Home » Modeling » UML2 » UML2 Stereotype with extensible properties
UML2 Stereotype with extensible properties [message #474753] Wed, 01 August 2007 03:48 Go to next message
Hi all,
I am a bit of a newbie with UML2, so please bear with me, and if you need
any further questions regarding my problems, please ask.
What I am trying do to is capture XML metadata in a stereotyped activity.
So what I have done is:
-Created a stereotype activity for my particular business activity, with
the property "metadata"
-I have also been able to load in the XML schema, defining the XML
metadata, as an ecore model.
-What I would like to do is have the type of the "metadata" property point
to the main class in the XML schema ecore model. I have managed to load in
the ecore model as a resource, but when I bring up the dropdown menu for
the types available for the "metadata" property none of the classes from
the "metadata" ecore model are available.
I thought this would be a viable approach, but obviously I am doing
something wrong? Any suggestions/opinion would be much appreciated.
Perhaps you know a better way to capture extensible properties in UML2?
Mark
Re: UML2 Stereotype with extensible properties [message #474863 is a reply to message #474753] Wed, 01 August 2007 15:42 Go to previous messageGo to next message
Mark,
The type of a stereotype property must be a(nother) UML element, i.e. an
instance of (a specialization of) Type - you can't use an arbitrary Ecore
class as the type. You can, however, reference the existing type by creating
a placeholder classifier in UML (which you would use as the type of the
stereotype property), stereotype is as an <<eClass>> or <<eDataType>>, and
specify its instance class name as the name of the Java class that
implements the desired type from your schema.
Kenn
"Mark Melia" <mmelia@computing.dcu.ie> wrote in message
news:5818a01bcc576683dfd2d21573626386$1@www.eclipse.org...
> Hi all,
> Mark
Re: UML2 Stereotype with extensible properties [message #474865 is a reply to message #474863] Thu, 02 August 2007 06:24 Go to previous messageGo to next message
Thanks Kenn for that, while I am on the topic just wondering do you (or
anyone else for that matter) know if you can covert an XSD to a UML model
rather than an Ecore model. Has anyone else tried to capture extensible
data as an property to a UML class? Perhaps I am over looking a very
simple way of capturing this XML data?
Thanks again,
Mark
Re: UML2 Stereotype with extensible properties [message #474867 is a reply to message #474865] Thu, 02 August 2007 08:06 Go to previous messageGo to next message
Mark,
You can convert XSD to Ecore and then you can convert Ecore to UML2.
Does that help?
> (or anyone else for that matter) know if you can covert an XSD to a
> UML model rather than an Ecore model. Has anyone else tried to capture
> extensible data as an property to a UML class? Perhaps I am over
> looking a very simple way of capturing this XML data?
> Thanks again,
> Mark
Re: UML2 Stereotype with extensible properties [message #474869 is a reply to message #474867] Thu, 02 August 2007 09:46 Go to previous messageGo to next message
Hi Ed,
Thanks for your response. I am aware that you can do this using ATL, but
as far as I known this has a fairly steep learning curve. Is this the
conversion from ecore to UML2 you have in mind?
Thanks again for your help!
Mark
Re: UML2 Stereotype with extensible properties [message #474870 is a reply to message #474869] Thu, 02 August 2007 11:04 Go to previous messageGo to next message
Mark,
Are you wanting to do it programatically or via the GUI tools (or Ant
tasks)?
Mark Melia wrote:
> Hi Ed,
> but as far as I known this has a fairly steep learning curve. Is this
> the conversion from ecore to UML2 you have in mind?
> Mark
Re: UML2 Stereotype with extensible properties [message #474871 is a reply to message #474869] Thu, 02 August 2007 11:53 Go to previous messageGo to next message
Mark,
There's an option to export an Ecore model to UML format via the 'Export
Model...' context menu for generator models in the Package Explorer...
Kenn
news:5ac7d9663811ed8d78197f9f36534f89$1@www.eclipse.org...
> Hi Ed,
> Mark
Re: UML2 Stereotype with extensible properties [message #474876 is a reply to message #474870] Fri, 03 August 2007 04:20 Go to previous messageGo to next message
Hi Ed,
I am hoping to do it through the GUI.
Mark
Re: UML2 Stereotype with extensible properties [message #474877 is a reply to message #474871] Fri, 03 August 2007 04:31 Go to previous messageGo to next message
Hi Kenn,
I have found the "export model..." option when right-clicking on the
genmodel but the only options are to export to "XML schema" or "XML
schema for XMI". Am I looking in the wrong place to export to UML2 or can
the XML schema for XMI be used in some fashion to get my UML2 model?
