Home » Modeling » UML2 » Importing Superstructure.uml to Rational Software Architect
Importing Superstructure.uml to Rational Software Architect [message #477925] Tue, 04 November 2008 19:08 Go to next message
I was trying to visualize the UML superstructure and imported the file
"Superstructure.uml" to RSA but I can only see model elements (packages,
relationships, classes, etc.) does anyone know if there is a way I can
actually see the class diagram. The UML I'm using is the version 2.2.1.
Thanks for your help.
Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477928 is a reply to message #477925] Wed, 05 November 2008 06:08 Go to previous messageGo to next message
Hector,
the .uml files usually contain only "semantic" model elements and no
visualization information. There are RSA-versions (.emx) of the UML
metamodel, which include many diagrams. You can find them in the Eclipse
UML2 CVS:
:pserver:anonymous@dev.eclipse.org:/cvsroot/modeling
org.eclipse.mdt/org.eclipse.uml2/plugins/org.eclipse.uml2.um l/model
Marco
Hector M Chavez schrieb:
> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477930 is a reply to message #477928] Wed, 05 November 2008 08:15 Go to previous messageGo to next message
Hector,
Do you mean that you would like to create a new class diagram from only
your UML model ?
If yes, then you can use EclipseUML 2008 which a tool for Java/JEE or UML
modelers who would like to become plumbers and not just designers :-)
Just past and copy the .uml file at the root of your project, then rename
your .uml in order to have the same name as your project. Finally click to
open your .uml file contextual menu > Open with > Omondo xmi editor.
You then can see your UML model inside the XMI editor. The XMI Editor is
an Omondo concept. If you don't understand this model concept based on UML
metamodel ( e.g. not on EMF transformation) please let me know and we will
add some documentations on our website.
The next step is to create your graphical view (e.g. have a class diagram
from your UML model). You just need to create a package or a class diagram
in your project, then drag and drop UML superstructure elements from the
xmi editor to your diagrams. You can select one or many elements at the
same time.
After the classes are inside your diagram you can navigate dynamically by
using the package or class diagram contextual menu (Show/ hide
inheritance, association, dependencies).
Vlad VARNICA
Omondo
Re: Importing Superstructure.uml to Rational Software Architect [message #477931 is a reply to message #477928] Wed, 05 November 2008 11:07 Go to previous messageGo to next message
Hi Marco,
The .emx files were recently removed for UML2 3.0.0 since they were out of
date and one needed RSA (non-opensource) to modify them.
There are efforts at the OMG to possibly provide an education licsense for
RSA. The models should be updated soon and an appropriate home will be
found for them.
- James.
"Marco Mosconi" <mosconi@cs.tu-berlin.de> wrote in message
news:gerurk$jig$1@build.eclipse.org...
> Hector,
> UML2 CVS:
> Marco
>> Hi,
>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477933 is a reply to message #477931] Wed, 05 November 2008 16:00 Go to previous messageGo to next message
Longer term, we will be producing diagrams for the source models using
tooling available at Eclipse, i.e. UML2 Tools and/or Papyrus.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:gesg96$c4e$1@build.eclipse.org...
> Hi Marco,
> found for them.
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477937 is a reply to message #477931] Thu, 06 November 2008 05:49 Go to previous messageGo to next message
Hi James,
That's bad news ... I can't imagine how to analyse/navigate the UML
metamodel without RSA ;-)
> found for them.
That would be great. Please notify when it is available again.
Marco
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477938 is a reply to message #477933] Thu, 06 November 2008 05:57 Go to previous messageGo to next message
.... or MST, I guess (hope) ;-)
Personally I think it's still a long way for the open source modeling
tools to get mature enough for serious use. At least when it comes to
tooling details. But it's the right path to follow and perhaps Papyrus
is a good starting point.
Marco
> Kenn
>> Hi Marco,
>> found for them.
>> Cheers,
>> - James.
>>> Hector,
>>> UML2 CVS:
>>> Marco
>>>> Hi,
>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477942 is a reply to message #477938] Thu, 06 November 2008 11:41 Go to previous message
Marco,
All that's required is a developer community willing/able to make it happen.
For example, Ed was able to replace the antiquated Rose models for EMF
metamodels with diagrams created using Ecore Tools in less than a year after
that component was created...
Kenn
news:geuij6$a68$1@build.eclipse.org...
> tooling details. But it's the right path to follow and perhaps Papyrus is
> Marco
>> Kenn
>>> Hi Marco,
>>> of date and one needed RSA (non-opensource) to modify them.
>>> for RSA. The models should be updated soon and an appropriate home will
>>> be found for them.
>>> Cheers,
>>> - James.
>>>> Hector,
>>>> Eclipse UML2 CVS:
>>>> Marco
>>>>> Hi,
>>>>> (packages, relationships, classes, etc.) does anyone know if there is
>>>>> a way I can actually see the class diagram. The UML I'm using is the
>>>>> version 2.2.1. Thanks for your help.
>>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627137 is a reply to message #477925] Wed, 05 November 2008 06:08 Go to previous message
Hector,
UML2 CVS:
Marco
> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627139 is a reply to message #477928] Wed, 05 November 2008 08:15 Go to previous message
Hector,
your UML model ?
same time.
Vlad VARNICA
Omondo
Re: Importing Superstructure.uml to Rational Software Architect [message #627140 is a reply to message #477928] Wed, 05 November 2008 11:07 Go to previous message
Hi Marco,
found for them.
- James.
> Hector,
> UML2 CVS:
> Marco
>> Hi,
>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627142 is a reply to message #477931] Wed, 05 November 2008 16:00 Go to previous message
Kenn
> Hi Marco,
> found for them.
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627146 is a reply to message #477931] Thu, 06 November 2008 05:49 Go to previous message
Hi James,
> found for them.
Marco
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627147 is a reply to message #477933] Thu, 06 November 2008 05:57 Go to previous message
Marco
> Kenn
>> Hi Marco,
>> found for them.
>> Cheers,
>> - James.
>>> Hector,
>>> UML2 CVS:
>>> Marco
>>>> Hi,
>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627151 is a reply to message #477938] Thu, 06 November 2008 11:41 Go to previous message
Marco,
Kenn
> Marco
>> Kenn
>>> Hi Marco,
>>> be found for them.
>>> Cheers,
>>> - James.
>>>> Hector,
>>>> Eclipse UML2 CVS:
>>>> Marco
>>>>> Hi,
>>>>> Hector
Previous Topic:Confusion about Generalization and Extensions of Stereotypes
Next Topic:[Announce] MDT UML2 2.2.2 M200811061144 is available
Current Time: Sun Jul 20 12:42:49 EDT 2025
Powered by FUDForum. Page generated in 0.07448 seconds
