Home » Modeling » UML2 » No Cast in case of templates
No Cast in case of templates [message #472883] |
Thu, 10 May 2007 19:13  |
I created a uml primitive type with Map<String, Datum> and assigned it to
content variable in a class.
Now when I convert it to Ecore then to code, I am getting the following
code. If you see the eUnset function there is proper cast but there is none
in eSet function. The compiler is complaining about the same saying it
cannot accept object.
How can I avoid this.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
@SuppressWarnings("unchecked")
public void eSet(int featureID, Object newValue) {
switch (featureID) {
case NewheadPackage.DATA_MAP__CONTENT:
setContent(newValue);
return;
super.eSet(featureID, newValue);
* @generated
public void eUnset(int featureID) {
setContent((Map<String, Datum>)null);
return;
super.eUnset(featureID);
Re: No Cast in case of templates [message #472884 is a reply to message #472883] |
Thu, 10 May 2007 19:25   |
Pradeep,
I'll need to see an Ecore model that reproduces this problem to
comment. It could be a bug, but without an example, who knows...
Pradeep wrote:
> * @generated
> @Override
> return;
> * @generated
> @Override
> return;
Re: No Cast in case of templates [message #472885 is a reply to message #472884] |
Thu, 10 May 2007 19:48   |
Please find the uml file attached. I used the file to generate genmodel and
then code.
Please import java.util.Map in the generated code.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f209lo$5hf$1@build.eclipse.org...
> Pradeep,
> Pradeep wrote:
>> Hi,
>> none
>> * @generated
>> @Override
>> return;
>> * @generated
>> @Override
>> return;
Attachment: test.uml
(Size: 1.40KB, Downloaded 246 times)
Re: No Cast in case of templates [message #472886 is a reply to message #472884] |
Thu, 10 May 2007 19:57   |
Hi Ed,
Also, Do you think there is a better way to create template variables. I
just reapplied the technique you suggested for creating arrays in my
previous post.
Suppose if I want to create an interface like
public interface Evaluate<E extends Datum>
Double eval(E input);
How should i proceed?
pradeep
> Pradeep,
> I'll need to see an Ecore model that reproduces this problem to comment.
> Pradeep wrote:
>> Hi,
>> none in eSet function. The compiler is complaining about the same saying
>> it cannot accept object.
>> * @generated
>> @Override
>> return;
>> * @generated
>> @Override
>> return;
Re: No Cast in case of templates [message #472887 is a reply to message #472885] |
Thu, 10 May 2007 20:46   |
--------------070205040900030509060607
Pradeep,
You need to use fully qualified names in the instance class name, i.e.,
use java.util.Map<java.lang.String, java.lang.String>.
> then code.
>> Pradeep,
>> Pradeep wrote:
>>> Hi,
>>> none
>>> * @generated
>>> @Override
>>> return;
>>> * @generated
>>> @Override
>>> return;
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Pradeep,<br>
<br>
use java.util.Map<java.lang.String, java.lang.String>.<br>
<br>
Pradeep wrote:
<blockquote cite="midf20avl$7mv$1@build.eclipse.org" type="cite">
<pre wrap="">Please find the uml file attached. I used the file to generate genmodel and
then code.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:f209lo$5hf$1@build.eclipse.org">news:f209lo$5hf$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Pradeep,
Pradeep wrote:
</pre>
<pre wrap="">Hi,
none
* @generated
return;
* @generated
return;
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070205040900030509060607--
Re: No Cast in case of templates [message #472888 is a reply to message #472886] |
Thu, 10 May 2007 20:55   |
--------------000904080807020303060403
Pradeep,
It's a UML2 question. In the Ecore editor you can create this directly,
but I'm not sure how to express it in UML2. I produced the attached UML
by modifying your example's .ecore and exporting it to UML.
Pradeep wrote:
> Hi Ed,
> previous post.