Mark
Re: UML2 Stereotype with extensible properties [message #474878 is a reply to message #474877] Fri, 03 August 2007 07:44 Go to previous messageGo to next message
--------------050805000407090804090709
Mark,
If you have UML2 installed properly, it should contribute an exporter
that looks like this:
Mark Melia wrote:
> Hi Kenn,
> can the XML schema for XMI be used in some fashion to get my UML2 model?
> Mark
Content-Type: multipart/related;
boundary="------------070606030904000303030904"
--------------070606030904000303030904
<html>
<head>
http-equiv="Content-Type">
</head>
Mark,<br>
<br>
that looks like this:<br>
<blockquote><img src="cid:part1.01090308.07060209@ca.ibm.com" alt=""><br>
<br>
</blockquote>
Mark Melia wrote:
<blockquote
cite="mid:2dc334205dfea9a8fd808b1f4914f91c$1@www.eclipse.org"
type="cite">Hi Kenn,
<br>
<br>
model?
<br>
<br>
<br>
Mark
<br>
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-29.jpg"
Content-ID: <part1.01090308.07060209@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-29.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDABALDA4MChAODQ4SERATGCgaGBYW GDEjJR0oOjM9
PDkzODdASFxOQERXRTc4UG1RV19iZ2hnPk1xeXBkeFxlZ2P/2wBDARESEhgV GC8aGi9jQjhC
Y2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2P/wAAR
CADYASYDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDX1rVLmwaAQNwyDIJPGAPQ +9VG1bWEjWR0
Cq3TLEZ/DdT9f2/bbHfjbxnPphah1S8hb93PKBs7bmH/ALIa2hFNI57OU5e8 7IjPiPUAcErn
6t/jU/8Aaut+V5v2aXy9u7fsfGOuc56Vgs9u7kwSbz3+cn+aD+dbusW7SWdl ItrcSFbKP96n
3FAyTkbfT3FVKKTsc05Ti2uZ6EH/AAkd/wD3l/Nv8aX/AISO/wD7y/m3+NXI dLtGs7WRrX95
J5HmL5h+VWcjfnPO7AGO1PGk2TXUSTwfZgbx4lXew82MLkH5iepwMj1+lT7v YX77+Yof8JHf
/wB5fzb/ABo/4SO//vL+bf41cj0618gTTWgjmFpNK1uWcBSrDacE7uRnvVPW yGh01lUFfsiL
5gzyRwR6cf1ppRfQmUqsVdyLH9qa15Xm/Z5fL27t+x8Y65znpTDreqB40KEN IAUBDZYHpjnn
NO1i3aSzspFtbhytlH+9X7igZJyMf1rWh+wH+y3uP+PiGCLy1+X59/yjrydp GfbrS07Fp1G7
cxlx6prUu7y7eV9rFW2o5wR1B561Gut6o83kqjNLkjYAxbI68ZqxfGFdNvDO juv9pvgI4U5w
e5Bql4a/5Dtt/wAC/wDQTTsrXsQ5z51Hm3JF13UmjeRRlExuYbsLnpk54pv/ AAkN9/eX82/x
rRu/sA0K/wDsPPmeXM/3fl3NwnHTGDx2zUdxpdivmhk8mBHgEVxvP70N945P ynjJ4HahcvYb
9t0l/Wv+RV/tzUvK83B8vdt3/NjPpnPWiPXNSk3eWC+1SzbdxwB3PPStQWUD QpaTwfZ7f+0G
