Home » Modeling » UML2 » Sterotypes
Sterotypes [message #477514] Fri, 13 June 2008 10:16 Go to next message
Hello all
I'm developing a plugin which takes a UML file and according to a
multiplicity stereotype instantiate it.
I wrote here an example and its a bit long so whoever reads it understand
my problem better,
so please bear with me.
Lets say that I have a class diagram file called a.uml with the following
classes:
1. class Student that has multiplicity 2..2 with the following properties:
name with multiplicity 1..1
id with multiplicity 2..2
2. Class Lecturer that has multiplicity 1..1 with the following properties:
name with multiplicity 4..4
id with multiplicity 4..4
My plugin will creates a new UML class diagram with the number of
instances for each class in the a.uml according to their multiplicity,
thus I will have:
2 Students
1 Lecturer
each student has 1 instance of the property called name and 2 instances of
the property called id
the lecturer has 4 instances of the property called name
and 4 instances of the property called id
My plugin also creates a Profile that accordingly for each element in a.uml
creates a stereotype with an attribute called path that has the uri of the
element and sets the stereotype name to be the element name.
you can say that these stereotypes are classifiers.
so in this example I will have the following stereotypes:
stereotype called Student
with the property path that has the value of Student.uri
stereotype called name
with the property path that has the value of Student.name.uri
stereotype called id
with the property path that has the value of Student.id.uri
stereotype called Lecturer
with the property path that has the value of Lecturer.uri
with the property path that has the value of Lecturer.name.uri
with the property path that has the value of Lecturer.id.uri
Finally!! :-) my problem is:
After defining the profile and applying it to the new class diagram
some how when applying stereotypes with the same name to different
instances in my new class diagram, the applied stereotype for them is only
the first one and the other stereotypes are ignored.
all of the I'm doing of course programmatically.
so in this example the instance of Student.name will be applied with the
sterotype for Student.name which is good, but also the instance of
Lecturer.name will be applied with the same stereotype instead of the
stereotype for Lecturer.name.
does anyone have any idea why this happens ?
thx for any help,
if you need me to post my code I'll be more the happy :-)
thx again
Re: Sterotypes [message #477516 is a reply to message #477514] Fri, 13 June 2008 15:52 Go to previous messageGo to next message
Hi Nadav,
Perhaps you could post a code snippet? and possibly your model and profile.
If you apply a stereotype to different instances of some type then it should
work. Are you getting any errors? Does this work if you try doing it from
the editor?
- James.
"Nadav" <nadav.hoze@gmail.com> wrote in message
news:82fd61024ea8f8d010b66e06bf2160b2$1@www.eclipse.org...
> Hello all
> my problem better, so please bear with me.
> classes:
> properties:
> thus I will have:
> 2 Students 1 Lecturer
> a.uml
> stereotype called Student with the property path that has the value of
> Student.uri
> stereotype called id with the property path that has the value of
> Student.id.uri
> thx for any help, if you need me to post my code I'll be more the happy
> thx again
Re: Sterotypes [message #477519 is a reply to message #477516] Sat, 14 June 2008 04:43 Go to previous message
Sure, no problem
if you have any problem reading this (cause its long...) , here is my mail
(nadav.hoze@gmail.com), you can send my your mail, and i'll give you my
files.
thx :)
These are code sinppets from My instantiator class.
First for each element in the domain file that need to be instantiated I
created a stereotype as written below.
private Stereotype createStereotype(Element domainElement) {
Stereotype stp = UMLFactory.eINSTANCE.createStereotype();
EStructuralFeature nameFeature =
domainElement.eClass().getEStructuralFeature("name");
String name = (String) domainElement.eGet(nameFeature);
stp.setName(name);
URI uri = EcoreUtil.getURI(domainElement);
Property stpProperty = UMLFactory.eINSTANCE.createProperty();
stpProperty.setType(stringPrimitiveType);
stpProperty.setName("path");
stpProperty.setIsReadOnly(true);
LiteralString pathLiteralString = UMLFactory.eINSTANCE.