> Thanks
> pradeep
>> Pradeep,
>> Pradeep wrote:
>>> Hi,
>>> * @generated
>>> @Override
>>> return;
>>> * @generated
>>> @Override
>>> return;
Content-Type: text/xml;
name="test.uml"
Content-Disposition: inline;
filename="test.uml"
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:Ecore="http://www.eclipse.org/uml2/schemas/Ecore/4" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Ecore/4 pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA">
<uml:Model xmi:id="_8Pp2gP9ZEdu2-NJ3YDjyEA" name="test">
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_8Pp2gf9ZEdu2-NJ3YDjyEA" name="MapStringString"/>
<packagedElement xmi:type="uml:Class" xmi:id="_8Pp2gv9ZEdu2-NJ3YDjyEA" name="DataBag">
<ownedTemplateSignature xmi:type="uml:RedefinableTemplateSignature" xmi:id="_8Pp2g_9ZEdu2-NJ3YDjyEA" parameter="_8Pp2hP9ZEdu2-NJ3YDjyEA">
<ownedParameter xmi:type="uml:ClassifierTemplateParameter" xmi:id="_8Pp2hP9ZEdu2-NJ3YDjyEA" parameteredElement="_8Pp2hf9ZEdu2-NJ3YDjyEA">
<ownedParameteredElement xmi:type="uml:Class" xmi:id="_8Pp2hf9ZEdu2-NJ3YDjyEA" name="E" templateParameter="_8Pp2hP9ZEdu2-NJ3YDjyEA"/>
</ownedParameter>
</ownedTemplateSignature>
<ownedAttribute xmi:id="_8Pp2hv9ZEdu2-NJ3YDjyEA" name="content" visibility="public" type="_8Pp2gf9ZEdu2-NJ3YDjyEA"/>
<ownedOperation xmi:id="_8Pp2h_9ZEdu2-NJ3YDjyEA" name="eval" visibility="public">
<ownedParameter xmi:id="_8Pp2iP9ZEdu2-NJ3YDjyEA" isOrdered="true" direction="return">
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_8Pp2if9ZEdu2-NJ3YDjyEA"/>
</ownedParameter>
<ownedParameter xmi:id="_8Pp2iv9ZEdu2-NJ3YDjyEA" name="input" type="_8Pp2hf9ZEdu2-NJ3YDjyEA" isOrdered="true">
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_8Pp2i_9ZEdu2-NJ3YDjyEA"/>
</ownedParameter>
</ownedOperation>
</packagedElement>
<profileApplication xmi:id="_8Pp2jP9ZEdu2-NJ3YDjyEA">
<eAnnotations xmi:id="_8Pp2jf9ZEdu2-NJ3YDjyEA" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Ecore.profile.uml#_0"/>
</profileApplication>
</uml:Model>
<Ecore:EPackage xmi:id="_8Pp2jv9ZEdu2-NJ3YDjyEA" base_Package="_8Pp2gP9ZEdu2-NJ3YDjyEA" nsPrefix="test" nsURI="http:///test.ecore"/>
<Ecore:EDataType xmi:id="_8Pp2j_9ZEdu2-NJ3YDjyEA" instanceClassName="Map<String, String>" base_PrimitiveType="_8Pp2gf9ZEdu2-NJ3YDjyEA"/>
<Ecore:EClass xmi:id="_8Pp2kP9ZEdu2-NJ3YDjyEA" base_Class="_8Pp2gv9ZEdu2-NJ3YDjyEA"/>
<Ecore:ETypeParameter xmi:id="_8Pp2kf9ZEdu2-NJ3YDjyEA" base_TemplateParameter="_8Pp2hP9ZEdu2-NJ3YDjyEA">
<bounds xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/EcorePrimitiveTypes.library.uml#EStr ing"/>
</Ecore:ETypeParameter>
<Ecore:EAttribute xmi:id="_8Pp2kv9ZEdu2-NJ3YDjyEA" base_Property="_8Pp2hv9ZEdu2-NJ3YDjyEA"/>
<Ecore:EOperation xmi:id="_8Pp2k_9ZEdu2-NJ3YDjyEA" base_Operation="_8Pp2h_9ZEdu2-NJ3YDjyEA"/>
<Ecore:EParameter xmi:id="_8Pp2lP9ZEdu2-NJ3YDjyEA" base_Parameter="_8Pp2iv9ZEdu2-NJ3YDjyEA"/>
</xmi:XMI>
--------------000904080807020303060403--
Re: No Cast in case of templates [message #472889 is a reply to message #472887] |
Thu, 10 May 2007 23:03   |
------=_NextPart_000_0181_01C7933E.3AFEC8E0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks a lot. That worked.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f20ecd$112$1@build.eclipse.org...
Pradeep,
You need to use fully qualified names in the instance class name, =
i.e., use java.util.Map<java.lang.String, java.lang.String>.
Pradeep wrote:=20
Please find the uml file attached. I used the file to generate genmodel =
and=20
then code.
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Pradeep,
Pradeep wrote:
I created a uml primitive type with Map<String, Datum> and assigned it =
to
code. If you see the eUnset function there is proper cast but there is=20
none
* @generated
return;
* @generated
return;
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks a lot. That worked.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f20ecd$112$1@build.eclipse.org">news:f20ecd$112$1@build.ecli=
pse.org</A>...</DIV>Pradeep,<BR><BR>You=20
need to use fully qualified names in the instance class name, i.e., =
use=20
java.util.Map<java.lang.String, =
java.lang.String>.<BR><BR>Pradeep wrote:=20
<BLOCKQUOTE cite=3Dmidf20avl$7mv$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Please find the uml file attached. I used =
the file to generate genmodel and=20
then code.