CjLDeAh2nJPfAHH4VBDbwwrcGO3kgd7GbcrjbnkYO0sxHfr1xxS93sP98vtF D/hIL7+8Pzb/
ABo/4SC+/vD82/xrKpa05I9jl+sVf5jV/wCEgvv7w/Nv8aP7fvv7w/Nv8ayq Wjkj2F9Yq/zG
p/b99/eH5t/jS/2/ff3h+bf41lUtPkj2D6xV/mNT+377+8Pzb/Gj+3r7+8Pz b/Gsulo5I9hf
WKv8xqf29e/3h+bf40f29e/3h+bf41l0tHJHsH1mr/Maf9vXv98fm3+NH9u3 v98fm3+NZlFH
JHsL6zV/mNT+3b3++Pzb/Gj+3b3++Pzb/Gsylp8kewfWav8AMaX9uXv98fm3 +NL/AG5e/wB8
fm3+NZlFHJHsL6zV/mNP+3L3++Pzb/Gj+3L3++Pzb/Gs2ijkj2D6zW/mNL+2 73++PzP+NL/b
d7/f/U/41m0Uezj2F9ZrfzGl/bd5/f8A1P8AjRWdRT9nHsH1qt/Mber6Vc6m 8X2bZ+7Qbtxx
1Uf4VRm8MapcRhJvJcL0y3P54zXVWP35P9yP/wBBq5XKptbHuOjFyctdThU8 JX8a4RYQPZ6d
/wAIrqXpD/33XcUUe0kZvC03ucVF4a1SGVJYzCHRgynd0I6dqJfDWqTSvLIY Wd2LMd3Unr2r
taKOdh9Vp7HEf8ItqXpD/wB90f8ACLaj6Rf99129FHtJC+qUzif+EW1H0i/7 7o/4RfUfSL/v
uu2oo9pIPqlM4n/hF9R9Iv8Avul/4RfUfSL/AL7rtaKftJB9UpHFf8IxqPpF /wB90f8ACMaj
6Rf9912tFHtJB9TpHFf8IxqPpF/33S/8IxqPpF/33XaUUe0kL6nSOL/4RnUf SL/vuj/hGdR9
Iv8Avuu0oo9pIPqdI4z/AIRnUPSL/vuj/hGdQ9Iv++67Oij2kg+p0jjP+Ea1 D0i/77pf+Ea1
D0i/77rsqKPayD6lSON/4RrUPSL/AL7o/wCEa1D0i/77rsqKPayD6lSON/4R vUPSL/vul/4R
vUPSP/vuuxoo9rIX1Kkcd/wjeoekf/fdH/CN6h6R/wDfddjRR7WQfUqRx/8A wjmoekf/AH3R
/wAI5f8ApH/33XYUUe1kH1Kkcf8A8I5f+kf/AH3R/wAI7f8ApH/33XYUU/ay D6jSOQ/4R2/9
I/8Avuj/AIR2/wD7sf8A33XX0Ue1kH1Gich/wjt//dj/AO+6X/hHr/8Aux/9 9111FHtZC+o0
Tkf+Eev/AO7H/wB90V11FHtZB9RolOx+/J/uR/8AoNc7cyz2a6leajLebPtL CC9t7jdDAmQq
5iDjO1uGG05IOc10Vj9+T/cj/wDQajn0SwuWYzRSMjPvaLzn8pjnOTHnaeeT xyeTWR2mHL4l
1Fmv3tLXzvsl2YFtktJZGlCkBj5qnap5JwRxx1qjp+rzaffXVpAqg3er3eZD C820IqnhEIJy
SO/FdU2iWDTSyeVIvnPvlRJnWOQnglkB2nOOcjnvmmnQdNLFhbsjmd7jzEld XDsMMQwORkdQ
Dj2oAyYdf1Sa5s7FraO3nubieMTTQOqtHGoYMIyQRuyBy3GD+DtVl1VfEWhQ JdxRGUThlVGM
blV6su4ZyMED+E55atZ9EsHWMNFJvicusomcSgkYJ8zO48YHJ6ADsKdLo9jN HAjQsDbktG6S
MjqTncd4IbnJzzyeTmgB2q3y2Fn5hkjR3dY496s2WY4GFXlj1O0dcdR1FHQt Xm1C+1C0nVSb
Qx4kELw7g655RySMEHvzWle2NvfwrFdR71Vw6kMVZWHQgjBB9xUdjpdpYTTz W6SebcbfNeSV
5GbbwMliemaAObgvdS0/UpWRp7uPUpZ4YA5aRYJklcLn+7Ht5OMn5T2FQ6Lq d/b3f9kx3LTP
LqNzEtxeFpiiRIpAxkZzn1A68c12EVrBEqhIlwsjSrnna7EliM9M7m/PFUzo Omliwt2RzO9x
5iSurh2GGIYHIyOoBx7UAY9v4jv7m+g05EtkuGvLi2acozJiJQ2Qm4EZyP4j jHvxm6Xq9zp1
zcWaeWZbvVbrzJhbvKBsVScRqdxyT68D1rqv7B00RxotuymORpVkWV1k3t94 lwdxz3yecD0F
NTw7pUahYrXydsrTKYpGRkZhhtpUggEADA446UAYMd9d33iXQmvbdoXjnvI1 YxNH5qCMYcK3
