Home » Modeling » UML2 » Continuing saga of the standalone app
Continuing saga of the standalone app [message #477617] |
Thu, 17 July 2008 16:14  |
Originally posted by: jlansing.spawar.navy.mil
It is possible to find on this list a working code snippet showing how to
get an org.eclipse.uml2.uml.Package from a .uml file, in a standalone app.
My problem occurs when that Package has an imported package that has a
"pathmap" URL.
I think what I should do is map the pathmap URL to the actual URL, like
this:
Map<URI, URI> uriMap = RESOURCE_SET.getURIConverter().getURIMap();
URI pathmap =
URI.createURI("pathmap://XMLmodeling_LIBRARIES/XSDDataTypes.library.uml");
URI types = URI.createFileURI(new File(typesFilename).getAbsolutePath());
uriMap.put(pathmap, types);
But when I try to get the imported stuff, like this:
EList<Package> importList = model.getImportedPackages();
I get an exception:
java.lang.ClassCastException:
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl cannot be cast to
at
org.eclipse.uml2.uml.internal.impl.PackageImportImpl.getImpo rtedPackage(PackageImportImpl.java:204)
at
org.eclipse.uml2.uml.internal.operations.NamespaceOperations .getImportedPackages(NamespaceOperations.java:207)
at
org.eclipse.uml2.uml.internal.impl.NamespaceImpl.getImported Packages(NamespaceImpl.java:552)
(Similarly if I try to use EcoreUtil.resolveAll(resource); ). It looks like
it doesn't know that the imported package is UML.
Any help on this? Thanks.
Re: Continuing saga of the standalone app [message #477621 is a reply to message #477618] |
Fri, 18 July 2008 20:17   |
Originally posted by: jeff.lansing.sbcglobal.net
Thanks, James. That stopped the exception. But somehow I thought that the
external package would magically be imported, and all of the references into
it would be resolved.
Which is not what is happening.
Here is the relevant code, and attached are the problematic models.
private Model getModel(String filename, String typesFilename) {
RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
URI pathmap =
URI.createURI("pathmap://XMLmodeling_LIBRARIES/XSDDataTypes.library.uml/");
URI uri = URI.createFileURI(new File(filename).getAbsolutePath());
Model model = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true);
model = (Model) EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.MODEL);
} catch (WrappedException we) {
System.err.println(we.getMessage());
return model;
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:g5q81a$42a$1@build.eclipse.org...
> Hi Jeff,
> It looks like you might be missing a trailing slash at the end of your
> pathmap string. This is mentioned in the FAQ
> http://wiki.eclipse.org/MDT-UML2-FAQ.
> If that still doesn't work I can provide a code snippet that should load
> your model (post a small section of the problematic model so I can test it
> out the code ).
> Cheers,
> - James.
> "Jeff Lansing" <jlansing@spawar.navy.mil> wrote in message
> news:g5o96q$ph2$1@build.eclipse.org...
>> app.
>> "pathmap" URL.
>> this:
>> URI pathmap =
>> I get an exception:
>> at
>> at
>> at
>> like it doesn't know that the imported package is UML.
Re: Continuing saga of the standalone app [message #477622 is a reply to message #477621] |
Mon, 21 July 2008 16:06   |
Hi Jeff,
The following code snippet will properly resolve the data type from the
library.
There was one little 'gotcha' that had me wondering what was going on.
Your XSDDataTypes.library.uml was not upgraded to the latest version. You
have at the top of the file ...
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"> which should be
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML">
1. Change the nsURI in your library by either re-saving it out or edit with
a text editor.
2. Try the following code (pardon the hard-coded stuff):
3. You should notice the type of "breed" is not a proxy.
Cheers,...
