Home » Modeling » UML2 » Re: errors while metamodeling
Re: errors while metamodeling [message #475249] |
Tue, 28 August 2007 08:32  |
Ed,
It is not clear for me. Could you illustrate it for me?
Manar,
Ed Merks wrote:
> --------------060109010005040605060000
> Content-Type: text/html; charset=ISO-8859-1
> Content-Transfer-Encoding: 7bit
> <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
> <html>
> <head>
> <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
> </head>
> <body bgcolor="#ffffff" text="#000000">
> Manar,<br>
> <br>
> I see. The build.properties doesn't include them in the binary
plugin,
> so I suppose the way you did it is the only way<br>
> <blockquote>bin.includes = about.html,\<br>
plugin.*,\<br>
..,\<br>
model/*.ecore,\<br>
model/*.ecore2xml,\<br>
model/*.genmodel,\<br>
META-INF/<br>
> src.includes = about.html,\<br>
model/*.ecore2ecore,\<br>
<b>
model/*.uml,\</b><br>
templates/<br>
> exclude.. = **/doc-files/**<br>
> javacSource = 1.5<br>
> javacTarget = 1.5<br>
> </blockquote>
> I get those same warnings when I validate the instance I have directly
> from CVS, so I suppose those warnings are something to ignore.<br>
> <br>
> That still leaves your other questions unanswered, so someone with UML2
> expertise will need to answer those. Definitely change your "\"
to "/"
> though or you're likely to have problems.<br>
> <br>
> <br>
> Manar El-Kady wrote:
> <blockquote cite="mid:fac69v$dcj$1@build.eclipse.org" type="cite"><br>
> Ed Merks wrote:
> <br>
> <blockquote type="cite">Manar,
> <br>
> <br>
> Comments below.
> <br>
> <br>
> <br>
> <br>
> <blockquote type="cite">Hi,
> <br>
> <br>
> I build a metamodel as a heavyweight extension.I do the following
> steps:
> <br>
> - create an empty UML model
> <br>
> - convert the model to a metamodel
> <br>
> - apply the ecore profile, and then apply the epackage stereotype to
> the
> <br>
> root model element
> <br>
> - add some elements for the metamodel
> <br>
> - merge the primitive types package
> <br>
> - add the infrastructure.uml as a resource to my metamodel (Note: I
> added it by using the editor. I added it from a project in my workspace
> that containing
platform:/resource/org.eclipse.uml2.source\src\org.eclipse.u ml2.uml_2.1.0.v200706141134\model\Infrastructure.uml)
> <br>
> </blockquote>
> I think you should have loaded it using
> <br>
> <br>
platform:/plugin/org.eclipse.uml2.uml/model/Infrastructure.u ml
> <br>
> <br>
> </blockquote>
> <br>
> I did it but an error file not found raised
> <br>
> <br>
> I tried to add "/" after "platform:/" and the error
> " platform:/plugin/org.eclipse.uml2.uml/model/Infrastructure.u ml " showed
> <br>
> <br>
> I tried to add the name of the jar file that exist in my plugin folder
" platform:/plugin/org.eclipse.uml2.uml_2.1.0.v200706141134/mo del/Infrastructure.uml ",
> then a file not found error raised??
> <br>
> <br>
> <br>
> <blockquote type="cite">Don't ever use "\" in a URI since it's
> treated as just an ordinary character like "_" not like "/".
> <br>
> <blockquote type="cite">- While creating the elements of the
> metamodels I extended classes from the subpackages of the Abstractions
> package. So, I imported the packages that containing the classes which
> I extend.
> <br>
> - finally I apply the package merge, and convert it again to a
> metamodel.
> <br>
> <br>
> My questions are:
> <br>
> - After these steps I did a validation, and an error occur " Not all
> the members of a namespace'<<metamodel, ePackage>>
> <Model> MAS-UML' are distinguishable within it." ??
> <br>
> </blockquote>
> I'm not sure, but it sounds like you have multiple versions of the same
> model, which could be caused by the problem above where you load the
> model with one URI, there are other references to this model using a
> different URI.
> <br>
> <blockquote type="cite"><br>
> - I tried to do these steps without doing package import and I didn't
> notice any difference or errors happened. so, what is the need for
> doing a package import in a metamodeling?
> <br>
> <br>
> - After creating the metamodel I create an EMF project for code
> generation. Here, I obligated to generate code for the
> infrastructureLibrary package, which I didn't need. Why that?
> <br>
> </blockquote>
> In the final step of the wizard, you need to specify a GenModel for any
> packages that already exist and you don't want to generate yourself but
> rather want to reuse an existing generated model.
> <br>
> - After the code generation, there are some errors in the generated
> code for the infrastructureLibrary package and for my metamodel code.
> all the errors in the impl files and said that xxx cannot be resolved??
> <br>
> </blockquote>
> I'm sure you'll need to specify a dependency on the UML2 model in the
> final step of the wizard if you are trying to extend that
model. Note
> that once the plugin.xml and MANIFEST.MF exist, they won't be
> regenerated unless you delete them, so even fixing the problems above
> won't fix these files unless you delete them before you generate.
> <br>
> <br>
> Sorry for this long mail, and thanks in advance.
> <br>
> <br>
> Manar
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> </blockquote>
> </blockquote>
> </blockquote>
> <br>
> </body>
> </html>
> --------------060109010005040605060000--
Re: errors while metamodeling [message #475252 is a reply to message #475249] |
Tue, 28 August 2007 08:41   |
Manar,
What is "it"? Hasn't Kenn answered your remaining questions? I'm not a
UML2 expert by any means so it's unlikely I can answer detailed
questions about it. What specifically is still causing a problem?
> Ed,
> Manar,
> > <html>
> > <head>
> > </head>
> > Manar,<br>
> > <br>
> plugin,
> plugin.*,\<br>
> .,\<br>
> model/*.ecore,\<br>
> META-INF/<br>
> <b>
> templates/<br>
> > </blockquote>
> > <br>
> "\" to "/"
> > <br>
> > <br>
> > Ed Merks wrote:
> > <br>
> > <br>
> > <br>
> > Comments below.
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > steps:
> > <br>
> > <br>
> > <br>
> > the
> > <br>
> > root model element
> > <br>
> > <br>
> > <br>
> > that containing
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > I extend.
> > <br>
> > metamodel.
> > <br>
> > <br>
> > My questions are:
> > <br>
> > <br>
> > </blockquote>
> > different URI.
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > </blockquote>
> model. Note
> > <br>
> > <br>
> > <br>
> > <br>
> > Manar
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > </blockquote>
> > </blockquote>
> > <br>
> > </body>
> > </html>
Re: errors while metamodeling [message #475254 is a reply to message #475252] |
Tue, 28 August 2007 09:52   |
I mean what is mentioned about the build.properties file.
thanks,
Manar,
Ed Merks wrote:
> Manar,
>> Ed,
>> Manar,
>> > <html>
>> > <head>
>> > </head>
>> > Manar,<br>
>> > <br>
>> plugin,
>> plugin.*,\<br>
>> .,\<br>
>> model/*.ecore,\<br>
>> META-INF/<br>
>> <b>
>> templates/<br>
>> > </blockquote>
>> > <br>
>> "\" to "/"
>> > <br>
>> > <br>
>> > Ed Merks wrote:
>> > <br>
>> > <br>
>> > <br>
>> > Comments below.
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > steps:
>> > <br>
>> > <br>
>> > <br>
>> > the
>> > <br>
>> > root model element
>> > <br>
>> > <br>
>> > <br>
>> > that containing
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > I extend.
>> > <br>
>> > metamodel.
>> > <br>
>> > <br>
>> > My questions are:
>> > <br>
>> > <br>
>> > </blockquote>
>> > different URI.
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > </blockquote>
>> model. Note
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > Manar
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > </blockquote>
>> > </blockquote>
>> > <br>
>> > </body>
>> > </html>
Re: errors while metamodeling [message #475262 is a reply to message #475254] |
Tue, 28 August 2007 13:30   |
Manar,
That's just a comment about what artifacts that appear in the plugin
during development end up being copied into the deployed plugin when
it's shipped as a jarred binary result. The .genmodel and .ecore models
are included but the .uml ones are not. This doesn't help you at all
with your problem though, other than make clear you need to find these
in the source plugin rather than in the binary plugin as I assumed would
be the case.
> thanks,
> Manar,
> Ed Merks wrote:
>> Manar,
>> not a UML2 expert by any means so it's unlikely I can answer detailed
>>> Ed,
>>> Manar,
>>> > <html>
>>> > <head>
>>> > </head>
>>> > Manar,<br>
>>> > <br>
>>> binary plugin,
>>> plugin.*,\<br>
>>> .,\<br>
>>> model/*.ecore,\<br>
>>> META-INF/<br>
>>> <b>
>>> templates/<br>
>>> > </blockquote>
>>> directly
>>> > <br>
>>> UML2
>>> "\" to "/"
>>> > <br>
>>> > <br>
>>> type="cite"><br>
>>> > Ed Merks wrote:
>>> > <br>
>>> > <br>
>>> > <br>
>>> > Comments below.
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > steps:
>>> > <br>
>>> > <br>
>>> > <br>
>>> > the
>>> > <br>
>>> > root model element
>>> > <br>
>>> > <br>
>>> > <br>
>>> workspace
>>> > that containing
>>> > <br>
>>> > </blockquote>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> > <br>
>>> > <br>
>>> > <br>
>>> showed
>>> > <br>
>>> > <br>
>>> folder
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> Abstractions
>>> which
>>> > I extend.
