Home » Modeling » UML2 » Re: Loading a Resource fails
Re: Loading a Resource fails [message #477851] |
Mon, 20 October 2008 12:09  |
--------------020602040301090903040609
Timothy,
These are really questions to direct to the UML2 newsgroup because I
just can't answer them from an EMF perspective. I'm not sure there is
any way in the IDE, given just an Ecore model, to create an instance of
UML's GenModel...
Timothy Marc wrote:
> But it is really strange, because obviously, the
> DerivedUnionEObjectList-Type is used... so, why is this Liste-Type
> used, but not the SubsetSuperset-one?
> "Timothy Marc" <timothymarc@freenet.de
> <mailto:timothymarc@freenet.de>> schrieb im Newsbeitrag
> news:gdi15h$9re$1@build.eclipse.org...
> Okay, and how can i use it explicitly. I didn't found any tutorial
> for it. Do you know some?
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>>
> schrieb im Newsbeitrag news:gdi10t$5nk$1@build.eclipse.org...
> Timothy,
> In order to generate the right things, you really have to be
> using UML's extended GenModel, which you'll only get if you
> specify your model using UML2 and import it. So it's not
> sufficient just to have an Ecore model with annotations just
> like the ones UML produces, you have to be using UML's
> extended GenModel for those annotations to be recognized...
> Timothy Marc wrote:
>> Ed,
>> i've tried it with a reall simple model. It consists only of
>> the following elements:
>> ModelElement
>> +owner:ModelElement (union)
>> +ownedElement:ModelElement (union)
>> A : ModelElement
>> +theB :B (subsets +ownedElemend) -containment
>> B : ModelElement
>> +theA:A (subsets +owner)
>> and the Editor allows, to construct things like
>> A
>> + B
>> But the access fails with the message, that B is not a legal
>> value.
>> It is wierd, because i thought, that the generator should
>> made use of the UML2-specific SupersetSubsetEList-Type, for
>> the subsetting properties (annotated as subsets), as it made
>> use of the DerivedUnionEList-Type for the EReferences,
>> annotated as Unions. But instead of, it uses the simple
>> Ecore-List-Type.
>> After your last post, i've tried a lot with these annotations
>> ans the code generation for UML2. I'm confused right now,
>> because I'm pretty sure, that, in a former approach, the code
>> generator exactly has used this UML2-specific types. But now,
>> everytime i regenerate this simple model, it uses only the
>> EMF-specific one...
>> I'm a bit frustrated currently, because i didn't get forward
>> with this problem...
>> Timothy
>> <mailto:Ed.Merks@gmail.com>> schrieb im Newsbeitrag
>> news:gdhrs1$2du$1@build.eclipse.org...
>> Timothy,
>> Comments below.
>> Timothy Marc wrote:
>>> Ed,
>>> you were right. It was because of an invalid reference. However, this kind
>>> of reference was allowed by the generated editor. Currently, i'm playing a
>>> little bit with the UML2 codegenerator, in particular the
>>> Union/Subset-mechanism.
>> Hmmm. It should never allow you to construct an instance
>> that isn't sound. In fact, the underlying model simply
>> doesn't allow it, which is why the deserializer is
>> failing. Maybe you just had two objects with the same ID
>> or something else that the validator could notice if you
>> invoked it?
>>> Thx
>>> Timothy
>>> "Timothy Marc" <timothymarc@freenet.de> schrieb im Newsbeitrag
>>> news:gdhhid$rqj$1@build.eclipse.org...
>>>> Hey all,
>>>> i've a problem when i try to load a resource programmatically. I think,
>>>> this is because of a missconfiguration of ResourceFactories, but i didn't
>>>> get it work.
>>>> The genmodel settings uses the None as Resource Type. That works fine. But
>>>> when i try to load my model programmatically via the following snippet:
>>>> final ResourceSet resourceSet = new ResourceSetImpl();
>>>> final Resource r = resourceSet.getResource(uri,true);
>>>> final TestingModel model = (TestingModel)r.getContents().get(0);
>>>> it fails with the following exception:
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
>>>> org.eclipse.emf.ecore.xmi.IllegalValueException: Value
>>>> 'testing.impl.PackageImpl@1325aef (id: null, description: null, name:
>>>> pack)' is not legal.
>>>> (file:/D:/workspaces/esaWorkspace/testing.victoria/My.testin g, -1, -1)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:316)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:275)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
>>>> at unit.UMLismTesting.test(UMLismTesting.java:28)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>>> at
>>>> org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodRunner.java:99)
>>>> at
>>>> org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunner.java:81)
>>>> at
>>>> org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
>>>> at
>>>> org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.java:75)
>>>> at
>>>> org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)
>>>> at
>>>> org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:66)
>>>> at
>>>> org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
>>>> at
>>>> org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
>>>> at
>>>> at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
>>>> at
>>>> org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:38)
>>>> at
>>>> org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
>>>> at
>>>> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
>>>> at
>>>> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
>>>> at
>>>> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
>>>> at
>>>> org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
>>>> at
>>>> org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:24)
>>>> at
>>>> org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:572)
>>>> at
>>>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:171)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
>>>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
>>>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
>>>> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
>>>> at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
>>>> Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2535)
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1098)
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1179)
>>>> at
>>>> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown
>>>> Source)
>>>> at
>>>> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
>>>> Source)
>>>> at
>>>> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
>>>> Source)
>>>> at
>>>> Source)
>>>> at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
>>>> Source)
>>>> at
>>>> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
>>>> Source)
>>>> at
>>>> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
>>>> Source)
>>>> at javax.xml.parsers.SAXParser.parse(Unknown Source)
>>>> at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
>>>> at
>>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
>>>> ... 41 more
>>>> Caused by: java.lang.UnsupportedOperationException
>>>> at
>>>> org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(DerivedEObjectEList.java:278)
>>>> at java.util.AbstractSequentialList.add(Unknown Source)
>>>> at
>>>> org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObjectEList.java:660)
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1179)
>>>> at
>>>> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2530)
>>>> ... 57 more
>>>> Can anyone help me? I think this is just a configuration issue, isnt' it?
