Home » Modeling » UML2 » Re: Convert a UML file to Ecore file
Re: Convert a UML file to Ecore file [message #477090] |
Thu, 13 March 2008 09:15  |
Rasha,
It's best to ask on the UML newsgroup, which I've added to the "to" list
of the reply. Did you also install all the prerequisites for UML?
I.e., if you run with -clean -debug and look at the
<workspace>/.metadata/.log or the Error log view, does it complain about
missing dependencies?
rasha wrote:
> I need to know how I can convert a UML file to ecore file. I use UML
> modeling tool called Papyrus which creates two files: the first one
> describe the graphical parts and the second one is the uml model. I
> use Eclipse SDK 3.3.1.1 with Papyrus and mdt-uml2-SDK-2.1.1 plug-in it.
> I can convert from Ecore to UML from "Sample Ecore Editor\Convert to
> UML Model.." after I plug-in the "examples" from the UML project.
> I tried to plug-in the package org.eclipse.uml2.uml.util which
> contains UMLUtil.UML2EcoreConverter, but I couldn't find it.
> Could you please help me. I would appreciate very much any information
> that could help solve the problem.
> Many thanks,
> Rasha
Re: Convert a UML file to Ecore file [message #477092 is a reply to message #477090] |
Thu, 13 March 2008 10:02   |
Hi Ed and Rasha,
Converting a UML file to an Ecore file starts with the
ConvertToEcoreModelAction from the examples plugins.
You would need to select the root model element of your model (some subtype
of Package) then select
'UML Editor > Convert To... > Ecore Model'
You should then see an options dialog appear.
Hope that Helps.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:frb9dm$7q8$1@build.eclipse.org...
> Rasha,
> of the reply. Did you also install all the prerequisites for UML? I.e.,
> if you run with -clean -debug and look at the <workspace>/.metadata/.log
> or the Error log view, does it complain about missing dependencies?
> rasha wrote:
>> Hi,
>> describe the graphical parts and the second one is the uml model. I use
>> I can convert from Ecore to UML from "Sample Ecore Editor\Convert to UML
>> I tried to plug-in the package org.eclipse.uml2.uml.util which contains
>> Many thanks,
>> Rasha
Re: Convert a UML file to Ecore file [message #477096 is a reply to message #477095] |
Thu, 13 March 2008 16:30   |
--------------080303000303030003020807
Rasha,
news://news.eclipse.org/eclipse.modeling.mdt.uml2
rasha wrote:
> Thanks Ed and James for your help. Ed, could you please send to me the
> contact info for the UML newsgroup, I couldn?t see it in the ?to? list.
> James, the problem that I couldn?t find the ?UML Editor?. I have the
> features UML2Examples and UML2ExamplesSource plugins. I have the
> SampleEcoreEdit but not the UML Edit. If you could know what I missed
> to install as prerequisites for UML, It?ll be highly appreciated.
> Cheers,
> Rasha
<html>
<head>
http-equiv="Content-Type">
</head>
Rasha,<br>
<blockquote><a href="news://news.eclipse.org/eclipse.modeling.mdt.uml2">news://news.eclipse.org/eclipse.modeling.mdt.uml2</a><br>
</blockquote>
<br>
<br>
rasha wrote:
<blockquote
cite="mid:a966c9a27f5468dbedf42deca65a44c4$1@www.eclipse.org"
type="cite">Thanks Ed and James for your help. Ed, could you please
send to me the contact info for the UML newsgroup, I couldn�t see it in
the �to� list.
<br>
<br>
James, the problem that I couldn�t find the �UML Editor�. I have the
to install as prerequisites for UML, It�ll be highly appreciated.
<br>
<br>
Cheers, <br>
Rasha
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080303000303030003020807--
Re: Convert a UML file to Ecore file [message #477099 is a reply to message #477096] |
Fri, 14 March 2008 10:31   |
------=_NextPart_000_007B_01C885BE.81A00ED0
charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
You can download the entire SDK or runtime from here: =
http://www.eclipse.org/modeling/mdt/downloads/?project=3Duml 2
The prerequisites are also listed. Downloading the SDK for example =
would enable the menus you are looking for.
Or you can selectively choose the source code you want from cvs.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:frc2st$va0$1@build.eclipse.org...
