Home » Modeling » UML2 » problem with generated uml-editor
problem with generated uml-editor [message #472732] |
Mon, 23 April 2007 14:08  |
I have done the following steps:
- downloaded and extracted uml2-sdk-2.0.3.zip in eclipse dir
- File -> Import -> Plugins and Fragments
org.eclipse.uml2.uml
Now clicking at model/UML.genmodel yields a FeatureNotFoundException
(Features creationSubmenus and complianceLevel not found). I tried
removing the .genmodel and generating a new one. However, after
generating All code from this I got a lot of "...cannot be resolved to a
type"-errors within the generated editor. Is this a classpath issue?
How can I fix at least one of these problems? I just want to generate a
standard uml tree-editor out of the specification.
Any hints are greatly appreciated.
Steffen
Re: problem with generated uml-editor [message #472746 is a reply to message #472742] |
Tue, 24 April 2007 02:23   |
Hello James, Kenn and others,
at my department a diagram editor generator was developed called
DiaMeta. The diagrams were originally represented by hypergraphs,
however, it is pretty difficult to write a hypergraph grammar to
specify a particular diagram language.
So support for EMF was added, i.e. an EMF model can be imported
so that the classes are added automatically as diagram components
and even the concrete syntax is modeled via EMF. For example, you
can have Nodes and Links in the abstract syntax and connect them
with Circles (x,y,radius) and Arrows in the concrete syntax.
Now we want to test the framework with a pretty complex diagram
language, UML. So I plan to import the uml.ecore enriched by
visual components relating to e.g. classes, associations, ...
Hopefully it won't be necessary to enrich the whole uml metamodel
with visual components to get a start *g*
My problem is now, that I have to know, which eclasses are used
for which purpose. So it would be very helpful to see the
abstract syntax of a concrete little uml diagram. That is, what
I want to produce.
> Let me try to understand what you are doing ... your goal is to have a look
> at the UML metamodel in the UML editor?
> Just double click on the UML.merged.uml.
I have found this file, however I do not understand how I could use
it to get what I want. What is this all about? Can you please point
me to the right places to look for further information? I guess some
important pieces of the puzzle I still don't understand.
Steffen
Re: problem with generated uml-editor [message #472846 is a reply to message #472746] |
Tue, 01 May 2007 15:17  |
Hi Steffen,
Sorry for the delayed response ...
Some comments below ...
- James.
"Steffen Mazanek" <modeling@steffen-mazanek.de> wrote in message
news:f0k7p4$o8n$1@build.eclipse.org...
> I want to produce.
You can create a little uml model using the default uml editor. Open up
the resulting .uml file as text and have a peek.
UML.ecore is the ecore representation of the UML metamodel.
look
UML.merged.uml is the complete uml metamodel.
If you want to add diagramming capablities you might want to look at the
UMLTools project.
>I guess some
> Best regards,
> Steffen
Re: problem with generated uml-editor [message #611037 is a reply to message #472732] |
Mon, 23 April 2007 18:27  |
Steffen,
If you want to regenerate the UML API then you can open the UML.genmodel but
it doesn't sound like that's what you want to do.
- James
news:f0isnr$gr2$1@build.eclipse.org...
> Hello,
> Best regards,
> Steffen
Re: problem with generated uml-editor [message #611040 is a reply to message #472732] |
Mon, 23 April 2007 22:02  |
Steffen,
Do you have the right version of EMF installed (UML2 2.0.x requires 2.2.x)?
Are you sure you downloaded UML2 2.0.3 and not a 2.1 build? The features you
refer to were introduced in EMF 2.3 and so should not appear in the
generator model from UML2 2.0.x...
Kenn
> Hello,
> removing the .genmodel and generating a new one. However, after generating
> All code from this I got a lot of "...cannot be resolved to a type"-errors
> Best regards,
> Steffen
Re: problem with generated uml-editor [message #611041 is a reply to message #472742] |
I want to produce.
Steffen
Re: problem with generated uml-editor [message #611043 is a reply to message #472745] |
Tue, 24 April 2007 03:00  |
Kenn,
I tried it again and you are right. I had installed the
wrong version of uml2. The feature problem is now resolved.
Thank you!
Steffen
> Kenn
>> Hello,
>> Best regards,
>> Steffen
Re: problem with generated uml-editor [message #614267 is a reply to message #472746] |
Hi Steffen,
- James.
> I want to produce.
look
UMLTools project.
>I guess some
> Best regards,
> Steffen
Current Time: Sat Jul 19 14:37:05 EDT 2025
Powered by FUDForum. Page generated in 0.05051 seconds