>>>> Thx
>>>> Timothy
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Timothy,<br>
<br>
UML's GenModel...<br>
<br>
<br>
Timothy Marc wrote:
<blockquote cite="mid:gdi1dj$b0v$1@build.eclipse.org" type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.5659" name="GENERATOR">
<div><font face="Arial" size="2">But it is really strange, because
obviously, the DerivedUnionEObjectList-Type is used... so, why is this
Liste-Type used, but not the SubsetSuperset-one?</font></div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Timothy Marc" <<a moz-do-not-send="true"
href="mailto:timothymarc@freenet.de">timothymarc@freenet.de</a>>
schrieb im Newsbeitrag <a moz-do-not-send="true"
href="news:gdi15h$9re$1@build.eclipse.org">news:gdi15h$9re$1@build.eclipse.org</a>...</div>
<div><font face="Arial" size="2">Okay, and how can i use it
explicitly. I didn't found any tutorial for it. Do you know some?</font></div>
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</a>> schrieb im
href="news:gdi10t$5nk$1@build.eclipse.org">news:gdi10t$5nk$1@build.eclipse.org</a>...</div>
Timothy,<br>
<br>
In order to generate the right things, you really have to be using
UML's extended GenModel, which you'll only get if you specify your
model using UML2 and import it. So it's not sufficient just to have
an Ecore model with annotations just like the ones UML produces, you
have to be using UML's extended GenModel for those annotations to be
recognized...<br>
<br>
<br>
Timothy Marc wrote:
<blockquote cite="mid:gdi0f1$vn8$1@build.eclipse.org" type="cite">
<style></style>
<div><font face="Arial" size="2">Ed,</font></div>
<div> </div>
<div><font face="Arial" size="2">i've tried it with a reall
simple model. It consists only of the following elements:</font></div>
<div> </div>
<div><font face="Arial" size="2">ModelElement</font></div>
<div><font face="Arial" size="2"> +owner:ModelElement (union)</font></div>
<div><font face="Arial" size="2"> +ownedElement:ModelElement
<div> </div>
<div><font face="Arial" size="2">A : ModelElement</font></div>
<div><font face="Arial" size="2"> +theB :B (subsets
+ownedElemend) -containment</font></div>
<div> </div>
<div><font face="Arial" size="2">B : ModelElement</font></div>
<div><font face="Arial" size="2"> +theA:A (subsets +owner)</font></div>
<div> </div>
<div><font face="Arial" size="2">and the Editor allows, to
construct things like </font></div>
<div> </div>
<div><font face="Arial" size="2"> A</font></div>
<div><font face="Arial" size="2"> + B</font></div>
<div> </div>
<div><font face="Arial" size="2">But the access fails with the
message, that B is not a legal value.</font></div>
<div> </div>
<div><font face="Arial" size="2">It is wierd, because i
thought, that the generator should made use of the UML2-specific
SupersetSubsetEList-Type, for the subsetting properties (annotated as
subsets), as it made use of the DerivedUnionEList-Type for the
EReferences, annotated as Unions. But instead of, it uses the simple
Ecore-List-Type.</font></div>
<div> </div>
<div><font face="Arial" size="2">After your last post, i've
tried a lot with these annotations ans the code generation for UML2.
I'm confused right now, because I'm pretty sure, that, in a former
approach, the code generator exactly has used this UML2-specific types.
But now, everytime i regenerate this simple model, it uses only the
EMF-specific one...</font></div>
<div> </div>
<div><font face="Arial" size="2">I'm a bit frustrated
currently, because i didn't get forward with this problem...</font></div>
<div> </div>
<div><font face="Arial" size="2">Timothy</font></div>
<div>"Ed Merks" <<a href="mailto:Ed.Merks@gmail.com"
moz-do-not-send="true">Ed.Merks@gmail.com</a>> schrieb im
Newsbeitrag <a href="news:gdhrs1$2du$1@build.eclipse.org"
moz-do-not-send="true">news:gdhrs1$2du$1@build.eclipse.org</a>...</div>
Timothy,<br>
<br>
Comments below.<br>
<br>
Timothy Marc wrote:
<blockquote cite="mid:gdhr0p$v5v$1@build.eclipse.org"
type="cite">
<pre wrap="">Ed,
</pre>
</blockquote>
Hmmm. It should never allow you to construct an instance that isn't
sound. In fact, the underlying model simply doesn't allow it, which
is why the deserializer is failing. Maybe you just had two objects
with the same ID or something else that the validator could notice if
you invoked it?<br>
type="cite">
<pre wrap="">Thx
Timothy
"Timothy Marc" <a class="moz-txt-link-rfc2396E"
href="mailto:timothymarc@freenet.de" moz-do-not-send="true"><timothymarc@freenet.de></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext"
href="news:gdhhid$rqj$1@build.eclipse.org" moz-do-not-send="true">news:gdhhid$rqj$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hey all,
get it work.
(<a class="moz-txt-link-freetext"
href=" file:/D:/workspaces/esaWorkspace/testing.victoria/My.testing "
moz-do-not-send="true"> file:/D:/workspaces/esaWorkspace/testing.victoria/My.testing </a>, -1, -1)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
at
at
at
.... 41 more
at
at
at
at
.... 57 more
Thx
Timothy
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------020602040301090903040609--
Re: Loading a Resource fails [message #477877 is a reply to message #477851] |
Thu, 23 October 2008 13:07   |
------=_NextPart_000_00D1_01C93510.40C8A550
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I would not expect to see a subset/superset list used in this case, =
because the only subsets are subsets of derived unions which, by =
definition, are derived and read-only, which means they are computed on =
the fly. The subset/superset lists are only used for subset and superset =
properties which aren't read-only, i.e., where modifiying one list =
requires dynamically updating the other list. In the case of derived =
unions, a new list is returned each time you ask for the value of that =
feature, and it essentially provides a view onto the subset lists =
(which, as in this case, may just be "normal" EMF lists...).
Kenn=20
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gdiagl$m5s$3@build.eclipse.org...
Timothy,
These are really questions to direct to the UML2 newsgroup because I =
just can't answer them from an EMF perspective. I'm not sure there is =
any way in the IDE, given just an Ecore model, to create an instance of =
UML's GenModel...
Timothy Marc wrote:=20
But it is really strange, because obviously, the =
DerivedUnionEObjectList-Type is used... so, why is this Liste-Type used, =
"Timothy Marc" <timothymarc@freenet.de> schrieb im Newsbeitrag =
Okay, and how can i use it explicitly. I didn't found any tutorial =
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag =
Timothy,
In order to generate the right things, you really have to be =
using UML's extended GenModel, which you'll only get if you specify your =
model using UML2 and import it. So it's not sufficient just to have an =
Ecore model with annotations just like the ones UML produces, you have =
to be using UML's extended GenModel for those annotations to be =
recognized...
Ed,
i've tried it with a reall simple model. It consists only of =
ModelElement
A : ModelElement
B : ModelElement
and the Editor allows, to construct things like=20
A
+ B
But the access fails with the message, that B is not a legal =
value.
It is wierd, because i thought, that the generator should made =
use of the UML2-specific SupersetSubsetEList-Type, for the subsetting =
properties (annotated as subsets), as it made use of the =
DerivedUnionEList-Type for the EReferences, annotated as Unions. But =
instead of, it uses the simple Ecore-List-Type.
