Home » Modeling » UML2 » Confusion about Generalization and Extensions of Stereotypes
Confusion about Generalization and Extensions of Stereotypes [message #477939] Thu, 06 November 2008 08:32 Go to next message
I have a profile with a couple of stereotypes. I would like to apply a
given stereotype to classes as well as associations. To create my
profile I followed the steps in the tutorial that comes with Eclipse and
that got me to the point where I can apply the stereotype to classes.
Then I repeated the steps of creating an extension for uml:Association
and was expecting that I then would be able to apply the stereotype to
associations. That however doesn't work.
Now here's my question:
In the tutorial most stereotypes have "EStructuralFeature" as
Generalization, and then an "Extension" to the actual UML Metaclass the
stereotype should be applied to. What I'm not clear about is whether or
not the Generalizations have anything to do with the applicability of
stereotypes to model elements.
Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #477940 is a reply to message #477939] Thu, 06 November 2008 11:31 Go to previous messageGo to next message
Hi Jochen,
You should be able to apply a stereotype to any UML element including
Generalization or Association.
When you say ".. that doesn't work" what exactly doesn't work. Are you
seeing errors?
Posting a snippet of your profile and/or model would be helpful.
- James.
"Jochen" <jochen.wuttke@gmx.de> wrote in message
news:geurlv$856$1@build.eclipse.org...
> given stereotype to classes as well as associations. To create my profile
> I followed the steps in the tutorial that comes with Eclipse and that got
> me to the point where I can apply the stereotype to classes. Then I
> repeated the steps of creating an extension for uml:Association and was
> Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #477941 is a reply to message #477939] Thu, 06 November 2008 11:37 Go to previous messageGo to next message
Jochen,
Generalizations between stereotypes aren't necessary, but may be useful if
you find that several steretypes shared the same tags. Generally speaking,
it's better to create the extensions on concrete stereotypes, e.g. on the
leaf stereotypes in a hierarchy.
After you created your new extension to Association, did you redefine your
profile? In order for it to work, you'll need to redefine the profile, which
effectively updates the Ecore metadata so that it knows that the stereotype
can now be applied to associations. Of course, if you already have the
profile applied to a package, you'll need to reapply the profile to pick up
the latest version...
Kenn
> Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #477945 is a reply to message #477941] Fri, 07 November 2008 04:59 Go to previous messageGo to next message
Kenn Hussey wrote:
> Jochen,
That was the problem, I didn't redefine the profile. This leads me to a
question about the general workflow while developing a profile.
I'm working on this project with a colleague and we are extending the
profile in different parts. When he adds something new to the profile,
he simply re-defines the profile without deleting the previous
"definition". That leads to multiple "definitions" showing up in the
editor and in the file. However, this has the advantage that the models
using older versions of the profile will continue working and you can
still use the new elements.
Instead, I always delete all old definitions and the define the profile.
However, that way the models don't work anymore, because all the
identifiers are different.
I would say my way of doing things is more tidy, but creates a lot of
overhead, because we have to update the model every time. So what is the
suggested or intended workflow? Or is there no such thing, because
profiles are usually developed once and then only used?
Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #477947 is a reply to message #477945] Fri, 07 November 2008 11:20 Go to previous message
Jochen,
The older definitions are kept intentionally to support migration of models
that may be using previous versions of the profile. Whether your application
needs to support this is up to you. I know some consumers of UML2 have
introduced additional metadata/signifiance to specific definitions (e.g. by
calling them "releases") and provided a "purge" utility to help users
compact profiles that have grown over the development cycle...
Kenn
news:gf13ib$j49$1@build.eclipse.org...
> Kenn Hussey wrote:
>> Jochen,
>> if you find that several steretypes shared the same tags. Generally
>> speaking, it's better to create the extensions on concrete stereotypes,
>> e.g. on the leaf stereotypes in a hierarchy.
>> your profile? In order for it to work, you'll need to redefine the
>> profile, which effectively updates the Ecore metadata so that it knows
>> that the stereotype can now be applied to associations. Of course, if you
>> already have the profile applied to a package, you'll need to reapply the
>> profile to pick up the latest version...
> profile in different parts. When he adds something new to the profile, he
> simply re-defines the profile without deleting the previous "definition".
> That leads to multiple "definitions" showing up in the editor and in the
> file. However, this has the advantage that the models using older versions
> of the profile will continue working and you can still use the new
> elements.
> Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #627149 is a reply to message #477939] Thu, 06 November 2008 11:31 Go to previous message
Hi Jochen,
seeing errors?
- James.
> Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #627150 is a reply to message #477939] Thu, 06 November 2008 11:37 Go to previous message
Jochen,
Kenn
> Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #627154 is a reply to message #477941] Fri, 07 November 2008 04:59 Go to previous message
Kenn Hussey wrote:
> Jochen,
Jochen
Re: Confusion about Generalization and Extensions of Stereotypes [message #627159 is a reply to message #477945] Fri, 07 November 2008 11:20 Go to previous message
Jochen,
Kenn
> Kenn Hussey wrote:
>> Jochen,
> elements.
> Jochen
Previous Topic:Signal-Reception and Method-Attribute
Next Topic:Dynamic Modeling Tutorial with EclipseUML 2008
Current Time: Sat Jul 19 14:45:22 EDT 2025
Powered by FUDForum. Page generated in 0.05928 seconds
