Installation or settings problem [message #477169] |
Wed, 02 April 2008 03:24  |
Originally posted by: mtrzeciecki.yahoo.co.uk
I have a problem with the installation of my eclipse plugins, probably.
According to the "Product configuration", the following components are
installed properly:
- EMF
- GEF
- UML2 tools
So I can draw UML diagrams visually, but I cannot write any java code for
generating UML (I get, for instance, "Model cannot be resoved to a type").
In fact, I can't use any classes from org.eclipse.* . Do I have to set
something additionally?
Re: Installation or settings problem [message #477182 is a reply to message #477176] |
Thu, 03 April 2008 11:07  |
.... some comments below..
"Mikolaj Trzeciecki" <mtrzeciecki@yahoo.co.uk> wrote in message
news:ft052g$4ie$1@build.eclipse.org...
> Hi James,
> James Bruck wrote:
>> Hi Mikolaj ,
>> Verify that you have properly created a dependency from your plugin to
>> UML plugins.
> Yes I suspect this is the point. I haven't created _any_ dependencies...
> What dependencies are needed? Does an UML project create them
> automatically?
If you select your Mainifest.mf file, you should be able to add
org.eclipse.uml2.uml to your dependencies.
>> Try following the getting started article:
>> http://www.elipse.org/modeling/mdt/uml2/docs/articles/Gettin g_Started_with_UML2/article.html
> Thank you. But there I have the same problem. I get stuck at the point
> "Let's look at how to perform the same task using Java code. ". The types
> Model and Package maka my Eclipse complain that it doesn't know them.
> Should I go on with the tutorial nevertheless?
Scroll to the bottom of the document for references to source code.
The article is out of date so the version numbers are off a bit but the same
general ideas still apply.
> Cheers,
> Mikolaj
Re: Installation or settings problem [message #626335 is a reply to message #477169] |
Wed, 02 April 2008 09:29  |
Hi Mikolaj ,
Try checking that you can create a .uml model using the creation wizards.
If you can create UML diagrams visually then I would suspect that you have
all the UML plugins properly installed.
Verify that you have properly created a dependency from your plugin to UML
plugins.
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
- James.
news:fsvcbk$3ii$1@build.eclipse.org...
> installed properly:
> - EMF
> - GEF
> - UML2 tools
Re: Installation or settings problem [message #626336 is a reply to message #477175] |
Wed, 02 April 2008 10:26  |
Hi James,
James Bruck wrote:
> Hi Mikolaj ,
> plugins.
What dependencies are needed? Does an UML project create them automatically?
types Model and Package maka my Eclipse complain that it doesn't know
them. Should I go on with the tutorial nevertheless?
Mikolaj
Re: Installation or settings problem [message #626342 is a reply to message #477176] |
> Hi James,
> James Bruck wrote:
>> Hi Mikolaj ,
>> UML plugins.
> automatically?
> Cheers,
> Mikolaj
FUDForum. Page generated in 0.57001 seconds