>>> > <br>
>>> > metamodel.
>>> > <br>
>>> > <br>
>>> > My questions are:
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> same
>>> > different URI.
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> for any
>>> yourself but
>>> > <br>
>>> resolved??
>>> > <br>
>>> > </blockquote>
>>> model. Note
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > Manar
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> > </blockquote>
>>> > </blockquote>
>>> > <br>
>>> > </body>
>>> > </html>
Re: errors while metamodeling [message #475263 is a reply to message #475262] |
Tue, 28 August 2007 18:58   |
These artifacts aren't part of the binary plug-in because they are
development-time (only) resources, and clients aren't expected to make
direct references to them... There's no problem with someone building a
heavyweight extension based on these models, but since UML2 does not provide
an implementation for each of them, they either have to be factored (merged)
out or implemented from scratch.
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fb1m43$lb6$2@build.eclipse.org...
> Manar,
> during development end up being copied into the deployed plugin when it's
> shipped as a jarred binary result. The .genmodel and .ecore models are
> included but the .uml ones are not. This doesn't help you at all with
> your problem though, other than make clear you need to find these in the
> source plugin rather than in the binary plugin as I assumed would be the
> case.
>> thanks,
>> Manar,
>> Ed Merks wrote:
>>> Manar,
>>>> Ed,
>>>> Manar,
>>>> > <html>
>>>> > <head>
>>>> > </head>
>>>> > Manar,<br>
>>>> > <br>
>>>> binary plugin,
>>>> plugin.*,\<br>
>>>> .,\<br>
>>>> model/*.ecore,\<br>
>>>> META-INF/<br>
>>>> <b>
>>>> templates/<br>
>>>> > </blockquote>
>>>> directly
>>>> > <br>
>>>> UML2
>>>> "\" to "/"
>>>> > <br>
>>>> > <br>
>>>> type="cite"><br>
>>>> > Ed Merks wrote:
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > Comments below.
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > steps:
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > the
>>>> > <br>
>>>> > root model element
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> workspace
>>>> > that containing
>>>> > <br>
>>>> > </blockquote>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> showed
>>>> > <br>
>>>> > <br>
>>>> folder
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> Abstractions
>>>> which
>>>> > I extend.
>>>> > <br>
>>>> > metamodel.
>>>> > <br>
>>>> > <br>
>>>> > My questions are:
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> same
>>>> > different URI.
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> for any
>>>> yourself but
>>>> > <br>
>>>> resolved??
>>>> > <br>
>>>> > </blockquote>
>>>> model. Note
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > Manar
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> > </blockquote>
>>>> > </blockquote>
>>>> > <br>
>>>> > </body>
>>>> > </html>
Re: errors while metamodeling [message #475350 is a reply to message #475263] |
Tue, 28 August 2007 19:37   |
--------------020105060601000501060504
Kenn,
I see. That makes perfect sense. Either clients do the same merging
you've done to arrive at an extension of the UML implementation you have
provided or they generate all the things they need that aren't provide
by UML directly because you've merged those concepts away.
> Kenn
>> Manar,
>> case.
>>> thanks,
>>> Manar,
>>> Ed Merks wrote:
>>>> Manar,
>>>>> Ed,
>>>>> Manar,
>>>>>> <html>
>>>>>> <head>
>>>>>> </head>
>>>>>> Manar,<br>
>>>>>> <br>
>>>>> binary plugin,
>>>>> plugin.*,\<br>
>>>>> .,\<br>
>>>>> model/*.ecore,\<br>
>>>>> META-INF/<br>
>>>>> <b>
>>>>> templates/<br>
>>>>>> </blockquote>
>>>>> directly
>>>>>> <br>
>>>>> UML2
>>>>> "\" to "/"
>>>>>> <br>
>>>>>> <br>
>>>>> type="cite"><br>
>>>>>> Ed Merks wrote:
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> Comments below.
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> steps:
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> the
>>>>>> <br>
>>>>>> root model element
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> workspace
>>>>>> that containing
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> showed
>>>>>> <br>
>>>>>> <br>
>>>>> folder
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> Abstractions
>>>>> which
>>>>>> I extend.
>>>>>> <br>
>>>>>> metamodel.
>>>>>> <br>
>>>>>> <br>
>>>>>> My questions are:
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>> same
>>>>>> different URI.
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>> for any
>>>>> yourself but
>>>>>> <br>
>>>>> resolved??
>>>>>> <br>
>>>>>> </blockquote>
>>>>> model. Note
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> Manar
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> </body>
>>>>>> </html>
<html>
<head>
</head>
Kenn,<br>
<br>
have provided or they generate all the things they need that aren't
provide by UML directly because you've merged those concepts away.<br>
<br>
<br>
Kenn Hussey wrote:
<blockquote cite="mid:fb29af$2fj$1@build.eclipse.org" type="cite">
<pre wrap="">These artifacts aren't part of the binary plug-in because they are
Kenn
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fb1m43$lb6$2@build.eclipse.org">news:fb1m43$lb6$2@build.eclipse.org</a>...
</pre>
<pre wrap="">Manar,
case.
</pre>
<pre wrap="">I mean what is mentioned about the build.properties file.
thanks,
Manar,
Ed Merks wrote:
</pre>
<pre wrap="">Manar,
</pre>
<pre wrap="">Ed,
Manar,
Ed Merks wrote:
</pre>
<pre wrap="">--------------060109010005040605060000
<html>
<head>
</pre>
</blockquote>
<pre wrap="">http-equiv="Content-Type">
</pre>
<pre wrap=""></head>
Manar,<br>
<br>
I see.&nbsp; The build.properties doesn't include them in the
</pre>
</blockquote>
<pre wrap="">binary plugin,
</pre>
<pre wrap="">so I suppose the way you did it is the only way<br>
</pre>
</blockquote>
<pre wrap=""> &nbsp;&nbsp;&nbsp;&nbsp;& ;amp;nbsp;&nbsp;&nbsp;&nbsp;& ;nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;
plugin.*,\<br>
</pre>
..,\<br>
</pre>
model/*.ecore,\<br>
</pre>
</pre>
</pre>
META-INF/<br>
</pre>
<pre wrap="">src.includes = about.html,\<br>
</pre>
</blockquote>
</pre>
<pre wrap=""> <b>&nbsp;&nbsp;&nbsp;& amp;amp;nbsp;&nbsp;&nbsp;&nbsp;& amp;nbsp;&nbsp;&nbsp;&nbsp;& nbsp;&nbsp;&nbsp;
</pre>
templates/<br>
</pre>
<pre wrap="">exclude.. = **/doc-files/**<br>
</blockquote>
</pre>
</blockquote>
<pre wrap="">directly
</pre>
<pre wrap="">from CVS, so I suppose those warnings are something to ignore.<br>
<br>
</pre>
</blockquote>
<pre wrap="">UML2
</pre>
<pre wrap="">expertise will need to answer those.&nbsp; Definitely change your
</pre>
</blockquote>
<pre wrap="">"\" to "/"
</pre>
<pre wrap="">though or you're likely to have problems.<br>
<br>
<br>
<blockquote cite=<a class="moz-txt-link-rfc2396E" href="mailto:mid:fac69v$dcj$1@build.eclipse.org">"mid:fac69v$dcj$1@build.eclipse.org"</a>
</pre>
</blockquote>
<pre wrap="">type="cite"><br>
</pre>
<pre wrap="">Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
</pre>
</blockquote>
<pre wrap="">workspace
</pre>
<pre wrap="">that containing
</pre>
</blockquote>
<pre wrap=""> platform:/resource/org.eclipse.uml2.source\src\org.eclipse.u ml2.uml_2.1.0.v200706141134\model\Infrastructure.uml)
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap=""> <br>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp;
</pre>
</blockquote>
<pre wrap=""> platform:/plugin/org.eclipse.uml2.uml/model/Infrastructure.u ml
</pre>
<pre wrap=""> <br>
<br>
</blockquote>
<br>
<br>
<br>
</pre>
</blockquote>
<pre wrap="">showed
</pre>
<pre wrap=""> <br>
<br>
</pre>
</blockquote>
<pre wrap="">folder
</pre>
<pre wrap="">" platform:/plugin/org.eclipse.uml2.uml_2.1.0.v200706141134/mo del/Infrastructure.uml ",
</pre>
<pre wrap="">then a file not found error raised??
<br>
<br>
<br>
<br>
</pre>
</blockquote>
<pre wrap="">Abstractions
</pre>
<pre wrap="">package. So, I imported the packages that containing the classes
</pre>
</blockquote>
<pre wrap="">which
</pre>
<pre wrap="">I extend.
<br>
metamodel.
<br>
<br>
My questions are:
<br>
the members of a namespace'&lt;&lt;metamodel, ePackage&gt;&gt;
&lt;Model&gt; MAS-UML' are distinguishable within it." ??
<br>
</blockquote>
</pre>
</blockquote>
<pre wrap="">same
</pre>
<pre wrap="">model, which could be caused by the problem above where you load the
different URI.
<br>
<br>
<br>
<br>
</blockquote>
</pre>
</blockquote>
<pre wrap="">for any
</pre>
<pre wrap="">packages that already exist and you don't want to generate
</pre>
</blockquote>
<pre wrap="">yourself but
</pre>
<pre wrap="">rather want to reuse an existing generated model.
<br>
</pre>
</blockquote>
<pre wrap="">resolved??