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:f209lo$5hf$1@build.eclipse.org">news:f209lo$5hf$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Pradeep,
Pradeep wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
I created a uml primitive type with Map<String, Datum> and =
assigned it to
none
* @generated
return;
* @generated
return;
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0181_01C7933E.3AFEC8E0--
Re: No Cast in case of templates [message #472890 is a reply to message #472888] |
Thu, 10 May 2007 23:04   |
The draft document at https://bugs.eclipse.org/bugs/attachment.cgi?id=57909
describes how UML templates map to Ecore generics. We will be focusing on
documentation (polishing this and other articles, etc.) once we declare M7
for this release.
Kenn
news:f20euk$8tb$1@build.eclipse.org...
> Pradeep,
> Pradeep wrote:
>> Hi Ed,
>> previous post.
>> Thanks
>> pradeep
>>> Pradeep,
>>> Pradeep wrote:
>>>> Hi,
>>>> to
>>>> saying
>>>> * @generated
>>>> @Override
>>>> return;
>>>> * @generated
>>>> @Override
>>>> return;
> name="DataBag">
> </ownedParameter>
> direction="return">
> </ownedParameter>
> </ownedParameter>
> </ownedOperation>
> </packagedElement>
> </eAnnotations>
> </uml:Model>
> </xmi:XMI>
Re: No Cast in case of templates [message #472892 is a reply to message #472890] |
Fri, 11 May 2007 00:34   |
Hi Ed and Kenn,
Somehow my UML editor is not opening the UML file sent by Ed.
The word document, even though incomplete, helped me a lot. I am able
achieve the different template definitions that I want using the illustrated
figures.
Actually both EMF and UML2 has more support for Generics than I thought. I
recently listened to a podcast by Ed in which he said that while Ecore
generates generic classes, support for user defined generic classes is
little into the future. I didn't realize he literally meant "little". :)
Thanks once again for both of you.
Pradeep
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f20mfs$l38$1@build.eclipse.org...
> https://bugs.eclipse.org/bugs/attachment.cgi?id=57909 describes how UML
> templates map to Ecore generics. We will be focusing on documentation
> (polishing this and other articles, etc.) once we declare M7 for this
> release.
> Kenn
>> Pradeep,
>> Pradeep wrote:
>>> Hi Ed,
>>> previous post.
>>> Thanks
>>> pradeep
>>>> Pradeep,
>>>> comment.
>>>> Pradeep wrote:
>>>>> Hi,
>>>>> to
>>>>> following
>>>>> saying
>>>>> * @generated
>>>>> @Override
>>>>> return;
>>>>> * @generated
>>>>> @Override
>>>>> return;
>> <?xml version="1.0" encoding="UTF-8"?>
>> name="DataBag">
>> </ownedParameter>
>> direction="return">
>> </ownedParameter>
>> </ownedParameter>
>> </ownedOperation>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Model>
>> </xmi:XMI>
Re: No Cast in case of templates [message #472896 is a reply to message #472892] |
Fri, 11 May 2007 16:34  |
Pradeep,
To open the model Ed sent you, you'll need to use the latest integration
build of UML2 (I200705111324). This is because the namespace URI for UML2
changed, as previously announced on the newsgroup.
Kenn
"Pradeep" <eclipseuser123@yahoo.com> wrote in message
news:f20rp1$v73$1@build.eclipse.org...
> Hi Ed and Kenn,
> illustrated figures.
> Pradeep
>> release.
>> Kenn
>>> Pradeep,
>>> Pradeep wrote:
>>>> Hi Ed,
>>>> I
>>>> previous post.
>>>> Thanks
>>>> pradeep
>>>>> Pradeep,
>>>>> comment.
>>>>> Pradeep wrote:
>>>>>> Hi,
>>>>>> it to
>>>>>> following
>>>>>> is
>>>>>> saying
>>>>>> * @generated
>>>>>> @Override
>>>>>> return;
>>>>>> * @generated
>>>>>> @Override
>>>>>> return;
>>> </ownedParameter>
>>> direction="return">
>>> </ownedParameter>
>>> </ownedParameter>
>>> </ownedOperation>
>>> </packagedElement>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Model>
>>> </xmi:XMI>
Re: No Cast in case of templates [message #615690 is a reply to message #472883] |
Pradeep,
Pradeep wrote:
> * @generated
> @Override
> return;
> * @generated
> @Override
> return;
Re: No Cast in case of templates [message #615691 is a reply to message #472884] |
then code.
