations
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> </xmi:XMI>
> </eAnnotations>
> </eParameters>
> </eAnnotations>
> </eGenericType>
> </eParameters>
> </eOperations>
> </eClassifiers>
> </eSubpackages>
> </ecore:EPackage>
Re: Reusing package-element in UML Metamodel extension [message #478114 is a reply to message #478113] Thu, 08 January 2009 03:54 Go to previous messageGo to next message
Thanks James !!
That's exactly what I want.
I thought it could be done in with the UML editor itself.
Deepak
> Hi Deepak,
> all.
> -James.
>> Hi James,
>> OCL constraints.
>> uml:package
>> Activity
>> CallOperationAction
>> InputPin
>> OutputPin
>> ControlFlow
>> InitialNode
>> FinalNode....
>> Regards,
>> Deepak
>>> Hi Deepak,
>>> Cheers,
>>> - James.
>>>> Hello,
>>>> model
>>>> model
>>>> and editor.
>>>> model.
>>>> Regards,
>>>> Deepak
Re: Reusing package-element in UML Metamodel extension [message #478115 is a reply to message #478114] Thu, 08 January 2009 11:00 Go to previous messageGo to next message
Hi Deepak,
Yes you could do this with UML itself - you can do all your metamodeling
using UML only. Simply create a meta-type called MyPackage that
specializes the Package meta-type from UML. Behind the scenes, the .uml
model gets converted to a .ecore model. EMF codegeneration works with the
..ecore representation. The .ecore representation should look like the
previously attached file - I cut some corners by just jumping to the .ecore
representation.
What you are doing in your example is "meta-modeling" not "modeling". That
is, you are trying to create specializtions of UML meta-types etc. as
opposed to creating a model using *instances* of UML types. It looks like
you created a "Package" which is an instance of the uml:Package metatype
(modeling); what you want to do is create a new meta-type called "MyPackge"
which extends uml:Package (meta-modeling). The "MyPackage" would be
represented with an instance of a MOF meta-type.
Hopefully I didn't overly complicate this ;)
- James.
news:gk4eve$igu$1@build.eclipse.org...
> Thanks James !!
> Regards,
> Deepak
>> Hi Deepak,
>> all.
>> -James.
>>> Hi James,
>>> OCL constraints.
>>> uml:package
>>> Activity
>>> CallOperationAction
>>> InputPin
>>> OutputPin
>>> ControlFlow
>>> InitialNode
>>> FinalNode....
>>> Regards,
>>> Deepak
>>>> Hi Deepak,
>>>> Cheers,
>>>> - James.
>>>>> Hello,
>>>>> UML-Metamodel ?
>>>>> model
>>>>> model
>>>>> and editor.
>>>>> model.
>>>>> Regards,
>>>>> Deepak
Re: Reusing package-element in UML Metamodel extension [message #478119 is a reply to message #478115] Fri, 09 January 2009 04:18 Go to previous messageGo to next message
Hi James,
Thank you very much for your explanation. I should always keep in mind
the difference between metamodeling and modeling.
This confused me:
The element uml:model will be converted to <<metamodel>> when choosing
"convert to"-->"Metamodel.
So I somehow thought uml:package will also be automatically converted to
<<metapackage>>
Deepak
> Hi Deepak,
> representation.
> Cheers,
> - James.
>> Thanks James !!
>> Regards,
>> Deepak
>>> Hi Deepak,
>>> all.
>>> -James.
>>>> Hi James,
>>>> OCL constraints.
>>>> uml:package
>>>> Activity
>>>> CallOperationAction
>>>> InputPin
>>>> OutputPin
>>>> ControlFlow
>>>> InitialNode
>>>> FinalNode....
>>>> Regards,
>>>> Deepak
>>>>> Hi Deepak,
>>>>> Cheers,
>>>>> - James.
>>>>>> Hello,
>>>>>> UML-Metamodel ?
>>>>>> model
>>>>>> model
>>>>>> and editor.
>>>>>> model.
>>>>>> Regards,
>>>>>> Deepak
UML2 Metamodel extension [message #478154 is a reply to message #478102] Wed, 04 February 2009 06:28 Go to previous messageGo to next message
Hi Deepak,
I am trying to transform a annotated(with MARTE)deployment diagram (source
model in .di2 extension)into another model.
Can I directly use the UML2 metamodel(.ecore) or I need to extend it with
MARTE profile first.
Please can you let me know if the source model file has to be in .ecore
for the transformation to be successful.
Re: UML2 Metamodel extension [message #478161 is a reply to message #478154] Thu, 05 February 2009 12:19 Go to previous message
Rodrigues schrieb:
> Hi Deepak,
> (source model in .di2 extension)into another model.
> with MARTE profile first.
> Thanks
You should better ask in M2M newsgroup :-)
Anyway; if you are using ATL you have to use the UML2 metamodel in ecore.
I think you must use both of them : UML.ecore and Marte Profile
The source model can be in uml.
This would be the first lines in ATL:
module MARTE2AnoterModel
create OUT : UML2 from IN: UML2, MARTEProfile:UML2;
You have to point to the UML.ecore for "UML2" while MARTEProfile will be
directed to the MARTE-Profile.