Rasha,
rasha wrote:=20
Thanks Ed and James for your help. Ed, could you please send to me =
the contact info for the UML newsgroup, I couldn?t see it in the ?to? =
list.=20
James, the problem that I couldn?t find the ?UML Editor?. I have the =
features UML2Examples and UML2ExamplesSource plugins. I have the =
SampleEcoreEdit but not the UML Edit. If you could know what I missed to =
install as prerequisites for UML, It?ll be highly appreciated.=20
Cheers,=20
Rasha=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>You can download the entire SDK or =
runtime from=20
here: <A=20
href=3D" http://www.eclipse.org/modeling/mdt/downloads/?project=3Duml 2">ht=
tp://www.eclipse.org/modeling/mdt/downloads/?project=3Duml2</A></FONT></D=
IV>
<DIV><FONT face=3DArial size=3D2>The prerequisites are also =
listed. =20
Downloading the SDK for example would enable the menus you are looking=20
for.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Or you can selectively choose the =
source code you=20
want from cvs.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:frc2st$va0$1@build.eclipse.org">news:frc2st$va0$1@build.ecli=
pse.org</A>...</DIV>Rasha,<BR>
<BLOCKQUOTE><A=20
href=3D"news://news.eclipse.org/eclipse.modeling.mdt.uml2">news://news.ec=
lipse.org/eclipse.modeling.mdt.uml2</A><BR></BLOCKQUOTE><BR ><BR>rasha=20
wrote:=20
<BLOCKQUOTE =
cite=3Dmid:a966c9a27f5468dbedf42deca65a44c4$1@www.eclipse.org=20
type=3D"cite">Thanks Ed and James for your help. Ed, could you please =
send to=20
me the contact info for the UML newsgroup, I couldn�t see it =
in the �to�=20
list. <BR><BR>James, the problem that I couldn�t find the =
�UML Editor�. I=20
have the features UML2Examples and UML2ExamplesSource plugins. I =
have the=20
SampleEcoreEdit but not the UML Edit. If you could know what I =
missed to=20
install as prerequisites for UML, It�ll be highly =
appreciated.=20
<BR><BR>Cheers, <BR>Rasha=20
<BR><BR><BR></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_007B_01C885BE.81A00ED0--
Re: Convert a UML file to Ecore file [message #477147 is a reply to message #477137] |
Thu, 27 March 2008 11:25  |
Note that the action James is referring to is only an example... If the EMF
model wizard is used instead, and UML chosen as a source type, I believe you
should be able to convert multiple UML packages to Ecore at once...
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fseh2l$s11$2@build.eclipse.org...
> Hi Rasha,
> Unfortunately I believe you can only select one at a time.
> - James.
> "Rasha" <rtawhid@connect.carleton.ca> wrote in message
> news:6176741e023e45504b67aad1e704e578$1@www.eclipse.org...
>> Hi James,
>> Thanks so much for your help. I have one more question. It works fine
>> when I have only one package in my file. However when the file contains
>> more that one package for example another package for a profile, I
>> couldn't select more than one root model element.
>> Is there is any way to select more than one root model element?
>> Any help is greatly appreciated,
>> Rasha
Re: Convert a UML file to Ecore file [message #626221 is a reply to message #477090] |
Hi Ed and Rasha,
Hope that Helps.
- James.
> Rasha,
> rasha wrote:
>> Hi,
>> Many thanks,
>> Rasha
Re: Convert a UML file to Ecore file [message #626224 is a reply to message #477092] |
Thu, 13 March 2008 15:58  |
contact info for the UML newsgroup, I couldnt see it in the to list.
James, the problem that I couldnt find the UML Editor. I have the
install as prerequisites for UML, Itll be highly appreciated.
Rasha
Re: Convert a UML file to Ecore file [message #626225 is a reply to message #477095] |
Rasha,
> Cheers,
> Rasha
<html>
<head>
</head>
Rasha,<br>
</blockquote>
<br>
<br>
rasha wrote:
<blockquote
the �to� list.
<br>
<br>
<br>
<br>
Cheers, <br>
Rasha
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Convert a UML file to Ecore file [message #626228 is a reply to message #477096] |
- James.
Rasha,
rasha wrote:=20
list.=20
Cheers,=20
Rasha=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
runtime from=20
here: <A=20
IV>
listed. =20
for.</FONT></DIV>
source code you=20
<BLOCKQUOTE=20
<BLOCKQUOTE><A=20
wrote:=20
<BLOCKQUOTE =
send to=20
in the �to�=20
�UML Editor�. I=20
have the=20
missed to=20
appreciated.=20
Re: Convert a UML file to Ecore file [message #626266 is a reply to message #477092] |
Tue, 25 March 2008 21:51  |
Hi James,
Thanks so much for your help. I have one more question. It works fine when
I have only one package in my file. However when the file contains more
that one package for example another package for a profile, I couldn't
Rasha
Re: Convert a UML file to Ecore file [message #626271 is a reply to message #477130] |
Wed, 26 March 2008 18:00  |
Hi Rasha,
- James.
> Hi James,
> Rasha
Re: Convert a UML file to Ecore file [message #626281 is a reply to message #477137] |
Kenn
> Hi Rasha,
> - James.
>> Hi James,
>> Rasha
Current Time: Sun Jul 20 09:46:08 EDT 2025
Powered by FUDForum. Page generated in 0.07817 seconds
