Home » Eclipse Projects » Platform - User Assistance (UA) » Does the infocenter provides a remote API to get context hep
Does the infocenter provides a remote API to get context hep [message #474175] Tue, 12 August 2008 09:07 Go to next message
hi,
we are using the infocenter as a standalone app to provide help support
for a web project that has nothing to do with eclipse.
It works great as far as running it our web server but now we would like
to add support for context help on our web app.
So, does the infocenter provide a remote API to get the context help
content as set up in the context.xml?
the only documentation i could find about was for the JAVA APIs which are
no good to me.
i noticed that the context.xml is directly available from the root URL of
the infocenter so i guess our app could just fetch it, parse it and then
render itself the contexts desc and links as appropriate but if the
infocenter is providing this already we might as well make use of it
rgds,
d.
Re: Does the infocenter provides a remote API to get context hep [message #474223 is a reply to message #474175] Tue, 12 August 2008 13:37 Go to previous messageGo to next message
There is a context servlet which is used for remote help support which
returns context information in xml format. For example
http://help.eclipse.org/ganymede/context?id=org.eclipse.ui.w orkbench_window_context
results in
<?xml version="1.0" encoding="UTF-8" ?>
- <context>
<description>Each workbench window contains one or more perspectives,
which are made up of various views and editors.</description>
<topic label="Workbench"
href="/org.eclipse.platform.doc.user/concepts/concepts-2.htm " />
<topic label="Perspectives"
href="/org.eclipse.platform.doc.user/concepts/concepts-4.htm " />
<topic label="Customizing the Workbench"
href="/org.eclipse.platform.doc.user/tasks/tasks-1.htm" />
</context>
Re: Does the infocenter provides a remote API to get context hep [message #474224 is a reply to message #474175] Tue, 12 August 2008 17:26 Go to previous messageGo to next message
We have a requirement for this as well. We have non-Eclipse products that
use context sensitive help. A Java API would be great.
Eric
"david beaurpere" <david.beaurpere@iona.com> wrote in message
news:8278964709ecf016d2593bf0f49fbc29$1@www.eclipse.org...
> hi,
> no good to me.
> rgds,
> d.
Re: Does the infocenter provides a remote API to get context hep [message #474226 is a reply to message #474223] Tue, 12 August 2008 17:35 Go to previous messageGo to next message
Is there any documentation about this? What's the formula for the id
paramter?
Eric
"Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
news:g7shon$q3o$1@build.eclipse.org...
> results in
> - <context>
> </context>
Re: Does the infocenter provides a remote API to get context hep [message #474228 is a reply to message #474226] Tue, 12 August 2008 19:24 Go to previous messageGo to next message
There is not any documentation because it is an internal mechanism, and
not API. You are welcome to use it but it is one of those hidden
features that comes without documentation or warranty. If you would like
to see it become a supported feature then you should file a bug report
to request that.
Re: Does the infocenter provides a remote API to get context hep [message #474229 is a reply to message #474226] Tue, 12 August 2008 19:26 Go to previous message
.... and the formula for the id parameter is <plugin_name>.<context_id>
Re: Does the infocenter provides a remote API to get context hep [message #619376 is a reply to message #474175] Tue, 12 August 2008 13:37 Go to previous message
results in
- <context>
</context>
Re: Does the infocenter provides a remote API to get context hep [message #619377 is a reply to message #474175] Tue, 12 August 2008 17:26 Go to previous message
Eric
> hi,
> no good to me.
> rgds,
> d.
Re: Does the infocenter provides a remote API to get context hep [message #619378 is a reply to message #474223] Tue, 12 August 2008 17:35 Go to previous message
paramter?
Eric
> results in
> - <context>
> </context>
Re: Does the infocenter provides a remote API to get context hep [message #619380 is a reply to message #474226] Tue, 12 August 2008 19:24 Go to previous message
to request that.
Re: Does the infocenter provides a remote API to get context hep [message #619382 is a reply to message #474226] Tue, 12 August 2008 19:26 Go to previous message
Previous Topic:Infocenter as war file - dynamic plugin update
Next Topic:What could limiting help search.
Current Time: Sat Jul 19 07:55:54 EDT 2025
Powered by FUDForum. Page generated in 0.05214 seconds
