Home » Modeling » UML2 » template expansion
template expansion [message #472105] |
Mon, 02 April 2007 23:31  |
I only recently started to get familiar with the support for templates
in UML2. One thing that I am missing is the ability of expanding a
template binding in a way that would generate a new element from a bound
element by effecting all template parameter substitutions. Is there
anything like that in UML or at least in UML2? Or is this something that
tools have to do themselves?
Rafael
Re: template expansion [message #472215 is a reply to message #472213] |
Tue, 03 April 2007 13:20   |
James, it seems you misunderstood my comment (I did not ask for any UI
support, for instance). It was just an expansion of my own original post
(that one you understood correctly, as you replied with very relevant
comments). Let me try to rephrase my question.
I understand per your other reply that there is no support for automatic
expansion of templates, but let's ignore that fact for now, as my question
here has more to do with UML practices than with UML2 per se.
I was just trying to make sure I understood what to do if I wanted to
reference elements in a bound element that are actually defined in the
template, should I expand the bound element first (so it has all the
elements defined in the template), or should I just reference the original
element.
Again, in my example:
class Car
class List<T>
operation get(i : Integer) : T
If I wanted to refer to invoke the operation "get" on a List<Car>, should
I just refer to the generic operation as defined in List<T>, or should I
first expand List<Car> as:
class List_Of_Car
operation get(i : Integer) : Car
and then refer to this specific "get" operation instead.
I looked for info on this in the spec but could not find anything.
Rafael
James Bruck wrote:
> Rafael,
> There is no menu option to create a new "merged" version of a class with all
> the substitutions applied.
> What does exist is the ability to convert your fully specified UML to ecore
> and vice versa.
> - James.
> "Rafael Chaves" <chaves@inf.ufsc.nospam.br> wrote in message
> news:a374ee74f94d65b1bb16603f9c8cf50c$1@www.eclipse.org...
>> This is my motivation for asking this question: imagine you have the
>> following classes in your model:
>> class Car
>> class List<T>
>> Now consider an activity wants to call get(Integer) on an object whose
>> type is List<Car>. In the CallOperationAction, what would be the operation
>> element referred to? The generic version? Or should the generic get
>> operation be somehow expanded, generating a List<Car> specific operation,
>> and that operation be referred?
Re: template expansion [message #472220 is a reply to message #472215] |
Tue, 03 April 2007 16:47   |
Rafael,
The two representations are supposed to be semantically equivalent, but I
would think that it's not generally a good idea to reference the template
representations of things from non-templates...
Kenn
news:556811df69c76fc7cc955159ea8a7703$1@www.eclipse.org...
> element.
> class Car
> class List<T>
> class List_Of_Car
> Thanks
> Rafael
> James Bruck wrote:
>> Rafael,
>> all
>> ecore
>> and vice versa.
>> - James.
>>> class Car
>>> class List<T>
>>> operation
>>> operation,
Re: template expansion [message #472227 is a reply to message #472220] |
Wed, 04 April 2007 15:57   |
Kenn, so if I understood well, there isn't a single right way.
I guess I agree with your position on the issue of referring to
templates from non-template elements. But at the same time, I feel that
expanding bound elements will lose information that might be useful
later on (for instance, when generating code in a language that supports
parametric types). Unless I am missing something.
I guess what I would really like to see was some way of figuring out the
template binding that generated any given bound element in expanded form
(just annotated bug 180744 with that information).
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> element.
>> class Car
>> class List<T>
>> class List_Of_Car
>> Thanks
>> Rafael
>> James Bruck wrote:
>>> Rafael,
>>> all
>>> ecore
>>> and vice versa.
>>> - James.
>>>> class Car
>>>> class List<T>
>>>> operation
>>>> operation,
Re: template expansion [message #472497 is a reply to message #472227] |
Sun, 08 April 2007 21:09   |
Some comments below...
news:ev0vv0$hie$1@build.eclipse.org...
> expanding bound elements will lose information that might be useful later
From the above paragraph it seems that... to paraphrase...: Given a bound
element in expanded form, you want to know the template binding that
generated it. Since there are many different ways that an element could
be bound ... ie by either substituting default parameters or via multiple
bindings I'm not sure if there is a definitive way of doing this (although I
have not thought about this in great detail)
This seems to be a little bit different from what you ask for in the bug
detail... "Ideally, on the expanded form, there would be a way of telling
apart things that were defined in the element itself from those coming from
a template binding expansion.". This request seems possible since we could
annotate the expanded model while applying the substitutions.
