Home » Modeling » UML2 » java API which converts Ecore object model to UML model.
java API which converts Ecore object model to UML model. [message #475168] Wed, 22 August 2007 08:10 Go to next message
Originally posted by: rmishra.tibco.com
Hi ,
I have Epackage corresponding to the ecore model ,now i want to convert
epackage to UML Model and serialize it .Can some body help me out ,if there
is any java API Which i can use --if there is ,then please let me know how
to use that---
Thanks and Regards
Raju Mishra
Re: java API which converts Ecore object model to UML model. [message #475171 is a reply to message #475168] Wed, 22 August 2007 08:16 Go to previous messageGo to next message
Raju,
Have a look at org.eclipse.uml2.uml.ecore.exporter's UMLExporter.java.
Note that an Export Model... action is available on the popup of a
..genmodel.
Raju Mishra wrote:
> Hi ,
> to use that---
> Thanks and Regards
> Raju Mishra
Re: java API which converts Ecore object model to UML model. [message #475175 is a reply to message #475171] Wed, 22 August 2007 09:00 Go to previous messageGo to next message
Hi ,
I did look into the UMLExporter.java but couldn't find any thing relevant--
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fah9ft$8jd$1@build.eclipse.org...
> Raju,
> .genmodel.
> Raju Mishra wrote:
>> Hi ,
>> there is any java API Which i can use --if there is ,then please let me
>> know how to use that---
>> Thanks and Regards
>> Raju Mishra
Re: java API which converts Ecore object model to UML model. [message #475178 is a reply to message #475175] Wed, 22 August 2007 09:07 Go to previous messageGo to next message
--------------050107010608000602000900
Raju,
I think you need to look a little harder:
protected Diagnostic doExport(Monitor monitor, ExportData
exportData)
throws Exception {
Diagnostic diagnostic = Diagnostic.OK_INSTANCE;
ResourceSet resourceSet = new ResourceSetImpl();
UMLUtil.Ecore2UMLConverter ecore2umlConverter = new
UMLUtil.*Ecore2UMLConverter*();
Raju Mishra wrote:
> Hi ,
>> Raju,
>> .genmodel.
>> Raju Mishra wrote:
>>> Hi ,
>>> Thanks and Regards
>>> Raju Mishra
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Raju,<br>
<br>
I think you need to look a little harder:<br>
<blockquote><small>&nbsp;&nbsp;&nbsp; protected Diagnostic doExport(Monitor monitor,
ExportData exportData)</small><br>
<small>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; throws Exception {</small><br>
<small>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Diagnostic diagnostic = Diagnostic.OK_INSTANCE;</small><br>
<br>
<small>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; ResourceSet resourceSet = new ResourceSetImpl();</small><br>
<small>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; UMLUtil.Ecore2UMLConverter ecore2umlConverter = new
UMLUtil.<b>Ecore2UMLConverter</b>();</small><br>
</blockquote>
<br>
Raju Mishra wrote:
<blockquote cite="mid:fahc14$g09$1@build.eclipse.org" type="cite">
<pre wrap="">Hi ,
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fah9ft$8jd$1@build.eclipse.org">news:fah9ft$8jd$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Raju,
..genmodel.
Raju Mishra wrote:
</pre>
<pre wrap="">Hi ,
Thanks and Regards
Raju Mishra
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050107010608000602000900--
Re: java API which converts Ecore object model to UML model. [message #475192 is a reply to message #475178] Wed, 22 August 2007 09:44 Go to previous message
------=_NextPart_000_0157_01C7E4F0.B1855DE0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks -- i got it--
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fahcek$gl8$1@build.eclipse.org...
Raju,
protected Diagnostic doExport(Monitor monitor, ExportData =
exportData)
throws Exception {
Diagnostic diagnostic =3D Diagnostic.OK_INSTANCE;
ResourceSet resourceSet =3D new ResourceSetImpl();
UMLUtil.Ecore2UMLConverter ecore2umlConverter =3D new =
UMLUtil.Ecore2UMLConverter();
Raju Mishra wrote:=20
Hi ,
I did look into the UMLExporter.java but couldn't find any thing =
relevant--
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Raju,
Have a look at org.eclipse.uml2.uml.ecore.exporter's UMLExporter.java.=20
Note that an Export Model... action is available on the popup of a=20
..genmodel.
