Multiple help plugin directories for workbench and standalone help [message #473907] |
Tue, 10 June 2008 19:50  |
Originally posted by: alan.ittvis.com
I would like to have documentation content plugins in multiple separate
directories, with one or more specified at startup in order to have the
help system display different subsets of online help for different
products. I'd like to use the same Eclipse distribution for both workbench
help and standalone help.
I thought the "links" directory would allow me to set up multiple
locations for help plugins, but from my testing it seems that links are
not recognized by the standalone help system. Even if links worked I'd
prefer a startup parameter to specify the plugin locations rather than a
file.
Currently we are using Eclipse 3.3, but will probably be migrating to
Eclipse 3.4. Can you suggest a way to provide access to different subsets
of help plugins that will work with both the workbench and standalone
help?
Alan
Re: Multiple help plugin directories for workbench and standalone help [message #474077 is a reply to message #474071] |
Wed, 18 June 2008 14:36  |
HELP_DATA and ignoredTOCS work in exactly the same way. If the entries
are showing up in the search then that seems like a bug. I think there
are ways to get OSGI to load exactly the set of plugins you want - I
just don't know how to do it.
Alan Youngblood wrote:
> Thanks Chris, for the HELP_DATA suggestion. I was unable to get the help
> system to pick up the settings I applied in the file specified with
> HELP_DATA. I think this may have to do with bug 216170:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=216170
> I was able to use the deprecated fields ignoredTOCS and ignoredIndexes
> in the plugin_customization file to work, so I know that at least the
> plugin_customization file was being used. Can you clarify what it takes
> to get the HELP_DATA file read in Eclipse 3.3?
> Even though I was able to use ignoredTOCS and hide the table of
> contents, this doesn't completely hide the content from a particular doc
> plugin. I wonder if the use of HELP_DATA would be any different. For
> example, if a help plugin is hidden with ignoredTOCS and ignoredIndexes,
> the plugin is still loaded and a search will display references to
> topics in the help plugin. Selecting one of those references in the
> search list displays the content that I want to be hidden, and displays
> a dialog with the message "The current document displayed does not exist
> in the table of contents."
> Would the behavior using HELP_DATA customization be any different? In
> particular, if a category is hidden does it hide all the content from
> the help plugin? Would this prevent help content from showing up in a
> search?
> I think that the cached search information from a user's first search is
> written to disk and then different configurations using the same Eclipse
> directory would not be able to have different subsets of help content.
> Is there any OSGI functionality that would allow me to unload a help
> plugin at startup?
> Alan
Re: Multiple help plugin directories for workbench and standalone help [message #615279 is a reply to message #473909] |
Mon, 16 June 2008 18:04  |
I was able to use the deprecated fields ignoredTOCS and ignoredIndexes in
plugin_customization file was being used. Can you clarify what it takes to
Even though I was able to use ignoredTOCS and hide the table of contents,
this doesn't completely hide the content from a particular doc plugin. I
wonder if the use of HELP_DATA would be any different. For example, if a
help plugin is hidden with ignoredTOCS and ignoredIndexes, the plugin is
still loaded and a search will display references to topics in the help
plugin. Selecting one of those references in the search list displays the
content that I want to be hidden, and displays a dialog with the message
"The current document displayed does not exist in the table of contents."
particular, if a category is hidden does it hide all the content from the
help plugin? Would this prevent help content from showing up in a search?
plugin at startup?
Alan
Re: Multiple help plugin directories for workbench and standalone help [message #615294 is a reply to message #474071] |
> search?
> plugin at startup?
> Alan
FUDForum. Page generated in 0.07712 seconds