After your last post, i've tried a lot with these annotations =
ans the code generation for UML2. I'm confused right now, because I'm =
pretty sure, that, in a former approach, the code generator exactly has =
used this UML2-specific types. But now, everytime i regenerate this =
simple model, it uses only the EMF-specific one...
I'm a bit frustrated currently, because i didn't get forward =
Timothy
Timothy,
Comments below.
Ed,
you were right. It was because of an invalid reference. However, this =
kind=20
of reference was allowed by the generated editor. Currently, i'm playing =
a=20
little bit with the UML2 codegenerator, in particular the=20
Hmmm. It should never allow you to construct an instance that isn't =
sound. In fact, the underlying model simply doesn't allow it, which is =
why the deserializer is failing. Maybe you just had two objects with =
the same ID or something else that the validator could notice if you =
invoked it?
Thx
Timothy
"Timothy Marc" <timothymarc@freenet.de> schrieb im Newsbeitrag=20
Hey all,
i've a problem when i try to load a resource programmatically. I think,=20
this is because of a missconfiguration of ResourceFactories, but i =
didn't=20
get it work.
The genmodel settings uses the None as Resource Type. That works fine. =
But=20
final ResourceSet resourceSet =3D new ResourceSetImpl();
final Resource r =3D resourceSet.getResource(uri,true);
final TestingModel model =3D (TestingModel)r.getContents().get(0);
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedExc=
eption:=20
org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
'testing.impl.PackageImpl@1325aef (id: null, description: null, name:=20
pack)' is not legal.=20
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadExcep=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Reso=
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceS=
etImpl.java:398)
at=20
org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodR=
unner.java:99)
at=20
org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunn=
er.java:81)
at=20
org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAft=
erRunner.java:34)
at=20
org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.ja=
va:75)
at=20
org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)=
at=20
org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestCl=
at=20
org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRun=
ner.java:35)
at=20
org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunn=
er.java:42)
at=20
erRunner.java:34)
at =
at=20
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4Test=
Reference.java:38)
at=20
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.jav=
a:38)
at=20
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTes=
tRunner.java:460)
at=20
tRunner.java:673)
at=20
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunn=
er.java:386)
at=20
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(Remote=
at=20
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestAp=
plication.java:24)
at=20
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAp=
at=20
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.ja=
va:171)
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
63)
at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
76)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value=20
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java=
:2535)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHand=
ler.java:1098)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:117=
9)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(=
Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.sc=
anDocument(Unknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unkno=
wn=20
Source)
at=20
wn=20
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown=20
Source)
at=20
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknow=
n=20
Source)
at=20
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse=
(Unknown=20
Source)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.jav=
a:180)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1=
354)
at=20
155)
at=20
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSe=
tImpl.java:256)
at=20
.... 41 more
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(=
at=20
org.eclipse.uml2.common.util.DerivedEObjectEList.addUnique(D erivedEObject=
EList.java:660)
at=20
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:=
1179)
at=20
:2530)
.... 57 more
Can anyone help me? I think this is just a configuration issue, isnt' =
it?
Thx
Timothy
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16705" name=3DGENERATOR></HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I would not expect to see a =
subset/superset list=20
used in this case, because the only subsets are subsets of derived =
unions which,=20
by definition, are derived and read-only, which means they are computed =
on the=20
fly. The subset/superset lists are only used for subset and superset=20
requires=20
dynamically updating the other list. In the case of derived unions, a =
new=20
list is returned each time you ask for the value of that feature, =
and=20
it essentially provides a view onto the subset lists (which, as in =
this=20
case, may just be "normal" EMF lists...).</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Kenn</FONT> </DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote in =
message=20
<A=20
href=3D"news:gdiagl$m5s$3@build.eclipse.org">news:gdiagl$m5s$3@build.ecli=
pse.org</A>...</DIV>Timothy,<BR><BR>These=20
are really questions to direct to the UML2 newsgroup because I just =
can't=20
answer them from an EMF perspective. I'm not sure there is any =
way in=20
the IDE, given just an Ecore model, to create an instance of UML's=20
GenModel...<BR><BR><BR>Timothy Marc wrote:=20
<BLOCKQUOTE cite=3Dmid:gdi1dj$b0v$1@build.eclipse.org type=3D"cite">
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR>
<DIV><FONT face=3DArial size=3D2>But it is really strange, because =
obviously,=20
the DerivedUnionEObjectList-Type is used... so, why is this =
Liste-Type used,=20
but not the SubsetSuperset-one?</FONT></DIV>
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Timothy Marc" <<A href=3D"mailto:timothymarc@freenet.de"=20
moz-do-not-send=3D"true">timothymarc@freenet.de</A>> schrieb im =
Newsbeitrag <A href=3D"news:gdi15h$9re$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdi15h$9re$1@build.eclipse.org</A>...</DIV>=
<DIV><FONT face=3DArial size=3D2>Okay, and how can i use it =
explicitly. I=20
didn't found any tutorial for it. Do you know some?</FONT></DIV>
<DIV>"Ed Merks" <<A href=3D"mailto:Ed.Merks@gmail.com"=20
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>> schrieb im =
Newsbeitrag=20
<A href=3D"news:gdi10t$5nk$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdi10t$5nk$1@build.eclipse.org</A>...</DIV>=
Timothy,<BR><BR>In=20
order to generate the right things, you really have to be using =
UML's=20
model using=20
UML2 and import it. So it's not sufficient just to =
have an=20
Ecore model with annotations just like the ones UML produces, =
you have=20
to be using UML's extended GenModel for those annotations to be=20
recognized...<BR><BR><BR>Timothy Marc wrote:=20
<BLOCKQUOTE cite=3Dmid:gdi0f1$vn8$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>i've tried it with a reall =
simple model.=20
It consists only of the following elements:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>ModelElement</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =
+owner:ModelElement=20
(union)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> =20
+ownedElement:ModelElement (union)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>A : ModelElement</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> +theB :B =
(subsets=20
+ownedElemend) -containment</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>B : ModelElement</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> +theA:A =
(subsets=20
+owner)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>and the Editor allows, to =
construct=20
things like </FONT></DIV>
<DIV> </DIV>
A</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> + =
B</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>But the access fails with the =
message,=20
that B is not a legal value.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>It is wierd, because i =
thought, that the=20
generator should made use of the UML2-specific=20
SupersetSubsetEList-Type, for the subsetting properties =
(annotated as=20
subsets), as it made use of the DerivedUnionEList-Type for the =
EReferences, annotated as Unions. But instead of, it uses the =
simple=20
Ecore-List-Type.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>After your last post, i've =
tried a lot=20
with these annotations ans the code generation for UML2. I'm =
confused=20
right now, because I'm pretty sure, that, in a former =
approach, the=20
code generator exactly has used this UML2-specific types. But =
now,=20
everytime i regenerate this simple model, it uses only the=20
EMF-specific one...</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>I'm a bit frustrated =
currently, because i=20
didn't get forward with this problem...</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Timothy</FONT></DIV>
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>> schrieb =
im=20
Newsbeitrag <A href=3D"news:gdhrs1$2du$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:gdhrs1$2du$1@build.eclipse.org</A>...</DIV>=
Timothy,<BR><BR>Comments=20
below.<BR><BR>Timothy Marc wrote:=20
<BLOCKQUOTE cite=3Dmid:gdhr0p$v5v$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Ed,
kind=20
a=20
</PRE></BLOCKQUOTE>Hmmm. It should never allow you to=20
construct an instance that isn't sound. In fact, =
the=20
underlying model simply doesn't allow it, which is why the=20
deserializer is failing. Maybe you just had two =
objects with=20
the same ID or something else that the validator could =
notice if you=20
invoked it?<BR>
type=3D"cite"><PRE wrap=3D"">Thx
Timothy
"Timothy Marc" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:timothymarc@freenet.de" =
moz-do-not-send=3D"true"><timothymarc@freenet.de></A> schrieb im =
Newsbeitrag=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:gdhhid$rqj$1@build.eclipse.org" =
moz-do-not-send=3D"true">news:gdhhid$rqj$1@build.eclipse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hey all,
didn't=20
get it work.