createLiteralString();
pathLiteralString.setValue(uri.toString());
stpProperty.setDefaultValue(pathLiteralString);
stp.getOwnedAttributes().add(stpProperty);
return stp;
stringPrimitiveType is a field in my class that I imported from the
UML_PRIMITIVE_TYPES_LIBRARY_URI
then I add each stereotype to an already created profile (also a field in
my Instantiator class) with an AddCommand that look like this:
new
AddCommand(ed,profile,UMLPackage.Literals.PROFILE__OWNED_STE REOTYPE,stp);
after executing the AddCommand I need to do the following:
1.define my Profile
2.apply it to the relevant packages
3.applying for each set of instantiated elements the relevant stereotype.
these is how I do it:
private void defineProfile() {
Map<Stereotype, StereotypeStructure> data = getData();
DefineProfileCommand defineProfileCommand = new
DefineProfileCommand(profile,data,data);
ed.getCommandStack().execute(defineProfileCommand);
private Map<Stereotype, StereotypeStructure> getData() {
HashMap<Stereotype, StereotypeStructure> data = new HashMap<Stereotype,
StereotypeStructure>();
EList<Stereotype> stpList = profile.getOwnedStereotypes();
for (Stereotype stereotype : stpList) {
StereotypeStructure structure = new StereotypeStructure(stereotype);
structure.updateMetaclasses(metaClasses);
data.put(stereotype,structure);
return data;
metaClasses is a field in My instantiator class that has the metaclass of
Element (these is the metaclass that I want any of the created stereotypes
to be applicable to)
private void applyProfile() {
List<Package> filteredList =
filter(appRoot.getNestedPackages(),ADOMConstants.PACKAGE_IMP L);
ed.getCommandStack().execute(new
ApplyProfileCommand(ed,filteredList,profile));
the filter function return all the packages that instances of
org.eclipse.uml2.uml.internal.impl.PackageImpl (to avoid applying the
profile to itself which is an instance of org.eclipse.uml2.uml.Package)
private void applyStereotypes() {
Set<Entry<Element, Entry<Collection<Element>, Stereotype>>> entrySet
domainElementsToNewElementsSteroetypeMapper.entrySet();
CompoundCommand cc = new CompoundCommand("apply stereotype classifier
to
all instantiate
elements");
for (Entry<Element, Entry<Collection<Element>, Stereotype>> entry :
entrySet) {
Entry<Collection<Element>, Stereotype> elementsToStereotype =
entry.getValue();
Collection<Element> newElements = elementsToStereotype.getKey();
Stereotype stp = elementsToStereotype.getValue();
for (Element element : newElements) {
cc.append(new ApplyStereoTypeCommand(element,stp));
if (!cc.isEmpty())
ed.getCommandStack().execute(cc);
domainElementsToNewElementsSteroetypeMapper is a hashmap field in My
instantiator class that during the instantiaton process maps all the
domain elements to list of the corresponding instantiated elements and
their matching stereotype.
code of StereotypeStructure (belongs to TOPCASED):
import java.util.ArrayList;
import java.util.Iterator;
import java.util.List;
import org.eclipse.swt.widgets.Text;
import org.eclipse.uml2.uml.Extension;
import org.eclipse.uml2.uml.Property;
import org.eclipse.uml2.uml.Stereotype;
import org.eclipse.uml2.uml.Type;
* Structure that stores stereotype data
public class StereotypeStructure
private Stereotype stereotype;
private Text nameText;
private String name;
private Text extensionTxt;
private List metaclasses;
* @param stereo
public StereotypeStructure(Stereotype stereo)
stereotype = stereo;
name = stereo.getName();
metaclasses = new ArrayList();
Iterator iterator = stereo.getOwnedAttributes().iterator();
while (iterator.hasNext())
Object o = iterator.next();
if (o instanceof Property)
Property property = (Property) o;
if (property.getAssociation() instanceof Extension)
metaclasses.add(property.getType());
* @return Stereotype the Stereotype
public Stereotype getStereotype()
return stereotype;
* @return List the list of MetaClasses
public List getMetaclasses()
return metaclasses;
* @return String the new name
public String getNewName()
return name;
* @param metas
public void updateMetaclasses(List metas)
metaclasses = metas;
public void updateLabel()
boolean first = true;