</pre>
<pre wrap=""> <br>
</blockquote>
</pre>
</blockquote>
<pre wrap="">model.&nbsp; Note
</pre>
<pre wrap="">that once the plugin.xml and MANIFEST.MF exist, they won't be
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; <br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020105060601000501060504--
Re: errors while metamodeling [message #475351 is a reply to message #475350] |
Tue, 28 August 2007 20:05   |
------=_NextPart_000_0157_01C7E9AE.D8875E80
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Exactly.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fb2bjh$gd5$1@build.eclipse.org...
Kenn,
I see. That makes perfect sense. Either clients do the same merging =
you've done to arrive at an extension of the UML implementation you have =
provided or they generate all the things they need that aren't provide =
Kenn Hussey wrote:=20
These artifacts aren't part of the binary plug-in because they are=20
development-time (only) resources, and clients aren't expected to make=20
direct references to them... There's no problem with someone building a=20
heavyweight extension based on these models, but since UML2 does not =
provide=20
an implementation for each of them, they either have to be factored =
(merged)=20
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Manar,
That's just a comment about what artifacts that appear in the plugin=20
during development end up being copied into the deployed plugin when =
it's=20
shipped as a jarred binary result. The .genmodel and .ecore models are=20
included but the .uml ones are not. This doesn't help you at all with=20
your problem though, other than make clear you need to find these in the =
source plugin rather than in the binary plugin as I assumed would be the =
case.
thanks,
Manar,
Ed Merks wrote:
Manar,
What is "it"? Hasn't Kenn answered your remaining questions? I'm not a =
UML2 expert by any means so it's unlikely I can answer detailed=20
Ed,
Manar,
Content-Type: text/html; charset=3DISO-8859-1
<html>
<head>
<meta content=3D"text/html;charset=3DISO-8859-1"
http-equiv=3D"Content-Type">
</head>
<body bgcolor=3D"#ffffff" text=3D"#000000">
Manar,<br>
<br>
binary plugin,
<blockquote>bin.includes =3D about.html,\<br>
nbsp; =20
plugin.*,\<br>
nbsp; =20
..,\<br>
nbsp; =20
model/*.ecore,\<br>
nbsp; =20
nbsp; =20
nbsp; =20
META-INF/<br>
src.includes =3D about.html,\<br>
nbsp; =20
<b> &nbs=
p; =20
nbsp; =20
templates/<br>
exclude.. =3D **/doc-files/**<br>
javacSource =3D 1.5<br>
javacTarget =3D 1.5<br>
</blockquote>
directly
from CVS, so I suppose those warnings are something to =
ignore.<br>
<br>
UML2
expertise will need to answer those. Definitely change =
your
"\" to "/"
<br>
<br>
<blockquote cite=3D"mid:fac69v$dcj$1@build.eclipse.org"
type=3D"cite"><br>
Ed Merks wrote:
<br>
<blockquote type=3D"cite">Manar,
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<blockquote type=3D"cite">Hi,
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
workspace
that containing
platform:/resource/org.eclipse.uml2.source\src\org.eclipse.u ml2.uml_2.1.0=
..v200706141134\model\Infrastructure.uml)
=20
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
showed
<br>
<br>
folder
" platform:/plugin/org.eclipse.uml2.uml_2.1.0.v200706141134/mo del/Infrastr=
ucture.uml",
<br>
<br>
<br>
<blockquote type=3D"cite">Don't ever use "\" in a URI since it's
<br>
<blockquote type=3D"cite">- While creating the elements of the
Abstractions
package. So, I imported the packages that containing the =
classes
which
I extend.
<br>
metamodel.
<br>
<br>
My questions are:
<br>
<br>
</blockquote>
same
model, which could be caused by the problem above where you =
load the
different URI.
<br>
<blockquote type=3D"cite"><br>
<br>
<br>
<br>
</blockquote>
for any
yourself but
<br>
resolved??
<br>
</blockquote>
model. Note
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------060109010005040605060000--=20
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16481" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Exactly.</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fb2bjh$gd5$1@build.eclipse.org">news:fb2bjh$gd5$1@build.ecli=
pse.org</A>...</DIV>Kenn,<BR><BR>I=20
see. That makes perfect sense. Either clients do the same =
merging=20
you've done to arrive at an extension of the UML implementation you =
have=20
by UML=20
directly because you've merged those concepts away.<BR><BR><BR>Kenn =
Hussey=20
wrote:=20
<BLOCKQUOTE cite=3Dmid:fb29af$2fj$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">These artifacts aren't part of the binary =
provide=20
(merged)=20
Kenn
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fb1m43$lb6$2@build.eclipse.org">news:fb1m43$lb6$2@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Manar,
it's=20
case.
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I mean what is mentioned =
thanks,
Manar,
Ed Merks wrote:
</PRE>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Ed,
Manar,
Ed Merks wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE =
wrap=3D"">--------------060109010005040605060000
<html>
<head>
</PRE></BLOCKQUOTE><PRE =
wrap=3D"">http-equiv=3D"Content-Type">
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D""></head>
Manar,<br>
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">binary plugin,
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">so I suppose the =
wrap=3D""> &nbsp;&nbsp;&nbsp;&nbsp;& ;amp;nbsp;&nbsp;&am=
p;nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;&n=
bsp;=20
plugin.*,\<br>
</PRE><PRE =
bsp;=20
..,\<br>
</PRE><PRE =
bsp;=20
model/*.ecore,\<br>
</PRE><PRE =
bsp;=20
</PRE><PRE =
bsp;=20
</PRE><PRE =
bsp;=20
META-INF/<br>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">src.includes =3D =
about.html,\<br>
bsp;=20
</PRE><PRE =
wrap=3D""> <b>&nbsp;&nbsp;&nbsp;& amp;amp;nbsp;&nbsp;&=
;nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;&nbsp;&nb=
sp;&nbsp;=20
</PRE><PRE =
bsp;=20
templates/<br>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">exclude.. =3D =
**/doc-files/**<br>
</blockquote>
</PRE></BLOCKQUOTE><PRE wrap=3D"">directly
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">from CVS, so I =
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">UML2
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">expertise will need =
</PRE></BLOCKQUOTE><PRE wrap=3D"">"\" to "/"
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">though or you're =
<br>
<br>
<blockquote cite=3D<A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:mid:fac69v$dcj$1@build.eclipse.org">"mid:fac69v$dcj$1@buil=
d.eclipse.org"</A>
wrap=3D"">type=3D"cite"><br>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">workspace
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">that containing
wrap=3D""> platform:/resource/org.eclipse.uml2.source\src\org.eclipse.u ml2=
..uml_2.1.0.v200706141134\model\Infrastructure.uml)
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D""> <br>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp;
wrap=3D""> platform:/plugin/org.eclipse.uml2.uml/model/Infrastructure.u ml
</PRE>
<br>
</blockquote>
<br>
<br>
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">showed
</PRE>
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">folder
</PRE><PRE =
wrap=3D"">" platform:/plugin/org.eclipse.uml2.uml_2.1.0.v200706141134/mo de=
l/Infrastructure.uml",
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">then a file not =
<br>
<br>
<br>
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">Abstractions
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">package. So, I =
</PRE></BLOCKQUOTE><PRE wrap=3D"">which
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I extend.
<br>
metamodel.
<br>
<br>
My questions are:
<br>
the members of a namespace'&lt;&lt;metamodel, =
ePackage&gt;&gt;
<br>
</blockquote>
</PRE></BLOCKQUOTE><PRE wrap=3D"">same
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">model, which could =
different URI.
<br>
<br>
<br>
<br>
</blockquote>
</PRE></BLOCKQUOTE><PRE wrap=3D"">for any
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">packages that =
</PRE></BLOCKQUOTE><PRE wrap=3D"">yourself but
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">rather want to =
<br>
</PRE></BLOCKQUOTE><PRE wrap=3D"">resolved??
</PRE>
</blockquote>
</PRE></BLOCKQUOTE><PRE wrap=3D"">model.&nbsp; Note
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">that once the =
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE><P=
RE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0157_01C7E9AE.D8875E80--
Re: errors while metamodeling [message #475353 is a reply to message #475351] |
Wed, 29 August 2007 06:59   |
I'd like to thank you for that illustration. But, I didn't get the
difference between these direction clear for me. Moreover, I am still
have a problem in what I am doing. I didn't know for which direction it
belongs.
Manar
Kenn Hussey wrote:
> Exactly.
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:fb2bjh$gd5$1@build.eclipse.org...
> Kenn,
> merging you've done to arrive at an extension of the UML
> implementation you have provided or they generate all the things
> they need that aren't provide by UML directly because you've merged
>> Kenn
>>> Manar,
>>> case.
>>>> thanks,
>>>> Manar,
>>>> Ed Merks wrote:
>>>>> Manar,
>>>>>> Ed,
>>>>>> Manar,
>>>>>>> <html>
>>>>>>> <head>
>>>>>>> </head>
>>>>>>> Manar,<br>
>>>>>>> <br>
>>>>>> binary plugin,
>>>>>> plugin.*,\<br>
>>>>>> ..,\<br>
>>>>>> model/*.ecore,\<br>
>>>>>> META-INF/<br>
>>>>>> <b>
>>>>>> templates/<br>
>>>>>>> </blockquote>
>>>>>> directly
>>>>>>> <br>
>>>>>> UML2
>>>>>> "\" to "/"
>>>>>>> <br>
>>>>>>> <br>
>>>>>> type="cite"><br>
>>>>>>> Ed Merks wrote:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> Comments below.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> steps:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> the
>>>>>>> <br>
>>>>>>> root model element
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> workspace
>>>>>>> that containing
>>>>>> platform:/resource/org.eclipse.uml2.source\src\org.eclipse.u ml2..uml_2.1.0.v200706141134\model\Infrastructure.uml)
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> showed
>>>>>>> <br>
>>>>>>> <br>
>>>>>> folder
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> Abstractions
>>>>>> which
>>>>>>> I extend.