But=20
eption:=20
(<A class=3Dmoz-txt-link-freetext =
href=3D" file:/D:/workspaces/esaWorkspace/testing.victoria/My.testing " =
moz-do-not-send=3D"true">file:/D:/workspaces/esaWorkspace/testing.victori=
a/My.testing</A>, -1, -1)
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE></=
BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00D1_01C93510.40C8A550--
Re: Loading a Resource fails [message #477879 is a reply to message #477877] |
Fri, 24 October 2008 06:17   |
------=_NextPart_000_01E9_01C935D2.88193F10
Dear Kenn,
thanks, that was a good explanation concerning the list types. You =
helped me a lot with this...
Thx
Timothy
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> schrieb im Newsbeitrag =
news:gdqavr$mgk$1@build.eclipse.org...
Kenn=20
Timothy,
UML's GenModel...
Okay, and how can i use it explicitly. I didn't found any =
Timothy,
recognized...
Ed,
ModelElement
A : ModelElement
B : ModelElement
A
+ B
value.
It is wierd, because i thought, that the generator should =
made use of the UML2-specific SupersetSubsetEList-Type, for the =
subsetting properties (annotated as subsets), as it made use of the =
After your last post, i've tried a lot with these =
annotations ans the code generation for UML2. I'm confused right now, =
because I'm pretty sure, that, in a former approach, the code generator =
exactly has used this UML2-specific types. But now, everytime i =
regenerate this simple model, it uses only the EMF-specific one...
Timothy
Timothy,
Comments below.
Ed,
kind=20
a=20
invoked it?
Thx
Timothy
Hey all,
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
=20
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Dear Kenn,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>thanks, that was a good explanation =
concerning the=20
list types. You helped me a lot with this...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thx</FONT></DIV>
<DIV>"Kenn Hussey" <<A=20
href=3D"mailto:Kenn.Hussey@embarcadero.com">Kenn.Hussey@embarcadero.com</=
A>>=20
schrieb im Newsbeitrag <A=20
href=3D"news:gdqavr$mgk$1@build.eclipse.org">news:gdqavr$mgk$1@build.ecli=
unions=20
which, by definition, are derived and read-only, which means they are =
computed=20
on the fly. The subset/superset lists are only used for subset and =
superset=20
properties which aren't read-only, i.e., where modifiying one =
list=20
unions, a=20
feature, and=20
it essentially provides a view onto the subset lists (which, as =
in this=20
<DIV> </DIV>
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote =
in message=20
<A=20
can't=20
way in=20
obviously,=20
Liste-Type=20
used, but not the SubsetSuperset-one?</FONT></DIV>
<DIV>"Timothy Marc" <<A =
moz-do-not-send=3D"true">timothymarc@freenet.de</A>> schrieb =
im=20
explicitly. I=20
Newsbeitrag <A href=3D"news:gdi10t$5nk$1@build.eclipse.org"=20
using UML's=20
model=20
using UML2 and import it. So it's not sufficient =
just to=20
have an Ecore model with annotations just like the ones UML =
produces,=20
you have to be using UML's extended GenModel for those =
annotations to=20
be recognized...<BR><BR><BR>Timothy Marc wrote:=20
type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
simple=20
model. It consists only of the following =
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>A : =
(subsets=20
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>B : =
(subsets=20
<DIV> </DIV>
construct=20
<DIV> </DIV>
A</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> +=20
B</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>But the access fails with =
the message,=20
<DIV> </DIV>
thought, that=20
the generator should made use of the UML2-specific=20
(annotated=20
as subsets), as it made use of the DerivedUnionEList-Type =
for the=20
EReferences, annotated as Unions. But instead of, it uses =
the simple=20
<DIV> </DIV>
tried a lot=20
confused right now, because I'm pretty sure, that, in a =
former=20
approach, the code generator exactly has used this =
UML2-specific=20
types. But now, everytime i regenerate this simple model, it =
uses=20
only the EMF-specific one...</FONT></DIV>
<DIV> </DIV>
currently, because=20
i didn't get forward with this problem...</FONT></DIV>
<DIV> </DIV>
moz-do-not-send=3D"true">Ed.Merks@gmail.com</A>> =
schrieb im=20
Newsbeitrag <A =
kind=20
a=20
construct an instance that isn't sound. In =
fact, the=20
underlying model simply doesn't allow it, which is why the =
objects with=20
notice if=20
you invoked it?<BR>
Timothy
Newsbeitrag=20
</PRE>
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_01E9_01C935D2.88193F10--
Re: Loading a Resource fails [message #478145 is a reply to message #477879] |
Wed, 28 January 2009 12:24   |
--------------070806030006080000070504
Hi everyone,
I am having a similar problem although the subsetted properties are
derived union. I am attaching the source UML model and the generated
ecore and genmodel. I am able to use the editor to save but when loading
the saved model I am getting the attached exception. I am using Eclipse
3.5M4.
Timothy Marc wrote:
> Dear Kenn,
> Thx
> Timothy
> <mailto:Kenn.Hussey@embarcadero.com>> schrieb im Newsbeitrag
> superset properties which aren't read-only, i.e., where modifiying
> one list requires dynamically updating the other list. In the case
> of derived unions, a new list is returned each time you ask for the
> value of that feature, and it essentially provides a view onto the
> subset lists (which, as in this case, may just be "normal" EMF
> lists...).