- James
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> Kenn
>>> question here has more to do with UML practices than with UML2 per se.
>>> original element.
>>> class Car
>>> class List<T>
>>> should I just refer to the generic operation as defined in List<T>, or
>>> should I first expand List<Car> as:
>>> class List_Of_Car
>>> Thanks
>>> Rafael
>>> James Bruck wrote:
>>>> Rafael,
>>>> with all
>>>> ecore
>>>> and vice versa.
>>>> - James.
>>>>> class Car
>>>>> class List<T>
>>>>> operation
>>>>> operation,
Re: template expansion [message #472498 is a reply to message #472215] |
Sun, 08 April 2007 21:20  |
Rafael,
.... I meant additional API that could be exposed through the example UI ..
but I understand that you are requesting support for template expansion...
....I believe Kenn answered your second question about how to refer to
specific "get" operation in the example below....
- James.
> element.
> class Car
> class List<T>
> class List_Of_Car
> Thanks
> Rafael
> James Bruck wrote:
>> Rafael,
>> all
>> ecore
>> and vice versa.
>> - James.
>>> class Car
>>> class List<T>
>>> operation
>>> operation,
Re: template expansion [message #604245 is a reply to message #472105] |
Tue, 03 April 2007 10:38  |
class Car
class List<T>
Re: template expansion [message #604252 is a reply to message #472105] |
Tue, 03 April 2007 10:47  |
Rafael,
That is currently lacking from the UML API but it is on the TODO list.
The way I see it, it would work somewhat like the package merge does now in
UMLUtil.
I don't think there is a bugzilla for that so you if you really need that
functionality, you can create a bugzilla to make an official request.
- James.
news:eushp4$bpd$1@build.eclipse.org...
> Rafael
Re: template expansion [message #604254 is a reply to message #472211] |
Tue, 03 April 2007 12:06  |
> UMLUtil.
That is what I expected too.
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=180744
Rafael
Re: template expansion [message #605362 is a reply to message #472210] |
Tue, 03 April 2007 12:37  |
Rafael,
and vice versa.
- James.
> class Car
> class List<T>
Re: template expansion [message #605374 is a reply to message #472213] |
element.
class Car
class List<T>
class List_Of_Car
Rafael
James Bruck wrote:
> Rafael,
> and vice versa.
> - James.
>> class Car
>> class List<T>
Re: template expansion [message #605398 is a reply to message #472215] |
Rafael,
Kenn
> element.
> class Car
> class List<T>
> class List_Of_Car
> Thanks
> Rafael
> James Bruck wrote:
>> Rafael,
>> all
>> ecore
>> and vice versa.
>> - James.
>>> class Car
>>> class List<T>
>>> operation
>>> operation,
Re: template expansion [message #605428 is a reply to message #472220] |
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> element.
>> class Car
>> class List<T>
>> class List_Of_Car
>> Thanks
>> Rafael
>> James Bruck wrote:
>>> Rafael,
>>> all
>>> ecore
>>> and vice versa.
>>> - James.
>>>> class Car
>>>> class List<T>
>>>> operation
>>>> operation,
Re: template expansion [message #607421 is a reply to message #472227] |
- James
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> Kenn
>>> original element.
>>> class Car
>>> class List<T>
>>> class List_Of_Car
>>> Thanks
>>> Rafael
>>> James Bruck wrote:
>>>> Rafael,
>>>> with all
>>>> ecore
>>>> and vice versa.
>>>> - James.
>>>>> class Car
>>>>> class List<T>
>>>>> operation
>>>>> operation,
Re: template expansion [message #607422 is a reply to message #472215] |
Rafael,
- James.
> element.
> class Car
> class List<T>
> class List_Of_Car
> Thanks
> Rafael
> James Bruck wrote:
>> Rafael,
>> all
>> ecore
>> and vice versa.
>> - James.
>>> class Car
>>> class List<T>
>>> operation
>>> operation,
Current Time: Sat Jul 19 14:14:23 EDT 2025
Powered by FUDForum. Page generated in 0.16734 seconds
