Home » Eclipse Projects » Platform - User Assistance (UA) » Contributing to root Welcome page
Contributing to root Welcome page [message #474308] Tue, 02 September 2008 03:06 Go to next message
Is it possible to add another icon/button to the root welcome page of
Eclipse Workbench (like 'Overview', 'Samples', etc)?
If yes then how?
I am able to contribute to second level pages (e.g. Overview, Samples),
but want a link/button from root page to provide switching to my plugin's
perspective.
Please help
Thanks.
Re: Contributing to root Welcome page [message #474312 is a reply to message #474308] Tue, 02 September 2008 13:24 Go to previous messageGo to next message
The short answer is yes, it is possible to contribute to the root page.
The hard part is figuring out the name of the anchor you need to
contribute to. If I can find some time I'll create and post an example
or maybe someone else on the group already has one that they can share.
> If yes then how?
> plugin's perspective.
> Please help
> Thanks.
Re: Contributing to root Welcome page [message #474313 is a reply to message #474312] Wed, 03 September 2008 02:10 Go to previous messageGo to next message
Thanks for replying.
Could some give some indication where to look for, to locate the anchor(s)
of the root page.
An example will certainly be still more helpful.
Thanks.
Re: Contributing to root Welcome page [message #475098 is a reply to message #474313] Mon, 02 February 2009 19:30 Go to previous messageGo to next message
Vikram, did you ever figure this out? Chris, can you provide more info on
this if possible? I am looking to do the same thing.
Re: Contributing to root Welcome page [message #475099 is a reply to message #475098] Tue, 03 February 2009 09:14 Go to previous messageGo to next message
> on this if possible? I am looking to do the same thing.
Because you did not quote the original message, I don't know what
specifically you are asking about. But here is some material on
contributing to the universal welcome:
http://www.eclipsecon.org/2007/index.php?page=sub/&id=36 55 (click the
"Presentation File" link near the top).
We've used that information to add our own section to the welcome page.
Hope this helps,
Eric
Re: Contributing to root Welcome page [message #475100 is a reply to message #474312] Tue, 03 February 2009 12:31 Go to previous messageGo to next message
Sorry Eric, here is the original message
>> If yes then how?
>> Please help
>> Thanks.
Re: Contributing to root Welcome page [message #475101 is a reply to message #475098] Tue, 03 February 2009 13:45 Go to previous message
--------------010503020600020907060507
I just made an attachment which adds a contribution to the root page.
Creating an intro contribution is relatively easy if you use the PDE
wizard as follows:
File/New/Project/Plug-In Project
Give the project a name and accept the defaults but on the templates
page select "Custom plug-in wizard".
Hit next and select Universal Welcome Contribution.
Moving it to the root page is harder. I started with this contribution
and changed the path to be "root/head-anchor" changed the text a little
and modified the css to change the color of the text.
The hardest part was figuring out what the anchor was so I just made a
change today which will make this a little easier. This will start to
show up in the nightly builds soon. If you use Eclipse 3.5M5 there are
two additional tools which can help you to debug intro. To turn them on
in the Tracing tab of the Run Configurations dialog set debugging on for
org.eclipse.ui.intro and turn on debug./toolbar. Then when you launch
intro you will see two new toolbar buttons, one launches the intro page
in an external browser so you can use Firebug to debug your css. The
other shows a tree of the intro model, however it does not show the path
to anchors. That was the change I made today.
Intro is way more confusing than it should be, if anyone is interested
in writing a doc page on tips and trick for writing intro I will be
happy to incorporate it into the Eclipse documentation.
