Home » Modeling » UML2 » Special Characters (< and &) in names breaks parser
Special Characters (< and &) in names breaks parser [message #477635] Sat, 26 July 2008 01:42 Go to next message
I am reading a UML2 XMI model that contains < and &
in the names of UML model elements (it is a C++ model
and it contains, for example, an operator< method).
When trying to read this via the Eclipse UML tooling,
the parser dies and says something about illegal char-
acters. The same is true for the & in names (like in
C++ reference attributes).
Any idea what I can do?
Markus
Markus Völter
voelter - ingenieurbüro für softwaretechnologie
Grabenstrasse 4, 73033 Goeppingen, Germany
Tel. +49 (0) 171 / 86 01 869
Email: voelter@acm.org
Web: http://www.voelter.de
Blog: http://www.voelter.de/blog
Podcast: http://www.se-radio.net
PGP Public Key: http://www.voelter.de/data/MarkusVoelter.gpg
Re: Special Characters (< and &) in names breaks parser [message #477636 is a reply to message #477635] Sat, 26 July 2008 04:35 Go to previous message
--------------060404010404070406050100
I was just going to say that probably those characters were not properly
encoded as they should given that they are XML predefined entities, but
then I just tried to open both a .xmi file and a .uml having "<", "&"
and ">" in operation names and they opened just fine (see attachment),
regardless those characters where encoded as entities or not, I guess
because they appear in attributes, not as nodes.
Can you provide an example of a model that you can't load?
Rafael
Markus Voelter wrote:
> Markus
Content-Type: text/xml;
name="test.uml"
Content-Disposition: inline;
filename="test.uml"
<uml:Package xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_tTL0IFrsEd2FZqWlQqCSgg" name="test">
<eAnnotations xmi:id="_tTL0IVrsEd2FZqWlQqCSgg" source="com.abstratt/mdd/"/>
<packagedElement xmi:type="uml:Class" xmi:id="_tTL0IlrsEd2FZqWlQqCSgg" name="A">
<ownedOperation xmi:id="_tTL0I1rsEd2FZqWlQqCSgg" name=">" visibility="public"/>
</packagedElement>
</uml:Package>
name="test.xmi"
filename="test.xmi"
<uml:Package xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://schema.omg.org/spec/UML/2.1.1" xsi:schemaLocation="http://schema.omg.org/spec/UML/2.1.1 http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_CN-BcFrsEd2FZqWlQqCSgg" name="test">
<xmi:Extension extender="http://www.eclipse.org/emf/2002/Ecore">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_CN-BcVrsEd2FZqWlQqCSgg" source="com.abstratt/mdd/"/>
</xmi:Extension>
<packagedElement xmi:type="uml:Class" xmi:id="_CN-BclrsEd2FZqWlQqCSgg" name="A">
<ownedOperation xmi:type="uml:Operation" xmi:id="_CN-Bc1rsEd2FZqWlQqCSgg" name=">&amp;&lt;&quot;" visibility="public" class="_CN-BclrsEd2FZqWlQqCSgg"/>
</packagedElement>
</uml:Package>
--------------060404010404070406050100--
Re: Special Characters (< and &) in names breaks parser [message #626827 is a reply to message #477635] Sat, 26 July 2008 04:35 Go to previous message
Rafael
> Markus
name="test.uml"
filename="test.uml"
</packagedElement>
</uml:Package>
name="test.xmi"
filename="test.xmi"
</xmi:Extension>
</packagedElement>
</uml:Package>
Previous Topic:Special Characters (< and &) in names breaks parser
Next Topic:Instrumenting field class on Operation?
Current Time: Sat Jul 19 11:44:02 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