> Kenn
> wrote in message news:gdiagl$m5s$3@build.eclipse.org...
> Timothy,
> because I just can't answer them from an EMF perspective. I'm
> not sure there is any way in the IDE, given just an Ecore model,
> to create an instance of UML's GenModel...
>> Timothy,
>> to be using UML's extended GenModel, which you'll only
>> get if you specify your model using UML2 and import
>> it. So it's not sufficient just to have an Ecore
>> produces, you have to be using UML's extended GenModel
>> Timothy Marc wrote:
>>> Ed,
>>> ModelElement
>>> A : ModelElement
>>> B : ModelElement
>>> A
>>> + B
>>> a legal value.
>>> EMF-specific one...
>>> Timothy
>>> Newsbeitrag news:gdhrs1$2du$1@build.eclipse.org...
>>> Timothy,
>>> Comments below.
>>> Timothy Marc wrote:
>>>> Ed,
>>> instance that isn't sound. In fact, the
>>> just had two objects with the same ID or
>>> you invoked it?
>>>> Thx
>>>> Timothy
>>>>> Hey all,
>>>>> get it work.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 41 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 57 more
>>>>> Thx
>>>>> Timothy
Content-Type: application/octet-stream;
name="jdsl.zip"
filename="jdsl.zip"
UEsDBBQAAAAIAIiKPDp1E107rwQAAKEdAAANAAAAamRzbC5nZW5tb2RlbNVZ XW/iOBR9H2n+
Q5R9HtzpSqsVKh1lQuhmFgIiodq3KCQG3HFsZBta9tfvdRJTMoUu0ELbqkIk vh/H9x6fOObq
20NOrSUWknDWsr82LmwLs5RnhE1b9ijqfPnT/nb9+dPVFLOcZ5g2bzDr6S/W Q06aa8dLcPz8
yYI/iMdkEwZb9kypeROh+/v7Bs+nDS6m6J+ebxsTWTe5/72wuLy4+Apm3TCd 4Tz5QphUCUtx
LTpOucA1Z5xSMpe4iIDziY5yiTxtZtKZCex0W+T0El02YCbIzNG2Cpc2EThV XKxaNgLLhpoR
9jPHKmlkkiIp0gpcYTygiylhfrtlPzGtwgVJDuB/FDcESWcuJZipAU3UhIu8 ZSuxANQkn3Oh
sDCRDFQNU380iiI0jFkFIeX5nBJdsC5e6sn+oTua8vlKkOlMdQimmWzZk4RK bF9rH91ZhzGu
EgWdlJbkC5HuUVxTI2QQoH1QXpcwrzIoCaHS+omhqJ7bH3px5NzceO341umO vNC2lgldAIzB
sO96YWijrZ6jwO8HMdgMvGHk7+3WHg26vutEXtzxnGg03NsxHH0PvSjyg5vD k7r9Xs8LoqMx
xn7wlzf0IydwvYNjaKxOBMXaN70f3DpD3wmi2AWnaOj4+0Mfem2v4wdHVckJ gn5UII3bXuT4
3cPrtZ7rERXbgH5wydqQ6xYYfCCnHuF+77cPoJPT87qx64ReHMDX/RkM6WK3 64Rh3B8C5B1+
V6iuC+VNEChMpuXCv240EPzXVa4QOFR+3oHCaQ24QjU3IzqDJP2ZTLG04EHQ VKs5QNh8yFTD
tjUXeEIejGCOE4mroW0KW07ZsjIi51wmY4oHgi9JhkUnqSS8lNdCl9aBCqjF rd/QWqMAjccW
+S6Aesy29P0wmWB95YL4QrUgqVHYMo0eq+dAP26JJGNCiVr9TVhmcj5m7RKQ S4jxTPLKZCNJ
def5XGi+GFOSrvlxnpyCLBOFz52UK3hw4+zMaSvmrhcgMkzaYJZLEyl3kr8Y 1XuAgp2bXCpG
fgXgUZzDFqLOog5O1ELsTFEN6/XF51goLX44yTijK9uCZU8mK5PZRC02GAL8 sDsjNKsDq+K1
7OKq6Q3xBAvYSmJrK1Z0179nOOvhfAzbAvThkIt6e6t2nqrBbZ4udG4taKbZ 6FTJKtU/S64I
AryUtgFncJ3qxkLbKoHf2fkN+d+38RpkxVf9Vb6YriXiOlW38XNzEkciFkWF jwO894pxlBJk
vFDbYTzK48dY5yVqA+6s67zckGyuvPfOtCeI0d1g2/PvxIXT79TZi2r2YrJv QkAMLl6lAP/H
lfevnhXONS9Mjc67sszMj6rWYevH1DbkQrkzTlIsjypcZYfu3lLCDQip3wN/ fWk4O4oJYbAh
/xBPkXX3nj6FT6MHpcHb9KfIjZKxVAJes19pf3RCTSrx3pXHoR8Gbg+rGc9e RzefUUpdlDfi
UZEbAYmYJJvvHW8CY8kpaB49VnrPuAkr8ZZKU/b3tBQpifhGHCmTv1RsXguG XLF0Jjgj/z45
ZnqHRKlAn48pfZhZcYB8+BHC7qA+U1hMkhS/ZtDHs+6ThNfnf/VSFAU3h+D6 J1a0GdCclf8H
UEsDBBQAAAAIAHaKPDrGNdVKUAcAADg+AAAIAAAAamRzbC51bWzdW1tz4jYU fu9M/4PHfesM
GNJ2JpuB7hAMGwi3cEn3jTG2AsrasmuZkOTXV76BsSXb+JZsX0Iw0pHO+T5/ OtKxW19fNZV7
ASaGOmrzzXqD5wCSdQWibZtfLfu1a/7r37/+0nrV4M338YCzP4/Nr+pNnlxR Eb4h19v8zrKM
G0HA8g5oUl3XtnXd3ArYALJA+grB5vjU/HA41A9/OE2vGo0maTpaOBZqEGFL QjLwe/Vk3QRn
