Home » Modeling » UML2 » Installation or settings problem
Installation or settings problem [message #477169] Wed, 02 April 2008 03:24 Go to next message
Originally posted by: mtrzeciecki.yahoo.co.uk
I have a problem with the installation of my eclipse plugins, probably.
According to the "Product configuration", the following components are
installed properly:
- EMF
- GEF
- UML2 tools
So I can draw UML diagrams visually, but I cannot write any java code for
generating UML (I get, for instance, "Model cannot be resoved to a type").
In fact, I can't use any classes from org.eclipse.* . Do I have to set
something additionally?
Re: Installation or settings problem [message #477175 is a reply to message #477169] Wed, 02 April 2008 09:29 Go to previous messageGo to next message
Hi Mikolaj ,
Try checking that you can create a .uml model using the creation wizards.
If you can create UML diagrams visually then I would suspect that you have
all the UML plugins properly installed.
Verify that you have properly created a dependency from your plugin to UML
plugins.
Try following the getting started article:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
- James.
"Mikolaj Trzeciecki" <mtrzeciecki@yahoo.co.uk> wrote in message
news:fsvcbk$3ii$1@build.eclipse.org...
> installed properly:
> - EMF
> - GEF
> - UML2 tools
Re: Installation or settings problem [message #477176 is a reply to message #477175] Wed, 02 April 2008 10:26 Go to previous messageGo to next message
Hi James,
James Bruck wrote:
> Hi Mikolaj ,
> plugins.
Yes I suspect this is the point. I haven't created _any_ dependencies...
What dependencies are needed? Does an UML project create them automatically?
> http://www.elipse.org/modeling/mdt/uml2/docs/articles/Gettin g_Started_with_UML2/article.html
Thank you. But there I have the same problem. I get stuck at the point
"Let's look at how to perform the same task using Java code. ". The
types Model and Package maka my Eclipse complain that it doesn't know
them. Should I go on with the tutorial nevertheless?
Mikolaj
Re: Installation or settings problem [message #477182 is a reply to message #477176] Thu, 03 April 2008 11:07 Go to previous message
.... some comments below..
news:ft052g$4ie$1@build.eclipse.org...
> Hi James,
> James Bruck wrote:
>> Hi Mikolaj ,
>> UML plugins.
> automatically?
If you select your Mainifest.mf file, you should be able to add
org.eclipse.uml2.uml to your dependencies.
> "Let's look at how to perform the same task using Java code. ". The types
> Model and Package maka my Eclipse complain that it doesn't know them.
Scroll to the bottom of the document for references to source code.
The article is out of date so the version numbers are off a bit but the same
general ideas still apply.
> Cheers,
> Mikolaj
Re: Installation or settings problem [message #626335 is a reply to message #477169] Wed, 02 April 2008 09:29 Go to previous message
Hi Mikolaj ,
plugins.
- James.
> installed properly:
> - EMF
> - GEF
> - UML2 tools
Re: Installation or settings problem [message #626336 is a reply to message #477175] Wed, 02 April 2008 10:26 Go to previous message
Hi James,
James Bruck wrote:
> Hi Mikolaj ,
> plugins.
Mikolaj
Re: Installation or settings problem [message #626342 is a reply to message #477176] Thu, 03 April 2008 11:07 Go to previous message
> Hi James,
> James Bruck wrote:
>> Hi Mikolaj ,
>> UML plugins.
> automatically?
> Cheers,
> Mikolaj
Previous Topic:xmi Id in Dependency
Next Topic:How to represent dependency model with UML2
Current Time: Sun Jul 20 11:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.04013 seconds
