Home » Modeling » UML2 » minor extensions to the UML metamodel
minor extensions to the UML metamodel [message #472544] |
Tue, 17 April 2007 10:45  |
I need to extend the UML metamodel in a purely additive manner: I just
need to subclass a few metaclasses to provide features that UML itself
does not have. I considered the profiles and stereotypes route, but it
is just too limited for my needs (because I need to create new
associations between metaclasses, and all that stereotypes let me do is
to add properties with primitive types - is that correct?).
However, after going the heavyweight route, I realized that even if I
was able to add elements of my new metaclasses to a UML model and
persist it, I would not be able to load the model as those elements
would not be understood when loading the resource. I guess that should
have been obvious were I a bit more knowledgeable about UML.
So now I am stuck. Is there a way of doing what I want so that:
a) I don't have to re-implement UML and can basically extend the UML2
API and implementation
b) models created with my metamodel can be read by any tools that can
read UML2 UML models
Rafael
Re: minor extensions to the UML metamodel [message #472545 is a reply to message #472544] |
Tue, 17 April 2007 11:48   |
Hi Rafael,
Christian Damus (a.k.a. Mr. OCL) just mentioned to me that you can have a
look at the OCL metamodel for a concrete example of a heavyweight extension
to UML that subclasses a few metaclasses. In particular, have a look at
the OCL Expression metaclass that specializes UML OpaqueExpression.
Please have a look at that OCL metamodel and ensure that your packages are
properly registered in order to load your specialized models.
You might have problems with tools that do not understand your specialized
metaclasses. That's one of the reasons why the profile route is
preferrable. Whether a particular tool can understand your metatypes
depends on how flexible the implementation was made ... you may want to look
at extensibility options in the tool you wish to work with. RSA for example
allows users to extend pallettes, menus and tooling for such things.
Also, I'm not sure if you had a look at the draft articles describing
pros/cons of the various extension methods but you might want to look at the
bugzilla entitled "Improved Documentation".
- James.
"Rafael Chaves" <chaves@inf.ufsc.nospam.br> wrote in message
news:f02mht$3vh$1@build.eclipse.org...
> Rafael
Re: minor extensions to the UML metamodel [message #472548 is a reply to message #472545] |
Tue, 17 April 2007 12:54  |
D'oh! I forgot to do that. After doing it, I can now open the model with
foreign elements in the UML editor. Thanks for suggesting the sanity check!
BTW, I created the metamodel by following the article "Extending UML2:
Creating Heavy-weight Extensions" which is quite good as it is already
(content-wise).
Rafael
James Bruck wrote:
> Hi Rafael,
> Regards,
> - James.
>> Thanks,
>> Rafael
Re: minor extensions to the UML metamodel [message #607702 is a reply to message #472544] |
Hi Rafael,
- James.
> Rafael
Re: minor extensions to the UML metamodel [message #607704 is a reply to message #472545] |
Tue, 17 April 2007 12:01  |
James Bruck wrote:
> Hi Rafael,
> extension
You'll find that in the org.eclipse.ocl.uml plug-in in the model/OCLUML.uml
model. Have a look at ocl::uml::ExpressionInOcl.
Christian
<snip>
> Regards,
> - James.
<snip>
Re: minor extensions to the UML metamodel [message #607710 is a reply to message #472545] |
(content-wise).
Rafael
James Bruck wrote:
> Hi Rafael,
> Regards,
> - James.
>> Thanks,
>> Rafael
Current Time: Sat Jul 19 17:36:39 EDT 2025
Powered by FUDForum. Page generated in 0.04013 seconds
