xhtml markup in Comment body [message #476735] |
Tue, 11 December 2007 13:55  |
I need to find a way to include "rich text" in UML comment body using xhtml
markup tags. Only a limited set of tags will be used most of the time
(e.g., <p> <b> <i> <ul> and maybe <table>). Any suggestions on how to make
this work using EMF resources?
Is there a way to load and save UML resources, leaving the xhtml markup as
DOM elements? Or is it necessary to create an EMF model for xhtml, so that
UML comments will include a reference to a second xhtml model EObjects? Is
this even allowed by the UML metamodel?
I found this w3c work on creating XSD for xhtml. Has anyone attempted an
EMF model from these schemas?
Thanks for any advice,
Dave Carlson
Re: xhtml markup in Comment body [message #476736 is a reply to message #476735] |
Tue, 11 December 2007 14:01   |
--------------020506030108010103080309
Dave,
I think you could do it using demand created metadata and embed that
data as an instance of AnyType within the contents feature of an
EAnnotation.
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
UMLResourceFactoryImpl already uses the extended metadata option so I
think it should just work.
> Dave Carlson
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Dave,<br>
<br>
EAnnotation.<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
</blockquote>
think it should just work.<br>
<br>
<br>
Dave Carlson wrote:
<blockquote cite="mid:fjmmev$jjt$1@build.eclipse.org" type="cite">
<pre wrap="">I need to find a way to include "rich text" in UML comment body using xhtml
Dave Carlson
</pre>
</blockquote>
<br>
</body>
</html>
--------------020506030108010103080309--
Re: xhtml markup in Comment body [message #476737 is a reply to message #476736] |
Tue, 11 December 2007 14:36  |
------=_NextPart_000_0010_01C83BF2.7B41BF90
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Excellent, thanks Ed. I'll test this within the next day or two and let =
you know how it works.
Dave
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fjmmr7$mmk$1@build.eclipse.org...
Dave,
I think you could do it using demand created metadata and embed that =
data as an instance of AnyType within the contents feature of an =
EAnnotation.
Binding XML to Java
UMLResourceFactoryImpl already uses the extended metadata option so I =
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16544" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Excellent, thanks Ed. I'll test =
this within=20
the next day or two and let you know how it works.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Dave</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fjmmr7$mmk$1@build.eclipse.org">news:fjmmr7$mmk$1@build.ecli=
pse.org</A>...</DIV>Dave,<BR><BR>I=20
data as an=20
instance of AnyType within the contents feature of an EAnnotation.<BR>
<BLOCKQUOTE><A=20
href=3D" http://www.theserverside.com/tt/articles/article.tss?l=3DBin dingX=
MLJava"=20
target=3D_out>Binding XML to =
Java</A><BR></BLOCKQUOTE>UMLResourceFactoryImpl=20
already uses the extended metadata option so I think it should just=20
work.<BR><BR><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0010_01C83BF2.7B41BF90--
Re: xhtml markup in Comment body [message #625709 is a reply to message #476735] |
Dave,
EAnnotation.
Binding XML to Java
> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
EAnnotation.<br>
XML to Java</a><br>
</blockquote>
<br>
<br>
Dave Carlson
</pre>
</blockquote>
<br>
</body>
</html>
Re: xhtml markup in Comment body [message #625710 is a reply to message #476736] |
Dave
Dave,
EAnnotation.
Binding XML to Java
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
this within=20
<BLOCKQUOTE=20
data as an=20
<BLOCKQUOTE><A=20
MLJava"=20
FUDForum. Page generated in 0.05855 seconds