Content-Type: application/x-zip-compressed;
name="org.eclipse.demo.zip"
Content-Disposition: inline;
filename="org.eclipse.demo.zip"
UEsDBBQAAAAIACtLQzpPww7kzwAAAHYBAAAsAAAAb3JnLmVjbGlwc2UuZGVt by5yb290Y29u
dHJpYnV0aW9uLy5jbGFzc3BhdGiVkMFqAjEQhs8V+g5L7s7WQqGH3UopK1So im69lpgM67Rx
EieJ6NtXS6WlB6G3+YdvPoa/Gu43rtihRPJcqwHcqALZeEvc1eq1HfXv1fDh ulcZp2MMOq2P
4eonISc5FB/EtlbGsypOy1p56QCNoxAR3m0CpzOb9dEJ43nz9jSdtI/Pk2Ze /uWIEwprBxZX
uYNM35cosEiarRa7fGkPAcvx7aLpD+BOlf9+KFgE4wVBcJtJ0M5c7ojjJVUU c1adxgukzynk
dIZXxF9wVf4u8BNQSwMEFAAAAAgAK0tDOoIbwuTuAAAAtgIAACoAAABvcmcu ZWNsaXBzZS5k
ZW1vLnJvb3Rjb250cmlidXRpb24vLnByb2plY3S9ksFOAyEURdea+A/N7IW6 c0GniZruNCbV
D6DwHGmGB3lA4+cLyGgmo4kL4+7dy70cAojtmx1XJ6BgHG66K7buVoDKaYPD pnt+2l1ed9v+
4lx4ckdQ8Q6CIuNjTmf3TKC00DsaGKjR+ABMg3WMnIvKYSRzSCUqeM2VgnLW AsZe8Gkqbts9
VMFn6pDMqPceVFFN3uaqRF2db85w1JEpR3mQJ1kLQF9HyA1JQyrs0DSfG4Iv KL/ieg3sXqJ5
gRBv/he7V69g5Z9AmzNdeebFRNDSH2KBfxzTYPChLhZ6Df1UmD0PLjrTXIif f2H+794BUEsD
BAoAAAAAAMtSQzoAAAAAAAAAAAAAAAAmAAAAb3JnLmVjbGlwc2UuZGVtby5y b290Y29udHJp
YnV0aW9uL2Jpbi9QSwMECgAAAAAAy1JDOgAAAAAAAAAAAAAAACoAAABvcmcu ZWNsaXBzZS5k
ZW1vLnJvb3Rjb250cmlidXRpb24vYmluL29yZy9QSwMECgAAAAAAy1JDOgAA AAAAAAAAAAAA
ADIAAABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rjb250cmlidXRpb24vYmluL29y Zy9lY2xpcHNl
L1BLAwQKAAAAAADLUkM6AAAAAAAAAAAAAAAANwAAAG9yZy5lY2xpcHNlLmRl bW8ucm9vdGNv
bnRyaWJ1dGlvbi9iaW4vb3JnL2VjbGlwc2UvZGVtby9QSwMECgAAAAAAy1JD OgAAAAAAAAAA
AAAAAEgAAABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rjb250cmlidXRpb24vYmlu L29yZy9lY2xp
cHNlL2RlbW8vcm9vdGNvbnRyaWJ1dGlvbi9QSwMEFAAAAAgAy1JDOjRAjENX AgAAwwQAAFcA
AABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rjb250cmlidXRpb24vYmluL29yZy9l Y2xpcHNlL2Rl
bW8vcm9vdGNvbnRyaWJ1dGlvbi9BY3RpdmF0b3IuY2xhc3Olk21PE0EQx/9L S6+tB2gRFBER
FOiD9CS+rDEqiGnSECLCW7M9lmPxenvZ20M+lg8vML7wA/ihjLNH5aEaDPHN 3c7szG/+M3P3
4+e37wBWsOxgiKGhdOAJP5RxIrxd0VOeVsr4KjJadlMjVeS98I085EZpB3mG xfMJqfTiMA0k
BXUTo7lvttubmYOhtNnZft3eeNdeY6h0Dvgh90IeBd4WkaOgxTCyqqLE8Mjs 8DAVRZQY5gje
7MObVk1zUA1DIe4XWO5cQTvVKzyVkTTPGHLV2g5DflXtijJyuO7CxQjDWEdG YiPtdYV+y7uh