>>>>>>> <br>
>>>>>>> metamodel.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> My questions are:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> same
>>>>>>> different URI.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> for any
>>>>>> yourself but
>>>>>>> <br>
>>>>>> resolved??
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> model. Note
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> Manar
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> </body>
>>>>>>> </html>
Re: errors while metamodeling [message #475357 is a reply to message #475353] |
Wed, 29 August 2007 07:12   |
I am doing a trial for building a metamodel that hasn't any merge
package, but just load a resource for the infrastructureLibrary package
as a file system from the UML source in the plugin older. The result has
two undesired things:
1- I obligated to generate code for all the subpackages in the
InfrastructureLibrary
2- the generated code has errors
Manar
> belongs.
> Manar
> Kenn Hussey wrote:
>> Exactly.
>> Kenn,
>>> are development-time (only) resources, and clients aren't
>>> expected to make direct references to them... There's no problem
>>> with someone building a heavyweight extension based on these
>>> models, but since UML2 does not provide an implementation for
>>> each of them, they either have to be factored (merged) out or
>>> Kenn
>>>> Manar,
>>>> plugin during development end up being copied into the deployed
>>>> plugin when it's shipped as a jarred binary result. The
>>>> .genmodel and .ecore models are included but the .uml ones are
>>>> not. This doesn't help you at all with your problem though,
>>>> other than make clear you need to find these in the source
>>>> case.
>>>>> thanks,
>>>>> Manar,
>>>>> Ed Merks wrote:
>>>>>> Manar,
>>>>>> I'm not a UML2 expert by any means so it's unlikely I can
>>>>>> answer detailed questions about it. What specifically is
>>>>>>> Ed,
>>>>>>> Manar,
>>>>>>>> <html>
>>>>>>>> <head>
>>>>>>>> </head>
>>>>>>>> Manar,<br>
>>>>>>>> <br>
>>>>>>> binary plugin,
>>>>>>> plugin.*,\<br>
>>>>>>> ..,\<br>
>>>>>>> model/*.ecore,\<br>
>>>>>>> META-INF/<br>
>>>>>>> <b>
>>>>>>> templates/<br>
>>>>>>>> </blockquote>
>>>>>>> directly
>>>>>>>> ignore.<br>
>>>>>>>> <br>
>>>>>>>> someone with
>>>>>>> UML2
>>>>>>>> your
>>>>>>> "\" to "/"
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> type="cite"><br>
>>>>>>>> Ed Merks wrote:
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> Comments below.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> following
>>>>>>>> steps:
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> stereotype to
>>>>>>>> the
>>>>>>>> <br>
>>>>>>>> root model element
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> (Note: I
>>>>>>> workspace
>>>>>>>> that containing
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> showed
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> folder
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> it's
>>>>>>>> <br>
>>>>>>>> the
>>>>>>> Abstractions
>>>>>>>> classes
>>>>>>> which
>>>>>>>> I extend.
>>>>>>>> <br>
>>>>>>>> metamodel.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> My questions are:
>>>>>>>> <br>
>>>>>>>> Not all
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> of the
>>>>>>> same
>>>>>>>> load the
>>>>>>>> using a
>>>>>>>> different URI.
>>>>>>>> <br>
>>>>>>>> I didn't
>>>>>>>> need for
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>> for any
>>>>>>> yourself but
>>>>>>>> <br>
>>>>>>>> generated
>>>>>>>> metamodel code.
>>>>>>> resolved??
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> model in the
>>>>>>> model. Note
>>>>>>>> problems above
>>>>>>>> generate.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> Manar
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> </blockquote>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> </body>
>>>>>>>> </html>
Re: errors while metamodeling [message #475362 is a reply to message #475357] |
Wed, 29 August 2007 20:25   |
Manar,
I hate to tread in territory where I'm ignorant, but if you want to
extend the UML2 implementation, which is based on a merge model of all
the various compliance points, you really need to be basing it on a
merged model, otherwise you will end up having to reimplement much of
what Kenn has worked very hard to implement correctly for UML2...
> package as a file system from the UML source in the plugin older. The
> result has two undesired things:
> Manar
>> it belongs.
>> Manar
>> Kenn Hussey wrote:
>>> Exactly.
>>> Kenn,
>>>> problem with someone building a heavyweight extension based on
>>>> these models, but since UML2 does not provide an implementation
>>>> for each of them, they either have to be factored (merged) out
>>>> Kenn
>>>>> Manar,
>>>>> deployed plugin when it's shipped as a jarred binary result.
>>>>> The .genmodel and .ecore models are included but the .uml ones
>>>>> are not. This doesn't help you at all with your problem
>>>>> be the case.
>>>>>> thanks,
>>>>>> Manar,
>>>>>> Ed Merks wrote:
>>>>>>> Manar,
>>>>>>> questions? I'm not a UML2 expert by any means so it's
>>>>>>> unlikely I can answer detailed questions about it. What
>>>>>>>> Ed,
>>>>>>>> Manar,
>>>>>>>>> Transitional//EN">
>>>>>>>>> <html>
>>>>>>>>> <head>
>>>>>>>>> </head>
>>>>>>>>> Manar,<br>
>>>>>>>>> <br>
>>>>>>>> binary plugin,
>>>>>>>> plugin.*,\<br>
>>>>>>>> ..,\<br>
>>>>>>>> model/*.ecore,\<br>
>>>>>>>> META-INF/<br>
>>>>>>>> <b>
>>>>>>>> templates/<br>
>>>>>>>>> </blockquote>
>>>>>>>> directly
>>>>>>>>> ignore.<br>
>>>>>>>>> <br>
>>>>>>>>> someone with
>>>>>>>> UML2
>>>>>>>>> change your
>>>>>>>> "\" to "/"
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>> type="cite"><br>
>>>>>>>>> Ed Merks wrote:
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> Comments below.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> following
>>>>>>>>> steps:
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> stereotype to
>>>>>>>>> the
>>>>>>>>> <br>
>>>>>>>>> root model element
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> (Note: I
>>>>>>>> workspace
>>>>>>>>> that containing
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>> showed
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> plugin
>>>>>>>> folder
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> since it's
>>>>>>>>> <br>
>>>>>>>>> of the
>>>>>>>> Abstractions
>>>>>>>>> classes
>>>>>>>> which
>>>>>>>>> I extend.
>>>>>>>>> <br>
>>>>>>>>> to a
>>>>>>>>> metamodel.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> My questions are:
>>>>>>>>> <br>
>>>>>>>>> " Not all
>>>>>>>>> ePackage>>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> versions of the
>>>>>>>> same
>>>>>>>>> you load the
>>>>>>>>> model using a
>>>>>>>>> different URI.
>>>>>>>>> <br>
>>>>>>>>> and I didn't
>>>>>>>>> need for
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> code
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> GenModel
>>>>>>>> for any
>>>>>>>> yourself but
>>>>>>>>> <br>
>>>>>>>>> generated
>>>>>>>>> metamodel code.
>>>>>>>> resolved??
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> model in the
>>>>>>>> model. Note
>>>>>>>>> problems above
>>>>>>>>> generate.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> Manar
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> </blockquote>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> </body>
>>>>>>>>> </html>
Re: errors while metamodeling [message #475374 is a reply to message #475362] |
Thu, 30 August 2007 10:07   |
Ed, you make a good point about reimplementing existing work.
The table at the end of this article goes over some of the pros/cons of
doing what Manar is attempting.
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Custo mizing_UML2_Which_Technique_is_Right_For_You/article.html
Manar, What errors are you getting in the generated code?
- James.
news:fb52pb$mg2$3@build.eclipse.org...
> Manar,
> > Manar
> >> it belongs.
> >> Manar
> >> Kenn Hussey wrote:
> >>> Exactly.
> >>> Kenn,
merged
> >>>> Kenn
> >>>>> Manar,
> >>>>> be the case.
> >>>>>> thanks,
> >>>>>> Manar,
> >>>>>> Ed Merks wrote:
> >>>>>>> Manar,
> >>>>>>>> Ed,
> >>>>>>>> Manar,
> >>>>>>>>> Transitional//EN">
> >>>>>>>>> <html>
> >>>>>>>>> <head>
> >>>>>>>>> </head>
> >>>>>>>>> Manar,<br>
> >>>>>>>>> <br>
the
> >>>>>>>> binary plugin,
&nbs
p;
> >>>>>>>> plugin.*,\<br>
&nbs
p;
> >>>>>>>> ..,\<br>
&nbs
p;
> >>>>>>>> model/*.ecore,\<br>
&nbs
p;
&nbs
p;
&nbs
p;
> >>>>>>>> META-INF/<br>
&nbs
p;
<b> &
nbsp;
&nbs
p;
> >>>>>>>> templates/<br>
> >>>>>>>>> </blockquote>
have
> >>>>>>>> directly
> >>>>>>>>> ignore.<br>
> >>>>>>>>> <br>
> >>>>>>>>> someone with
> >>>>>>>> UML2
> >>>>>>>>> change your
> >>>>>>>> "\" to "/"
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>> type="cite"><br>
> >>>>>>>>> Ed Merks wrote:
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> Comments below.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> following
> >>>>>>>>> steps:
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> stereotype to
> >>>>>>>>> the
> >>>>>>>>> <br>
> >>>>>>>>> root model element
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> (Note: I
my
> >>>>>>>> workspace
> >>>>>>>>> that containing
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>> showed
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> plugin
> >>>>>>>> folder
ure.uml",
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> since it's
> >>>>>>>>> <br>
> >>>>>>>>> of the
> >>>>>>>> Abstractions
> >>>>>>>>> classes
> >>>>>>>> which
> >>>>>>>>> I extend.