/YCsQgMDp/NeU6+8sbHgNBX+8nuC2J5Ae7KHvnJ7+X2IvfixiD/1hrAaj0gP DG/coUe6LFlO
dC6YJmdI1k6T7ObE3Ho2n/YHo97C/blumPoTVEGd9Pxt/d6c9uW75397ytv1 4s+ueT2X15MO
TzDiuBZpcTOT5B/SFjhIQaXNr/96x93rWvO+p1xN/7Fqh2Vjflc78BySNBKS ZwWrbm/S33D7
Kj0VaABZjg3rzSDNbMtdVcKYPzf8ZcoyPPSM8BzEnQ22TEm22rxl7oE/HBlw CxAwJRW+OzEL
mQZR0xAv9sQWtPaWtFGBZ4/zzLgdxftoRyHlkPusQ0Y7BobUDwgoHcsy4WZv hZD5wkZmancb
A20DTJ57gRhuoAqttzZvmPBFssgkXGyYQEA8NRVgAsWfNMRzIClTpL6droiA WAs28S6skMNi
96q03Zpg6xFb1jVDx9CeACGELkPvuhuJ6DyOgbAZahjAfJTUPQiRa0TskXiu kAo18q8ykaw9
+R6iW41JNxIh22qb/z0QeTKgqh9iBxwgC2ztAJ+PQ+GeN04AV+Ec2HSA1ygc CwD+8VBXDSnz
BjhC2iwC0jWbOomQtoSQMmYXzDWTWcMl6ZhZLddZpetbNP4ppWudIF22PziZ zrSIROjMEiBM
HAQWIdfM1AkN7TGYshpl9qhMZoudasRK7JQmVmInQaxcymZBmAUcTR4rB64a SRJvc0hSAnC3
TE48Px7RSkROHFHMRNEYRzErEI1bJgcLRuNi1BXwJO1VizbSwNu6OL+FBurG 6IK/5fHjH5tX
ZmJGl82MPrABSKHZ4uRDss18Yv9QqmZ0k1laiNh32SytMI0RRfa+z22eKmsR xYx7PNqSki5r
EUUmUJKXd9HpH4TOjk0oSDPTZgehsrsk7kzwRPqebetHg9t5Zz4g+3ry7aw9 rqtwY0rmm7PH
v9V1FUgo950usvOzPgSqkuI+fyghN6MqUPR2XUVbFXi79irKzXrl5WY9dm42 BtZOT4PvghKG
kuAsNUfoJa/dhcDZ/xSbSLHP3kTa8zafJDnlvlHsZ9w3xilwkZ4ygR12ENIt x6NLff5GzV4+
jc/f2Oj20F4j87FdSuvr58aXcvrg++oeZNsTzHmSLN5lxFscZs4y7thZtndA nyzOA8q0822b
76PRLlCE7yraqN19jhSYBs8ZddPSc5C10JH56E4csHOH2XkgUiQRtHu4ogO8 cgk9qCirGH6O
rIKidj6hJ+RDySvDw6xLEaXgkZLnQyaC9t+P3ugtyJzRtjSMO6fbJYQ0paJz JLbmFBx7iF2g
5FgrjpCde5Sarc89UZf3tpX4TCDP2Ewx9HPMQoaOgSNGZ0JwUJSbYyUcuedF OWVn0iRaDOJY
FYSU8wrmuqF5sclyOty+h0jhQyrhqXDIGhN+Y79RoRzRGroVJoa+rqQyM2aG 3DB1C8hkrUpp
iBkjL+p5s3k2bSjlACadxwzaUOoXIa+JjdCwcat1hgpVqjpHCVsi2tm6x27v gD7zCjzJmmlm
3whN2Jlm9uJhFJpZqcdLk4oKgtPkU8lm7nPDKXtrmrOmW1wFKN82t9xKz7Si be70MtJlI8OM
yThsn63JH50iF1ULmTFJ/wSRDfFP4mbhizVFOJmL9YyxWFM0PmmxjppKvVhT F8hUK0JpGQ9F
cJhBjJZLOJYs59jT0Ap3fhJh1/5SJgwPWZ8qo2CUMmF4iH+qzPS8TSIJrUDN qmDRVsSqC5Lz
y5b+zKvKvLyC5JwpJSRTRRg6u+efRGeTXGWS9EVXCWnUDz9bKntFoYkOrZrs iY5bkU6pOous
25Rl5gPxRcKDjh+nOqVubBYVbWyW5T3puGQK2v/teZ4lk6P4Dck7U0fwHSg/ jbcFCg/lvveF
Z2pcVi9fZa0Vx2Q8heeblFSEmW9GnwLjWHlW7gNjilgx5xV9fIljKfFpXu6b cB3DUKFMAy+m
HNgCpwdG8Hm3R5pq63vTfgw3/gXAhvcCYPD2IvcOMAGSAQ7EzXkB8aZ3rP3T 7rAMr/0Fb7Kg
f6fLkh0rZ+2xjV08biNI4kj0nZ9aQuC1Q/dKz/WWqmNwfk0J96umTlzRPjpx fCtxI2Gw9hfP
Sz3oHQWgdjKNPa9aQnimyfPH3WrnP5NMYpisrcXNn6Ie5c0/WDouzgWK0JQJ gcPty2dPexdX
fKSE352f29p3kbKmebo8Ob25yyE8I97A19P31XxwJlvWDqIfhEGSI1wIC8/S i+QOeRyR/BJo
5xgyPLND+5vtbUuw3fg+HpD//wNQSwMEFAAAAAgAhIo8OoN7jYzkAwAAcBwA AAoAAABqZHNs
LmVjb3Jl5VnJbtswEL0X6D8I6jlRlkthxAm6OEDapgmyoVeaGttsKNIgKTvp 13cokbJleZFt
OUlRHxKImhm9mXmzyD45e0p4MAKlmRTt8HD/IAxAUBkz0W+H93fnex/Ds9P3 706ASgWtzjWh
j6QPwVPCWoXWEWq9fxfgB40J3cKb7XBgzLAVRePxeF8m/X2p+tGvy4vQi+iy yPg4kzg6ODhE
sR+3dAAJ2WNCGyIolKxnSErKQDkbasgsQNKzVo6ijhULA0ESFP4da+6MCH1/ c1FSNwMmHhMw
JDMgdPSbjAhq6msFPfbktE+t+gl84URr1mPoe4BOtMzzEO276GQ3/TO/dTgk IEwYkK42ilDT
Do1KERPcpkNQd6ip2+GHKPr2SQhpiCFdDk4psMdfJU3txdR5DsMCuUVb1KSK 8HMg+B/m4LmB
HiiwAfRxuBoLiC8h6YIKg3SIMD7LVMTtcO/Qxcd+4C6zYjEUTtABEX2wUNph j3CNNkeSE8Ps
Qe5XDIqNIC7cvBoOpWambCnKMCjviHXFuY9c0oGWqaKokQq8DCPvbjTH3wZC gUGY4+skEM06
7QPfkOt4Z4qN6/NzHr1muRqtb7ZK5ias2izVqKS8PzVdMNkD6tVLjpNKDCsT FsACYlg5VwqZ
ygpO6LSrwSAG5RHqJQTbednkXkqF5LfUz0tjSTwWOu9C24j3Tfr9yRjFuqmZ +P3ANOsyzszz