- James.
protected static void registerPathmaps(URI umlResourcePluginURI) {
URIConverter.URI_MAP.put(URI.createURI(UMLResource.LIBRARIES _PATHMAP),
umlResourcePluginURI.appendSegment("libraries").appendSegment( ""));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.METAMODEL S_PATHMAP),
umlResourcePluginURI.appendSegment("metamodels").appendSegment( ""));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.PROFILES_ PATHMAP),
umlResourcePluginURI.appendSegment("profiles").appendSegment( ""));
URIConverter.URI_MAP.put(URI.createURI("pathmap://XMLmodeling_LIBRARIES/"),
URI.createFileURI("C:/UMLDevelopment/NewsGroupIssue").appendSegment( "libraries").appendSegment(""));
protected static void registerExtensions() {
Map<String, Object> extensionFactoryMap = Resource.Factory.Registry.INSTANCE
..getExtensionToFactoryMap();
extensionFactoryMap.put(UMLResource.FILE_EXTENSION,
extensionFactoryMap.put(Ecore2XMLResource.FILE_EXTENSION,
Ecore2XMLResource.Factory.INSTANCE);
extensionFactoryMap.put(UML22UMLResource.FILE_EXTENSION,
UML22UMLResource.Factory.INSTANCE);
protected static void registerPackages(ResourceSet resourceSet) {
Registry packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
packageRegistry.put(Ecore2XMLPackage.eNS_URI,
Ecore2XMLPackage.eINSTANCE);
packageRegistry.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
public static Model getModel(URI resourceURI, URI umlPluginURI, URI
ResourceSet resourceSet = new ResourceSetImpl();
registerPathmaps(umlResourcePluginURI);
registerPackages(resourceSet);
registerExtensions();
// Map references to legacy (1.x) model elements to their new locations.
Map<URI,URI> uriMap = UML22UMLExtendedMetaData.getURIMap();
resourceSet.getURIConverter().getURIMap().putAll(uriMap);
// Load a resource in the resource set.
try {
resourceSet.getResource(resourceURI, true);
} catch (Exception e) {
System.out.println(e.getMessage());
return null;
EList<Resource> resources = resourceSet.getResources();
EcoreUtil.resolveAll(resources.get(0));
Model model = (Model) EcoreUtil.getObjectByType(resources.get(0)
..getContents(), UMLPackage.Literals.MODEL);
// Sanity check.
org.eclipse.uml2.uml.Package packageableElement =
(org.eclipse.uml2.uml.Package) model
..getPackagedElement("pets");
org.eclipse.uml2.uml.Class animal = (org.eclipse.uml2.uml.Class)
packageableElement
..getOwnedMember("Animal");
org.eclipse.uml2.uml.Property breed = animal
..getAttribute("breed", null);
System.out.println("BreedType: " + breed.getType());
return model;
String fileToOpen = "C:/UMLDevelopment/NewsGroupIssue/pets.uml";
String umlPluginPath =
" C:/UMLDevelopment/Download_Zips/Eclipse_Downloads/Eclipse3.4
final/eclipse-SDK-3.4-win32/eclipse/plugins/org.eclipse.uml2 .uml_2.2.0.v200805141133.jar ";
String umlResourcePath =
final/eclipse-SDK-3.4-win32/eclipse/plugins/org.eclipse.uml2 .uml.resources_2.2.0.v200805131030.jar ";
URI umlPluginURI = URI.createURI("jar:file:/" + umlPluginPath + "!/");
URI umlResourcePluginURI = URI.createURI("jar:file:/" + umlResourcePath
getModel(URI.createFileURI(fileToOpen), umlPluginURI, umlResourcePluginURI);
"Jeff Lansing" <jeff.lansing@sbcglobal.net> wrote in message
news:g5rbqt$kmk$1@build.eclipse.org...
> into it would be resolved.
> URI pathmap =
> Model model = null;
> try {
> return model;
>> Hi Jeff,
>> it
>> out the code ).
>> Cheers,
>> - James.
>>> to
>>> app.
>>> "pathmap" URL.
>>> this:
>>> URI pathmap =
>>> I get an exception:
>>> at
>>> at
>>> at
Re: Continuing saga of the standalone app [message #477623 is a reply to message #477622] |
Tue, 22 July 2008 09:09   |
Thanks, James. Incredibly helpful.