> >>>>>>>>> <br>
> >>>>>>>>> to a
> >>>>>>>>> metamodel.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> My questions are:
> >>>>>>>>> <br>
> >>>>>>>>> " Not all
> >>>>>>>>> ePackage>>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> versions of the
> >>>>>>>> same
> >>>>>>>>> you load the
> >>>>>>>>> model using a
> >>>>>>>>> different URI.
> >>>>>>>>> <br>
> >>>>>>>>> and I didn't
> >>>>>>>>> need for
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> code
that?
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> GenModel
> >>>>>>>> for any
> >>>>>>>> yourself but
> >>>>>>>>> <br>
> >>>>>>>>> generated
> >>>>>>>>> metamodel code.
> >>>>>>>> resolved??
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> model in the
> >>>>>>>> model. Note
be
> >>>>>>>>> problems above
> >>>>>>>>> generate.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> Manar
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> </blockquote>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> </body>
> >>>>>>>>> </html>
Re: errors while metamodeling [message #475377 is a reply to message #475374] |
Thu, 30 August 2007 10:52   |
James,
In the generated code I found errors in all the impl files states that a
xxx can't be resolved as a type, where xxx is changed from file to
another. This error raise in the generated code of the
InfrastructureLibrary package and my package. (Note: I didn't want to
generate code to the InfrastructureLibrary package)
thanks,
Manar,
> - James.
>> Manar,
>>> Manar
>>>> it belongs.
>>>> Manar
>>>> Kenn Hussey wrote:
>>>>> Exactly.
>>>>> Kenn,
> merged
>>>>>> Kenn
>>>>>>> Manar,
>>>>>>> be the case.
>>>>>>>> thanks,
>>>>>>>> Manar,
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Manar,
>>>>>>>>>> Ed,
>>>>>>>>>> Manar,
>>>>>>>>>>> Transitional//EN">
>>>>>>>>>>> <html>
>>>>>>>>>>> <head>
>>>>>>>>>>> </head>
>>>>>>>>>>> Manar,<br>
>>>>>>>>>>> <br>
> the
>>>>>>>>>> binary plugin,
> &nbs
> p;
>>>>>>>>>> plugin.*,\<br>
> &nbs
> p;
>>>>>>>>>> ..,\<br>
> &nbs
> p;
>>>>>>>>>> model/*.ecore,\<br>
> &nbs
> p;
> &nbs
> p;
> &nbs
> p;
>>>>>>>>>> META-INF/<br>
> &nbs
> p;
> <b> &
> nbsp;
> &nbs
> p;
>>>>>>>>>> templates/<br>
>>>>>>>>>>> </blockquote>
> have
>>>>>>>>>> directly
>>>>>>>>>>> ignore.<br>
>>>>>>>>>>> <br>
>>>>>>>>>>> someone with
>>>>>>>>>> UML2
>>>>>>>>>>> change your
>>>>>>>>>> "\" to "/"
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>> type="cite"><br>
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> Comments below.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> following
>>>>>>>>>>> steps:
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> stereotype to
>>>>>>>>>>> the
>>>>>>>>>>> <br>
>>>>>>>>>>> root model element
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> (Note: I
> my
>>>>>>>>>> workspace
>>>>>>>>>>> that containing
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>> showed
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> plugin
>>>>>>>>>> folder
> ure.uml",
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> since it's
>>>>>>>>>>> <br>
>>>>>>>>>>> of the
>>>>>>>>>> Abstractions
>>>>>>>>>>> classes
>>>>>>>>>> which
>>>>>>>>>>> I extend.
>>>>>>>>>>> <br>
>>>>>>>>>>> to a
>>>>>>>>>>> metamodel.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> My questions are:
>>>>>>>>>>> <br>
>>>>>>>>>>> " Not all
>>>>>>>>>>> ePackage>>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> versions of the
>>>>>>>>>> same
>>>>>>>>>>> you load the
>>>>>>>>>>> model using a
>>>>>>>>>>> different URI.
>>>>>>>>>>> <br>
>>>>>>>>>>> and I didn't
>>>>>>>>>>> need for
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> code
> that?
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> GenModel
>>>>>>>>>> for any
>>>>>>>>>> yourself but
>>>>>>>>>>> <br>
>>>>>>>>>>> generated
>>>>>>>>>>> metamodel code.
>>>>>>>>>> resolved??
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> model in the
>>>>>>>>>> model. Note
> be
>>>>>>>>>>> problems above
>>>>>>>>>>> generate.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> Manar
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> </body>
>>>>>>>>>>> </html>
Re: errors while metamodeling [message #475380 is a reply to message #475377] |
Thu, 30 August 2007 11:31  |
Manar,
James will probably be too nice to tell you this, but the sparse details
you are providing will never prompt a definitive or helpful answer. As
has been explained, UML generates from a merged Ecore model, not
separate models for each of the separate compliance points, so if you
don't produce a merged Ecore model that extends the UML merged Ecore
model, you are responsible for generating everything yourself. Keep in
mind that xxx doesn't provide much for James to go on, but it sounds
like you'd need to generate the model for xxx as well but haven't.
> James,
> a xxx can't be resolved as a type, where xxx is changed from file to
> thanks,
> Manar,
>> - James.
>>> Manar,
>>>> Manar
>>>>> it belongs.
>>>>> Manar
>>>>> Kenn Hussey wrote:
>>>>>> Exactly.
>>>>>> Kenn,
>> merged
>>>>>>> Kenn
>>>>>>>> Manar,
>>>>>>>> be the case.
>>>>>>>>> thanks,
>>>>>>>>> Manar,
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Manar,
>>>>>>>>>>> Ed,
>>>>>>>>>>> Manar,
>>>>>>>>>>>> Transitional//EN">
>>>>>>>>>>>> <html>
>>>>>>>>>>>> <head>
>>>>>>>>>>>> </head>
>>>>>>>>>>>> Manar,<br>
>>>>>>>>>>>> <br>
>> the
>>>>>>>>>>> binary plugin,
>> &nbs
>> p;
>>>>>>>>>>> plugin.*,\<br>
>> &nbs
>> p;
>>>>>>>>>>> ..,\<br>
>> &nbs
>> p;
>>>>>>>>>>> model/*.ecore,\<br>
>> &nbs
>> p;
>> &nbs
>> p;
>> &nbs
>> p;
>>>>>>>>>>> META-INF/<br>
>> &nbs
>> p;
>> <b> &
>> nbsp;
>> &nbs
>> p;
>>>>>>>>>>> templates/<br>
>>>>>>>>>>>> </blockquote>
>> have
>>>>>>>>>>> directly
>>>>>>>>>>>> ignore.<br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> someone with
>>>>>>>>>>> UML2
>>>>>>>>>>>> change your
>>>>>>>>>>> "\" to "/"
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>> type="cite"><br>
>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> Comments below.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> following
>>>>>>>>>>>> steps:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> stereotype to
>>>>>>>>>>>> the
>>>>>>>>>>>> <br>
>>>>>>>>>>>> root model element
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> (Note: I
>> my
>>>>>>>>>>> workspace
>>>>>>>>>>>> that containing
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>> showed
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> plugin
>>>>>>>>>>> folder
>> ure.uml",
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> since it's
>>>>>>>>>>>> <br>
>>>>>>>>>>>> of the
>>>>>>>>>>> Abstractions
>>>>>>>>>>>> classes
>>>>>>>>>>> which
>>>>>>>>>>>> I extend.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> to a
>>>>>>>>>>>> metamodel.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> My questions are:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> " Not all
>>>>>>>>>>>> ePackage>>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> versions of the
>>>>>>>>>>> same
>>>>>>>>>>>> you load the
>>>>>>>>>>>> model using a
>>>>>>>>>>>> different URI.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> and I didn't
>>>>>>>>>>>> need for
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> code
>> that?
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> GenModel
>>>>>>>>>>> for any
>>>>>>>>>>> yourself but
>>>>>>>>>>>> <br>
>>>>>>>>>>>> generated
>>>>>>>>>>>> metamodel code.
>>>>>>>>>>>> cannot be
>>>>>>>>>>> resolved??
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> model in the
>>>>>>>>>>> model. Note
>> be
>>>>>>>>>>>> problems above
>>>>>>>>>>>> generate.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> Manar
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </body>
>>>>>>>>>>>> </html>
Re: errors while metamodeling [message #624548 is a reply to message #475249] |
Manar,
> Ed,
> Manar,
> > <html>
> > <head>
> > </head>
> > Manar,<br>
> > <br>
> plugin,
> plugin.*,\<br>
> .,\<br>
> model/*.ecore,\<br>
> META-INF/<br>
> <b>
> templates/<br>
> > </blockquote>
> > <br>
> "\" to "/"
> > <br>
> > <br>
> > Ed Merks wrote:
> > <br>
> > <br>
> > <br>
> > Comments below.
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > steps:
> > <br>
> > <br>
> > <br>
> > the
> > <br>
> > root model element
> > <br>
> > <br>
> > <br>
> > that containing
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > I extend.
