Home » Eclipse Projects » Platform - User Assistance (UA) » Cheat Sheet
Cheat Sheet [message #474092] Tue, 24 June 2008 04:27 Go to next message
Originally posted by: bucher_jenny.web.de
I would like to have cheat sheets in my application.
What I have done so far:
I add a cheatsheet,
and following plugins:
org.apache.lucene
org.apache.lucene.analysis
org.eclipse.help.base
org.eclipse.help.ui
org.eclipse.ui.cheatsheets
org.eclipse.ui.forms
But it also adds menu actions like Search and Run. But I would like to
have only my cheat sheet.
Do sb know why this menu actions are added and how I can get rid of them
and the eclipse standart cheat sheets?
Re: Cheat Sheet [message #474108 is a reply to message #474092] Wed, 25 June 2008 13:55 Go to previous messageGo to next message
I think the standard cheat sheets as well as the menu items are probably
coming from org.eclipse.ui.platform. If you see the cheat sheet "Check
out a CVS project" then that is coming from the platform, and the
solution would be to not include that project in your application.
Jenni wrote:
> I add a cheatsheet,
> org.apache.lucene
> org.eclipse.help.ui
Re: Cheat Sheet [message #474119 is a reply to message #474108] Wed, 02 July 2008 09:56 Go to previous messageGo to next message
You're right.
But I still have a little problem ;)
If I open the Cheat Sheet Selection there is a category called Java
Development. Do somebody know how I can get this out?
Cheers
> Jenni wrote:
>> Hi,
>> I add a cheatsheet,
>> org.apache.lucene
>> org.eclipse.help.ui
Re: Cheat Sheet [message #474122 is a reply to message #474119] Wed, 02 July 2008 17:23 Go to previous messageGo to next message
I can give you a short answer and a longer answer.
The short answer is org.eclipse.jdt is contributing these cheat sheets.
The longer answer is that to find out where any cheat sheet comes from
open the Plug-in Registry view and look under org.eclipse.ui.cheatsheets
at the extension point org.eclipse.ui.cheatsheets.cheatSheetContent. You
will see a list of cheat sheets and can see which plugin contributed them.
Jenni wrote:
> You're right.
> Cheers
>> probably coming from org.eclipse.ui.platform. If you see the cheat
>> sheet "Check out a CVS project" then that is coming from the platform,
>> and the solution would be to not include that project in your
>> application.
>> Jenni wrote:
>>> Hi,
>>> I add a cheatsheet,
>>> org.apache.lucene
>>> org.eclipse.help.ui
>>> to have only my cheat sheet.
>>> them and the eclipse standart cheat sheets?
Re: Cheat Sheet [message #474123 is a reply to message #474122] Thu, 03 July 2008 04:22 Go to previous message
Hey, thats cool, thank you.
But I cant get the org.eclipse.jdt out. Its in the run configuration and I
need it there. Is there another way to get this cheatsheet out?
Sry for this noob questions, but I cant find a solution...
Cheers
> Jenni wrote:
>> You're right.
>> Cheers
>>> application.
>>> Jenni wrote:
>>>> Hi,
>>>> I add a cheatsheet,
>>>> org.apache.lucene
>>>> org.eclipse.help.ui
Re: Cheat Sheet [message #617656 is a reply to message #474092] Wed, 25 June 2008 13:55 Go to previous message
Jenni wrote:
> I add a cheatsheet,
> org.apache.lucene
> org.eclipse.help.ui
Re: Cheat Sheet [message #618941 is a reply to message #474108] Wed, 02 July 2008 09:56 Go to previous message
You're right.
Cheers
> Jenni wrote:
>> Hi,
>> I add a cheatsheet,
>> org.apache.lucene
>> org.eclipse.help.ui
Re: Cheat Sheet [message #618951 is a reply to message #474119] Wed, 02 July 2008 17:23 Go to previous message
Jenni wrote:
> You're right.
> Cheers
>> application.
>> Jenni wrote:
>>> Hi,
>>> I add a cheatsheet,
>>> org.apache.lucene
>>> org.eclipse.help.ui
Re: Cheat Sheet [message #618953 is a reply to message #474122] Thu, 03 July 2008 04:22 Go to previous message
Cheers
> Jenni wrote:
>> You're right.
>> Cheers
>>> application.
>>> Jenni wrote:
>>>> Hi,
>>>> I add a cheatsheet,
>>>> org.apache.lucene
>>>> org.eclipse.help.ui
Previous Topic:eclipse standalone contextsensitive help
Next Topic:Default to pop-up help window in RCP?
Current Time: Sun Jul 20 16:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.04817 seconds