StringBuffer result = new StringBuffer();
Iterator iterator = metaclasses.iterator();
int counter = 0;
if (first)
first = false;
else
result.append(", ");
result.append(((Type) iterator.next()).getName());
counter++;
if (metaclasses.size() == 0)
result.append("none");
if (extensionTxt != null)
extensionTxt.setText(result.toString());
else
throw new IllegalStateException("Label cannot be null at this
point.");
* @return String the name
protected String getName()
if (nameText != null)
return nameText.getText();
else
throw new IllegalStateException("Text cannot be null at this
point.");
* @param name
protected void setName(String name)
this.name = name;
* @return Text the Text widget associated with the extension
protected Text getExtensionTxt()
return extensionTxt;
* @param extensionTxt
protected void setExtensionTxt(Text extensionTxt)
this.extensionTxt = extensionTxt;
* @return Text the Text widget associated with the name
protected Text getNameText()
return nameText;
* @param nameText
protected void setNameText(Text nameText)
this.nameText = nameText;
code of DefineProfileCommand (also belongs to TOPCASED):
import java.util.Map;
import org.eclipse.emf.common.command.AbstractCommand;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Profile;
import org.topcased.modeler.uml.dialogs.StereotypeStructure;
* TODO completly refactor and redesign this class Class that create a
command in order to update profile settings <br>
* creation : 31 may 2005
* @author <a href="mailto:mathieu.garcia@anyware-tech.com">Mathieu
Garcia</a>
public class DefineProfileCommand extends AbstractCommand
/** Current profile */
private Profile profile;
/** Old values */
private Map<Stereotype, StereotypeStructure> oldDatas;
/** New values */
private Map<Stereotype, StereotypeStructure> datas;
* Create a command for updating parameters on a given profile
* @param prof the profile
* @param data the new datas
* @param oldData the old datas
public DefineProfileCommand(Profile prof, Map<Stereotype,
StereotypeStructure> data, Map<Stereotype, StereotypeStructure> oldData)
profile = prof;
datas = data;
oldDatas = oldData;
* Set the values
protected void setValues()
// Remove imported classes
// TODO check if the following code line is clean
profile.getElementImports().clear();
// Look for properties that handle extension
ArrayList propertyToRemove = new ArrayList();
Iterator itStereotype = profile.getOwnedStereotypes().iterator();
while (itStereotype.hasNext())
Stereotype stereotype = (Stereotype) itStereotype.next();
Iterator itAttribute =
stereotype.getOwnedAttributes().iterator();
while (itAttribute.hasNext())
Property property = (Property) itAttribute.next();
propertyToRemove.add(property);
// Remove the found properties and extension associated to
Iterator itProperty = propertyToRemove.iterator();
while (itProperty.hasNext())
Property property = (Property) itProperty.next();
if (property.getAssociation() != null)
property.getAssociation().destroy();
property.destroy();
// Update each stereotype
Iterator itValues = datas.values().iterator();
while (itValues.hasNext())
Object object = itValues.next();
if (object instanceof StereotypeStructure)
StereotypeStructure stSt = (StereotypeStructure) object;
Stereotype stereotype = stSt.getStereotype();
// update name
stereotype.setName(stSt.getNewName());
// update metaclass
for (Iterator metaIterator =
stSt.getMetaclasses().iterator(); metaIterator.hasNext();)
Class metaclass = (Class) metaIterator.next();
if
(!profile.getMetaclassReferences().contains(metaclass))
profile.createMetaclassReference(metaclass);
stereotype.createExtension(metaclass, false);
profile.define();
* Switch the old and new values
protected void switchValues()
Map temp = datas;
datas = oldDatas;
oldDatas = temp;
public void execute()
setValues();
public void undo()
switchValues();
setValues();
public void redo()
switchValues();
setValues();
protected boolean prepare() {
return !datas.isEmpty();
finally :-)
here are my domain.uml file and domain_app.file
domain.uml:
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:Multiplicity="http:///schemas/Multiplicity/_v55BMDObEd2Ax4zFLRHZ-Q/0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xsi:schemaLocation="http:///schemas/Multiplicity/_v55BMDObEd2Ax4zFLRHZ-Q/0