Re: Reusing package-element in UML Metamodel extension [message #627316 is a reply to message #478102] Tue, 06 January 2009 09:48 Go to previous message
Hi Deepak,
- James.
> Hello,
> and editor.
> model.
> Regards,
> Deepak
Re: Reusing package-element in UML Metamodel extension [message #627317 is a reply to message #478109] Wed, 07 January 2009 08:17 Go to previous message
Hi James,
OCL constraints.
uml:package
Activity
CallOperationAction
InputPin
OutputPin
ControlFlow
InitialNode
FinalNode....
Deepak
> Hi Deepak,
> Cheers,
> - James.
>> Hello,
>> and editor.
>> model.
>> Regards,
>> Deepak
name="My.uml"
filename="My.uml"
</specification>
</ownedRule>
</generalization>
</packagedElement>
</packagedElement>
</eAnnotations>
</uml:Model>
</xmi:XMI>
</eAnnotations>
</eParameters>
</eAnnotations>
</eGenericType>
</eParameters>
</eOperations>
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
Re: Reusing package-element in UML Metamodel extension [message #627320 is a reply to message #478110] Wed, 07 January 2009 13:37 Go to previous message
Hi Deepak,
all.
-James.
> Hi James,
> OCL constraints.
> uml:package
> Activity
> CallOperationAction
> InputPin
> OutputPin
> ControlFlow
> InitialNode
> FinalNode....
> Regards,
> Deepak
>> Hi Deepak,
>> Cheers,
>> - James.
>>> Hello,
>>> model
>>> model
>>> and editor.
>>> model.
>>> Regards,
>>> Deepak
> </specification>
> </ownedRule>
> <generalization
> </generalization>
> </packagedElement>
> </packagedElement>
> <eAnnotations
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> </xmi:XMI>
> </eAnnotations>
> </eParameters>
> </eAnnotations>
> </eGenericType>
> </eParameters>
> </eOperations>
> </eClassifiers>
> </eSubpackages>
> </ecore:EPackage>
Re: Reusing package-element in UML Metamodel extension [message #627321 is a reply to message #478113] Thu, 08 January 2009 03:54 Go to previous message
Thanks James !!
Deepak
> Hi Deepak,
> all.
> -James.
>> Hi James,
>> OCL constraints.
>> uml:package
>> Activity
>> CallOperationAction
>> InputPin
>> OutputPin
>> ControlFlow
>> InitialNode
>> FinalNode....
>> Regards,
>> Deepak
>>> Hi Deepak,
>>> Cheers,
>>> - James.
>>>> Hello,
>>>> model
>>>> model
>>>> and editor.
>>>> model.
>>>> Regards,
>>>> Deepak
Re: Reusing package-element in UML Metamodel extension [message #627322 is a reply to message #478114] Thu, 08 January 2009 11:00 Go to previous message
Hi Deepak,
representation.
- James.
> Thanks James !!
> Regards,
> Deepak
>> Hi Deepak,
>> all.
>> -James.
>>> Hi James,
>>> OCL constraints.
>>> uml:package
>>> Activity
>>> CallOperationAction
>>> InputPin
>>> OutputPin
>>> ControlFlow
>>> InitialNode
>>> FinalNode....
>>> Regards,
>>> Deepak
>>>> Hi Deepak,
>>>> Cheers,
>>>> - James.
>>>>> Hello,
>>>>> UML-Metamodel ?
>>>>> model
>>>>> model
>>>>> and editor.
>>>>> model.
>>>>> Regards,
>>>>> Deepak
Re: Reusing package-element in UML Metamodel extension [message #627326 is a reply to message #478115] Fri, 09 January 2009 04:18 Go to previous message
Hi James,
This confused me:
<<metapackage>>
Deepak
> Hi Deepak,
> representation.
> Cheers,
> - James.
>> Thanks James !!
>> Regards,
>> Deepak
>>> Hi Deepak,
>>> all.
>>> -James.
>>>> Hi James,
>>>> OCL constraints.
>>>> uml:package
>>>> Activity
>>>> CallOperationAction
>>>> InputPin
>>>> OutputPin
>>>> ControlFlow
>>>> InitialNode
>>>> FinalNode....
>>>> Regards,
>>>> Deepak
>>>>> Hi Deepak,
>>>>> Cheers,
>>>>> - James.
>>>>>> Hello,
>>>>>> UML-Metamodel ?
>>>>>> model
>>>>>> model
>>>>>> and editor.
>>>>>> model.
>>>>>> Regards,
>>>>>> Deepak
UML2 Metamodel extension [message #627359 is a reply to message #478102] Wed, 04 February 2009 06:28 Go to previous message
Hi Deepak,
Re: UML2 Metamodel extension [message #627367 is a reply to message #478154] Thu, 05 February 2009 12:19 Go to previous message
Rodrigues schrieb:
> Hi Deepak,
> Thanks
Previous Topic:No automatic generation of OCL classes
Next Topic:API for manipulating UML Profiled
Current Time: Sat Jul 19 21:16:29 EDT 2025
Powered by FUDForum. Page generated in 0.07291 seconds