> Pradeep,
> Pradeep wrote:
>> Hi,
>> none
>> * @generated
>> @Override
>> return;
>> * @generated
>> @Override
>> return;
(Size: 1.40KB, Downloaded 251 times)
Re: No Cast in case of templates [message #615692 is a reply to message #472884] |
Hi Ed,
previous post.
pradeep
> Pradeep,
> Pradeep wrote:
>> Hi,
>> * @generated
>> @Override
>> return;
>> * @generated
>> @Override
>> return;
Re: No Cast in case of templates [message #615693 is a reply to message #472885] |
Pradeep,
> then code.
>> Pradeep,
>> Pradeep wrote:
>>> Hi,
>>> none
>>> * @generated
>>> @Override
>>> return;
>>> * @generated
>>> @Override
>>> return;
<html>
<head>
</head>
Pradeep,<br>
<br>
<br>
then code.
</pre>
Pradeep wrote:
</pre>
<pre wrap="">Hi,
none
* @generated
return;
* @generated
return;
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: No Cast in case of templates [message #615694 is a reply to message #472886] |
Pradeep,
Pradeep wrote:
> Hi Ed,
> previous post.
> Thanks
> pradeep
>> Pradeep,
>> Pradeep wrote:
>>> Hi,
>>> * @generated
>>> @Override
>>> return;
>>> * @generated
>>> @Override
>>> return;
name="test.uml"
filename="test.uml"
</ownedParameter>
</ownedParameter>
</ownedParameter>
</ownedOperation>
</packagedElement>
</eAnnotations>
</uml:Model>
</xmi:XMI>
Re: No Cast in case of templates [message #615695 is a reply to message #472887] |
Pradeep,
Pradeep wrote:=20
and=20
then code.
Pradeep,
to
none
* @generated
return;
* @generated
return;
=20
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BLOCKQUOTE=20
use=20
then code.
message=20
pse.org</A>...
</PRE>
Pradeep wrote:
</PRE>
assigned it to
none
* @generated
return;
* @generated
return;
Re: No Cast in case of templates [message #615696 is a reply to message #472888] |
for this release.
Kenn
> Pradeep,
> Pradeep wrote:
>> Hi Ed,
>> previous post.
>> Thanks
>> pradeep
>>> Pradeep,
>>> Pradeep wrote:
>>>> Hi,
>>>> to
>>>> saying
>>>> * @generated
>>>> @Override
>>>> return;
>>>> * @generated
>>>> @Override
>>>> return;
> name="DataBag">
> </ownedParameter>
> direction="return">
> </ownedParameter>
> </ownedParameter>
> </ownedOperation>
> </packagedElement>
> </eAnnotations>
> </uml:Model>
> </xmi:XMI>
Re: No Cast in case of templates [message #615698 is a reply to message #472890] |
Hi Ed and Kenn,
figures.
Pradeep
> release.
> Kenn
>> Pradeep,
>> Pradeep wrote:
>>> Hi Ed,
>>> previous post.
>>> Thanks
>>> pradeep
>>>> Pradeep,
>>>> comment.
>>>> Pradeep wrote:
>>>>> Hi,
>>>>> to
>>>>> following
>>>>> saying
>>>>> * @generated
>>>>> @Override
>>>>> return;
>>>>> * @generated
>>>>> @Override
>>>>> return;
>> name="DataBag">
>> </ownedParameter>
>> direction="return">
>> </ownedParameter>
>> </ownedParameter>
>> </ownedOperation>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Model>
>> </xmi:XMI>
Re: No Cast in case of templates [message #615702 is a reply to message #472892] |
Pradeep,
Kenn
> Hi Ed and Kenn,
> Pradeep
>> release.
>> Kenn
>>> Pradeep,
>>> Pradeep wrote:
>>>> Hi Ed,
>>>> I
>>>> previous post.
>>>> Thanks
>>>> pradeep
>>>>> Pradeep,
>>>>> comment.
>>>>> Pradeep wrote:
>>>>>> Hi,
>>>>>> it to
>>>>>> following
>>>>>> is
>>>>>> saying
>>>>>> * @generated
>>>>>> @Override
>>>>>> return;
>>>>>> * @generated
>>>>>> @Override
>>>>>> return;
>>> </ownedParameter>
>>> direction="return">
>>> </ownedParameter>
>>> </ownedParameter>
>>> </ownedOperation>
>>> </packagedElement>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Model>
>>> </xmi:XMI>
Current Time: Sat Jul 19 18:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