../../.ADOMResources/adomutitlity/MultiplicityProfile.uml#_v 55BMjObEd2Ax4zFLRHZ-Q ">
<uml:Model xmi:id="_qb8akM37EdqwVrslYOdUDA">
<packagedElement xmi:type="uml:Package"
xmi:id="_w8IxIM37EdqwVrslYOdUDA" name="domain">
<elementImport xmi:id="_2TAwADnpEd2-cMuNDU2d2Q">
<importedElement xmi:type="uml:PrimitiveType"
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</elementImport>
<packagedElement xmi:type="uml:Class"
xmi:id="_vOBDQDnpEd2-cMuNDU2d2Q" name="Student">
<ownedAttribute xmi:id="_wsyuYDnpEd2-cMuNDU2d2Q" name="name">
<type xmi:type="uml:PrimitiveType"
</ownedAttribute>
<ownedAttribute xmi:id="_xfmrYjnpEd2-cMuNDU2d2Q" name="id">
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
</ownedAttribute>
<ownedOperation xmi:id="_yJxpwDnpEd2-cMuNDU2d2Q" name="getName">
<ownedParameter xmi:id="_6rdW8DnpEd2-cMuNDU2d2Q" name="return"
direction="return">
</ownedParameter>
</ownedOperation>
<ownedOperation xmi:id="_y6WyIjnpEd2-cMuNDU2d2Q" name="getId">
<ownedParameter xmi:id="_6VZnYDnpEd2-cMuNDU2d2Q" name="return"
direction="return">
</ownedParameter>
</ownedOperation>
</packagedElement>
xmi:id="_9yO6qDnpEd2-cMuNDU2d2Q" name="Lecturer">
<ownedAttribute xmi:id="__VVFEjnpEd2-cMuNDU2d2Q" name="name">
</ownedAttribute>
<ownedAttribute xmi:id="__tK9UjnpEd2-cMuNDU2d2Q" name="id">
</ownedAttribute>
<ownedOperation xmi:id="_DFF7YjnqEd2-cMuNDU2d2Q" name="getName">
<ownedParameter xmi:id="_H1qucDnqEd2-cMuNDU2d2Q" name="return"
direction="return">
</ownedParameter>
</ownedOperation>
<ownedOperation xmi:id="_DWhpoDnqEd2-cMuNDU2d2Q" name="getId">
<ownedParameter xmi:id="_IkAbIDnqEd2-cMuNDU2d2Q" name="return"
direction="return">
</ownedParameter>
</ownedOperation>
</packagedElement>
<profileApplication xmi:id="_MTxRcDnqEd2-cMuNDU2d2Q">
<eAnnotations xmi:id="_MTxRcTnqEd2-cMuNDU2d2Q"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href=" ../../.ADOMResources/adomutitlity/MultiplicityProfile.uml#_v 55BMjObEd2Ax4zFLRHZ-Q "/>
</eAnnotations>
<appliedProfile
href=" ../../.ADOMResources/adomutitlity/MultiplicityProfile.uml#_a wtoADObEd2Ax4zFLRHZ-Q "/>
</profileApplication>
</packagedElement>
</uml:Model>
<Multiplicity:Multiplicity xmi:id="_OFBMoDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_vOBDQDnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_QDOlwDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_wsyuYDnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_SNXiEDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_xfmrYjnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_Td1EYDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_yJxpwDnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_U44GEDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_y6WyIjnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_ZvkIMDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_9yO6qDnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_bcMpIDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="__VVFEjnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_b5tEgDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="__tK9UjnpEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_cW594DnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_DFF7YjnqEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_cq4CwDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_DWhpoDnqEd2-cMuNDU2d2Q"/>
<Multiplicity:Multiplicity xmi:id="_kBwJsDnqEd2-cMuNDU2d2Q" min="1"
max="1" base_Element="_w8IxIM37EdqwVrslYOdUDA"/>
</xmi:XMI>
here is my domain_app.uml:
xmlns:domain_app=" http://model_domain_app/schemas/domain_app/_GcccTznrEd2-cMuN DU2d2Q/0"
xsi:schemaLocation=" http://model_domain_app/schemas/domain_app/_GcccTznrEd2-cMuN DU2d2Q/0
#_GcccUTnrEd2-cMuNDU2d2Q">
<uml:Model xmi:id="_qb8akM37EdqwVrslYOdUDA" name="model_domain_app">
<packagedElement xmi:type="uml:Profile"
xmi:id="_GbQJcDnrEd2-cMuNDU2d2Q" name="domain_app"
metaclassReference="_GcSrbDnrEd2-cMuNDU2d2Q _GcSrcDnrEd2-cMuNDU2d2Q
_GcSrdDnrEd2-cMuNDU2d2Q _GcSreDnrEd2-cMuNDU2d2Q _GcSrfDnrEd2-cMuNDU2d2Q