IyD0yelWtTkmfxktttvp4P7PEnkWtyYsN5hG4/Oo6cdfStqPR7GO4t7gQsZr cu0cjyMzZYBS
SSctwAOc4AGOlF1pFndXovJFlW4EfleZFPJGdmc4+UjvQBj6nrV7pmpDSoUt mluBELBpZCcc
4fzSW3duCM59zkVDP4k1KKw1S/8ALtDBp961vs2tulUOo65wpwevOc9Bjnal 0HTZo7qOW3Zx
diMTlpXJfZ93JznjHXv3zVGw8MxK1+dRHnLcXr3CRrM/llSQVDJkKTkdwe1A FW68R38Vjqmo
xpbfZ9PvDbeQyMXkAZVJ37sDO4/wnHvVrTNS1jU7y8WNbGO1trua3LsHLnaP kO3OOpGeRntj
vel0HTZpJXe3YiWQSyRiVxG7jHLIDtPQZyOe9WrSxt7Lz/s0ezz5Wmk+Ync7 dTz9KAOR0rW9
RsvCWnXMsy3L3dyIEeSN5HTLvkthsycDgDH41am8RarA6x/ZI333sFvHNLby 26yq6nOFbJBB
XGeevT12hoOmi3aAW7CIyCVUErgRuCSCnPyck/dxTjolg3lmSKSRo5VmV5Jn dgy52/MSTgZP
HTk8c0AWLD7Z9jj/ALQ8j7Vzv8jOzqcYzz0xViiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKAKdj9+T/cj/8AQatSSJFG0kjqiICzMxwFA6kmqtj9+T/cj/8A QaNYgkudGvre
Fd0stvIiLnGSVIA5oAda6hb3Uhjj81XA3bZoXiJHcgMBnGRnHTI9RVqse/uz f2vk2kV8uZYd
7iKSEhTKgYAkBvu7uR0AOSOM04f7Uj1SeXdPNKrzH7P5bqjp83ljzGbyxn5O VXd6/wARoA6J
pERkV3VS52qCcbjgnA9eAT+FOrk7KG6kv4BI93NaQXEUu9oZ4yrFJVP+sYuR kx5wduDyMbjT
rGPUvs85uLm8Mpg/0gJbyDbJlc4LP82Pn/1IGRnGDsoA6aeeO3QPK21S6oDj PLMFA/Mio5b6
3hlaOSTa6+XkbTx5jFE/NgR/Os+ZJpdBgPlzlklhlKOS7hFlVj23NhRxkbjx kbsiqeo241b7
Wwtp3tZ/scLB4njZgs5L8EBsBWBz0688HABuXV9b2m77RJs2xPMflJ+RMbjx 6bh+dWK5O906
+P2ue5WSe6k0y6t9yp1C7AgwvGWO9wOvzY5210lpeRXe/wApJ12Yz5sDxdfT cBn8KALFFcvY
w38MFq5N8ZFis3bzJJG+d32zZBPOFA4P3eowTmiP7f5CbPt3meUv9obvM+/v j3eXn/Z87/Ve
2OdtAHSRTxyvMkbZaF9jjHQ7Q2PyYfnRFPHK8yRtloX2OMdDtDY/Jh+dcm0N x5k5tnvoLF7h
m3SQ3LyM3lwhchWWTHEnJO3j/dqwI76PzGlF8ZWuEJMSbTI3kRDPy5AOQ2M5 jyCG7EAHSNPG
twluW/eujOq46hSAT/48PzqSsXWY4zqtlJcJeGFYJlLWolyGLR4BMfPIB68c VReTVRcWDT+f
HdJ9nSRUildZASvmMSp8perjlSflyDyuADqKjuJ47a3luJm2xRIXdsZwAMk8 Vzcov2tHVJL5
E+0Dz3kSRm27WzhUIfO7YD5Z2cArwWAh1CK6fSbiK8OoT7rNltfKjlXc5MnD qhJ+75X+sJPX
PO6gDrqKy9Xz9ot/O+1/Y9j7/svmbvMyuzPl/NjG/wBumecVn2sWqCJrm6ku zdpcWy+WD8gB
WESkKOCOX9QMEjByaAOkorn9cS/fUR5E88UYiXyPKhkkzLls52sqj+D/AFmV /DdQ32z/AEzy
ft39p/v9nXydvzeV979308v7vzZ6/wAVAHQUVzsKTSajbC1OoDTxOhPnNMG3 BJS2d/zbciLg
/KTx1zTvDyX4uC15PO7mL/SEeGRVEuR0Z2IP8X+rAX/x2gDoKK5PVpNT+1XT W32tJHSZDFHF
MwCiJ9jB8mPJIQ/KAwLYznObl1Fc294YTJfSWH7p53UuzsSJQ20r8w+YRZVM AegBNAG5BPHc
IXibcodkJxjlWKkfmDUlYNrHNH4bZYEuUzcuxDBxL5JuCWPPz5MZJ/venOKz WNxLJOltcXyW
KXDDMkdzJIG8uEqCFZZAOZDydv5rQB2FFc7DDqKiS4mmvHnS5tkVTwu0rCJW 2LlTnL56hSCR
