Home » Eclipse Projects » Platform - User Assistance (UA) » Computing help URLs
Computing help URLs [message #474763] Mon, 03 November 2008 17:47 Go to next message
I have made an eclipse plugin and facing the following issues in computing
the URL:
1. URL for documents relative paths : I have a help plugin that appears to
work when the document I refer to is located below the plug-in directory.
So when I compute the 'href' argument in
PlatformUI.getWorkbench().getHelpSystem().displayHelpResourc e(href);
in the following way:
href = "/org.eclipse.rtsc.xdctools.help/" + "cdoc/" +
elemName.replace('.', '/') + "/package.html";
help shows the document located in the 'cdoc' sub-directory located in the
plugin directory.
However, if the documents are kept at a level higher, the document does
not showup.
In other words computing 'href' in the following way
href = "/org.eclipse.rtsc.xdctools.help/" + "../docs/cdoc/" +
does not work. How do I compute 'href' when my docs are located above the
plugin directory?
2. URL for documents in zipped files: If I have the sub-directory 'cdoc'
mentioned in part 1 zipped up, then the following computation of 'href'
does not work
href = "/org.eclipse.rtsc.xdctools.help/" + "docs.zip!/cdoc/" +
What would be the right way to compute the URL for documents residing
within a zipped file?
Re: Computing help URLs [message #474769 is a reply to message #474763] Tue, 11 November 2008 19:38 Go to previous message
The help server will only serve documents that are located in plugins.
Partly this is for security reasons, we don't want users to be able to
access our entire disks through the web server.
If the server sees an address like
http://127.0.0.1:3477/help/topic/org.eclipse.jdt.doc.user/co ncepts/concept-java-search.htm
it will interpret it as a file in the plugin org.eclipse.jdt.doc.user.
When you use ".." it does not cause you to navigate relative to the file
structure on disc, rather it affects the url so if from that page you
opened "../../foo.html" it would try to open
http://127.0.0.1:3477/help/topic/foo.html
which would not be found.
Amit Mookerjee wrote:
> computing the URL:
> to work when the document I refer to is located below the plug-in
> directory. So when I compute the 'href' argument in
> the plugin directory.
> not showup.
> the plugin directory?
> does not work
Re: Computing help URLs [message #621806 is a reply to message #474763] Tue, 11 November 2008 19:38 Go to previous message
> computing the URL:
> not showup.
> does not work
Previous Topic:add files that do not lay in project folder
Next Topic:Error searching in remote infocenter
Current Time: Sat Jul 19 05:25:27 EDT 2025
Powered by FUDForum. Page generated in 0.06875 seconds