_GcSrgDnrEd2-cMuNDU2d2Q _GcSrhDnrEd2-cMuNDU2d2Q _GcSriDnrEd2-cMuNDU2d2Q
_GcccQznrEd2-cMuNDU2d2Q _GcccRznrEd2-cMuNDU2d2Q _GcccSznrEd2-cMuNDU2d2Q">
<eAnnotations xmi:id="_GcccUDnrEd2-cMuNDU2d2Q"
<contents xmi:type="ecore:EPackage"
xmi:id="_GcccUTnrEd2-cMuNDU2d2Q" name="domain_app"
nsURI=" http://model_domain_app/schemas/domain_app/_GcccTznrEd2-cMuN DU2d2Q/0"
nsPrefix="domain_app">
<eClassifiers xmi:type="ecore:EClass"
xmi:id="_GcccUjnrEd2-cMuNDU2d2Q" name="domain">
<eAnnotations xmi:id="_GcccUznrEd2-cMuNDU2d2Q"
references="_GcSrQDnrEd2-cMuNDU2d2Q"/>
<eStructuralFeatures xmi:type="ecore:EAttribute"
xmi:id="_GcccVDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
lowerBound="1" changeable="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_w8IxIM37EdqwVrslYOdUDA ">
<eType xmi:type="ecore:EDataType"
href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_GcccVjnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/2.1.0/UML#//Element"/>
</eClassifiers>
xmi:id="_GcccWDnrEd2-cMuNDU2d2Q" name="Student">
<eAnnotations xmi:id="_GcccWTnrEd2-cMuNDU2d2Q"
references="_GcSrRDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccWjnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_vOBDQDnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccXDnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccXjnrEd2-cMuNDU2d2Q" name="name">
<eAnnotations xmi:id="_GcccXznrEd2-cMuNDU2d2Q"
references="_GcSrSDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccYDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_wsyuYDnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccYjnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccZDnrEd2-cMuNDU2d2Q" name="id">
<eAnnotations xmi:id="_GcccZTnrEd2-cMuNDU2d2Q"
references="_GcSrTDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccZjnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_xfmrYjnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccaDnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccajnrEd2-cMuNDU2d2Q" name="getName">
<eAnnotations xmi:id="_GcccaznrEd2-cMuNDU2d2Q"
references="_GcSrUDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccbDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_yJxpwDnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccbjnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GccccDnrEd2-cMuNDU2d2Q" name="getId">
<eAnnotations xmi:id="_GccccTnrEd2-cMuNDU2d2Q"
references="_GcSrVDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GccccjnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_y6WyIjnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccdDnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccdjnrEd2-cMuNDU2d2Q" name="Lecturer">
<eAnnotations xmi:id="_GcccdznrEd2-cMuNDU2d2Q"
references="_GcSrWDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GccceDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_9yO6qDnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccejnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccfDnrEd2-cMuNDU2d2Q" name="name">
<eAnnotations xmi:id="_GcccfTnrEd2-cMuNDU2d2Q"
references="_GcSrXDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccfjnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#__VVFEjnpEd2-cMuNDU2d2Q ">
xmi:id="_GcccgDnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccgjnrEd2-cMuNDU2d2Q" name="id">
<eAnnotations xmi:id="_GcccgznrEd2-cMuNDU2d2Q"
references="_GcSrYDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GccchDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#__tK9UjnpEd2-cMuNDU2d2Q ">
xmi:id="_GccchjnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GccciDnrEd2-cMuNDU2d2Q" name="getName">
<eAnnotations xmi:id="_GccciTnrEd2-cMuNDU2d2Q"
references="_GcSrZDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GcccijnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_DFF7YjnqEd2-cMuNDU2d2Q ">
xmi:id="_GcccjDnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
xmi:id="_GcccjjnrEd2-cMuNDU2d2Q" name="getId">
<eAnnotations xmi:id="_GcccjznrEd2-cMuNDU2d2Q"
references="_GcSraDnrEd2-cMuNDU2d2Q"/>
xmi:id="_GccckDnrEd2-cMuNDU2d2Q" name="path" ordered="false"
defaultValueLiteral=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_DWhpoDnqEd2-cMuNDU2d2Q ">