> > <br>
> > metamodel.
> > <br>
> > <br>
> > My questions are:
> > <br>
> > <br>
> > </blockquote>
> > different URI.
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > <br>
> > <br>
> > </blockquote>
> model. Note
> > <br>
> > <br>
> > <br>
> > <br>
> > Manar
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > <br>
> > </blockquote>
> > </blockquote>
> > </blockquote>
> > <br>
> > </body>
> > </html>
Re: errors while metamodeling [message #624549 is a reply to message #475252] |
thanks,
Manar,
Ed Merks wrote:
> Manar,
>> Ed,
>> Manar,
>> > <html>
>> > <head>
>> > </head>
>> > Manar,<br>
>> > <br>
>> plugin,
>> plugin.*,\<br>
>> .,\<br>
>> model/*.ecore,\<br>
>> META-INF/<br>
>> <b>
>> templates/<br>
>> > </blockquote>
>> > <br>
>> "\" to "/"
>> > <br>
>> > <br>
>> > Ed Merks wrote:
>> > <br>
>> > <br>
>> > <br>
>> > Comments below.
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > steps:
>> > <br>
>> > <br>
>> > <br>
>> > the
>> > <br>
>> > root model element
>> > <br>
>> > <br>
>> > <br>
>> > that containing
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > I extend.
>> > <br>
>> > metamodel.
>> > <br>
>> > <br>
>> > My questions are:
>> > <br>
>> > <br>
>> > </blockquote>
>> > different URI.
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > <br>
>> > <br>
>> > </blockquote>
>> model. Note
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > Manar
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > <br>
>> > </blockquote>
>> > </blockquote>
>> > </blockquote>
>> > <br>
>> > </body>
>> > </html>
Re: errors while metamodeling [message #624552 is a reply to message #475254] |
Manar,
be the case.
> thanks,
> Manar,
> Ed Merks wrote:
>> Manar,
>>> Ed,
>>> Manar,
>>> > <html>
>>> > <head>
>>> > </head>
>>> > Manar,<br>
>>> > <br>
>>> binary plugin,
>>> plugin.*,\<br>
>>> .,\<br>
>>> model/*.ecore,\<br>
>>> META-INF/<br>
>>> <b>
>>> templates/<br>
>>> > </blockquote>
>>> directly
>>> > <br>
>>> UML2
>>> "\" to "/"
>>> > <br>
>>> > <br>
>>> type="cite"><br>
>>> > Ed Merks wrote:
>>> > <br>
>>> > <br>
>>> > <br>
>>> > Comments below.
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > steps:
>>> > <br>
>>> > <br>
>>> > <br>
>>> > the
>>> > <br>
>>> > root model element
>>> > <br>
>>> > <br>
>>> > <br>
>>> workspace
>>> > that containing
>>> > <br>
>>> > </blockquote>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> > <br>
>>> > <br>
>>> > <br>
>>> showed
>>> > <br>
>>> > <br>
>>> folder
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> Abstractions
>>> which
>>> > I extend.
>>> > <br>
>>> > metamodel.
>>> > <br>
>>> > <br>
>>> > My questions are:
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> same
>>> > different URI.
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> for any
>>> yourself but
>>> > <br>
>>> resolved??
>>> > <br>
>>> > </blockquote>
>>> model. Note
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > Manar
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > <br>
>>> > </blockquote>
>>> > </blockquote>
>>> > </blockquote>
>>> > <br>
>>> > </body>
>>> > </html>
Re: errors while metamodeling [message #624553 is a reply to message #475262] |
Kenn
> Manar,
> case.
>> thanks,
>> Manar,
>> Ed Merks wrote:
>>> Manar,
>>>> Ed,
>>>> Manar,
>>>> > <html>
>>>> > <head>
>>>> > </head>
>>>> > Manar,<br>
>>>> > <br>
>>>> binary plugin,
>>>> plugin.*,\<br>
>>>> .,\<br>
>>>> model/*.ecore,\<br>
>>>> META-INF/<br>
>>>> <b>
>>>> templates/<br>
>>>> > </blockquote>
>>>> directly
>>>> > <br>
>>>> UML2
>>>> "\" to "/"
>>>> > <br>
>>>> > <br>
>>>> type="cite"><br>
>>>> > Ed Merks wrote:
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > Comments below.
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > steps:
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > the
>>>> > <br>
>>>> > root model element
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> workspace
>>>> > that containing
>>>> > <br>
>>>> > </blockquote>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> showed
>>>> > <br>
>>>> > <br>
>>>> folder
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> Abstractions
>>>> which
>>>> > I extend.
>>>> > <br>
>>>> > metamodel.
>>>> > <br>
>>>> > <br>
>>>> > My questions are:
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> same
>>>> > different URI.
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> for any
>>>> yourself but
>>>> > <br>
>>>> resolved??
>>>> > <br>
>>>> > </blockquote>
>>>> model. Note
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > Manar
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > <br>
>>>> > </blockquote>
>>>> > </blockquote>
>>>> > </blockquote>
>>>> > <br>
>>>> > </body>
>>>> > </html>
Re: errors while metamodeling [message #624557 is a reply to message #475263] |
Kenn,
> Kenn
>> Manar,
>> case.
>>> thanks,
>>> Manar,
>>> Ed Merks wrote:
>>>> Manar,
>>>>> Ed,
>>>>> Manar,
>>>>>> <html>
>>>>>> <head>
>>>>>> </head>
>>>>>> Manar,<br>
>>>>>> <br>
>>>>> binary plugin,
>>>>> plugin.*,\<br>
>>>>> .,\<br>
>>>>> model/*.ecore,\<br>
>>>>> META-INF/<br>
>>>>> <b>
>>>>> templates/<br>
>>>>>> </blockquote>
>>>>> directly
>>>>>> <br>
>>>>> UML2
>>>>> "\" to "/"
>>>>>> <br>
>>>>>> <br>
>>>>> type="cite"><br>
>>>>>> Ed Merks wrote:
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> Comments below.
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> steps:
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> the
>>>>>> <br>
>>>>>> root model element
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> workspace
>>>>>> that containing
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> showed
>>>>>> <br>
>>>>>> <br>
>>>>> folder
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>> Abstractions
>>>>> which
>>>>>> I extend.
>>>>>> <br>
>>>>>> metamodel.
>>>>>> <br>
>>>>>> <br>
>>>>>> My questions are:
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>> same
>>>>>> different URI.
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>> for any
>>>>> yourself but
>>>>>> <br>
>>>>> resolved??
>>>>>> <br>
>>>>>> </blockquote>
>>>>> model. Note
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> Manar
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> <br>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> </body>
>>>>>> </html>
<html>
<head>
</head>
Kenn,<br>
<br>
<br>
<br>
Kenn
</pre>
<pre wrap="">Manar,
case.
</pre>
thanks,
Manar,
Ed Merks wrote:
</pre>
<pre wrap="">Manar,
</pre>
<pre wrap="">Ed,
Manar,
Ed Merks wrote:
</pre>
<html>
<head>
</pre>
</blockquote>
</pre>
Manar,<br>
<br>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
plugin.*,\<br>
</pre>
..,\<br>
</pre>
model/*.ecore,\<br>
</pre>
</pre>
</pre>
META-INF/<br>
</pre>
</pre>
</blockquote>
</pre>
</pre>
templates/<br>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
<br>
</pre>
</blockquote>
<pre wrap="">UML2
</pre>
</pre>
</blockquote>
</pre>
<br>
<br>
</pre>
</blockquote>
</pre>
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap=""> <br>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp;
</pre>
</blockquote>
</pre>
<pre wrap=""> <br>
<br>
</blockquote>
<br>
<br>
<br>
</pre>
</blockquote>
<pre wrap="">showed
</pre>
<pre wrap=""> <br>
<br>
</pre>
</blockquote>
<pre wrap="">folder
</pre>
</pre>
<br>
<br>
<br>
<br>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">which
</pre>
<br>
metamodel.
<br>
<br>
My questions are:
<br>
<br>
</blockquote>
</pre>
</blockquote>
<pre wrap="">same
</pre>
different URI.
<br>
<br>
<br>
<br>
</blockquote>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
<br>
</pre>
</blockquote>
</pre>
<pre wrap=""> <br>
</blockquote>
</pre>
</blockquote>
</pre>
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: errors while metamodeling [message #624558 is a reply to message #475350] |
Exactly.
Kenn,
provide=20
(merged)=20
Kenn
Manar,
it's=20
case.
thanks,
Manar,
Ed Merks wrote:
Manar,
Ed,
Manar,
<html>
<head>
</head>
Manar,<br>
<br>
binary plugin,
nbsp; =20
plugin.*,\<br>
nbsp; =20
..,\<br>
nbsp; =20
model/*.ecore,\<br>
nbsp; =20
nbsp; =20
nbsp; =20
META-INF/<br>
nbsp; =20
<b> &nbs=
p; =20
nbsp; =20
templates/<br>
</blockquote>
directly
ignore.<br>
<br>
UML2
your
"\" to "/"
<br>
<br>
type=3D"cite"><br>
Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
workspace
that containing
=20
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
showed
<br>
<br>
folder
ucture.uml",
<br>
<br>
<br>
<br>
Abstractions
classes
which
I extend.
<br>
metamodel.
<br>
<br>
My questions are:
<br>
<br>
</blockquote>
same
load the
different URI.
<br>
<br>
<br>
<br>
</blockquote>
for any
yourself but
<br>
resolved??