Ese5HBcMOSz1lon6dyZi2zZ6JOXmgfAUfmBgEE07HKZdzujEjQ1T5GXrMdZJ N9DhnaWd0/q1
G2e1ycw2Jo+z0p9+ooW4odbkdrF6dVgIz+TMnUfemgf3gjW5bTpKMV09IjaK fqUf2L+VyM/U
fyURzthXnI72IKi1wyLmDkLEhdzPzUbo+yLTs0KqWh1pTn2tHqgVpYLSLz1b 189PR6RJkZ6Z
SVFkwE0J7eQqs2L2PnZqYvk6siPG0nGJqDRADcSF8NESYc8eJ3rcECuLMbSy gJvsoSsWmcXz
PFNcb1BXeoi2TKRrP37jLvJZSg5EbAu7xwThbx310sV1RZue2uO3XYnyTbdY yBqeqa+9CLmr
SoVOr34bksx3gX+PZ+cMeFx397aydaZbJujSn0d9UyrNMHKXr4qXYAbShmJh CmdiNB2aXLlO
bHLJ1wnO1lMvJ0Clgvw03K6IsIKEZtkC9barqILcd9m3DnzBmHFJrvNi5nto mdPZaeR7yaZ0
nvNCvntK+8KtcPoKLzPk/8loqO57z4IOlBTsj1213zb4HRPbj4Z/itkTAi9u 2Bt8tX0h8AWr
R+i8d50pzzb5Eh6x7sK6fV9dHIrCKsa79KshHv0FUEsDBBQAAAAIAGCWPDoz qWpU1QAAAFoB
AAAHAAAAbTEuamRzbGWQwWrDMAyG74O9g9G9cZJdionXXVZoaWmhG+zqJSJx GishNnX79rVL
Fwi7iu/79UvF6mo6dsHR6p4kZEkKDKnsK021hO+v9WIJq/fXl6KtbCe2R1We VY3sarSYpDxK
IYasCHMJjXOD4Nx7n/SmTvqx5j/7zYTYOeLfHkSeplnAdqeyQaMWmqxTVOKf FdfPNNdoOht0
6mGT5a26KGDtwRNWezS/OErg/KN9Vq4+OzRIzsaypAxKGDIIlzFW/GNYKCnc bQjQ7O5nfkye
QnLg8T98BobJHVBLAwQUAAAACADbmjw614auX98CAADLCgAADQAAAGV4Y2Vw dGlvbi50eHTN
ll9v2jAQwJ83ad8hD5WaSqshEArhadXaqqtAQmVr+2qSA1wcO7Kdwcff2Uko lNDSPw97gNhn
38/n8/nOUs0IxJxlGgikU2xLBWSVMvKLc5hRfkd5DperGDLDpOh7ru8dS9Qz cyYWKRhKEs3J
o/1jacbJzYjGCzqDX9j50Y6aZ82J5wuaQt/LWifHHtOekMZzeOL5U8ah37jo N+ZSa5qSBVUs
bSylWjRSmQBnYrZunFqxzmgMp23SScPGth1GUaGnUqXUGtvQKi40G2ng7Pvu nQb2d/Lt6xdq
PLl3824fD8PBNRUJB0U0mCugJlfg9u9vDD3Sv7TfOgt7b4bO3fdKqiVVyS1M QYGIQe/Ag6Dd
eTMcRHIh4zwFYXaBrSAsgbFMic4FsWCKfp0jDRRaQZgwoASeUEaVBqXJ+USj f2MzPn8YOdHW
Gn/EQsil8MYyR/XD6ZXdFehK0Zn9jmMqBCgbQ0Rj+8MLVdvAtYLgpxRTNsuV i5Ni6L8Glw7/
HN7uQX6M+0hXGVnD7Ikd3WDvILyNxxUG8JN1B6m9fg8GkiYueDg2/E1BcQV6 hyeBW9Bubaed
yEEJ3BKX0OaLUFVqFOQtfWdlDTGM2p+NbPVa70COwRT7hxRTyWCTXQ0VmbDz cq46lH4NPAO1
Z43ue/xcIWZgKlE9vh11N/A1VS7DBTAVFXf8BiWXCTNSkVhhjYChrTj+hthB e1sF4s3QEdZT
vQONmnXOzpm9OoYMc26YVSxURlZW0ZTBTGWU5H7drMINragevr74hca6cm3A y9N7PsFxz7p1
pfIwbj0xDMNXiPf4bJigwtxCnrQxFBx1z7CDd6I9Pn5m7jkaWWzbvhbumGYT XvrU35lRhnFd
DtolD6nA49mLrYbLhBHUJYy90KMOUbm4Z2a+fuPVYaOw+wp1bNB1efZ7jptM 8KV2VApucyEo
mmyX8Z9PKgOtzg16aciSJXhCmlSMgYwXjrMlKBidk39QSwECFAAUAAAACACI ijw6dRNdO68E
AAChHQAADQAAAAAAAAABACAAAAAAAAAAamRzbC5nZW5tb2RlbFBLAQIUABQA AAAIAHaKPDrG
NdVKUAcAADg+AAAIAAAAAAAAAAEAIAAAANoEAABqZHNsLnVtbFBLAQIUABQA AAAIAISKPDqD
e42M5AMAAHAcAAAKAAAAAAAAAAEAIAAAAFAMAABqZHNsLmVjb3JlUEsBAhQA FAAAAAgAYJY8
OjOpalTVAAAAWgEAAAcAAAAAAAAAAQAgAAAAXBAAAG0xLmpkc2xQSwECFAAU AAAACADbmjw6
14auX98CAADLCgAADQAAAAAAAAABACAAAABWEQAAZXhjZXB0aW9uLnR4dFBL BQYAAAAABQAF
ABkBAABgFAAAAAA=
--------------070806030006080000070504--
Re: [RESOLVED] Loading a Resource fails [message #478147 is a reply to message #478145] |
Thu, 29 January 2009 16:13  |
Just in case someone faced the same problem, marking the superset
properties as transient will solve this problem.
Hossam Karim
On Wed, 28 Jan 2009 19:24:14 +0200, Hossam Karim <hossam.karim@gmail.com>
wrote:
> Hi everyone,
> 3.5M4.
> Timothy Marc wrote:
>> Dear Kenn,
>> Thx
>> Timothy
>> lists...).
>> Kenn
>> Timothy,
>>> Timothy,
>>> Timothy Marc wrote:
>>>> Ed,
>>>> ModelElement
>>>> A : ModelElement
>>>> B : ModelElement
>>>> A
>>>> + B
>>>> a legal value.
>>>> EMF-specific one...
>>>> Timothy
>>>> Timothy,
>>>> Comments below.