xmi:id="_GccckjnrEd2-cMuNDU2d2Q" name="base_Element" ordered="false"
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_GcSrbDnrEd2-cMuNDU2d2Q">
<importedElement xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Element"/>
</elementImport>
<elementImport xmi:id="_GcSrcDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSrdDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSreDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSrfDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSrgDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSrhDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcSriDnrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcccQznrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcccRznrEd2-cMuNDU2d2Q">
</elementImport>
<elementImport xmi:id="_GcccSznrEd2-cMuNDU2d2Q">
</elementImport>
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_GcSrQDnrEd2-cMuNDU2d2Q" name="domain">
<ownedAttribute xmi:id="_GcSrQTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
<defaultValue xmi:type="uml:LiteralString"
xmi:id="_GcSrQjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_w8IxIM37EdqwVrslYOdUDA "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrdznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrdTnrEd2-cMuNDU2d2Q">
<type xmi:type="uml:Class"
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrRDnrEd2-cMuNDU2d2Q" name="Student">
<ownedAttribute xmi:id="_GcSrRTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrRjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_vOBDQDnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcccQjnrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcccQDnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrSDnrEd2-cMuNDU2d2Q" name="name">
<ownedAttribute xmi:id="_GcSrSTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrSjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_wsyuYDnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrcznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrcTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrTDnrEd2-cMuNDU2d2Q" name="id">
<ownedAttribute xmi:id="_GcSrTTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrTjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_xfmrYjnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcccTjnrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcccTDnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrUDnrEd2-cMuNDU2d2Q" name="getName">
<ownedAttribute xmi:id="_GcSrUTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrUjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_yJxpwDnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrbznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrbTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrVDnrEd2-cMuNDU2d2Q" name="getId">
<ownedAttribute xmi:id="_GcSrVTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrVjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_y6WyIjnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSreznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSreTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrWDnrEd2-cMuNDU2d2Q" name="Lecturer">
<ownedAttribute xmi:id="_GcSrWTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrWjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_9yO6qDnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrhznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrhTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrXDnrEd2-cMuNDU2d2Q" name="name">
<ownedAttribute xmi:id="_GcSrXTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrXjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#__VVFEjnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcccRjnrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcccRDnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrYDnrEd2-cMuNDU2d2Q" name="id">
<ownedAttribute xmi:id="_GcSrYTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrYjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#__tK9UjnpEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrgznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrgTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSrZDnrEd2-cMuNDU2d2Q" name="getName">