<br>
</blockquote>
model. Note
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
=20
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV> </DIV>
<BLOCKQUOTE=20
merging=20
have=20
by UML=20
Hussey=20
wrote:=20
provide=20
(merged)=20
Kenn
message=20
pse.org</A>...
</PRE>
it's=20
case.
</PRE>
thanks,
Manar,
Ed Merks wrote:
</PRE>
</PRE>
Manar,
Ed Merks wrote:
</PRE>
<html>
<head>
</PRE>
Manar,<br>
<br>
</PRE>
bsp;=20
plugin.*,\<br>
</PRE><PRE =
bsp;=20
..,\<br>
</PRE><PRE =
bsp;=20
model/*.ecore,\<br>
</PRE><PRE =
bsp;=20
</PRE><PRE =
bsp;=20
</PRE><PRE =
bsp;=20
META-INF/<br>
</PRE>
about.html,\<br>
bsp;=20
</PRE><PRE =
sp;&nbsp;=20
</PRE><PRE =
bsp;=20
templates/<br>
</PRE>
**/doc-files/**<br>
</blockquote>
</PRE>
<br>
</PRE>
</PRE>
<br>
<br>
d.eclipse.org"</A>
</PRE>
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
steps:
<br>
<br>
<br>
the
<br>
root model element
<br>
<br>
<br>
</PRE>
</PRE>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp;
</PRE>
<br>
</blockquote>
<br>
<br>
<br>
</PRE>
<br>
</PRE><PRE =
</PRE>
<br>
<br>
<br>
<br>
</PRE>
</PRE>
<br>
metamodel.
<br>
<br>
My questions are:
<br>
ePackage&gt;&gt;
<br>
</blockquote>
</PRE>
different URI.
<br>
<br>
<br>
<br>
</blockquote>
</PRE>
</PRE>
<br>
</PRE>
</blockquote>
</PRE>
<br>
<br>
<br>
<br>
Manar
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: errors while metamodeling [message #624560 is a reply to message #475351] |
belongs.
Manar
Kenn Hussey wrote:
> Exactly.
> Kenn,
>> Kenn
>>> Manar,
>>> case.
>>>> thanks,
>>>> Manar,
>>>> Ed Merks wrote:
>>>>> Manar,
>>>>>> Ed,
>>>>>> Manar,
>>>>>>> <html>
>>>>>>> <head>
>>>>>>> </head>
>>>>>>> Manar,<br>
>>>>>>> <br>
>>>>>> binary plugin,
>>>>>> plugin.*,\<br>
>>>>>> ..,\<br>
>>>>>> model/*.ecore,\<br>
>>>>>> META-INF/<br>
>>>>>> <b>
>>>>>> templates/<br>
>>>>>>> </blockquote>
>>>>>> directly
>>>>>>> <br>
>>>>>> UML2
>>>>>> "\" to "/"
>>>>>>> <br>
>>>>>>> <br>
>>>>>> type="cite"><br>
>>>>>>> Ed Merks wrote:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> Comments below.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> steps:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> the
>>>>>>> <br>
>>>>>>> root model element
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> workspace
>>>>>>> that containing
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> showed
>>>>>>> <br>
>>>>>>> <br>
>>>>>> folder
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>> Abstractions
>>>>>> which
>>>>>>> I extend.
>>>>>>> <br>
>>>>>>> metamodel.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> My questions are:
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> same
>>>>>>> different URI.
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> for any
>>>>>> yourself but
>>>>>>> <br>
>>>>>> resolved??
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>> model. Note
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> Manar
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> <br>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> </body>
>>>>>>> </html>
Re: errors while metamodeling [message #624575 is a reply to message #475353] |
Manar
> belongs.
> Manar
> Kenn Hussey wrote:
>> Exactly.
>> Kenn,
>>> Kenn
>>>> Manar,
>>>> case.
>>>>> thanks,
>>>>> Manar,
>>>>> Ed Merks wrote:
>>>>>> Manar,
>>>>>>> Ed,
>>>>>>> Manar,
>>>>>>>> <html>
>>>>>>>> <head>
>>>>>>>> </head>
>>>>>>>> Manar,<br>
>>>>>>>> <br>
>>>>>>> binary plugin,
>>>>>>> plugin.*,\<br>
>>>>>>> ..,\<br>
>>>>>>> model/*.ecore,\<br>
>>>>>>> META-INF/<br>
>>>>>>> <b>
>>>>>>> templates/<br>
>>>>>>>> </blockquote>
>>>>>>> directly
>>>>>>>> ignore.<br>
>>>>>>>> <br>
>>>>>>>> someone with
>>>>>>> UML2
>>>>>>>> your
>>>>>>> "\" to "/"
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> type="cite"><br>
>>>>>>>> Ed Merks wrote:
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> Comments below.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> following
>>>>>>>> steps:
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> stereotype to
>>>>>>>> the
>>>>>>>> <br>
>>>>>>>> root model element
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> (Note: I
>>>>>>> workspace
>>>>>>>> that containing
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> showed
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>> folder
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> it's
>>>>>>>> <br>
>>>>>>>> the
>>>>>>> Abstractions
>>>>>>>> classes
>>>>>>> which
>>>>>>>> I extend.
>>>>>>>> <br>
>>>>>>>> metamodel.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> My questions are:
>>>>>>>> <br>
>>>>>>>> Not all
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> of the
>>>>>>> same
>>>>>>>> load the
>>>>>>>> using a
>>>>>>>> different URI.
>>>>>>>> <br>
>>>>>>>> I didn't
>>>>>>>> need for
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>> for any
>>>>>>> yourself but
>>>>>>>> <br>
>>>>>>>> generated
>>>>>>>> metamodel code.
>>>>>>> resolved??
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> model in the
>>>>>>> model. Note
>>>>>>>> problems above
>>>>>>>> generate.
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> Manar
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> <br>
>>>>>>>> </blockquote>
>>>>>>>> </blockquote>
>>>>>>>> </blockquote>
>>>>>>>> <br>
>>>>>>>> </body>
>>>>>>>> </html>
Re: errors while metamodeling [message #624578 is a reply to message #475357] |
Manar,
> Manar
>> it belongs.
>> Manar
>> Kenn Hussey wrote:
>>> Exactly.
>>> Kenn,
>>>> Kenn
>>>>> Manar,
>>>>> be the case.
>>>>>> thanks,
>>>>>> Manar,
>>>>>> Ed Merks wrote:
>>>>>>> Manar,
>>>>>>>> Ed,
>>>>>>>> Manar,
>>>>>>>>> Transitional//EN">
>>>>>>>>> <html>
>>>>>>>>> <head>
>>>>>>>>> </head>
>>>>>>>>> Manar,<br>
>>>>>>>>> <br>
>>>>>>>> binary plugin,
>>>>>>>> plugin.*,\<br>
>>>>>>>> ..,\<br>
>>>>>>>> model/*.ecore,\<br>
>>>>>>>> META-INF/<br>
>>>>>>>> <b>
>>>>>>>> templates/<br>
>>>>>>>>> </blockquote>
>>>>>>>> directly
>>>>>>>>> ignore.<br>
>>>>>>>>> <br>
>>>>>>>>> someone with
>>>>>>>> UML2
>>>>>>>>> change your
>>>>>>>> "\" to "/"
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>> type="cite"><br>
>>>>>>>>> Ed Merks wrote:
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> Comments below.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> following
>>>>>>>>> steps:
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> stereotype to
>>>>>>>>> the
>>>>>>>>> <br>
>>>>>>>>> root model element
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> (Note: I
>>>>>>>> workspace
>>>>>>>>> that containing
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>> showed
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> plugin
>>>>>>>> folder
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> since it's
>>>>>>>>> <br>
>>>>>>>>> of the
>>>>>>>> Abstractions
>>>>>>>>> classes
>>>>>>>> which
>>>>>>>>> I extend.
>>>>>>>>> <br>
>>>>>>>>> to a
>>>>>>>>> metamodel.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> My questions are:
>>>>>>>>> <br>
>>>>>>>>> " Not all
>>>>>>>>> ePackage>>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> versions of the
>>>>>>>> same
>>>>>>>>> you load the
>>>>>>>>> model using a
>>>>>>>>> different URI.
>>>>>>>>> <br>
>>>>>>>>> and I didn't
>>>>>>>>> need for
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> code
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> GenModel
>>>>>>>> for any
>>>>>>>> yourself but
>>>>>>>>> <br>
>>>>>>>>> generated
>>>>>>>>> metamodel code.
>>>>>>>> resolved??
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> model in the
>>>>>>>> model. Note
>>>>>>>>> problems above
>>>>>>>>> generate.
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> Manar
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> <br>
>>>>>>>>> </blockquote>
>>>>>>>>> </blockquote>
>>>>>>>>> </blockquote>
>>>>>>>>> <br>
>>>>>>>>> </body>
>>>>>>>>> </html>
Re: errors while metamodeling [message #624592 is a reply to message #475362] |
- James.
> Manar,
> > Manar
> >> it belongs.
> >> Manar
> >> Kenn Hussey wrote:
> >>> Exactly.
> >>> Kenn,
merged
> >>>> Kenn
> >>>>> Manar,
> >>>>> be the case.