Since it's a standalone app, I added:
URI umlResourcePluginURI = getJarURI("uml2.uml.resources");
protected static URI getJarURI(String key) {
for(String jarLoc : System.getProperty("java.class.path").split(";")) {
if(jarLoc.contains(key)) {
return URI.createURI("jar:file:/" + jarLoc.replace('\\', '/') + "!/");
return null;
news:g62q94$8in$1@build.eclipse.org...
> Hi Jeff,
> library.
> with a text editor.
> Cheers,...
> - James.
> try {
> return null;
> // Sanity check.
> packageableElement
> return model;
> public static void main(String[] args) {
>> URI pathmap =
>> Model model = null;
>> try {
>> return model;
>>> Hi Jeff,
>>> it
>>> out the code ).
>>> Cheers,
>>> - James.
>>>> to
>>>> app.
>>>> "pathmap" URL.
>>>> this:
>>>> URI pathmap =
>>>> I get an exception:
>>>> at
>>>> at
>>>> at
Re: Continuing saga of the standalone app [message #477624 is a reply to message #477622] |
Tue, 22 July 2008 09:35   |
I should mention (for others reading this thread) that the recommendation to
"edit the nsURI with a text editor" would not be a general solution. It
would work for this very specific example but not in general (in this case
there was one DataType in the library). The migration guides on the wiki
explain in more detail how to properly migrate to newer versions.
- James.
> Hi Jeff,
> library.
> with a text editor.
> Cheers,...
> - James.
> try {
> return null;
> // Sanity check.
> packageableElement
> return model;
>> URI pathmap =
>> Model model = null;
>> try {
>> return model;
>>> Hi Jeff,
>>> it
>>> out the code ).
>>> Cheers,
>>> - James.
>>>> to
>>>> app.
>>>> "pathmap" URL.
>>>> this:
>>>> URI pathmap =
>>>> I get an exception:
>>>> at
>>>> at
>>>> at
Re: Continuing saga of the standalone app [message #477625 is a reply to message #477624] |
Tue, 22 July 2008 12:29   |
James,
This doesn't quite do what I hoped. Stuff in the external model that is
referenced "indirectly" doesn't get imported.
Attached is a refinement of the importing model that uses a generalization
that references the external model.
The new sanity check is the following, which gets null for the supertype:
// Sanity check.
(org.eclipse.uml2.uml.Package) model.getPackagedElement("pets");
packageableElement.getOwnedMember("Animal");
org.eclipse.uml2.uml.Property breed = animal.getAttribute("breed", null);
org.eclipse.uml2.uml.DataType breedType = (org.eclipse.uml2.uml.DataType)
breed.getType();
System.out.println("BreedType: " + breedType);
org.eclipse.uml2.uml.Generalization gen = ((org.eclipse.uml2.uml.DataType)
breedType).getGeneralizations().get(0);
org.eclipse.uml2.uml.Classifier general = gen.getGeneral();
System.out.println("BreedSuperType: " + general.getName());
news:g64nml$1ha$1@build.eclipse.org...
>to
> Cheers,
> - James.
>> Hi Jeff,
>> library.
>> You
>> with a text editor.
>> Cheers,...
>> - James.
>> try {
>> return null;
>> // Sanity check.
>> packageableElement
>> return model;
>>> the
>>> URI pathmap =
>>> Model model = null;
>>> try {
>>> return model;
>>>> Hi Jeff,
>>>> load
>>>> it
>>>> out the code ).
>>>> Cheers,
>>>> - James.
>>>>> to
>>>>> app.
>>>>> "pathmap" URL.
>>>>> like
>>>>> this:
>>>>> URI pathmap =
>>>>> I get an exception:
>>>>> at
>>>>> at
>>>>> at
Attachment: petsplus.uml
(Size: 6.36KB, Downloaded 305 times)
Re: Continuing saga of the standalone app [message #477626 is a reply to message #477625] |
Tue, 22 July 2008 14:06   |
Hi Jeff,
That seems to work fine for me. I'm seeing BreedType: Breed and
BreedSuperType: string.