sLKVz8MdrqW1+8682ZcJwzBJ14ZhoZrJUEkgvT3Ne+KD0u+9l2m0Gwpq0Igj 07Llyq+OfBFb
UYmD2wzjZxM5vbFq7ri4iYkSGO66KOMag+OfYBjm/12K9CVGxZY052IWE1Q5 EGZN7PE0JIRX
rV1xbBVKb/d4INZE4msZk5fhefXPjV4EH+xxX3haJCrVdBggtMrU4JKLKmoM U/Li5bpWvd9f
0Zu/FPrP0jSimJt9GsxWFrAu7VpHT3tuWjzmSGCOfpQhTGEYBbKczCrSUmgt dB4mH3049Bwl
6wm9mfXWjzH2KQu9Qc8yvYEJ5DGJCp3ckyCMZwhmd00Rk3TOk3UrQ62Tx2aV 641jTNW/YPqM
N5qJmiHCPZRov5Y5eRLdZ9rTDN1aObOX0RmBbYX7g/RFil4ievVSegnzeNBv /mHWFVX5jOmP
p7RC5n2cUSyjRHEL/YwV8thbp1Ksf8XiYFLr3LAc1Mlrh9XIoh79AlBLAwQU AAAACAArS0M6
SHlpSlEAAACGAAAAMgAAAG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1 dGlvbi9idWls
ZC5wcm9wZXJ0aWVzK84vLUpO1dNTsFUoLkrW5+XKLy0pKC0BCyRl5gEFgKRe Zl5yTmlKajFQ
sCCnNB0oUpGboxPDy6WACnxdQxx1Pf3c9LHI6WERy8wrKcoH2gEAUEsDBAoA AAAAACtLQzoA
AAAAAAAAAAAAAAAoAAAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0 aW9uL2ludHJv
L1BLAwQKAAAAAAArS0M6AAAAAAAAAAAAAAAALAAAAG9yZy5lY2xpcHNlLmRl bW8ucm9vdGNv
bnRyaWJ1dGlvbi9pbnRyby9jc3MvUEsDBAoAAAAAACtLQzoAAAAAAAAAAAAA AAA1AAAAb3Jn
LmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9uL2ludHJvL2Nzcy9ncmFw aGljcy9QSwME
FAAAAAgAK0tDOhjHaD5kBAAAUgUAAD8AAABvcmcuZWNsaXBzZS5kZW1vLnJv b3Rjb250cmli
dXRpb24vaW50cm8vY3NzL2dyYXBoaWNzL3NhbXBsZS5naWYdU3tM1XUUP5k2 M3VsmqWS4TQz
xGl9l8jEarjwsVJqzi2FJVO/AlI4GWUj8JGKqZMoh3xDlJfKFYMrkmQIlSAv vzyKixCXlIfA
Be6F4BpcED2d8/v+d3bO+ZzP4/dbu95/pU/wclgOIwDITyMqRIkoEIErrVEr 1BK1QA3cVBqV
QiVRCVTAs1KjVCglSoESeFVoFAqFRCFQACEhaASFIBEEAjAwQxMWLdM08B1+ SmuptdAa+CxV
SmkltRJaAbOgplRaSi2FlsCkaFYoLaQWQgsgjrSqQWmQGoQGYMqsgUgTS6IF rIAvETRh0TKw
IK7pSaWEUsD66CxVUioplASWSyyoKaQSQgkg9USKZhVIBUIBsBlsFm2THaQf 2BuWRGBEmlgC
W8WHCZugCQvYOW5TTU9ICWwk6aOzVAkhBZCvJJdYUFOCkABsM6eieJaNBnad vVO8ynYAh8AK
FSMxaeBMmIdiYIYGjoinFd/hB5QYGUn66CxVAvjjACN+MAIGI0IwQgIjBjCM BsNKMMwCww4w
BIMhCQzSYNAC4zAY0GAsg9Gm+iniyBN0juPQY+wfQ/sY2lzY5cKOEXwwjH8/ wkYn5ubmpqZn
nDp1qteFF9LSawaeZhZXXa9pbnmEvz+w3+1zWQbG2oaxsrnN2jfUPjRqcaKl vftOReWvRcVt
DzutLhwaHHQ4HA0NDTExMVFRUaNj4/NHJz7DbLyIA/A/AZNJ9PPu68ypf3wz eYZnYIU5rSTO
bcGGc+uupd85+bIIa2lyC7oZ77HmhPv6txbejJ5WaQqszLt49+zSgYQ9ITmX qpNXRvaWhk56
pTrlvYit1z6ODPko/e25/duq8k31lx+7Brd5Rr36Tqxry3dLGt0ONuZuLznR cPmv3vXh41XB
