Home » Modeling » UML2 » Loading a Profile
Loading a Profile [message #476951] Mon, 18 February 2008 15:02 Go to next message
Originally posted by: flavio.p.duarte.gmail.com
I am trying to load a standard profile into my model, but although I am
being able to get the resource (resourceSet.getResource) I can not get the
profile out of it (EcoreUtil.getObjectByType); it returns null.
Since the profile I am reading was created using UML 2.0, I believe the
migration rules don't apply, am I right ? Assuming the previous assertion
is true, the code to read the profile should be similiar to the one in the
document "Introduction to UML2 Profiles", which is my case. My code is:
URI uri =
URI.createURI(" file:/C:\\UML_Profile_for_Schedulabilty,_Performance_and_Tim e_Specification.profile.uml ");
Resource res = RESOURCE_SET.getResource(uri, true);
prof=(org.eclipse.uml2.uml.Profile) EcoreUtil.getObjectByType(
res.getContents(), UMLPackage.Literals.PACKAGE);
The profile that I am trying to read is Standard Profile for
Schedulability, Performance and Time Specification and it was created by
OMG.
Any ideas ?
-Flávio
Re: Loading a Profile [message #476952 is a reply to message #476951] Mon, 18 February 2008 15:39 Go to previous messageGo to next message
If your profile was created using UML 2.0, then I assume it should be a
..uml2 model file for Eclipse UML2 (not .uml file). I encountered this
before, needing to migrate a .uml2 profile. Try opening your .uml2 profile
using the UML2 project sample editor -- it will automatically migrate to
..uml then save the .uml file. Now use the migratied .uml profile in your
application.
Dave Carlson
"Flavio Duarte" <flavio.p.duarte@gmail.com> wrote in message
news:97e76723b0c70ed46412e3e366d883e1$1@www.eclipse.org...
> URI uri =
> OMG.
> Any ideas ?
> -Fl
Re: Loading a Profile [message #476959 is a reply to message #476952] Wed, 20 February 2008 16:49 Go to previous messageGo to next message
Dave Carlson,
It seems that your hack worked but I still have two questions:
1 - Is there a way to do it programmatically ?
2 - How did you discovered it ?
thanks,
Flávio
Re: Loading a Profile [message #476961 is a reply to message #476959] Wed, 20 February 2008 18:31 Go to previous message
Hi Fl
Re: Loading a Profile [message #626051 is a reply to message #476951] Mon, 18 February 2008 15:39 Go to previous message
application.
Dave Carlson
> URI uri =
> OMG.
> Any ideas ?
> -Fl
Re: Loading a Profile [message #626058 is a reply to message #476952] Wed, 20 February 2008 16:49 Go to previous message
Dave Carlson,
thanks,
Flávio
Re: Loading a Profile [message #626060 is a reply to message #476959] Wed, 20 February 2008 18:31 Go to previous message
Hi Fl
Previous Topic:stereotypes with MagicDraw
Next Topic:[Announce] MDT UML2 2.2.0 I200802201750 is available
Current Time: Sun Jul 20 03:27:08 EDT 2025
Powered by FUDForum. Page generated in 0.04765 seconds