What are the problems you are seeing?
Are you certain you are loading the new petsplus.uml and not the older
pets.uml. You would see an exception in that case since there would be no
generalizations of the DataType from the library.
I could zip up my small test class to send you if you want.
- James.
news:g651sr$mg2$1@build.eclipse.org...
> James,
> // Sanity check.
> breed.getType();
>>to
>> case
>> wiki
>> Cheers,
>> - James.
>>> Hi Jeff,
>>> library.
>>> You
>>> with a text editor.
>>> Cheers,...
>>> - James.
>>> try {
>>> return null;
>>> // Sanity check.
>>> packageableElement
>>> return model;
>>>> the
>>>> URI pathmap =
>>>> Model model = null;
>>>> try {
>>>> return model;
>>>>> Hi Jeff,
>>>>> load
>>>>> test
>>>>> it
>>>>> out the code ).
>>>>> Cheers,
>>>>> - James.
>>>>>> how
>>>>>> to
>>>>>> app.
>>>>>> a
>>>>>> "pathmap" URL.
>>>>>> like
>>>>>> this:
>>>>>> URI pathmap =
>>>>>> I get an exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> looks
Re: Continuing saga of the standalone app [message #477627 is a reply to message #477626] |
Tue, 22 July 2008 16:18   |
.... the complete project attached ...
news:g657k1$7c1$1@build.eclipse.org...
> Hi Jeff,
> Cheers,
> - James.
>> James,
>> generalization
>> // Sanity check.
>> breed.getType();
>>>to
>>> It
>>> case
>>> wiki
>>> Cheers,
>>> - James.
>>>> Hi Jeff,
>>>> library.
>>>> You
>>>> with a text editor.
>>>> Cheers,...
>>>> - James.
>>>> locations.
>>>> try {
>>>> return null;
>>>> // Sanity check.
>>>> packageableElement
>>>> return model;
>>>>> the
>>>>> references
>>>>> URI pathmap =
>>>>> Model model = null;
>>>>> try {
>>>>> return model;
>>>>>> Hi Jeff,
>>>>>> your
>>>>>> load
>>>>>> test
>>>>>> it
>>>>>> out the code ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>>> how
>>>>>>> to
>>>>>>> standalone
>>>>>>> app.
>>>>>>> a
>>>>>>> "pathmap" URL.
>>>>>>> like
>>>>>>> this:
>>>>>>> URI pathmap =
>>>>>>> I get an exception:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> looks
Re: Continuing saga of the standalone app [message #477628 is a reply to message #477626] |
Tue, 22 July 2008 16:41   |
James,
My misunderstanding.
I see now that the pathmap to the external library points, not to the
library itself, but to a directory called "libraries" that contains the
actual library file.
Once again, thanks for this great help.
Jeff
> Hi Jeff,
> Cheers,
> - James.
>> James,
>> generalization that references the external model.
>> // Sanity check.
>> breed.getType();
>> ((org.eclipse.uml2.uml.DataType) breedType).getGeneralizations().get(0);
>>>to
>>> It
>>> case
>>> wiki
>>> Cheers,
>>> - James.
>>>> Hi Jeff,
>>>> library.
>>>> You
>>>> with a text editor.
>>>> Cheers,...
>>>> - James.
>>>> locations.
>>>> try {
>>>> return null;
>>>> // Sanity check.
>>>> packageableElement
>>>> return model;
>>>>> the
>>>>> references
>>>>> URI pathmap =
>>>>> Model model = null;
>>>>> try {
>>>>> return model;
>>>>>> Hi Jeff,
>>>>>> your
>>>>>> load
>>>>>> test
>>>>>> it
>>>>>> out the code ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>>> how
>>>>>>> to
>>>>>>> standalone
>>>>>>> app.
>>>>>>> a
>>>>>>> "pathmap" URL.
