Home » Modeling » UML2 » XMI question wrt Association
XMI question wrt Association [message #474388] Thu, 19 July 2007 11:32 Go to next message
Originally posted by: user.domain.invalid
Dear All,
I am doing an XSLT which uses the EMFT compare tool to create an XHTML
report on the differences between 2 models.
The only minor problem I am having is to see how in UML2/EMF XMI
Associations work.
Basically all I want to say is "the Association linking X with Y has
been deleted" or "An association between X and Y has been created".
Do Associations always link OwnedAttributes?
I am using the output form IBM RSA 6 & there appears to be some
variability e.g.
<packagedElement xmi:type="uml:Association"
xmi:id="_3iuUKg3aEdy0fvloa5NWrg" memberEnd="_3iuQcw3aEdy0fvloa5NWrg
_3iuULA3aEdy0fvloa5NWrg">
<ownedEnd xmi:id="_3iuULA3aEdy0fvloa5NWrg"
type="_3iuQTQ3aEdy0fvloa5NWrg" association="_3iuUKg3aEdy0fvloa5NWrg">
<upperValue xmi:type="uml:LiteralUnlimitedNatural"
xmi:id="_3iuULQ3aEdy0fvloa5NWrg" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger"
xmi:id="_3iuULg3aEdy0fvloa5NWrg" value="1"/>
</ownedEnd>
</packagedElement>
xmi:id="_3iuULw3aEdy0fvloa5NWrg" memberEnd="_3iuSFQ3aEdy0fvloa5NWrg
_3iuUMA3aEdy0fvloa5NWrg">
<ownedEnd xmi:id="_3iuUMA3aEdy0fvloa5NWrg" name="person"
visibility="private" type="_3iuSEA3aEdy0fvloa5NWrg"
association="_3iuULw3aEdy0fvloa5NWrg">
</ownedEnd>
</packagedElement>
So what ID'es do I use in the above examples to find the 2
OwnedAssociations at each end ?
TIA
Adam
Re: XMI question wrt Association [message #474389 is a reply to message #474388] Thu, 19 July 2007 13:41 Go to previous message
Adam,
Properties that represent ends of the associations are always referenced by
an association as its member ends, so you'd be interested in the 'memberEnd'
XML element/attribute. Sometimes an association is not navigable, in which
case it will be owned by the association and hence also be listed as an
owned end of the association (i.e. in the 'ownedEnd' XML element).
Kenn
"AdamF" <user@domain.invalid> wrote in message
news:f7o060$8do$1@build.eclipse.org...
> Dear All,
> Associations work.
> Basically all I want to say is "the Association linking X with Y has been
> variability e.g.
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> TIA
> Adam
Re: XMI question wrt Association [message #623912 is a reply to message #474388] Thu, 19 July 2007 13:41 Go to previous message
Adam,
Kenn
> Dear All,
> Associations work.
> variability e.g.
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> TIA
> Adam
Previous Topic:XMI question wrt Association
Next Topic:[Announce] MDT UML2 2.1.1 M200707191455 is available
Current Time: Sat Jul 19 22:25:13 EDT 2025
Powered by FUDForum. Page generated in 0.06998 seconds