> >>>>>> thanks,
> >>>>>> Manar,
> >>>>>> Ed Merks wrote:
> >>>>>>> Manar,
> >>>>>>>> Ed,
> >>>>>>>> Manar,
> >>>>>>>>> Transitional//EN">
> >>>>>>>>> <html>
> >>>>>>>>> <head>
> >>>>>>>>> </head>
> >>>>>>>>> Manar,<br>
> >>>>>>>>> <br>
the
> >>>>>>>> binary plugin,
&nbs
p;
> >>>>>>>> plugin.*,\<br>
&nbs
p;
> >>>>>>>> ..,\<br>
&nbs
p;
> >>>>>>>> model/*.ecore,\<br>
&nbs
p;
&nbs
p;
&nbs
p;
> >>>>>>>> META-INF/<br>
&nbs
p;
<b> &
nbsp;
&nbs
p;
> >>>>>>>> templates/<br>
> >>>>>>>>> </blockquote>
have
> >>>>>>>> directly
> >>>>>>>>> ignore.<br>
> >>>>>>>>> <br>
> >>>>>>>>> someone with
> >>>>>>>> UML2
> >>>>>>>>> change your
> >>>>>>>> "\" to "/"
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>> type="cite"><br>
> >>>>>>>>> Ed Merks wrote:
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> Comments below.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> following
> >>>>>>>>> steps:
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> stereotype to
> >>>>>>>>> the
> >>>>>>>>> <br>
> >>>>>>>>> root model element
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> (Note: I
my
> >>>>>>>> workspace
> >>>>>>>>> that containing
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>> showed
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> plugin
> >>>>>>>> folder
ure.uml",
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> since it's
> >>>>>>>>> <br>
> >>>>>>>>> of the
> >>>>>>>> Abstractions
> >>>>>>>>> classes
> >>>>>>>> which
> >>>>>>>>> I extend.
> >>>>>>>>> <br>
> >>>>>>>>> to a
> >>>>>>>>> metamodel.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> My questions are:
> >>>>>>>>> <br>
> >>>>>>>>> " Not all
> >>>>>>>>> ePackage>>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> versions of the
> >>>>>>>> same
> >>>>>>>>> you load the
> >>>>>>>>> model using a
> >>>>>>>>> different URI.
> >>>>>>>>> <br>
> >>>>>>>>> and I didn't
> >>>>>>>>> need for
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> code
that?
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> GenModel
> >>>>>>>> for any
> >>>>>>>> yourself but
> >>>>>>>>> <br>
> >>>>>>>>> generated
> >>>>>>>>> metamodel code.
> >>>>>>>> resolved??
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> model in the
> >>>>>>>> model. Note
be
> >>>>>>>>> problems above
> >>>>>>>>> generate.
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> Manar
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> <br>
> >>>>>>>>> </blockquote>
> >>>>>>>>> </blockquote>
> >>>>>>>>> </blockquote>
> >>>>>>>>> <br>
> >>>>>>>>> </body>
> >>>>>>>>> </html>
Re: errors while metamodeling [message #624594 is a reply to message #475374] |
James,
thanks,
Manar,
> - James.
>> Manar,
>>> Manar
>>>> it belongs.
>>>> Manar
>>>> Kenn Hussey wrote:
>>>>> Exactly.
>>>>> Kenn,
> merged
>>>>>> Kenn
>>>>>>> Manar,
>>>>>>> be the case.
>>>>>>>> thanks,
>>>>>>>> Manar,
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Manar,
>>>>>>>>>> Ed,
>>>>>>>>>> Manar,
>>>>>>>>>>> Transitional//EN">
>>>>>>>>>>> <html>
>>>>>>>>>>> <head>
>>>>>>>>>>> </head>
>>>>>>>>>>> Manar,<br>
>>>>>>>>>>> <br>
> the
>>>>>>>>>> binary plugin,
> &nbs
> p;
>>>>>>>>>> plugin.*,\<br>
> &nbs
> p;
>>>>>>>>>> ..,\<br>
> &nbs
> p;
>>>>>>>>>> model/*.ecore,\<br>
> &nbs
> p;
> &nbs
> p;
> &nbs
> p;
>>>>>>>>>> META-INF/<br>
> &nbs
> p;
> <b> &
> nbsp;
> &nbs
> p;
>>>>>>>>>> templates/<br>
>>>>>>>>>>> </blockquote>
> have
>>>>>>>>>> directly
>>>>>>>>>>> ignore.<br>
>>>>>>>>>>> <br>
>>>>>>>>>>> someone with
>>>>>>>>>> UML2
>>>>>>>>>>> change your
>>>>>>>>>> "\" to "/"
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>> type="cite"><br>
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> Comments below.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> following
>>>>>>>>>>> steps:
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> stereotype to
>>>>>>>>>>> the
>>>>>>>>>>> <br>
>>>>>>>>>>> root model element
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> (Note: I
> my
>>>>>>>>>> workspace
>>>>>>>>>>> that containing
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>> showed
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> plugin
>>>>>>>>>> folder
> ure.uml",
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> since it's
>>>>>>>>>>> <br>
>>>>>>>>>>> of the
>>>>>>>>>> Abstractions
>>>>>>>>>>> classes
>>>>>>>>>> which
>>>>>>>>>>> I extend.
>>>>>>>>>>> <br>
>>>>>>>>>>> to a
>>>>>>>>>>> metamodel.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> My questions are:
>>>>>>>>>>> <br>
>>>>>>>>>>> " Not all
>>>>>>>>>>> ePackage>>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> versions of the
>>>>>>>>>> same
>>>>>>>>>>> you load the
>>>>>>>>>>> model using a
>>>>>>>>>>> different URI.
>>>>>>>>>>> <br>
>>>>>>>>>>> and I didn't
>>>>>>>>>>> need for
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> code
> that?
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> GenModel
>>>>>>>>>> for any
>>>>>>>>>> yourself but
>>>>>>>>>>> <br>
>>>>>>>>>>> generated
>>>>>>>>>>> metamodel code.
>>>>>>>>>> resolved??
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> model in the
>>>>>>>>>> model. Note
> be
>>>>>>>>>>> problems above
>>>>>>>>>>> generate.
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> Manar
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> <br>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> </blockquote>
>>>>>>>>>>> <br>
>>>>>>>>>>> </body>
>>>>>>>>>>> </html>
Re: errors while metamodeling [message #624595 is a reply to message #475377] |
Manar,
> James,
> thanks,
> Manar,
>> - James.
>>> Manar,
>>>> Manar
>>>>> it belongs.
>>>>> Manar
>>>>> Kenn Hussey wrote:
>>>>>> Exactly.
>>>>>> Kenn,
>> merged
>>>>>>> Kenn
>>>>>>>> Manar,
>>>>>>>> be the case.
>>>>>>>>> thanks,
>>>>>>>>> Manar,
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Manar,
>>>>>>>>>>> Ed,
>>>>>>>>>>> Manar,
>>>>>>>>>>>> Transitional//EN">
>>>>>>>>>>>> <html>
>>>>>>>>>>>> <head>
>>>>>>>>>>>> </head>
>>>>>>>>>>>> Manar,<br>
>>>>>>>>>>>> <br>
>> the
>>>>>>>>>>> binary plugin,
>> &nbs
>> p;
>>>>>>>>>>> plugin.*,\<br>
>> &nbs
>> p;
>>>>>>>>>>> ..,\<br>
>> &nbs
>> p;
>>>>>>>>>>> model/*.ecore,\<br>
>> &nbs
>> p;
>> &nbs
>> p;
>> &nbs
>> p;
>>>>>>>>>>> META-INF/<br>
>> &nbs
>> p;
>> <b> &
>> nbsp;
>> &nbs
>> p;
>>>>>>>>>>> templates/<br>
>>>>>>>>>>>> </blockquote>
>> have
>>>>>>>>>>> directly
>>>>>>>>>>>> ignore.<br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> someone with
>>>>>>>>>>> UML2
>>>>>>>>>>>> change your
>>>>>>>>>>> "\" to "/"
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>> type="cite"><br>
>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> Comments below.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> following
>>>>>>>>>>>> steps:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> stereotype to
>>>>>>>>>>>> the
>>>>>>>>>>>> <br>
>>>>>>>>>>>> root model element
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> (Note: I
>> my
>>>>>>>>>>> workspace
>>>>>>>>>>>> that containing
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>> showed
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> plugin
>>>>>>>>>>> folder
>> ure.uml",
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> since it's
>>>>>>>>>>>> <br>
>>>>>>>>>>>> of the
>>>>>>>>>>> Abstractions
>>>>>>>>>>>> classes
>>>>>>>>>>> which
>>>>>>>>>>>> I extend.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> to a
>>>>>>>>>>>> metamodel.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> My questions are:
>>>>>>>>>>>> <br>
>>>>>>>>>>>> " Not all
>>>>>>>>>>>> ePackage>>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> versions of the
>>>>>>>>>>> same
>>>>>>>>>>>> you load the
>>>>>>>>>>>> model using a
>>>>>>>>>>>> different URI.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> and I didn't
>>>>>>>>>>>> need for
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> code
>> that?
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> GenModel
>>>>>>>>>>> for any
>>>>>>>>>>> yourself but
>>>>>>>>>>>> <br>
>>>>>>>>>>>> generated
>>>>>>>>>>>> metamodel code.
>>>>>>>>>>>> cannot be
>>>>>>>>>>> resolved??
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> model in the
>>>>>>>>>>> model. Note
>> be
>>>>>>>>>>>> problems above
>>>>>>>>>>>> generate.
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> Manar
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> </blockquote>
>>>>>>>>>>>> <br>
>>>>>>>>>>>> </body>
>>>>>>>>>>>> </html>
Current Time: Sun Jul 20 14:18:40 EDT 2025
Powered by FUDForum. Page generated in 0.70454 seconds