>>>>>>> like
>>>>>>> this:
>>>>>>> URI pathmap =
>>>>>>> I get an exception:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> looks
Re: Continuing saga of the standalone app [message #477737 is a reply to message #477715] |
Fri, 19 September 2008 02:30   |
Hi Friends,
thanks for yours answers! but... my problem continue...
i tried to execute the Jeff's answer but without success!
and as James request...
My full application can be found in this link:
the profile in this:
http://www.info.ufrn.br/~victorhugo//uml2/TesteLoadModels/mo dels/Profile_for_crossmda_profile-1.11.profile
the data model (bussiness):
http://www.info.ufrn.br/~victorhugo//uml2/TesteLoadModels/mo dels/model_teste.uml
ths aspects model:
http://www.info.ufrn.br/~victorhugo//uml2/TesteLoadModels/mo dels/model_aspects.uml
my java class thats load the model in this:
http://www.info.ufrn.br/~victorhugo//uml2/TesteLoadModels/sr c/test/Test.java
sorry about permission of directory to navigate into then, but i cannot
control this in server.
my problem is because i cannot load stereotypes that models has, i have to
apply profile before load model, how i can do this?
to simplify to yours here is the java code that i'm using to load models:
package test;
import java.io.IOException;
import java.util.Iterator;
import java.util.Map;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.EPackage.Registry;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.mapping.ecore2xml.Ecore2XMLPackage;
import org.eclipse.emf.mapping.ecore2xml.util.Ecore2XMLResource;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.NamedElement;
import org.eclipse.uml2.uml.Profile;
import org.eclipse.uml2.uml.Stereotype;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UML22UMLExtendedMetaData;
import org.eclipse.uml2.uml.resource.UML22UMLResource;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.resource.UML22UMLResource.Factory;
public class Test {
private ResourceSet resourceSet = null;
private Resource model = null;
private UMLResource uml2Resource = null;
private Profile profile = null;
@SuppressWarnings("unchecked")
protected void registerPathmaps(URI umlResourcePluginURI) {
String pathResource =
" /home/ceara/dev/mestrado/workspace/TesteLoadModels/lib/org.e clipse.uml2.uml.resources_2.2.0.v200805131030.jar ";
URI resourcePluginURI = URI.createURI("jar:file:/" + pathResource +
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
Map uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
resourcePluginURI.appendSegment("libraries").appendSegment( ""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
resourcePluginURI.appendSegment("metamodels").appendSegment( ""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
resourcePluginURI.appendSegment("profiles").appendSegment( ""));
protected void registerExtensions() {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( );
extensionFactoryMap.put(UMLResource.FILE_EXTENSION,UMLResour ce.Factory.INSTANCE);
extensionFactoryMap.put(Ecore2XMLResource.FILE_EXTENSION,Eco re2XMLResource.Factory.INSTANCE);
extensionFactoryMap.put(UML22UMLResource.FILE_EXTENSION,UML2 2UMLResource.Factory.INSTANCE);
protected void registerPackages(ResourceSet resourceSet) {
packageRegistry.put(Ecore2XMLPackage.eNS_URI,Ecore2XMLPackag e.eINSTANCE);
public Model getModel(URI resourceURI) {
registerPathmaps(null);
Map<URI, URI> uriMap = UML22UMLExtendedMetaData.getURIMap();
try {
model = resourceSet.getResource(resourceURI, true);
model.save(null);
EcoreUtil.resolveAll(model);
} catch (IOException e) {
e.printStackTrace();
if ( !(model instanceof UMLResource)) {
try {
throw new Exception("Modelo carregado esta inv�lido!");
System.out.println( "OoOps..!" );
this.uml2Resource = (UMLResource) model;
