Home » Modeling » UML2 » isLeaf in UML Class Diagram
isLeaf in UML Class Diagram [message #477523] |
Mon, 16 June 2008 08:48  |
Hi all,
i was doing some uml class diagramm stuff, just for research on my own. In
the UML superstructure i've found the definition of the attribute isLeaf
from RedefinableElement.
Indicates whether it is possible to further specialize a RedefinableElement.
If the value is true, then it is not possible to further specialize the
RedefinableElement. Default value is false.
IMHO, that sounds like if you defines an Operation (for example) as a leaf,
it is not allowed to redefine the operation in a subclassing class. Some
kind of "final" in the Java-world. Let me know, if i'm wrong.
I defined a Class A with an Operation foo, with isLeaf = true. Afterwards, i
defined a Class B with operation foo, that redefines the Operation A::foo().
I've exepected the validation to fail, but it succeeded. Did i
missunderstand the meaning of the isLeaf attribute?
-- Timothy
Re: isLeaf in UML Class Diagram [message #477525 is a reply to message #477523] |
Mon, 16 June 2008 14:27   |
Hi Timothy,
That's a very interesting observation. I think there is a problem with a
lacking constraint from the spec. It would seem that there should be some
constraint that would check that isLeaf property but after looking through
the spec, I cannot find it. I will double check this with someone from the
OMG and get back to you. We may have to raise an RTF issue.
By the way, not all of the constraints have been implemented in the UML2
project. There is an outstanding bugzilla requesting input from the
community on that. Please feel free to contribute ( have a look at the
existing validation rules as examples ).
- James.
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:g35ner$k8o$1@build.eclipse.org...
> Hi all,
> RedefinableElement. If the value is true, then it is not possible to
> further specialize the RedefinableElement. Default value is false.
> leaf, it is not allowed to redefine the operation in a subclassing class.
> Some kind of "final" in the Java-world. Let me know, if i'm wrong.
> i defined a Class B with operation foo, that redefines the Operation
> A::foo(). I've exepected the validation to fail, but it succeeded. Did i
> Thanks
> -- Timothy
Re: isLeaf in UML Class Diagram [message #477529 is a reply to message #477525] |
Tue, 17 June 2008 08:16   |
Dear James,
where can i find the outstanding bugzilla reports? I've searched form the
both in the eclipsepedia and on google, but didn't found them.
--Timothy
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag
news:g36ba7$c21$1@build.eclipse.org...
> Hi Timothy,
> some constraint that would check that isLeaf property but after looking
> through the spec, I cannot find it. I will double check this with
> someone from the OMG and get back to you. We may have to raise an RTF
> issue.
> Cheers,
> - James.
>> Hi all,
>> In the UML superstructure i've found the definition of the attribute
>> isLeaf from RedefinableElement.
>> Afterwards, i defined a Class B with operation foo, that redefines the
>> Operation A::foo(). I've exepected the validation to fail, but it
>> succeeded. Did i missunderstand the meaning of the isLeaf attribute?
>> Thanks
>> -- Timothy
Re: isLeaf in UML Class Diagram [message #477532 is a reply to message #477529] |
Tue, 17 June 2008 13:27   |
A list of all the UML bugs.
https://bugs.eclipse.org/bugs/buglist.cgi?product=MDT&co mponent=UML2&bug_status=NEW&bug_status=ASSIGNED& bug_status=REOPENED&bug_status=RESOLVED&resolution=F IXED&resolution=---&order=bugs.bug_status,bugs.targe t_milestone,bugs.bug_id&query_format=advanced
The particular bug in question:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=80307
- James.
news:g389vs$7s7$1@build.eclipse.org...
> Dear James,
> Thanks
> --Timothy
>> Hi Timothy,
>> a lacking constraint from the spec. It would seem that there should be
>> issue.
>> Cheers,
>> - James.
>>> Hi all,
>>> class. Some kind of "final" in the Java-world. Let me know, if i'm
>>> wrong.
>>> Thanks
>>> -- Timothy
Re: isLeaf in UML Class Diagram [message #477533 is a reply to message #477532] |
Tue, 17 June 2008 13:46  |
Hi Timothy,
Issue 12532 was raised at the OMG to address this issue.
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:g38s60$bhd$1@build.eclipse.org...
> Cheers,
> - James.
>> Dear James,
>> Thanks
>> --Timothy
>>> Hi Timothy,
>>> issue.
>>> Cheers,
>>> - James.
>>>> Hi all,
>>>> wrong.
>>>> Thanks
>>>> -- Timothy
Re: isLeaf in UML Class Diagram [message #626715 is a reply to message #477523] |
Hi Timothy,
- James.
> Hi all,
> Thanks
> -- Timothy
Re: isLeaf in UML Class Diagram [message #626719 is a reply to message #477525] |
Dear James,
--Timothy
> Hi Timothy,
> issue.
> Cheers,
> - James.
>> Hi all,
>> Thanks
>> -- Timothy
Re: isLeaf in UML Class Diagram [message #626722 is a reply to message #477529] |
- James.
> Dear James,
> Thanks
> --Timothy
>> Hi Timothy,
>> issue.
>> Cheers,
>> - James.
>>> Hi all,
>>> wrong.
>>> Thanks
>>> -- Timothy
Re: isLeaf in UML Class Diagram [message #626723 is a reply to message #477532] |
Hi Timothy,
- James.
> Cheers,
> - James.
>> Dear James,
>> Thanks
>> --Timothy
>>> Hi Timothy,
>>> issue.
>>> Cheers,
>>> - James.
>>>> Hi all,
>>>> wrong.
>>>> Thanks
>>>> -- Timothy
Current Time: Sat Jul 19 14:34:54 EDT 2025
Powered by FUDForum. Page generated in 0.24748 seconds
