Home » Modeling » UML2 » EPackage to Profile mapping
EPackage to Profile mapping [message #476429] Thu, 25 October 2007 11:10 Go to next message
The static profile definition capability relies on a mapping of EPackage
namespace URIs to URIs locating the corresponding UML Profiles (populated
in Eclipse environment from an extension point).
Why was it necessary to introduce this registry? It would seem, at first
blush, that EMF's support for registration of genmodels would cover this
need by mapping the EPackage to the GenModel, then getting the foreign
model from that.
I am particularly interested because, in OCL, I need to be able to map
EPackages not only to Profiles but to any UML package in order to find the
UML metamodel from which the Java classes describing run-time objects were
generated. Perhaps this mapping needs to be extended to metamodels as well
as profiles?
Christian
Re: EPackage to Profile mapping [message #476432 is a reply to message #476429] Fri, 26 October 2007 09:42 Go to previous messageGo to next message
Hi Christian,
The very first attempt at implementing this did involve attempting to use
the foreign model but a dedicated extension point was deemed a better choice
for several reasons:
1. A generator model is a development time artifact that need not be
deployed with the profile.
2. As a performance concern, parsing the generator model just to get back
the .uml model which may be one of several foreign models seemed like a lot
of overhead.
For the above mentioned reasons, an extension point dedicated to profiles
seemed like a more robust alternative.
- James.
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:ffqbkh$9k$1@build.eclipse.org...
> model from that.
> well
> as profiles?
> Christian
Re: EPackage to Profile mapping [message #476436 is a reply to message #476432] Fri, 26 October 2007 13:09 Go to previous messageGo to next message
Hi, James,
Thanks, that makes sense.
Any sense on the idea of extending this function to all generated Packages?
cW
James Bruck wrote:
> Hi Christian,
> choice for several reasons:
> lot of overhead.
> Cheers,
> - James.
>> Hi,
>> model from that.
>> the UML metamodel from which the Java classes describing run-time objects
>> were
>> well
>> as profiles?
>> Thanks,
>> Christian
Re: EPackage to Profile mapping [message #476438 is a reply to message #476436] Sat, 27 October 2007 20:29 Go to previous messageGo to next message
Hi Christian,
The mapping could be extended. I'll make the long trek over to your
cubicle so we can discuss the details ;)
- James.
news:fft70e$lmn$1@build.eclipse.org...
> Hi, James,
> Packages?
> cW
> James Bruck wrote:
>> Hi Christian,
>> lot of overhead.
>> Cheers,
>> - James.
>>> Hi,
>>> (populated
>>> first
>>> model from that.
>>> objects
>>> were
>>> well
>>> as profiles?
>>> Thanks,
>>> Christian
Re: EPackage to Profile mapping [message #476843 is a reply to message #476438] Thu, 10 January 2008 11:17 Go to previous messageGo to next message
James,
Any update on the in-cubicle discussion? Was a decision made to make any
changes here? Note that EMF has added support for registering dynamic
packages (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=145239)...
should consider a similar registry for dynamic profiles? Doing so might
obliviate the need for a profile registry, i.e. it would provide a discovery
mechanism for "known" profiles...
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fg0l61$p0k$1@build.eclipse.org...
> Hi Christian,
> Cheers,
> - James.
>> Hi, James,
>> Packages?
>> cW
>> James Bruck wrote:
>>> Hi Christian,
>>> use
>>> back
>>> lot of overhead.
>>> profiles
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> EPackage
>>>> (populated
>>>> first
>>>> this
>>>> model from that.
>>>> objects
>>>> were
>>>> well
>>>> as profiles?
>>>> Thanks,
>>>> Christian
Re: EPackage to Profile mapping [message #476844 is a reply to message #476843] Fri, 11 January 2008 13:37 Go to previous message
Hi Kenn,
Yes absolutely, UML could use a similar registry to provide a list of all
"known" profiles.
Thanks for pointing it out. I will raise a bugzilla on UML to address
this.
- James.
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
news:fm5gds$prk$1@build.eclipse.org...
> James,
> discovery mechanism for "known" profiles...
> Kenn
>> Hi Christian,
>> Cheers,
>> - James.
>>> Hi, James,
>>> Packages?
>>> cW
>>> James Bruck wrote:
>>>> Hi Christian,
>>>> use
>>>> back
>>>> lot of overhead.
>>>> profiles
>>>> Cheers,
>>>> - James.
>>>>> Hi,
>>>>> EPackage
>>>>> (populated
>>>>> first
>>>>> this
>>>>> model from that.
>>>>> objects
>>>>> were
>>>>> well
>>>>> as profiles?
>>>>> Thanks,
>>>>> Christian
Re: EPackage to Profile mapping [message #625335 is a reply to message #476429] Fri, 26 October 2007 09:42 Go to previous message
Hi Christian,
of overhead.
- James.
> model from that.
> well
> as profiles?
> Christian
Re: EPackage to Profile mapping [message #625339 is a reply to message #476432] Fri, 26 October 2007 13:09 Go to previous message
Hi, James,
cW
James Bruck wrote:
> Hi Christian,
> lot of overhead.
> Cheers,
> - James.
>> Hi,
>> model from that.
>> were
>> well
>> as profiles?
>> Thanks,
>> Christian
Re: EPackage to Profile mapping [message #625341 is a reply to message #476436] Sat, 27 October 2007 20:29 Go to previous message
Hi Christian,
- James.
> Hi, James,
> Packages?
> cW
> James Bruck wrote:
>> Hi Christian,
>> lot of overhead.
>> Cheers,
>> - James.
>>> Hi,
>>> (populated
>>> first
>>> model from that.
>>> objects
>>> were
>>> well
>>> as profiles?
>>> Thanks,
>>> Christian
Re: EPackage to Profile mapping [message #625891 is a reply to message #476438] Thu, 10 January 2008 11:17 Go to previous message
James,
Kenn
> Hi Christian,
> Cheers,
> - James.
>> Hi, James,
>> Packages?
>> cW
>> James Bruck wrote:
>>> Hi Christian,
>>> use
>>> back
>>> lot of overhead.
>>> profiles
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> EPackage
>>>> (populated
>>>> first
>>>> this
>>>> model from that.
>>>> objects
>>>> were
>>>> well
>>>> as profiles?
>>>> Thanks,
>>>> Christian
Re: EPackage to Profile mapping [message #625892 is a reply to message #476843] Fri, 11 January 2008 13:37 Go to previous message
Hi Kenn,
"known" profiles.
this.
- James.
> James,
> Kenn
>> Hi Christian,
>> Cheers,
>> - James.
>>> Hi, James,
>>> Packages?
>>> cW
>>> James Bruck wrote:
>>>> Hi Christian,
>>>> use
>>>> back
>>>> lot of overhead.
>>>> profiles
>>>> Cheers,
>>>> - James.
>>>>> Hi,
>>>>> EPackage
>>>>> (populated
>>>>> first
>>>>> this
>>>>> model from that.
>>>>> objects
>>>>> were
>>>>> well
>>>>> as profiles?
>>>>> Thanks,
>>>>> Christian
Previous Topic:stereotype application to an Operation
Next Topic:Primitive Type reuse
Current Time: Sat Jul 19 11:49:00 EDT 2025
Powered by FUDForum. Page generated in 0.06795 seconds