RXHfpzUV7B0c7SuPeP/dyMcVk/zias8X5TRNeGHeB0nm4ujhq2PVZQPz7r24 ZE5ZcmDuvtVf
JYla663Z825F3M8Pdd770HojoiUvNLu7INgnytzwU3JRTorD2r+ve2N5YUHE fYf956CsnJT+
jsIDzktrlwVFdtWlle+wBqQUft2RF3+ypqjwyx7L7CsYXfBk1WqHrT77Je+Y RSVRA6WmC5sO
xBbv95x7u/b1nN/oq3hucWvMaNHIxpX2hVmth6eusHkc6l86s/bQ9C0hbYdb S50JO+1HOtri
PI4tbj/etvOX+WsGzc+e3u11w9Z+cvntGdNjA9/cvOnb1odZHad9h20Z3nP8 swJW/+sKeZjg
O+GTVr+hg87qHwL83+g8szm2flqs36KF8d6BX/R0nt1+rHKX939eprrE7kxT 14/hN3q6fHae
t9T5/mMJ7U7Z32XandJiWVB/rmWipy31yKywkNTsowV1Plb3XlvG8faMLL+W 8B09F5PklZ5L
ibKkee+UzxY0Z2UmhvWaMmR946dTd3X0ZpvLlnn2XTVvmBLmd7TzSl9OE3iE Jk4efc1uLp21
x27eOu3On3l6RZ/9ep3/Eke+5fOZbrDqf1BLAwQUAAAACAArS0M638TRDi0F AAARBgAAQwAA
AG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1dGlvbi9pbnRyby9jc3Mv Z3JhcGhpY3Mv
c2FtcGxlX2hvdi5naWYdU3lUlFUUvyqlWUy4JClomB6IxMzzjEGEEAw5nBSX BMw9Rx+KWMc8
FC4IuY0mgogJL5RFJEVEUAxmcC1QhHkCCpKsBqPsDMIMMwMSr/e+9989997f /S3f5+O72GX+
d/NgHpgAmHiUMcIYZgwxBqKilFHCKGYUMQqiSSgjhBHMCGIExCymDBOGMcOI YRCriDJEGMIM
IYaAIzGgDAgDzAAxAAEsoDkWX+bTIO6IRyjFlCJKQZzlFSGUYEoQJSBY8CYm FGOKEcUgSPFZ
RCjCFCGKgHPkqxQIBUwBUQBBWWjgpDlLTguEAnGJQ3MsvgxCkKj5w4QgQkDo 42d5hTHBiGAQ
cjkL3kSYIEQQcPWcFJ8lgAkgAiDMEGbxbW4H1w/CGyGJg3HSnCUIq8Rhjs2h ORYI50Sb1/wh
jEEYyfXxs7xCCCPgvnK5nAVvYkAYQNgsUiFiVhgNwnXhHRGrwg4QIQiFRCAJ 0iAyETyIABbQ
ICIS00TcEQ94YtxIro+f5RUC8XGAFD9IAYMUIUghgRQDSEaDZCVIZoFkB0iC QZIEEmmQaIF0
GCRokJZBavN6mDHTf0w/xHSDrGuQtZmZ1sTqDewfPavSswePSrKzs1MupEVF RUVERHSYmfrW
7Yt3Sx93D+WW1d5/0dVkZCW1TXWdfc19Ay+MrMXMqppb68ysSautrn7W19tr Mpl0Ol15eXly
crJSqQwPDw8NDc3NzZ0+YDFCsHHiHED8EzCGi37H1jwnWRU+RB3XPcpJLVSO HeieEB+T8uCX
gYfEJii7+UGMnWdL5aVd54pjBs2phdY30jUnzBW9lcrTG+/Eu+wezpRXbi5N dD2U99L3m01f
JnrFHX3ZvsvWNX25xwWbwApbzeXVbzWjoFPB1dlaWe2bQf+P/o6zKMlYr8nL qsvfeX6DW7Ds
pepWmL6jQRPYUxUz1vOszRJVTlPhMcu100erdMVFpz5YOzlk64/q0sM2J2ix Ore1PKU7lDq4
bnTf1x8Qpdg/97UP5Cg0SUvfNK6v9LteM0M5paGyOnrO02l+t5PuHTAGGGbF z7VS720u2n7g
ZFZBf+fz6y8W+YwrUIUYK1LZhuubB71/bmvNSDZdu7Mv7HVT/g6H7ETnnQ2q hvj82Yl5e56Q
oHHz2ycmlLmOuVZYdvC9K9p/D1ktbrNb0DyEY3dYpxdGH7b1+tDPpSPS3HRs RoE2MdIiPU3m
3hSp/fj45w8/URx3GDl6pWtPJNIqPzO2aWM8fm97duSvb29Guy60z7h42qDa bf3rqKwJMvev
