Home » Modeling » UML2 » Re: No primitive types in .ecore files (party.javalang.String, ...)
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472749] |
Tue, 24 April 2007 10:52  |
Gonzalo,
I think this is more a question for the UML2 newsgroup, since that
project implements the UML importer and they can describe the various
stereotypes that are supported for mapping to Ecore better than me.
I've added that newsgroup to the "to" list so we can continue to use
this thread.
Gonzalo wrote:
> Hello! I'm searching for some help with the Omondo Eclipse UML to ecore
> mapping (.uml -> .ecore). I hope you can help me:
> Once I've created and saved an UML class diagram, Omondo Eclipse UML creates
> a .uml file (i.e. party.uml).
> I'm using this file (party.uml) to create a new Empty EMF Project, then
> create a new EMF Model, and then ,with party.genmodel, generate the Model
> Code. Then, I plan to persist my classes with Teneo and Hibernate.
> The problem I have is the types EMF creates inside the .ecore file (i.e.
> party.javalang.String, party.javautil.Date), because these types are
> different from the primitive types (String, Date, ...). If I could work with
> the primitives from the begining, maybe i could get rid of this problem.
> I would very much appreciate to get your input to this problem.
> Thanks in advance.
> With regards,
> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472750 is a reply to message #472749] |
Tue, 24 April 2007 17:14   |
Hi Gonzalo,
I'm not sure how Omondo handles these types but opensource UML implements a
XMLPrimitiveTypes.library.uml and UMLPrimitiveTypes.library.uml that should
be used.
You can experiment with the opensource editor by typing your properties with
primitive types coming from these libraries and then generating your .ecore
model.
That should work.
You can alternatively stereotype your primitive types with <eDataType>
(from the ecore profile) and specify the instance class name explicitly.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f0l5jg$7v8$2@build.eclipse.org...
> Gonzalo,
> this thread.
creates
Model
with
> > Thanks in advance.
> > With regards,
> > Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472751 is a reply to message #472749] |
Tue, 24 April 2007 17:31   |
Originally posted by: pradeep_tamma.yahoo.com
I also have the Date problem mentioned below.
Also, when I import uml model to ecore, classes are being created for
DataTypes in the uml model as well. Is there a way to avoid that?
The importer doesn't seem to differentiate between Class and Datatype.
Pradeep
> Gonzalo,
> I think this is more a question for the UML2 newsgroup, since that project
> implements the UML importer and they can describe the various stereotypes
> that are supported for mapping to Ecore better than me. I've added that
> newsgroup to the "to" list so we can continue to use this thread.
>> creates a .uml file (i.e. party.uml).
>> with the primitives from the begining, maybe i could get rid of this
>> problem.
>> Thanks in advance.
>> With regards,
>> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472794 is a reply to message #472751] |
Tue, 24 April 2007 18:07   |
Hi Pradeep,
some comments below ...
- James.
"Pradeep Tamma" <pradeep_tamma@yahoo.com> wrote in message
news:f0lt0b$e1n$1@build.eclipse.org...
.. see previous posting for some suggestions ...
If you define the Datatypes in your .uml model they will be created in the
..ecore model.
... not sure what you mean by "differentiate between"?
> Thanks
> Pradeep
> > Gonzalo,
project
stereotypes
ecore
Model
(i.e.
> >> problem.
> >> Thanks in advance.
> >> With regards,
> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472795 is a reply to message #472794] |
Tue, 24 April 2007 19:22   |
Please see the attachment. I am using uml2tools in eclipse. I created some
Datatypes, some primitive types and some classes using the graphical editor.
Now in the .uml file you will see those primitive types, DataTypes and
Classes. But when I import the same as ecore, there is no difference between
DataTypes and classes.
Also for the primitive type, java.util.Date in uml file changed to
javautilDate.
When I generate classes using the genmodel I get classes for Datatypes as
well. As expected javautilDate gives an error.
Please let me know if I am not clear.
Pradeep
There
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f0lv3g$7ks$2@build.eclipse.org...
> Hi Pradeep,
> - James.
> .ecore model.
>> Thanks
>> Pradeep
>> > Gonzalo,
> project
> stereotypes
>> > that
> ecore
>> >> then
> Model
> (i.e.
>> >> work
>> >> problem.
>> >> Thanks in advance.
>> >> With regards,
>> >> Gonzalo Castro
Attachment: uml.PNG
(Size: 29.77KB, Downloaded 200 times)
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472797 is a reply to message #472795] |
Wed, 25 April 2007 09:20   |
Hi Pradeep,
UML Primitive types map to ecore DataTypes.
UML Data types map to ecore Classes.
Ecore does not make distinctions between UML primitive types and UML data
types.
The name of your java.util.Date is not an appropriate ecore metatype name so
the periods were removed. I think what you really want to do is create a
type called "Date", then use a <<eDataType>> stereotype and set the instance
class name to java.util.Date. Or use the primitive types libraries as
mentioned previously.
