Home » Modeling » UML2 » Load samples using UML2 2.1.0 API
Load samples using UML2 2.1.0 API [message #471736] Tue, 20 March 2007 03:02 Go to next message
Hi all,
I would like to use the EMF/UML2 API to handle Magic Draw 12.1 EMF/UML2
Models. (Can I do that using the current version of Eclipse+EMF+UML2 ?)
Then, I'm starting using the sample files present in the "Introduction
to UML2 Profiles" and "Getting Started with UML2" articles. But, I had
problems using the ExtendedPO2 models.
My current configuation is Eclipse 3.3M5, EMF 2.3 and UML2 2.1. I'm
also using the UML2Article load and register methods to handle the model,
as following:
protected static org.eclipse.uml2.uml.Package load(URI uri) {
org.eclipse.uml2.uml.Package package_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true);
package_ = (org.eclipse.uml2.uml.Package) EcoreUtil
.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
err(we.getMessage());
System.exit(1);
return package_;
My implementation always run until "Resource resource =
RESOURCE_SET.getResource(uri, true)" line. Then, it stop printig the
message:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'null' is not
legal. (file:/C:/projetos/uml2Test/resources/resources2-0/ExtendedP O2.uml,
11, 21)
Some one could help me?
thanks in advance
Marcio
Re: Load samples using UML2 2.1.0 API [message #471737 is a reply to message #471736] Tue, 20 March 2007 09:07 Go to previous messageGo to next message
Marcio,
What does the ExtendedPO model from Magic Draw look like? It sounds like it
contains an invalid value for a feature on line 11.
Kenn
"Marcio" <marciofsoliveira@gmail.com> wrote in message
news:89bdab8c55b287f193e717ef5dea0c8a$1@www.eclipse.org...
> Hi all,
> Then, I'm starting using the sample files present in the "Introduction to
> My current configuation is Eclipse 3.3M5, EMF 2.3 and UML2 2.1. I'm also
> using the UML2Article load and register methods to handle the model, as
> following:
> try {
> System.exit(1);
> return package_;
> message:
> 11, 21)
> thanks in advance
> Marcio
Re: Load samples using UML2 2.1.0 API [message #471738 is a reply to message #471737] Tue, 20 March 2007 11:28 Go to previous messageGo to next message
Kenn,
The ExtendedPO model that I use is the same file provided by
"Introduction to UML2 Profile" and "Getting start with UML2" article
presented in eclipse.org site. I didn't model the ExtendedPO in the Magic
Draw and tried to load it with EMF/UML2 API. May, have the provided
ExtendedPO model in the articles problems with the UML2 2.1.0 version?
Marcio
Re: Load samples using UML2 2.1.0 API [message #471804 is a reply to message #471738] Fri, 23 March 2007 09:56 Go to previous message
Marcio,
I was able to load the model from the article (ExtendedPO.uml) without
errors using the latest build... Are you sure that you are registering the
required extensions, packages, and pathmaps? Could you provide the copy of
ExtendedPO.uml that you are trying to load (in case it is somehow different
from the one I tried)?
Kenn
news:e5f08fb9543fa8e14059542d304c39de$1@www.eclipse.org...
> Kenn,
> Marcio
Re: Load samples using UML2 2.1.0 API [message #601870 is a reply to message #471736] Tue, 20 March 2007 09:07 Go to previous message
Marcio,
Kenn
> Hi all,
> following:
> try {
> System.exit(1);
> return package_;
> message:
> 11, 21)
> thanks in advance
> Marcio
Re: Load samples using UML2 2.1.0 API [message #601878 is a reply to message #471737] Tue, 20 March 2007 11:28 Go to previous message
Kenn,
Marcio
Re: Load samples using UML2 2.1.0 API [message #603152 is a reply to message #471738] Fri, 23 March 2007 09:56 Go to previous message
Marcio,
Kenn
> Kenn,
> Marcio
Previous Topic:Profile reapplication
Next Topic:newbie to uml2
Current Time: Sun Jul 20 18:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.44386 seconds