A9Rb4pbVmp/Edu/XvorfdNSxJWG1zNfq6CS13s9Nkddun9CoSpt0ZqRav9Qt rCWjNWm/cfKy
c7uD9zTKG2lQW+ox+yvbFvS6lEyJtXusvyQ/ExDcnp6Aa0+ew7LD9p76m3Ht ly9uKNh+9tQB
Q7S872ZHR2bOQ92nmW71LjUZC5NlBj/5bWNHZ/b9tzWz5PqUvTjWontv2Q3q 3NmVW5G06Oq6
g2ss3pc/x5ndefU/neh21g/5z/Z8HaLQqdv+yNQVtAwHKq5Yn0+zvGWorvve vWfau0+dTf2d
PfdgdP0PzrDmco/PSIerOfdqwnxaPWq+cuotmhgY0ltkntLleGPU1tbeYjvF KLibP6yQeWyz
nNhQ6pTf1adxygyoWTf+pPekAOOSVX2PXY/8FuPvNutPf++qt6eeUfmM2DrP b4mlofLpnHGv
Jqxcfmhmv7dj1qovPOf2z1zpO3X20jW+jhFbrLys0rOMXuNXGFYshAX/A1BL AwQUAAAACAAE
UEM6EtOuEVMAAACIAAAANgAAAG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRy aWJ1dGlvbi9p
bnRyby9jc3Mvc2FtcGxlLmNzc+PlSlTOL0pPTc7JLChOTUnNzS/Kzy9Jzs8r KcpMKi3JzM/T
zQSy830y87IVChSqFZLzc/KLrBTKMzJLUhWsFWp5STGguCAxD2FGZWpOTn45 xBAAUEsDBBQA
AAAIAO5OQzqPzNrgDQEAADQCAAAyAAAAb3JnLmVjbGlwc2UuZGVtby5yb290 Y29udHJpYnV0
aW9uL2ludHJvL3NhbXBsZS54bWyVUc1OhDAQPi9PMZk7VG/GAHvYePOkvkAX RmgsLWkHWd/e
KWAWjQdtemi+zvczM+XxMlh4pxCNdxXeFjcI5BrfGtdVOPFrfodwrLPSOA7+ 5B2T4zoDOJR0
kXeibSiYtkIfOmqsGSO1NPjgPTfyG8x5YqnMF5WHLyJC5A9LFTYxqqiH0VIh TwSnB0GfFwR2
5aPmvsKkqnrSba5d0/uAdXY4lF3w07gK5ilJs6bKFxz/HO7RuLeNk9pcjqhb gcHqM9kKn4QI
px0TYQqC98zjvVLzPBebTSGO/7PGXzpI3tcwax6W6dcvvYkgV8NeDNgD9wTJ RCbWUamW6l03
KklegVItDa9rVT/3KstX37b/CVBLAwQKAAAAAAArS0M6AAAAAAAAAAAAAAAA KwAAAG9yZy5l
Y2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1dGlvbi9NRVRBLUlORi9QSwMEFAAA AAgAK0tDOrI5
BI/QAAAAqAEAADYAAABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rjb250cmlidXRp b24vTUVUQS1J
TkYvTUFOSUZFU1QuTUaNkEFLA0EMhe/7K+YHuMEWvKx4UNhLoSIteJ/OpiUw k2g2s7j+ekfb
rXZB6DXfy3svWXumPfZWv6L2JNy4BdxWT5m7iPX6BM9sOZFnn7BxGxELwqa0 y1YEE92OaSeR
wlElegAMkd56hA6TgM7W7l1PfIhoJeLBNOPk87fTb6vHYDR4E73CGs7iaoPv mRTro8vlbqab
6mIQRBE0s1HCGcoEVALknzFkpqH09nHqewru2g8MP6VaHkiFE7I1brXctvUC 7mbXFdnL9wvH
xkX/OVZfUEsDBBQAAAAIACtLQzqqXIW7rAAAAEwBAAAsAAAAb3JnLmVjbGlw c2UuZGVtby5y
b290Y29udHJpYnV0aW9uL3BsdWdpbi54bWx1T8sOgjAQvJPwD03vtho9eChw MJp41w8gsDab
lG3Dw/D5LiBKMO5pd2Z2JmOyvnLiCXWDnhK5U1spgApfItlE3m+XzVFmaRyZ DAqHoYGvdq8O
ExVcZ5F4iyMhhIG+BRok4zlN8EhtIn1t1dtHdagYq70qPD3Qnucvmc5/ZsUs /HiYZJxNRxfd