- James.
news:f0m3f0$acg$1@build.eclipse.org...
editor.
between
> javautilDate.
> Thanks
> Pradeep
> There
> > Hi Pradeep,
> > - James.
the
> > .ecore model.
> >> Thanks
> >> Pradeep
> >> > Gonzalo,
> > project
> > stereotypes
> >> > that
> > ecore
> >> >> then
> > Model
> > (i.e.
> >> >> work
> >> >> problem.
> >> >> Thanks in advance.
> >> >> With regards,
> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472804 is a reply to message #472797] |
Wed, 25 April 2007 17:45   |
Hi James,
I assume by type you mean an actual Class. But I don't see an option to
specify a stereotype in the diagram editor. How do i specify it?
Pradeep
news:f0nkjb$ap8$2@build.eclipse.org...
> Hi Pradeep,
> types.
> so
> instance
> - James.
>> some
> editor.
> between
>> javautilDate.
>> Thanks
>> Pradeep
>> There
>> > Hi Pradeep,
>> > - James.
> the
>> > .ecore model.
>> >> Thanks
>> >> Pradeep
>> >> > Gonzalo,
>> > project
>> > stereotypes
>> >> > that
>> > ecore
>> >> >> UML
>> >> >> then
>> > Model
>> > (i.e.
>> >> >> are
>> >> >> work
>> >> >> this
>> >> >> problem.
>> >> >> Thanks in advance.
>> >> >> With regards,
>> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472805 is a reply to message #472804] |
Thu, 26 April 2007 05:19   |
Pradeep,
My guess is James meant for you to create a UML Primitive Type as this is
where you can apply the <<eDataType>> stereotype.
Incase you don't have the profile here are the steps.
First you need to apply the ecore profile: Click on your model and use
Package->Apply Profile..
Then you need to apply the stereotype: Click on the primitive type and use
Element->Apply Stereotype..
The additional properties provided by the stereotype will appear in the
properties view under the "EData Type" category
Hope that helps.
This thread has reminded me of a something I've been meaning to ask... I'll
pop it in another thread.
Tas.
"Pradeep" <pradeep@live.com> wrote in message
news:f0oi6l$77t$1@build.eclipse.org...
> Hi James,
> Thanks
> Pradeep
>> Hi Pradeep,
>> types.
>> so
>> a
>> instance
>> - James.
>>> some
>> editor.
>> between
>>> javautilDate.
>>> as
>>> Thanks
>>> Pradeep
>>> There
>>> > Hi Pradeep,
>>> > - James.
>> the
>>> > .ecore model.
>>> >> Datatype.
>>> >> Thanks
>>> >> Pradeep
>>> >> > Gonzalo,
>>> > project
>>> > stereotypes
>>> >> > that
>>> > ecore
>>> >> >> UML
>>> >> >> then
>>> >> >> the
>>> > Model
>>> > (i.e.
>>> >> >> are
>>> >> >> work
>>> >> >> this
>>> >> >> problem.
>>> >> >> Thanks in advance.
>>> >> >> With regards,
>>> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #472816 is a reply to message #472805] |
Thu, 26 April 2007 15:42  |
Hi Tas,
Thanks a lot. That really helped.
Pradeep
"Tas Frangoullides" <tas.frangoullides@barclaysglobal.com> wrote in message
news:f0pqrv$kqd$1@build.eclipse.org...
> Pradeep,
> Hope that helps.
> I'll pop it in another thread.
> Tas.
>> Hi James,
>> Thanks
>> Pradeep
>>> Hi Pradeep,
>>> data
>>> types.
>>> name so
>>> a
>>> instance
>>> - James.
>>>> some
>>> editor.
>>> between
>>>> javautilDate.
>>>> as
>>>> Thanks
>>>> Pradeep
>>>> There
>>>> > Hi Pradeep,
>>>> > - James.
>>>> >> for
>>>> > in
>>> the
>>>> > .ecore model.
>>>> >> Datatype.
>>>> >> Thanks
>>>> >> Pradeep
>>>> >> > Gonzalo,
>>>> > project
>>>> > stereotypes
>>>> >> > added
>>>> >> > that
>>>> >> >> to
>>>> > ecore
>>>> >> >> UML
>>>> >> >> Project,
>>>> >> >> then
>>>> >> >> the
>>>> > Model
>>>> >> >> Hibernate.
>>>> >> >> file
>>>> > (i.e.
>>>> >> >> are
>>>> >> >> could
>>>> >> >> work
>>>> >> >> this
>>>> >> >> problem.
>>>> >> >> Thanks in advance.
>>>> >> >> With regards,
>>>> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #611045 is a reply to message #472749] |
Hi Gonzalo,
be used.
model.
