Home » Modeling » UML2 » problem extending "Getting Started with UML2"
problem extending "Getting Started with UML2" [message #471654] Fri, 16 March 2007 20:40 Go to next message
Thank you for developing such an amazing project! I like Eclipse UML2
very much!
I have some problems extending the "Getting Started with UML2" article.
Suppose I have a model and I save it in a file "file.uml" then another
tool or someone else modifies the file.
Now if I try to load again "file.uml" (to see the modification) the
modification doesn't appear. If I exit my program and start it again and
load the file, it works.
I am using save() and load() provided in "Getting Started with UML2"
article.
I believe that when the file is loaded it is cashed and then a cashed
URI is not refreshed on a new load.
Please tell me how to handle this, how can I refresh the model, or how
can I close it and open it again.
Thanks for any help.
Bogdan Pistol
Re: problem extending "Getting Started with UML2" [message #471733 is a reply to message #471654] Mon, 19 March 2007 22:49 Go to previous messageGo to next message
Bogdan,
I'm glad you like UML, you can thank Kenn Hussey for this API.
As far as your question goes, you can try to unload each of the resources in
your resource set.
p.303 of the "Eclipse Modeling Framework" book describes this method and
mentions "... This allows you to bring a resource up to date if, for
example, the underlying file has changed since it was last loaded ..".
Hope that helps,
- James.
"Bogdan Pistol" <bogdanciprian@yahoo.com> wrote in message
news:etfdaa$2gk$1@utils.eclipse.org...
> Hello,
> Thank you for developing such an amazing project! I like Eclipse UML2 very
> much!
> article.
> I believe that when the file is loaded it is cashed and then a cashed URI
> Please tell me how to handle this, how can I refresh the model, or how can
> Bogdan Pistol
Re: problem extending "Getting Started with UML2" [message #471742 is a reply to message #471733] Tue, 20 March 2007 21:13 Go to previous messageGo to next message
Hello James,
Thanks for the tip, I found the reference in the book. I'll read this
book to find out more about UML2.
Eclipse UML2 is great!
Bogdan Pistol
James Bruck wrote:
> Bogdan,
> your resource set.
> Hope that helps,
> - James.
>> Hello,
>> much!
>> article.
>> Bogdan Pistol
Re: problem extending "Getting Started with UML2" [message #471753 is a reply to message #471742] Thu, 22 March 2007 05:25 Go to previous messageGo to next message
May I ask which book is this? It seems there are many books have the name
"Eclipse Modeling Framework", which one should I buy?
Thank you
Re: problem extending "Getting Started with UML2" [message #471754 is a reply to message #471753] Thu, 22 March 2007 07:12 Go to previous messageGo to next message
Jerry,
I think there is only one such book:
http://www.awprofessional.com/bookstore/product.asp?isbn=013 1425420&rl=1
< http://www.awprofessional.com/bookstore/product.asp?isbn=013 1425420&rl=1>.
We are currently working on the second edition but don't expect that
will be available for another 3-4 months.
> name "Eclipse Modeling Framework", which one should I buy?
> Thank you
Re: problem extending "Getting Started with UML2" [message #471758 is a reply to message #471754] Thu, 22 March 2007 21:36 Go to previous messageGo to next message
Yes, that's the book.
Ed Merks wrote:
> Jerry,
>> Thank you
Re: problem extending "Getting Started with UML2" [message #471760 is a reply to message #471758] Fri, 23 March 2007 04:31 Go to previous message
Thanks! It will be good to have it since the API doc is too simple for a
beginner like me :)
Re: problem extending "Getting Started with UML2" [message #601838 is a reply to message #471654] Mon, 19 March 2007 22:49 Go to previous message
Bogdan,
your resource set.
Hope that helps,
- James.
> Hello,
> much!
> article.
> Bogdan Pistol
Re: problem extending "Getting Started with UML2" [message #601908 is a reply to message #471733] Tue, 20 March 2007 21:13 Go to previous message
Hello James,
Bogdan Pistol
James Bruck wrote:
> Bogdan,
> your resource set.
> Hope that helps,
> - James.
>> Hello,
>> much!
>> article.
>> Bogdan Pistol
Re: problem extending "Getting Started with UML2" [message #603112 is a reply to message #471742] Thu, 22 March 2007 05:25 Go to previous message
Thank you
Re: problem extending "Getting Started with UML2" [message #603117 is a reply to message #471753] Thu, 22 March 2007 07:12 Go to previous message
Jerry,
> Thank you
Re: problem extending "Getting Started with UML2" [message #603137 is a reply to message #471754] Thu, 22 March 2007 21:36 Go to previous message
Ed Merks wrote:
> Jerry,
>> Thank you
Re: problem extending "Getting Started with UML2" [message #603143 is a reply to message #471758] Fri, 23 March 2007 04:31 Go to previous message
beginner like me :)
Previous Topic:[Announce] MDT UML2 2.1.0 I200703221526 is available
Next Topic:Jar2UML reverse engineering tool available
Current Time: Sun Jul 20 15:21:03 EDT 2025
Powered by FUDForum. Page generated in 0.05896 seconds