5FVwoLiN/NGxybX8k94RDo1ydxp1i3S9ip8Yo2EBcHv9qf8CUEsDBAoAAAAA ACtLQzoAAAAA
AAAAAAAAAAAmAAAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9u L3NyYy9QSwME
CgAAAAAAK0tDOgAAAAAAAAAAAAAAACoAAABvcmcuZWNsaXBzZS5kZW1vLnJv b3Rjb250cmli
dXRpb24vc3JjL29yZy9QSwMECgAAAAAAK0tDOgAAAAAAAAAAAAAAADIAAABv cmcuZWNsaXBz
ZS5kZW1vLnJvb3Rjb250cmlidXRpb24vc3JjL29yZy9lY2xpcHNlL1BLAwQK AAAAAAArS0M6
AAAAAAAAAAAAAAAANwAAAG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1 dGlvbi9zcmMv
b3JnL2VjbGlwc2UvZGVtby9QSwMECgAAAAAAK0tDOgAAAAAAAAAAAAAAAEgA AABvcmcuZWNs
aXBzZS5kZW1vLnJvb3Rjb250cmlidXRpb24vc3JjL29yZy9lY2xpcHNlL2Rl bW8vcm9vdGNv
bnRyaWJ1dGlvbi9QSwMEFAAAAAgAK0tDOl2zj20MAgAAmwUAAFYAAABvcmcu ZWNsaXBzZS5k
ZW1vLnJvb3Rjb250cmlidXRpb24vc3JjL29yZy9lY2xpcHNlL2RlbW8vcm9v dGNvbnRyaWJ1
dGlvbi9BY3RpdmF0b3IuamF2Ya1UbW/TMBD+nEr9D6fxpa1Y8gMqpA0KqAih CdjnyXUuqZlr
W37phhD/nXOcpElGNUBIrVqd77nnee7ONozfsxpB2zpHLoVxmJd40LnV2nOt vBW74IVW6/ls
PhMHo60fJX+rGMfcotPB0p/tgapt0HErjNd2/VtMELmRoRYqv945bxn3t9ub JjDO164WeWXZ
AR+0vc9fB1VKfEOi8NE3eorVaj6DFXzdI1AVcWTECVwy56ARr6UDT4eR7lIo kKJC4N+5xIgr
5jMTdlLwFnLdlyACVCVFJvrgR6TNiqKh7KpuNxRrKznPPP1UQjEJX6h9qoab j7fvt5/utht4
BRfPdvpiPeRwe2axBKGosOIYiWwUiR3TSbTpWphFeGxN1vaGypOPwCmrCRYn vT18sYzmsp+J
vAUvlFaXH9iRlZovU+jKIf7hNF+QROsXz41yOdV01KKEhB0lNjONAJqp1Q8O 3j5yNLFnjfTM
BYM2T8AuNbYjS/qo+34v3Pr/u9Tmn00S9K889lZUkHI9dE2VhqY7i63Hz+iD Vek2PN0paLOu
bJN2Nmug/8n61eg3WLEgfbtKWVvstJdnNDEFIr4bUPYPB1T0jSrSQSUk3XDf RGpxRJUKdBfQ
oiQxR7qRzO+HdgyjaTTR9Ax0xyOjU+4zTidPW/Q7CS3a+x5pxi0Q48R3Vh/S 8iz6t+FlgrVt
os8vUEsBAhQLFAAAAAgAK0tDOk/DDuTPAAAAdgEAACwAAAAAAAAAAQAgAAAA AAAAAG9yZy5l
Y2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1dGlvbi8uY2xhc3NwYXRoUEsBAhQL FAAAAAgAK0tD
OoIbwuTuAAAAtgIAACoAAAAAAAAAAQAgAAAAGQEAAG9yZy5lY2xpcHNlLmRl bW8ucm9vdGNv
bnRyaWJ1dGlvbi8ucHJvamVjdFBLAQIUCwoAAAAAAMtSQzoAAAAAAAAAAAAA AAAmAAAAAAAA
AAAAEAAAAE8CAABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rjb250cmlidXRpb24v YmluL1BLAQIU
CwoAAAAAAMtSQzoAAAAAAAAAAAAAAAAqAAAAAAAAAAAAEAAAAJMCAABvcmcu ZWNsaXBzZS5k
ZW1vLnJvb3Rjb250cmlidXRpb24vYmluL29yZy9QSwECFAsKAAAAAADLUkM6 AAAAAAAAAAAA