g5JhsYb+GC1cm+MixWbt5kkjfO77ZsgnnCgcH7vUYJzQB1FRxTxyvMkbZaF9 jjHQ7Q2PyYfn
XNx/b/ITZ9u8zyl/tDd5n398e7y8/wCz53+q9sc7artDceZObZ76Cxe4Zt0k Ny8jN5cIXIVl
kxxJyTt4/wB2gDqhdQYuCZVUWxxKzcBPlDck+zA5psV7BLMkKmRZHQuqvGyE gbcnkD++v45H
UHGL9nuzoOupNHK9xLGcZjAaRvs0YOAuR94EcEjPAqvfW+orqFx9m+0hIwyJ Iwd9sZFruwc7
jwJOh3EhsHNAHVUVzKreJZRZl1CZfPPl7InjJGFx95mfg7iPM+Q4IbAKEdNQ AUUUUAU7H78n
+5H/AOg1cqnY/fk/3I//AEGrlABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFAEc8ENzC0NxFHNE33kkUMp78g0QQQ20Kw28UcMS/dSN QqjvwBUlFABR
RRQAUUUUAFFFFABRRRQAUUUUAU7H78n+5H/6DVysOcKXG5I2+RfvoGx8o9aj xH/zwg/78r/h
QB0FFc/iP/nhB/35X/CjEf8Azwg/78r/AIUAdBRXP4j/AOeEH/flf8KMR/8A PCD/AL8r/hQB
0FFc/iP/AJ4Qf9+V/wAKMR/88IP+/K/4UAdBRXP4j/54Qf8Aflf8KMR/88IP +/K/4UAdBRXP
4j/54Qf9+V/woxH/AM8IP+/K/wCFAHQUVz+I/wDnhB/35X/CjEf/ADwg/wC/ K/4UAdBRXP4j
/wCeEH/flf8ACjEf/PCD/vyv+FAHQUVz+I/+eEH/AH5X/CjEf/PCD/vyv+FA HQUVz+I/+eEH
/flf8KMR/wDPCD/vyv8AhQB0FFc/iP8A54Qf9+V/woxH/wA8IP8Avyv+FAHQ UVz+I/8AnhB/
35X/AAoxH/zwg/78r/hQB0FFc/iP/nhB/wB+V/woxH/zwg/78r/hQB0FFc/i P/nhB/35X/Cj
Ef8Azwg/78r/AIUAdBRXP4j/AOeEH/flf8KMR/8APCD/AL8r/hQB0FFc/iP/ AJ4Qf9+V/wAK
MR/88IP+/K/4UAdBRXP4j/54Qf8Aflf8KMR/88IP+/K/4UAdBRXP4j/54Qf9 +V/woxH/AM8I
P+/K/wCFAHQUVz+I/wDnhB/35X/CigCSf74/3F/9BFQTSpBDJNK22ONSzHGc ADJqef74/wBx
f/QRVHVUaTSbxEUs7QOFVRkk7TwKAJ3lSN41dsNI21BjqcE/yBp9YyWEsV/Z MwLRW0rRw4H3
YzG5yf8AxxOf7mf4qiT7Z5Sbfte/y1+2bt/3tybtmf8AZ8z/AFftj+GgDbSV JHkVGy0bbXGO
hwD/ACIpj3UKR3Ds+Ft8+acH5cKG/HgjpWCY5t8pha7itGmZtzxzs7HZGB0I fHD8njj6Vb8m
5Ok6ssqSPNIhxlMFz5CA4AyOoI4zzQBp29zHc7vLWUbcZ8yF0/LcBmpqzDLI 9hKsEt5LMHQo
00JjOSwwD8q5XI+bHOM+1Z5ecyTIzXn2wQAxKpk2CUvJzxxtyBjdxtAz3oA6 OkV1YsFYEqcM
AehxnB/Aj86wrv7Z5dx5P2v7V++3437fL2v5e3+HP+r+783X3p1zbTwvciFp 0R50LuPMkzGI
goI2kMTvXnBz0J4oA3KKxIY7rZMZJbs4t0CMFYcF3ydu7JO0Lnnfj0Y1o2Bz CpYTq+wZEpY4
GTjk4z+PzYxu5oAtUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAST/AHx/uL/6CKjqSf74/wBxf/QRVa6uI7W2knlyI4xuYgZ4 oAloqn/aB/58
NS/8A5P8KP7QP/PhqX/gHJ/hQBcoqn/aB/58NS/8A5P8KP7QP/PhqX/gHJ/h QBcpAihy4Uby
AC2OSBnA/U/nVT+0D/z4al/4Byf4Uf2gf+fDUv8AwDk/woAuUVT/ALQP/Phq X/gHJ/hR/aB/
58NS/wDAOT/CgC5RVP8AtA/8+Gpf+Acn+FH9oH/nw1L/AMA5P8KALlFU/wC0 D/z4al/4Byf4
Uf2gf+fDUv8AwDk/woAuUVT/ALQP/PhqX/gHJ/hR/aB/58NS/wDAOT/CgC5R VP8AtA/8+Gpf
