No automatic generation of OCL classes [message #478160] |
Thu, 05 February 2009 12:09  |
--------------040205090000060103060409
I have a metamodel in UML and I want to attach some OCL expressions to it.
In order to get my OCL code in my metamodel I followed this presentation:
http://www.eclipse.org/modeling/mdt/uml2/docs/presentations/ EclipseCon2008_LongTalk_NewFeaturesOfUML2.html
My metaclass contains a "constraint" which in turns contains the "Opaque
Expression".
I set "OCL" to the property field "Language" and the "Body" contains my
OCL expression.
I chose "Process all" for creating the genmodel.
However no OCL related files were generated.
What am I doing wrong ?
I attached the my uml model.
Thanks in advance,
Deepak
Content-Type: text/xml;
name="Test.Behavior.Commons.uml"
Content-Disposition: inline;
filename="Test.Behavior.Commons.uml"
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:Standard="http://www.eclipse.org/uml2/schemas/Standard/1" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Standard/1 pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w">
<uml:Model xmi:id="_0" name="TestMode">
<packagedElement xmi:type="uml:Package" xmi:id="SUM.Behavior.Activities" name="Test.Behavior.Activities">
<packagedElement xmi:type="uml:Class" xmi:id="SUM.Behavior.Activities-K2Activity" name="TestActivity">
<generalization xmi:id="SUM.Behavior.Activities-K2Activity-_generalization.0 ">
<general xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Activity"/>
</generalization>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="SUM.Behavior.Activities-K2CallOperationAction" name="TestCallOperationAction">
<generalization xmi:id=" SUM.Behavior.Activities-K2CallOperationAction-_generalizatio n.0 ">
<general xmi:type="uml:Class" href=" pathmap://UML_METAMODELS/UML.metamodel.uml#CallOperationActi on"/>
</generalization>
</packagedElement>
</packagedElement>
<packagedElement xmi:type="uml:Package" xmi:id="SUM.Structure.Classes" name="Test.Structure.Class">
<packagedElement xmi:type="uml:Class" xmi:id="SUM.Structure.Classes-ComponentClass" name="TestClass">
<generalization xmi:id="SUM.Structure.Classes-ComponentClass-_generalization.0 ">
<general xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</generalization>
<ownedAttribute xmi:id="SUM.Structure.Classes-ComponentClass-_ownedAttribute.0 " type="SUM.Behavior.Activities-K2CallOperationAction" association="SUM.Structure.Classes-_ClassComp_to_K2Op">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_m9dMYPOjEd23f4Okph-UlQ" value="*"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="SUM.Structure.Classes-K2Operation" name="TestOperation">
<ownedRule xmi:id="SUM.Structure.Classes-K2Operation-_ownedRule.0">
<specification xmi:type="uml:OpaqueExpression" xmi:id=" SUM.Structure.Classes-K2Operation-_ownedRule.0-_specificatio n ">
<language>OCL</language>
<body>method->oclIsKindOf(TestActivity)</body>
</specification>
</ownedRule>
<generalization xmi:id="SUM.Structure.Classes-K2Operation-_generalization.0 ">
<general xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Operation"/>
</generalization>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="SUM.Structure.Classes-_ClassComp_to_K2Op" name="_ClassComp_to_TestOp" visibility="private" memberEnd="SUM.Structure.Classes-ComponentClass-_ownedAttribute.0 _OxSRYPOlEd23f4Okph-UlQ">
<ownedEnd xmi:id="_OxSRYPOlEd23f4Okph-UlQ" type="SUM.Structure.Classes-ComponentClass" association="SUM.Structure.Classes-_ClassComp_to_K2Op">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_YeqVoPOlEd23f4Okph-UlQ" value="*"/>
</ownedEnd>
</packagedElement>
</packagedElement>
<profileApplication xmi:id="_profileApplication.0">
<eAnnotations xmi:id=" _profileApplication.0-_http2F2Fwww.eclipse.org2Fuml22F2.0.02 FUML " source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
</profileApplication>
</uml:Model>
<Standard:Metamodel xmi:id="_F5TKkPOFEd2E4LeBnWmniQ" base_Model="_0"/>
<Standard:Metaclass xmi:id="_NeL4UPOFEd2E4LeBnWmniQ" base_Class="SUM.Structure.Classes-ComponentClass"/>
<Standard:Metaclass xmi:id="_cd0gYPOFEd2E4LeBnWmniQ"/>
<Standard:Metaclass xmi:id="_FEKncPOHEd2E4LeBnWmniQ" base_Class="SUM.Structure.Classes-K2Operation"/>
<Standard:Metaclass xmi:id="_aUQPAPOJEd2E4LeBnWmniQ" base_Class="SUM.Behavior.Activities-K2Activity"/>
<Standard:Metaclass xmi:id="_aUQPAfOJEd2E4LeBnWmniQ" base_Class="SUM.Behavior.Activities-K2CallOperationAction"/ >
</xmi:XMI>
--------------040205090000060103060409--
Re: No automatic generation of OCL classes [message #478178 is a reply to message #478177] |
Sun, 08 February 2009 07:58  |
James Bruck schrieb:
> Hi Deepak,
> Your constraint doesn't have a name so the code generater doesn't know how
> to produce a method.
> 1. Set the constraint name to validateOperation.
> 2. Right click on your .genmodel and select "reload...".
> 3. Regenerate your code.
Thanks James !
It works nicely.
I thought UML OCL constraints would be mapped to EAnnotations and not as
method.
Deepak
Re: No automatic generation of OCL classes [message #627377 is a reply to message #478160] |
Fri, 06 February 2009 16:20  |
Hi Deepak,
That should do it.
- James.
"Deepak" <dee_n@gmx.de> wrote in message
news:gmf6gq$anu$1@build.eclipse.org...
> Hello,
> Expression".
> OCL expression.
> Thanks in advance,
> Deepak
> <generalization
> </generalization>
> </packagedElement>
> <generalization
> </generalization>
> </packagedElement>
> </packagedElement>
> <generalization
> </generalization>
> <ownedAttribute
> </ownedAttribute>
> </packagedElement>
> </specification>
> </ownedRule>
> <generalization
> </generalization>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </packagedElement>
> <eAnnotations
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> </xmi:XMI>
Re: No automatic generation of OCL classes [message #627378 is a reply to message #478177] |
> Hi Deepak,
Thanks James !
It works nicely.
method.
Deepak
FUDForum. Page generated in 0.24769 seconds