Raju Mishra wrote:
Hi ,
I have Epackage corresponding to the ecore model ,now i want to convert=20
epackage to UML Model and serialize it .Can some body help me out ,if=20
there is any java API Which i can use --if there is ,then please let me=20
Thanks and Regards
Raju Mishra
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3059" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks -- i got it--</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:fahcek$gl8$1@build.eclipse.org">news:fahcek$gl8$1@build.ecli=
pse.org</A>...</DIV>Raju,<BR><BR>I=20
think you need to look a little harder:<BR>
<BLOCKQUOTE><SMALL>&nbsp;&nbsp;&nbsp; protected Diagnostic =
doExport(Monitor=20
monitor, ExportData exportData)</SMALL><BR><SMALL>&nbsp;&nbsp;&nbsp; =
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; throws Exception=20
{</SMALL><BR><SMALL>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Diagnostic =
diagnostic =3D=20
Diagnostic.OK_INSTANCE;</SMALL><BR><BR><SMALL>&nbsp;&nbsp;&nbsp;=20
&nbsp;&nbsp;&nbsp; ResourceSet resourceSet =3D new=20
ResourceSetImpl();</SMALL><BR><SMALL>&nbsp;&nbsp;&nbsp; =
UMLUtil.Ecore2UMLConverter ecore2umlConverter =3D new=20
UMLUtil.<B>Ecore2UMLConverter</B>();</SMALL><BR></BLOCKQUOTE ><BR>Raju =
Mishra=20
wrote:=20
<BLOCKQUOTE cite=3Dmid:fahc14$g09$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi ,
relevant--
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fah9ft$8jd$1@build.eclipse.org">news:fah9ft$8jd$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Raju,
..genmodel.
Raju Mishra wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi ,
Thanks and Regards
Raju Mishra
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0157_01C7E4F0.B1855DE0--
Re: java API which converts Ecore object model to UML model. [message #624460 is a reply to message #475168] Wed, 22 August 2007 08:16 Go to previous message
Raju,
..genmodel.
Raju Mishra wrote:
> Hi ,
> to use that---
> Thanks and Regards
> Raju Mishra
Re: java API which converts Ecore object model to UML model. [message #624461 is a reply to message #475171] Wed, 22 August 2007 09:00 Go to previous message
Hi ,
> Raju,
> .genmodel.
> Raju Mishra wrote:
>> Hi ,
>> Thanks and Regards
>> Raju Mishra
Re: java API which converts Ecore object model to UML model. [message #624462 is a reply to message #475175] Wed, 22 August 2007 09:07 Go to previous message
Raju,
exportData)
throws Exception {
Raju Mishra wrote:
> Hi ,
>> Raju,
>> .genmodel.
>> Raju Mishra wrote:
>>> Hi ,
>>> Thanks and Regards
>>> Raju Mishra
<html>
<head>
</head>
Raju,<br>
<br>
<br>
</blockquote>
<br>
<pre wrap="">Hi ,
</pre>
<pre wrap="">Raju,
..genmodel.
Raju Mishra wrote:
</pre>
<pre wrap="">Hi ,
Thanks and Regards
Raju Mishra
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: java API which converts Ecore object model to UML model. [message #624467 is a reply to message #475178] Wed, 22 August 2007 09:44 Go to previous message
Raju,
exportData)
throws Exception {
Hi ,
relevant--
Raju,
..genmodel.
Raju Mishra wrote:
Hi ,
Thanks and Regards
Raju Mishra
=20
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BLOCKQUOTE=20
doExport(Monitor=20
diagnostic =3D=20
Mishra=20
wrote:=20
relevant--
message=20
pse.org</A>...
</PRE>
..genmodel.
Raju Mishra wrote:
</PRE>
Thanks and Regards
Raju Mishra
Previous Topic:ecore model to uml model
Next Topic:AddVariableValueAction doubled in UML editor
Current Time: Sun Jul 20 09:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.10455 seconds