return null;
String fileToOpen =
" /home/ceara/dev/mestrado/workspace/TesteLoadModels/models/mo del_teste.uml ";
Test t = new Test();
t.getModel(URI.createFileURI(fileToOpen));
public void displayAllElements() {
//Model o =
(Model)xmiutils.getUML2Resource().getContents().iterator().n ext();
Model o = (Model)uml2Resource.getContents().iterator().next();
EList<NamedElement> mbs = o.getMembers();
for( NamedElement mb : mbs ){
System.out.println( " NAMEDMEMBERS: " + mb.getClass() + mb.getName() );
EList<Profile> profiles = o.getAllAppliedProfiles();
for( Profile p : profiles ){
System.out.println( " \n\n\n PROFILE: " + p.getName() );
EList<Stereotype> stes = p.getAppliedStereotypes();
for(Stereotype ste : stes ){
System.out.println( "\n\n PROFILE STEREOTYPES: " + ste.getName() );
for(NamedElement ne : o.getOwnedMembers()){
System.out.println( ne.getClass() + " - " + ne.getName() );
if( ne instanceof org.eclipse.uml2.uml.Package ){
System.out.println("\n\nINSTANCE OF PACKAGE:");
EList<Stereotype> ste = ne.getAppliedStereotypes();
for( Stereotype s : ste ){
System.out.println("\n\n\nINSTANCE OF STEREOTYPES: " + s.getName());
private Profile reloadProfile() {
Resource inputResource = resourceSet.createResource(URI
.createFileURI("MyProfile.profile.uml"));
try {
inputResource.load(null);
} catch (IOException exception) {
exception.printStackTrace();
Iterator iterator = inputResource.getAllContents();
while (iterator.hasNext()) {
Object currentObject = iterator.next();
if (currentObject instanceof Profile) {
return (Profile) currentObject;
return null;
best regards!
Re: Continuing saga of the standalone app [message #477744 is a reply to message #477737] |
Tue, 23 September 2008 15:25  |
Victor,
The link to the profile does not work.
"Victor Hugo" <victorhcf@gmail.com> wrote in message
news:9eac12420be6134540295db21a1db739$1@www.eclipse.org...
> Hi Friends,
> ths aspects model:
> package test;
> public class Test {
> URI resourcePluginURI = URI.createURI("jar:file:/" + pathResource + "!/");
> try {
> model.save(null);
> try {
> return null;
> String fileToOpen =
> //Model o =
> try {
> return null;
> best regards!
Re: Continuing saga of the standalone app [message #626809 is a reply to message #477617] |
Fri, 18 July 2008 10:06  |
Hi Jeff,
out the code ).
- James.
> "pathmap" URL.
> this:
> URI pathmap =
> I get an exception:
> at
> at
> at
Re: Continuing saga of the standalone app [message #626812 is a reply to message #477618] |
URI pathmap =
Model model = null;
try {
return model;
> Hi Jeff,
> out the code ).
> Cheers,
> - James.
>> app.
>> "pathmap" URL.
>> this:
>> URI pathmap =
>> I get an exception:
>> at
>> at
>> at
Re: Continuing saga of the standalone app [message #626813 is a reply to message #477621] |
Hi Jeff,
library.
a text editor.
Cheers,...
- James.
try {
return null;
// Sanity check.
packageableElement
return model;
> URI pathmap =
> Model model = null;
> try {
> return model;
>> Hi Jeff,
>> it
>> out the code ).
>> Cheers,
>> - James.
>>> to
>>> app.
>>> "pathmap" URL.
>>> this:
>>> URI pathmap =
>>> I get an exception:
>>> at
>>> at
>>> at
Re: Continuing saga of the standalone app [message #626814 is a reply to message #477622] |
return null;
> Hi Jeff,
> library.
> with a text editor.
> Cheers,...
> - James.
> try {
> return null;
> // Sanity check.
> packageableElement
> return model;
>> URI pathmap =
>> Model model = null;
>> try {
>> return model;
>>> Hi Jeff,
>>> it
>>> out the code ).
>>> Cheers,
>>> - James.
>>>> to
>>>> app.
>>>> "pathmap" URL.
>>>> this:
>>>> URI pathmap =
>>>> I get an exception:
>>>> at
>>>> at
>>>> at
Re: Continuing saga of the standalone app [message #626815 is a reply to message #477622] |
- James.