AAAAMgAAAAAAAAAAABAAAADbAgAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29u dHJpYnV0aW9u
L2Jpbi9vcmcvZWNsaXBzZS9QSwECFAsKAAAAAADLUkM6AAAAAAAAAAAAAAAA NwAAAAAAAAAA
ABAAAAArAwAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9uL2Jp bi9vcmcvZWNs
aXBzZS9kZW1vL1BLAQIUCwoAAAAAAMtSQzoAAAAAAAAAAAAAAABIAAAAAAAA AAAAEAAAAIAD
bW8vcm9vdGNvbnRyaWJ1dGlvbi9QSwECFAsUAAAACADLUkM6NECMQ1cCAADD BAAAVwAAAAAA
AAAAACAAAADmAwAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9u L2Jpbi9vcmcv
ZWNsaXBzZS9kZW1vL3Jvb3Rjb250cmlidXRpb24vQWN0aXZhdG9yLmNsYXNz UEsBAhQLFAAA
AAgAK0tDOkh5aUpRAAAAhgAAADIAAAAAAAAAAQAgAAAAsgYAAG9yZy5lY2xp cHNlLmRlbW8u
cm9vdGNvbnRyaWJ1dGlvbi9idWlsZC5wcm9wZXJ0aWVzUEsBAhQLCgAAAAAA K0tDOgAAAAAA
AAAAAAAAACgAAAAAAAAAAAAQAAAAUwcAAG9yZy5lY2xpcHNlLmRlbW8ucm9v dGNvbnRyaWJ1
dGlvbi9pbnRyby9QSwECFAsKAAAAAAArS0M6AAAAAAAAAAAAAAAALAAAAAAA AAAAABAAAACZ
BwAAb3JnLmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9uL2ludHJvL2Nz cy9QSwECFAsK
AAAAAAArS0M6AAAAAAAAAAAAAAAANQAAAAAAAAAAABAAAADjBwAAb3JnLmVj bGlwc2UuZGVt
by5yb290Y29udHJpYnV0aW9uL2ludHJvL2Nzcy9ncmFwaGljcy9QSwECFAsU AAAACAArS0M6
GMdoPmQEAABSBQAAPwAAAAAAAAAAACAAAAA2CAAAb3JnLmVjbGlwc2UuZGVt by5yb290Y29u
dHJpYnV0aW9uL2ludHJvL2Nzcy9ncmFwaGljcy9zYW1wbGUuZ2lmUEsBAhQL FAAAAAgAK0tD
Ot/E0Q4tBQAAEQYAAEMAAAAAAAAAAAAgAAAA9wwAAG9yZy5lY2xpcHNlLmRl bW8ucm9vdGNv
bnRyaWJ1dGlvbi9pbnRyby9jc3MvZ3JhcGhpY3Mvc2FtcGxlX2hvdi5naWZQ SwECFAsUAAAA
CAAEUEM6EtOuEVMAAACIAAAANgAAAAAAAAABACAAAACFEgAAb3JnLmVjbGlw c2UuZGVtby5y
b290Y29udHJpYnV0aW9uL2ludHJvL2Nzcy9zYW1wbGUuY3NzUEsBAhQLFAAA AAgA7k5DOo/M
2uANAQAANAIAADIAAAAAAAAAAQAgAAAALBMAAG9yZy5lY2xpcHNlLmRlbW8u cm9vdGNvbnRy
aWJ1dGlvbi9pbnRyby9zYW1wbGUueG1sUEsBAhQLCgAAAAAAK0tDOgAAAAAA AAAAAAAAACsA
AAAAAAAAAAAQAAAAiRQAAG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1 dGlvbi9NRVRB
LUlORi9QSwECFAsUAAAACAArS0M6sjkEj9AAAACoAQAANgAAAAAAAAABACAA AADSFAAAb3Jn
LmVjbGlwc2UuZGVtby5yb290Y29udHJpYnV0aW9uL01FVEEtSU5GL01BTklG RVNULk1GUEsB
AhQLFAAAAAgAK0tDOqpchbusAAAATAEAACwAAAAAAAAAAQAgAAAA9hUAAG9y Zy5lY2xpcHNl
LmRlbW8ucm9vdGNvbnRyaWJ1dGlvbi9wbHVnaW4ueG1sUEsBAhQLCgAAAAAA K0tDOgAAAAAA