+Acn+FH9oH/nw1L/AMA5P8KALlFU/wC0D/z4al/4Byf4Uf2gf+fDUv8AwDk/ woAuUVT/ALQP
/PhqX/gHJ/hR/aB/58NS/wDAOT/CgC5RVP8AtA/8+Gpf+Acn+FH9oH/nw1L/ AMA5P8KALlFU
/wC0D/z4al/4Byf4Uf2gf+fDUv8AwDk/woAuUVT/ALQP/PhqX/gHJ/hR/aB/ 58NS/wDAOT/C
gC5RVP8AtA/8+Gpf+Acn+FH9oH/nw1L/AMA5P8KALlFU/wC0D/z4al/4Byf4 Uf2gf+fDUv8A
wDk/woAuUVT/ALQP/PhqX/gHJ/hR/aB/58NS/wDAOT/CgC5RVP8AtA/8+Gpf +Acn+FH9oH/n
w1L/AMA5P8KALlFU/wC0D/z4al/4Byf4UUAaE/3x/uL/AOgisvX/APkBXv8A 1yatSf74/wBx
f/QRWXr/APyAr3/rk1AHVXUpgt3kGNwwBnpknAz7ZNZVzOYVlLzzGSP5g6vw wwMfL098Y7Vq
3UC3Nu8L9HGM+h7GuYudE1KS5wFVlPG/zBtPoSOv6U7XWjsRJNu3Q1ItWlbw 7eXu1DPaxyHk
cMyrkZH5VKurw3mopaadd2k263lkZkYSbGBQLkA9PmPHfHUUR6QE0GfTvNAe eJ0eQLnlhjOP
b+lXHtd+ow3e/HlRSR7cddxQ5z7bP1oe+hS2Mk6rf22jz31wIrgpciFYreBg xAn8tsAuckjk
DjB9adqGveVNOlmI5Vi0+W78z7yFl2lVBB9GyR6Mp71c/sz/AEH7N53/AC9/ ad23/pv5u3Gf
wz+PtVebw/C0MsUEnlLJb3EP3AcebtweMcKECgegAzxSGbFFV7RLxN/2yeCX ONvlQmPHrnLN
nt6VYoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigDDn++P9xf8A0EVl6/8A8gK9/wCuTVqT/fH+4v8A6CKy9f8A+QFe /wDXJqAOl1Sf
7Pps8mWB27QV6gngH8zXMQajNMf3c9wrjJG6UsOD9a6PWrQXmmTR7dzqN6fJ uORzwPfp+Nct
a6bNBJva3mJGQMWzDqevSriotanLWc+dW2LeuM2prpAfEbTSPGSOQDuVc/1r Ds7P7Vt/ebN0
8cPTP393P4ba19Tkezt9IlkiYNFLLJsYFScOD36Vn291a2jxCJppVFxHM5aM KQEzwBuOc7vb
pWkb8py1bOpeX9aIgWwl8u8dxt+yYDjg/MW24/nz7VFdQ/ZruaDdu8p2TdjG cHGasnUC9o8M
gP8AqRGCMctuTk+nyoo/D3NN1GS1nuJbiCSYtLIXKPGFABJPUMc/lVK5i1G2 hCbO6CBzbTbS
hcHYcFR1P05HPvTTBMsCzNE4iY4Vyp2k+x/A1fi1GFJo3KvhZLZzwOkaFW7+ vSiHUYYJFuFV
2l2RI0ZACgIUOQ2ec7Bxjv7cl2HLHuQSabdRxwloJhLK7qsRjIbCgHIHfqfy qGW2aK3SR8qx
keMoRgqVC/8AxX6VfgvrW2txBG0rq2/c7wKduShHyliD9zuR19qr314tzEij cSjsclVXI2oo
4HA+707ccmhXHJRS0KVFFFMyCiiigArf8G/8haX/AK4H/wBCWsCt/wAG/wDI Wl/64H/0JamW
xtQ/iI7Siiiuc9gKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAw5/vj/cX/
ANBFZev/APICvf8Ark1ak/3x/uL/AOgisvX/APkBXv8A1yagDqrt2jtJpEOG WNiD6ECs6W8l
W5eCB7mWSNlDHYhQE8gHABxjuPzq9qJxp10f+mL/AMjWLctDLqMdxHc2abGU +YJMPgdVI6HP
4UKKbd2JtrY07qW0kslury1WRY22sGRW8v5trHJ6KOpPoM1Wv20fT3Cz2UAG FZ3ESbYwzqgL
E9MliforelWLeWY6YXs1SSRpWCkn5QDIQW6jIAJOMjOMd6pXOkSR2wsIIVuL SWSGSTeEGNkk
e4EcAgoCQMcbcDgqoE3YHFN7Et82j2MkkcllAzx20l0ypEhIRMZ4988duD6V e/syw/58bb/v
0v8AhWJc6HdiO4ILXM0lhc24kaQFjnYsSknB5CkntuZjxmt60uJbjf5tlPbb cY80od302sf1