That should work.
- James.
> Gonzalo,
> this thread.
creates
Model
with
> > Thanks in advance.
> > With regards,
> > Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #611046 is a reply to message #472749] |
Pradeep
> Gonzalo,
>> problem.
>> Thanks in advance.
>> With regards,
>> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #611049 is a reply to message #472751] |
Hi Pradeep,
- James.
..ecore model.
> Thanks
> Pradeep
> > Gonzalo,
project
stereotypes
ecore
Model
(i.e.
> >> problem.
> >> Thanks in advance.
> >> With regards,
> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #611050 is a reply to message #472794] |
javautilDate.
Pradeep
There
> Hi Pradeep,
> - James.
> .ecore model.
>> Thanks
>> Pradeep
>> > Gonzalo,
> project
> stereotypes
>> > that
> ecore
>> >> then
> Model
> (i.e.
>> >> work
>> >> problem.
>> >> Thanks in advance.
>> >> With regards,
>> >> Gonzalo Castro
Attachment: uml.PNG
(Size: 29.77KB, Downloaded 166 times)
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #611052 is a reply to message #472795] |
Hi Pradeep,
types.
- James.
editor.
between
> javautilDate.
> Thanks
> Pradeep
> There
> > Hi Pradeep,
> > - James.
the
> > .ecore model.
> >> Thanks
> >> Pradeep
> >> > Gonzalo,
> > project
> > stereotypes
> >> > that
> > ecore
> >> >> then
> > Model
> > (i.e.
> >> >> work
> >> >> problem.
> >> >> Thanks in advance.
> >> >> With regards,
> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #613186 is a reply to message #472797] |
Hi James,
Pradeep
> Hi Pradeep,
> types.
> so
> instance
> - James.
>> some
> editor.
> between
>> javautilDate.
>> Thanks
>> Pradeep
>> There
>> > Hi Pradeep,
>> > - James.
> the
>> > .ecore model.
>> >> Thanks
>> >> Pradeep
>> >> > Gonzalo,
>> > project
>> > stereotypes
>> >> > that
>> > ecore
>> >> >> UML
>> >> >> then
>> > Model
>> > (i.e.
>> >> >> are
>> >> >> work
>> >> >> this
>> >> >> problem.
>> >> >> Thanks in advance.
>> >> >> With regards,
>> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #613187 is a reply to message #472804] |
Pradeep,
Hope that helps.
Tas.
> Hi James,
> Thanks
> Pradeep
>> Hi Pradeep,
>> types.
>> so
>> a
>> instance
>> - James.
>>> some
>> editor.
>> between
>>> javautilDate.
>>> as
>>> Thanks
>>> Pradeep
>>> There
>>> > Hi Pradeep,
>>> > - James.
>> the
>>> > .ecore model.
>>> >> Datatype.
>>> >> Thanks
>>> >> Pradeep
>>> >> > Gonzalo,
>>> > project
>>> > stereotypes
>>> >> > that
>>> > ecore
>>> >> >> UML
>>> >> >> then
>>> >> >> the
>>> > Model
>>> > (i.e.
>>> >> >> are
>>> >> >> work
>>> >> >> this
>>> >> >> problem.
>>> >> >> Thanks in advance.
>>> >> >> With regards,
>>> >> >> Gonzalo Castro
Re: No primitive types in .ecore files (party.javalang.String, ...) [message #613198 is a reply to message #472805] |
Hi Tas,
Pradeep
> Pradeep,
> Hope that helps.
> Tas.
>> Hi James,
>> Thanks
>> Pradeep
>>> Hi Pradeep,
>>> data
>>> types.
>>> name so
>>> a
>>> instance
>>> - James.
>>>> some
>>> editor.
>>> between
>>>> javautilDate.
>>>> as
>>>> Thanks
>>>> Pradeep
>>>> There
>>>> > Hi Pradeep,
>>>> > - James.
>>>> >> for
>>>> > in
>>> the
>>>> > .ecore model.
>>>> >> Datatype.
>>>> >> Thanks
>>>> >> Pradeep
>>>> >> > Gonzalo,
>>>> > project
>>>> > stereotypes
>>>> >> > added
>>>> >> > that
>>>> >> >> to
>>>> > ecore
>>>> >> >> UML
>>>> >> >> Project,
>>>> >> >> then
>>>> >> >> the
>>>> > Model
>>>> >> >> Hibernate.
>>>> >> >> file
>>>> > (i.e.
>>>> >> >> are
>>>> >> >> could
>>>> >> >> work
>>>> >> >> this
>>>> >> >> problem.
>>>> >> >> Thanks in advance.
>>>> >> >> With regards,
>>>> >> >> Gonzalo Castro
Current Time: Sun Jul 20 16:15:08 EDT 2025
Powered by FUDForum. Page generated in 0.27115 seconds