> Hi Jeff,
> library.
> with a text editor.
> Cheers,...
> - James.
> try {
> return null;
> // Sanity check.
> packageableElement
> return model;
>> URI pathmap =
>> Model model = null;
>> try {
>> return model;
>>> Hi Jeff,
>>> it
>>> out the code ).
>>> Cheers,
>>> - James.
>>>> to
>>>> app.
>>>> "pathmap" URL.
>>>> this:
>>>> URI pathmap =
>>>> I get an exception:
>>>> at
>>>> at
>>>> at
Re: Continuing saga of the standalone app [message #626816 is a reply to message #477624] |
James,
// Sanity check.
breed.getType();
>to
> Cheers,
> - James.
>> Hi Jeff,
>> library.
>> You
>> with a text editor.
>> Cheers,...
>> - James.
>> try {
>> return null;
>> // Sanity check.
>> packageableElement
>> return model;
>>> the
>>> URI pathmap =
>>> Model model = null;
>>> try {
>>> return model;
>>>> Hi Jeff,
>>>> load
>>>> it
>>>> out the code ).
>>>> Cheers,
>>>> - James.
>>>>> to
>>>>> app.
>>>>> "pathmap" URL.
>>>>> like
>>>>> this:
>>>>> URI pathmap =
>>>>> I get an exception:
>>>>> at
>>>>> at
>>>>> at
(Size: 6.36KB, Downloaded 284 times)
Re: Continuing saga of the standalone app [message #626817 is a reply to message #477625] |
Hi Jeff,
- James.
> James,
> // Sanity check.
> breed.getType();
>>to
>> case
>> wiki
>> Cheers,
>> - James.
>>> Hi Jeff,
>>> library.
>>> You
>>> with a text editor.
>>> Cheers,...
>>> - James.
>>> try {
>>> return null;
>>> // Sanity check.
>>> packageableElement
>>> return model;
>>>> the
>>>> URI pathmap =
>>>> Model model = null;
>>>> try {
>>>> return model;
>>>>> Hi Jeff,
>>>>> load
>>>>> test
>>>>> it
>>>>> out the code ).
>>>>> Cheers,
>>>>> - James.
>>>>>> how
>>>>>> to
>>>>>> app.
>>>>>> a
>>>>>> "pathmap" URL.
>>>>>> like
>>>>>> this:
>>>>>> URI pathmap =
>>>>>> I get an exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> looks
Re: Continuing saga of the standalone app [message #626818 is a reply to message #477626] |
> Hi Jeff,
> Cheers,
> - James.
>> James,
>> generalization
>> // Sanity check.
>> breed.getType();
>>>to
>>> It
>>> case
>>> wiki
>>> Cheers,
>>> - James.
>>>> Hi Jeff,
>>>> library.
>>>> You
>>>> with a text editor.
>>>> Cheers,...
>>>> - James.
>>>> locations.
>>>> try {
>>>> return null;
>>>> // Sanity check.
>>>> packageableElement
>>>> return model;
>>>>> the
>>>>> references
>>>>> URI pathmap =
>>>>> Model model = null;
>>>>> try {
>>>>> return model;
>>>>>> Hi Jeff,
>>>>>> your
>>>>>> load
>>>>>> test
>>>>>> it
>>>>>> out the code ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>>> how
>>>>>>> to
>>>>>>> standalone
>>>>>>> app.
>>>>>>> a
>>>>>>> "pathmap" URL.
>>>>>>> like
>>>>>>> this:
>>>>>>> URI pathmap =
>>>>>>> I get an exception:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> looks
Re: Continuing saga of the standalone app [message #626819 is a reply to message #477626] |
James,
Jeff
> Hi Jeff,
> Cheers,
> - James.
>> James,
>> // Sanity check.
>> breed.getType();
>>>to
>>> It
>>> case
>>> wiki
>>> Cheers,
>>> - James.
>>>> Hi Jeff,
>>>> library.
>>>> You
>>>> with a text editor.