9ad2Llj2KFimnXuGTSVSJ08yKV4E2yr6jGcdQcNg89ODiae102CW3jewgJuJ DGuIV4IVm5/B
TVJLK9Md1DaRS2Aa2kjAe4Lp5pwEMWCSir83QLwV444b/ZSXElqqaR9itVuA 8sW9VDDy5ASU
QlcEsoPOWHBGAKLsOWPY1f7MsP8Anxtv+/S/4Uf2ZYf8+Nt/36X/AArnp9Dv JJAHjnKLvS2E
LQgQfvZCpy4JQbDHgx8gL04UVJNoc5juHis4xO6XkgYbQxmMmYGz/eClsH+H J6Zouw5Y9jd/
syw/58bb/v0v+FH9mWH/AD423/fpf8Kylsbz/hI47swSKfNfzZUEKxtFsYIM j94x+5kHjIOO
AK6Ci7Dlj2Kn9mWH/Pjbf9+l/wAKP7MsP+fG2/79L/hVuii7Dlj2Kn9mWH/P jbf9+l/wqSGz
tbdy8FtDExGCUQKcfhU9FFw5UugUUUUigooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigDDn++P8AcX/0EVl6/wD8gK9/65NWpP8AfH+4v/oIrL1//kBXv/XJ qAOruZDDbSyL
jKIWGfYVQm1FoJjEZonlBUFBCwBJ6DdkgEjpVvUDjTro/wDTJ/5GsueG4Gpr NbRum518xxIN
jrjB3Ke/pjNCjzNibsapvIVt1ndiiM6x8g5DFgoH/fRxRcX1vayxxzybXl+4 NpOfmVO3+06j
8frVUPjSpP8AR/tO+V4/KIyG3SFfm4Py88nBwM8Gs3UNNc2rWFxFJeLcvAXn UMTsWWMMjHJI
ABJHPTcTyCzJbDNy6vre03faJNm2J5j8pPyJjcePTcPzqxXJ3unXx+1z3KyT 3UmmXVvuVOoX
YEGF4yx3uB1+bHO2uktLyK73+Uk67MZ82B4uvpuAz+FMBtrqNrdyGOB2JxuU sjKHX+8hIAYc
jlcjkeoqaWeOJ4UkbDTPsQY6naWx+Sn8qw4PtsVvPbaYLsLHaOsUdzEF8iQA CNEYgBx97Jy4
+Uc88ta2W6ms0tTqa24ucu83mAr+6lBwZPnGcqCeByNpDZoA6KiuTnTVWkC+ fdxKm9LbbDLI
zMJZAMlWUfdEXMuVPX+9mSaG/WO4ljN95uy8mUeZIR5iSfuQBnGNpOF6MOoO BQB1FRpPHJNJ
EjbnixvwOFJ5Az0zjnHXBB7isNZL3/hI42/fojyuksXlTMgjCNtbeSY+SEPy gEbsE9ck8Esd
3eyst2tvLep53kmTc0Yt1AKhef8AWYBK88YPANAHQVXF9bmzhuxJ+4m2eW20 87yAvHXksKzd
FS7N9LJcm58tYFEIkZsbTLLjIPVtgjyT8w78k0QRSpJDqJtm8uWTcLXa26Dz MDfjoG5JfgYB
bBzuMgBpC+tzZw3Yk/cTbPLbaed5AXjryWFSQTx3CF4m3KHZCcY5VipH5g1y dpo91HpWmRNF
J5Fu9rcRxbfmSRnTzM9/l/eE54/e9tgrotHjeOzkWRGQm5uGwwxwZnIP4gg0 AXqKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMOf74/wBxf/QRWXr/ APyAr3/rk1ak
/wB8f7i/+gisvX/+QFe/9cmoA65lV1KsAysMEEZBFQf2fZf8+dv/AN+l/wAK s0UAMjjSJAkS
KiDoqjAFPoooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKAMOf74/3F/9BFZev/8AICvf+uTUUUAdhRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFAH//Z
--------------070606030904000303030904--
--------------050805000407090804090709--
Re: UML2 Stereotype with extensible properties [message #474880 is a reply to message #474877] Fri, 03 August 2007 08:01 Go to previous messageGo to next message
Mark,
Which version of UML2 are you using? I believe the exporter was added in the
2.0 release...
