Re: Stereotype creation [message #476226] |
Thu, 27 September 2007 09:41  |
Elguenbri,
I'll redirect you to the UML2 newsgroup, which I've added to the "to"
list of the reply, so you don't need to repost.
elguenbri foued wrote:
> hi
> i have create an UML profile to BPMN and im trying to integrate it into a activity diagam.
> i have made stereotype for each UML component, some stereotype have property witch type is Enumeration but when i tryed to apply this stereotype to UML component i had an exception
> java.lang.IllegalArgumentException: Trigger
> Trigger is the stereotype's property to witch i want to set a value choosed from a set of value.
> this is the methode:
> element.setValue( stereotype, property, ownedLiteral );
> the exception is in the property variable. Are they some constrainte on this field???
> some one can help me please
> thanks
Re: Stereotype creation [message #476257 is a reply to message #476255] |
Wed, 03 October 2007 10:44  |
The types of objects you can pass to Element#setValue() include lists of
items. So if your property on your stereotype boild down to an
eStructuralFeature with isMany() == true, then you can pass something of
type List to setValue().
Also, if your property is an enumeration, then you can pass an
EnumerationLiteral as the parameter to setValue(), or a String and an
attempt will be made to create the corresponding data type instance from the
specified string.
If something is going wrong because of how your stereotype is defined or how
data is passed then you need to set a breakpoint on
ElementOperations#setValue().
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fe05fh$c23$4@build.eclipse.org...
> If you don't reply with the UML2 newsgroup on the "to" list they will
> not see your question and you won't get an answer.
> In general, you'd get a list value if the upper bound of the attribute
> is > 1...
> > forget that :)
> > how can i create an attribute to a stereotype with a list of values??
> > so that a user can chose one of them!!!
> > thanks
Re: Stereotype creation [message #625066 is a reply to message #476226] |
Tue, 02 October 2007 20:51  |
There could be many reasons for such an error. Is it possible that the
property name is not set ( the second parameter ), or the stereotype is not
applied properly?
Do you have a more detailed stack trace with a line number perhaps?
- James.
news:fdgbuq$76p$2@build.eclipse.org...
> Elguenbri,
> I'll redirect you to the UML2 newsgroup, which I've added to the "to" list
>> hi
>> activity diagam.
>> this field???
>> thanks
Re: Stereotype creation [message #625067 is a reply to message #476254] |
Wed, 03 October 2007 09:29  |
is > 1...
> forget that :)
> thanks
Re: Stereotype creation [message #625069 is a reply to message #476255] |
specified string.
- James.
> is > 1...
> > forget that :)
> > thanks
FUDForum. Page generated in 0.03944 seconds
