Home » Modeling » UML2 » initializing an UML2 model with .ecore contents
initializing an UML2 model with .ecore contents [message #471150] Mon, 26 February 2007 09:46 Go to next message
Given a .ecore file, how can it be converted to a .uml file? It's not
necessary to generate diagram layout information, although that would be
desirable too.
Miguel
Re: initializing an UML2 model with .ecore contents [message #471159 is a reply to message #471150] Mon, 26 February 2007 13:13 Go to previous message
Hi Miguel,
Right click on your corresponding .genmodel. Select "Export Model...".
From the wizard that pops up, select UML model.
Alternatively, you can open your .ecore model. Select a EPackage that you
want to convert, then from the "Sample Ecore Editor" menu, select "Convert
to UML Model ..." .
You will need the org.eclipse.uml2.examples plugins to see those menu
options.
If you are using the latest version of the UML API, be on the lookout for
genercis in your generated UML model.
- James.
"Miguel Garcia" <mgarcia512@yahoo.com> wrote in message
news:erursi$9th$1@utils.eclipse.org...
> desirable too.
> Regards,
> Miguel
Re: initializing an UML2 model with .ecore contents [message #593875 is a reply to message #471150] Mon, 26 February 2007 13:13 Go to previous message
Hi Miguel,
to UML Model ..." .
options.
- James.
> desirable too.
> Regards,
> Miguel
Previous Topic:Programmetic Create Connetor between Port
Next Topic:Re: UML2 Profile Usage
Current Time: Sat Jul 19 05:01:27 EDT 2025
Powered by FUDForum. Page generated in 0.04723 seconds
