Home » Eclipse Projects » JavaServer Faces » f:loadBundle doesn't contibute it's "var" variable to EL
f:loadBundle doesn't contibute it's "var" variable to EL [message #474194] Fri, 25 May 2007 22:40 Go to next message
Hi!
I got some problem with EL contribution for loadbundle tag.
Contribution works fine for h:datatable or tomahawk library tags through
extension plugin, but for f:loadBundle it doesn't. Here is simple jsf page
source:
<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f" %>
<%@ taglib uri="http://java.sun.com/jsf/html" prefix="h" %>
<html>
<body>
<f:view>
<f:loadBundle var="msg" basename="com.test.msg" />
<h:outputText value="#{}" />
</f:view>
</body>
</html>
...and com.test.msg.properties contains single entry.
When i open content assist for EL expression in h:outputText - "msg" var
is not there. Maybe contribution for loadbundle just isn't implemented at
all and i search for a black cat in a dark room? :)
P.S.
JSF implementation is myfaces 1.1.5 (if it really matters at all). I fresh
installation of eclipse3.3 rc1, wtp2.0 rc1 and clean workspace, but with
no luck.
Thanks!
Solved my problem, but don't know, should it be considered as a bug or not [message #474195 is a reply to message #474194] Sun, 27 May 2007 22:33 Go to previous messageGo to next message
Solved my problem: extension of jsp file with jsf tags was "jsf" instead
of "jsp" (configured URL mapping pattern for project is "*.jsf" instead of
default "/faces/*", so i tangle extensions sometimes). If file has "jsp"
extension everything works fine.
That error seems to be ok, since JSF pages are all jsp at their base, so
they all must by named "*.jsp". But WTP, when installed, defines some more
file extensions bound to JSP file editor: jsf, jspf and jspx.
Should all JSF Tools content assist functionality be available for files
with these extensions (i.e. jsf)? Or should it be available only for *.jsp
files?
I don't know, should it be considered as a bug (and reported) or as a
feature (and be left as-is) :)
Hope you'll help me find answer for these questions.
Thanks for your attention again!
Re: Solved my problem, but don't know, should it be considered as a bug or not [message #474279 is a reply to message #474195] Tue, 29 May 2007 19:00 Go to previous message
Hi Vadim,
I think you're onto something here. The issue becomes even bigger when we
take into account the request to support facelets at some point in the
future. Can you enter this issue into bugzilla so we can track?
Cameron
Solved my problem, but don't know, should it be considered as a bug or not [message #610970 is a reply to message #474194] Sun, 27 May 2007 22:33 Go to previous message
files?
Re: Solved my problem, but don't know, should it be considered as a bug or not [message #611558 is a reply to message #474195] Tue, 29 May 2007 19:00 Go to previous message
Hi Vadim,
Cameron
Previous Topic:WYSIWYG HTML editor
Next Topic:3 metadata files are all required after refactoring?
Current Time: Sun Jul 20 02:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.04606 seconds