AAAAAAAAACYAAAAAAAAAAAAQAAAA7BYAAG9yZy5lY2xpcHNlLmRlbW8ucm9v dGNvbnRyaWJ1
dGlvbi9zcmMvUEsBAhQLCgAAAAAAK0tDOgAAAAAAAAAAAAAAACoAAAAAAAAA AAAQAAAAMBcA
AG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1dGlvbi9zcmMvb3JnL1BL AQIUCwoAAAAA
ACtLQzoAAAAAAAAAAAAAAAAyAAAAAAAAAAAAEAAAAHgXAABvcmcuZWNsaXBz ZS5kZW1vLnJv
b3Rjb250cmlidXRpb24vc3JjL29yZy9lY2xpcHNlL1BLAQIUCwoAAAAAACtL QzoAAAAAAAAA
AAAAAAA3AAAAAAAAAAAAEAAAAMgXAABvcmcuZWNsaXBzZS5kZW1vLnJvb3Rj b250cmlidXRp
b24vc3JjL29yZy9lY2xpcHNlL2RlbW8vUEsBAhQLCgAAAAAAK0tDOgAAAAAA AAAAAAAAAEgA
AAAAAAAAAAAQAAAAHRgAAG9yZy5lY2xpcHNlLmRlbW8ucm9vdGNvbnRyaWJ1 dGlvbi9zcmMv
b3JnL2VjbGlwc2UvZGVtby9yb290Y29udHJpYnV0aW9uL1BLAQIUCxQAAAAI ACtLQzpds49t
DAIAAJsFAABWAAAAAAAAAAEAIAAAAIMYAABvcmcuZWNsaXBzZS5kZW1vLnJv b3Rjb250cmli
dXRpb24vc3JjL29yZy9lY2xpcHNlL2RlbW8vcm9vdGNvbnRyaWJ1dGlvbi9B Y3RpdmF0b3Iu
amF2YVBLBQYAAAAAGQAZALUJAAADGwAAAAA=
--------------010503020600020907060507--
Re: Contributing to root Welcome page [message #619473 is a reply to message #474308] Tue, 02 September 2008 13:24 Go to previous message
> If yes then how?
> Please help
> Thanks.
Re: Contributing to root Welcome page [message #619475 is a reply to message #474312] Wed, 03 September 2008 02:10 Go to previous message
of the root page.
Thanks.
Re: Contributing to root Welcome page [message #622808 is a reply to message #474313] Mon, 02 February 2009 19:30 Go to previous message
Re: Contributing to root Welcome page [message #622809 is a reply to message #475098] Tue, 03 February 2009 09:14 Go to previous message
Hope this helps,
Eric
Re: Contributing to root Welcome page [message #622810 is a reply to message #474312] Tue, 03 February 2009 12:31 Go to previous message
>> If yes then how?
>> Please help
>> Thanks.
Re: Contributing to root Welcome page [message #622811 is a reply to message #475098] Tue, 03 February 2009 13:45 Go to previous message
wizard as follows:
Previous Topic:Welcome screen html
Next Topic:Help system Jetty problems
Current Time: Sat Jul 19 13:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.05671 seconds