<ownedAttribute xmi:id="_GcSrZTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrZjnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_DFF7YjnqEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcccSjnrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcccSDnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
xmi:id="_GcSraDnrEd2-cMuNDU2d2Q" name="getId">
<ownedAttribute xmi:id="_GcSraTnrEd2-cMuNDU2d2Q" name="path"
isReadOnly="true">
xmi:id="_GcSrajnrEd2-cMuNDU2d2Q"
value=" file:/D:/AdomProject/eclipse/runtime-EclipseApplication/Itay /Models/domain.uml#_DWhpoDnqEd2-cMuNDU2d2Q "/>
</ownedAttribute>
<ownedAttribute xmi:id="_GcSrfznrEd2-cMuNDU2d2Q"
name="base_Element" association="_GcSrfTnrEd2-cMuNDU2d2Q">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension"
xmi:id="_GcSrbTnrEd2-cMuNDU2d2Q" name="Element_getName"
memberEnd="_GcSrbjnrEd2-cMuNDU2d2Q _GcSrbznrEd2-cMuNDU2d2Q">
<ownedEnd xmi:type="uml:ExtensionEnd"
xmi:id="_GcSrbjnrEd2-cMuNDU2d2Q" name="extension_getName"
type="_GcSrUDnrEd2-cMuNDU2d2Q" aggregation="composite"
association="_GcSrbTnrEd2-cMuNDU2d2Q"/>
</packagedElement>
xmi:id="_GcSrcTnrEd2-cMuNDU2d2Q" name="Element_name"
memberEnd="_GcSrcjnrEd2-cMuNDU2d2Q _GcSrcznrEd2-cMuNDU2d2Q">
xmi:id="_GcSrcjnrEd2-cMuNDU2d2Q" name="extension_name"
type="_GcSrSDnrEd2-cMuNDU2d2Q" aggregation="composite"
association="_GcSrcTnrEd2-cMuNDU2d2Q"/>
</packagedElement>
xmi:id="_GcSrdTnrEd2-cMuNDU2d2Q" name="Element_domain"
memberEnd="_GcSrdjnrEd2-cMuNDU2d2Q _GcSrdznrEd2-cMuNDU2d2Q">
xmi:id="_GcSrdjnrEd2-cMuNDU2d2Q" name="extension_domain"
type="_GcSrQDnrEd2-cMuNDU2d2Q" aggregation="composite"
association="_GcSrdTnrEd2-cMuNDU2d2Q"/>
</packagedElement>
xmi:id="_GcSreTnrEd2-cMuNDU2d2Q" name="Element_getId"
memberEnd="_GcSrejnrEd2-cMuNDU2d2Q _GcSreznrEd2-cMuNDU2d2Q">
xmi:id="_GcSrejnrEd2-cMuNDU2d2Q" name="extension_getId"
type="_GcSrVDnrEd2-cMuNDU2d2Q" aggregation="composite"
association="_GcSreTnrEd2-cMuNDU2d2Q"/>
</packagedElement>
xmi:id="_GcSrfTnrEd2-cMuNDU2d2Q" name="Element_getId"
memberEnd="_GcSrfjnrEd2-cMuNDU2d2Q _GcSrfznrEd2-cMuNDU2d2Q">
<ownedEnd xmi
Re: Sterotypes [message #626706 is a reply to message #477514] Fri, 13 June 2008 15:52 Go to previous message
Hi Nadav,
the editor?
- James.
> Hello all
> classes:
> properties:
> thus I will have:
> a.uml
> Student.uri
> Student.id.uri
> thx again
Re: Sterotypes [message #626709 is a reply to message #477516] Sat, 14 June 2008 04:43 Go to previous message
Sure, no problem
files.
thx :)
stp.setName(name);
return stp;
new
1.define my Profile
return data;
to
all instantiate
elements");
entrySet) {
entry.getValue();
if (!cc.isEmpty())
* @param stereo
return stereotype;
return metaclasses;
return name;
* @param metas
int counter = 0;
if (first)
first = false;
else
counter++;
else
point.");
else
point.");
* @param name
this.name = name;
return nameText;
* @param nameText
Garcia</a>
/** Old values */
/** New values */
profile = prof;
datas = data;
oldDatas = oldData;
* Set the values
property.destroy();
// update name
// update metaclass
if
profile.define();
Map temp = datas;
datas = oldDatas;
oldDatas = temp;
setValues();
public void undo()
switchValues();
setValues();
public void redo()
switchValues();
setValues();
finally :-)
domain.uml:
</elementImport>
</ownedAttribute>
</ownedAttribute>
direction="return">
</ownedParameter>
</ownedOperation>
direction="return">
</ownedParameter>
</ownedOperation>
</packagedElement>
</ownedAttribute>
</ownedAttribute>
direction="return">
</ownedParameter>
</ownedOperation>
direction="return">
</ownedParameter>
</ownedOperation>
</packagedElement>
</eAnnotations>
<appliedProfile
</packagedElement>
</uml:Model>
</xmi:XMI>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
isReadOnly="true">
</ownedAttribute>
</ownedAttribute>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
<ownedEnd xmi
Previous Topic:Creating a UML Editor
Next Topic:how to clone a model
Current Time: Sat Jul 19 19:46:38 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