>>>> Cheers,...
>>>> - James.
>>>> locations.
>>>> try {
>>>> return null;
>>>> // Sanity check.
>>>> packageableElement
>>>> return model;
>>>>> the
>>>>> references
>>>>> URI pathmap =
>>>>> Model model = null;
>>>>> try {
>>>>> return model;
>>>>>> Hi Jeff,
>>>>>> your
>>>>>> load
>>>>>> test
>>>>>> it
>>>>>> out the code ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>>> how
>>>>>>> to
>>>>>>> standalone
>>>>>>> app.
>>>>>>> a
>>>>>>> "pathmap" URL.
>>>>>>> like
>>>>>>> this:
>>>>>>> URI pathmap =
>>>>>>> I get an exception:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> looks
Re: Continuing saga of the standalone app [message #626895 is a reply to message #477618] |
Tue, 02 September 2008 22:06  |
Hi Friends,
i have the same problem and try to solve using yours solutions by I obtain
this exception when i try to load model:
at
org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl.ge tAppliedProfile(ProfileApplicationImpl.java:182)
at
org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl.eG et(ProfileApplicationImpl.java:410)
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.prepareNext(DerivedEObjectEList.java:100)
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.hasNext(DerivedEObjectEList.java:149)
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.scanNext(DerivedEObjectEList.java:66)
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.prepareNext(DerivedEObjectEList.java:109)
at
at
org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.next(DerivedEObjectEList.java:158)
at
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:443)
at
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EContentsEList.java:561)
at
org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences( EcoreUtil.java:307)
at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.ja va:287)
at
br.ufrj.nce.crossmda.xml.util.EMFUML2RepositoryFacade.readMo del(EMFUML2RepositoryFacade.java:143)
at
br.ufrj.nce.crossmda.xml.util.EMFUML2RepositoryFacade.readMo del(EMFUML2RepositoryFacade.java:126)
at
br.ufrj.nce.crossmda.xml.util.EMFUML2RepositoryFacade.readMo del(EMFUML2RepositoryFacade.java:203)
at
br.ufrj.nce.crossmda.xmi.util.emf.EMF_XMIRepositoryImpl.load Model(EMF_XMIRepositoryImpl.java:227)
at br.ufrj.nce.crossmda.test.emf.TesteModelo.main(TesteModelo.j ava:248)
what should i do to resolve profiles?
thanks
Re: Continuing saga of the standalone app [message #626900 is a reply to message #477701] |
Thu, 04 September 2008 13:14  |
Hi Victor,
I don't think there is enough information here to figure out what the
problem is. Can you post your model and profile, or at least sections of
it, such that the exception can be reproduced ?
- James.
news:d05d6b4e49b96e4e3e7e108487524686$1@www.eclipse.org...
> Hi Friends,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thanks
Re: Continuing saga of the standalone app [message #626909 is a reply to message #477701] |
Wed, 10 September 2008 13:27  |
Victor,
This happened to me when I tried to use an older profile.
My solution was to open the profile with the UML Model Editor, select the
<Profile> element, then (in the top menu) click UML Editor | Profile |
Define.
The result is an up-to-date profile that can be loaded as
org.eclipse.uml2.uml.Profile instead of
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl .
It would be nice if this could be done programatically, though.
Jeff
> Hi Friends,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thanks
Re: Continuing saga of the standalone app [message #626936 is a reply to message #477715] |
Hi Friends,
ths aspects model:
package test;
public class Test {
try {
model.save(null);
try {
return null;
String fileToOpen =
//Model o =
try {
return null;
best regards!
Re: Continuing saga of the standalone app [message #626943 is a reply to message #477737] |
Victor,
> Hi Friends,
> ths aspects model:
> package test;
> public class Test {
> try {
> model.save(null);
> try {
> return null;
> String fileToOpen =
> //Model o =
> try {
> return null;
> best regards!
Current Time: Sat Jul 19 18:58:22 EDT 2025
Powered by FUDForum. Page generated in 0.12064 seconds