>>>> Timothy Marc wrote:
>>>>> Ed,
>>>>> particular the
>>>> you invoked it?
>>>>> Thx
>>>>> Timothy
>>>>> im Newsbeitrag
>>>>>> Hey all,
>>>>>> get it work.
>>>>>> ResourceSetImpl();
>>>>>> final Resource r =
>>>>>> Value
>>>>>> -1, -1)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> -1, -1)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 41 more
>>>>>> Caused by:
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 57 more
>>>>>> Thx
>>>>>> Timothy
Re: Loading a Resource fails [message #627077 is a reply to message #477851] |
Kenn=20
Timothy,
UML's GenModel...
Timothy,
recognized...
Ed,
ModelElement
A : ModelElement
B : ModelElement
A
+ B
value.
Timothy
Timothy,
Comments below.
Ed,
kind=20
a=20
invoked it?
Thx
Timothy
Hey all,
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
=20
unions which,=20
on the=20
requires=20
new=20
and=20
this=20
<DIV> </DIV>
message=20
<A=20
can't=20
way in=20
obviously,=20
Liste-Type used,=20
explicitly. I=20
Newsbeitrag=20
UML's=20
model using=20
have an=20
you have=20
type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
simple model.=20
<DIV> </DIV>
<DIV> </DIV>
(subsets=20
<DIV> </DIV>
(subsets=20
<DIV> </DIV>
construct=20
<DIV> </DIV>
A</FONT></DIV>
B</FONT></DIV>
<DIV> </DIV>
message,=20
<DIV> </DIV>
(annotated as=20
simple=20
<DIV> </DIV>
tried a lot=20
confused=20
approach, the=20
now,=20
<DIV> </DIV>
<DIV> </DIV>
im=20
kind=20
a=20
the=20
objects with=20
notice if you=20
invoked it?<BR>
Timothy
Newsbeitrag=20
</PRE>
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
Re: Loading a Resource fails [message #627079 is a reply to message #477877] |
Dear Kenn,
Thx
Timothy
Kenn=20
Timothy,
UML's GenModel...
Timothy,
recognized...
Ed,
ModelElement
A : ModelElement
B : ModelElement
A
+ B
value.
Timothy
Timothy,
Comments below.
Ed,
kind=20
a=20
invoked it?
Thx
Timothy
Hey all,
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
=20
concerning the=20
A>>=20
unions=20
computed=20
superset=20
list=20
unions, a=20
feature, and=20
in this=20
<DIV> </DIV>
in message=20
<A=20
can't=20
way in=20
obviously,=20
Liste-Type=20
im=20
explicitly. I=20
using UML's=20
model=20
just to=20
produces,=20
annotations to=20
type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
simple=20
<DIV> </DIV>
<DIV> </DIV>
(subsets=20
<DIV> </DIV>
(subsets=20
<DIV> </DIV>
construct=20
<DIV> </DIV>
A</FONT></DIV>
B</FONT></DIV>
<DIV> </DIV>
the message,=20
<DIV> </DIV>
thought, that=20
(annotated=20
for the=20
the simple=20
<DIV> </DIV>
tried a lot=20
former=20
UML2-specific=20
uses=20
<DIV> </DIV>
<DIV> </DIV>
schrieb im=20
Newsbeitrag <A =
kind=20
a=20
fact, the=20
objects with=20
notice if=20
you invoked it?<BR>
Timothy
Newsbeitrag=20
</PRE>
didn't=20
get it work.
But=20
eption:=20
at=20
at=20
at=20
etImpl.java:398)
at=20
unner.java:99)
at=20
er.java:81)
at=20
erRunner.java:34)
at=20
va:75)
at=20
at=20
at=20
ner.java:35)
at=20
er.java:42)
at=20
erRunner.java:34)
at =
at=20
Reference.java:38)
at=20
a:38)
at=20
tRunner.java:460)
at=20
tRunner.java:673)
at=20
er.java:386)
at=20
at=20
plication.java:24)
at=20
at=20
va:171)
at=20
at=20
at=20
63)
at=20
76)
at=20
:2535)
at=20
ler.java:1098)
at=20
9)
at=20
Unknown=20
Source)
at=20
Source)
at=20
wn=20
Source)
at=20
wn=20
Source)
Source)
at=20
n=20
Source)
at=20
(Unknown=20
Source)
at=20
a:180)
at=20
354)
at=20
155)
at=20
tImpl.java:256)
at=20
.... 41 more
at=20
at=20
EList.java:660)
at=20
1179)
at=20
:2530)
.... 57 more
it?
Thx
Timothy
Re: Loading a Resource fails [message #627350 is a reply to message #477879] |
Hi everyone,
3.5M4.
Timothy Marc wrote:
> Dear Kenn,
> Thx
> Timothy
> lists...).
> Kenn
> Timothy,
>> Timothy,
>> Timothy Marc wrote:
>>> Ed,
>>> ModelElement
>>> A : ModelElement
>>> B : ModelElement
>>> A
>>> + B
>>> a legal value.
>>> EMF-specific one...
>>> Timothy
>>> Timothy,
>>> Comments below.
>>> Timothy Marc wrote:
>>>> Ed,
>>> you invoked it?
>>>> Thx
>>>> Timothy
>>>>> Hey all,
>>>>> get it work.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 41 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 57 more
>>>>> Thx
>>>>> Timothy
name="jdsl.zip"
filename="jdsl.zip"
ABkBAABgFAAAAAA=
Re: [RESOLVED] Loading a Resource fails [message #627352 is a reply to message #478145] |
Hossam Karim
wrote:
> Hi everyone,
> 3.5M4.
> Timothy Marc wrote:
>> Dear Kenn,
>> Thx
>> Timothy
>> lists...).
>> Kenn
>> Timothy,
>>> Timothy,
>>> Timothy Marc wrote:
>>>> Ed,
>>>> ModelElement
>>>> A : ModelElement
>>>> B : ModelElement
>>>> A
>>>> + B
>>>> a legal value.
>>>> EMF-specific one...
>>>> Timothy
>>>> Timothy,
>>>> Comments below.
>>>> Timothy Marc wrote:
>>>>> Ed,
>>>>> particular the
>>>> you invoked it?
>>>>> Thx
>>>>> Timothy
>>>>> im Newsbeitrag
>>>>>> Hey all,
>>>>>> get it work.
>>>>>> ResourceSetImpl();
>>>>>> final Resource r =
>>>>>> Value
>>>>>> -1, -1)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> -1, -1)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 41 more
>>>>>> Caused by:
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 57 more
>>>>>> Thx
>>>>>> Timothy
Current Time: Sat Jul 19 06:24:42 EDT 2025
Powered by FUDForum. Page generated in 0.39901 seconds