Kenn
news:2dc334205dfea9a8fd808b1f4914f91c$1@www.eclipse.org...
> Hi Kenn,
> genmodel but the only options are to export to "XML schema" or "XML schema
> for XMI". Am I looking in the wrong place to export to UML2 or can the XML
> Mark
Re: UML2 Stereotype with extensible properties [message #474991 is a reply to message #474880] Wed, 08 August 2007 07:05 Go to previous message
Hi all,
Just to complete this thread, I reinstalled EMF and UML2 and found the
export option allowing an genmodel to be exported to a UML model. Thanks
lads for your help.
Mark
Re: UML2 Stereotype with extensible properties [message #624158 is a reply to message #474753] Wed, 01 August 2007 15:42 Go to previous message
Mark,
Kenn
> Hi all,
> Mark
Re: UML2 Stereotype with extensible properties [message #624160 is a reply to message #474863] Thu, 02 August 2007 06:24 Go to previous message
Thanks again,
Mark
Re: UML2 Stereotype with extensible properties [message #624243 is a reply to message #474865] Thu, 02 August 2007 08:06 Go to previous message
Mark,
Does that help?
> Thanks again,
> Mark
Re: UML2 Stereotype with extensible properties [message #624245 is a reply to message #474867] Thu, 02 August 2007 09:46 Go to previous message
Hi Ed,
Mark
Re: UML2 Stereotype with extensible properties [message #624246 is a reply to message #474869] Thu, 02 August 2007 11:04 Go to previous message
Mark,
tasks)?
Mark Melia wrote:
> Hi Ed,
> Mark
Re: UML2 Stereotype with extensible properties [message #624247 is a reply to message #474869] Thu, 02 August 2007 11:53 Go to previous message
Mark,
Kenn
> Hi Ed,
> Mark
Re: UML2 Stereotype with extensible properties [message #624252 is a reply to message #474870] Fri, 03 August 2007 04:20 Go to previous message
Hi Ed,
Mark
Re: UML2 Stereotype with extensible properties [message #624253 is a reply to message #474871] Fri, 03 August 2007 04:31 Go to previous message
Hi Kenn,
Mark
Re: UML2 Stereotype with extensible properties [message #624254 is a reply to message #474877] Fri, 03 August 2007 07:44 Go to previous message
Mark,
Mark Melia wrote:
> Hi Kenn,
> Mark
<html>
<head>
</head>
Mark,<br>
<br>
<br>
</blockquote>
Mark Melia wrote:
<blockquote
<br>
<br>
model?
<br>
<br>
<br>
Mark
<br>
<br>
</blockquote>
<br>
</body>
</html>
UUAFFFFAH//Z
Re: UML2 Stereotype with extensible properties [message #624256 is a reply to message #474877] Fri, 03 August 2007 08:01 Go to previous message
Mark,
2.0 release...
Kenn
> Hi Kenn,
> Mark
Re: UML2 Stereotype with extensible properties [message #624359 is a reply to message #474880] Wed, 08 August 2007 07:05 Go to previous message
Hi all,
lads for your help.
Mark
Previous Topic:navigable owned end property vs. owned end property
Next Topic:RE: Activity Diagram
Current Time: Sat Jul 19 11:52:24 EDT 2025
Powered by FUDForum. Page generated in 0.30535 seconds
