Home » Modeling » UML2 » Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #470413] |
Wed, 14 February 2007 06:57  |
Paul,
It sounds likely that this is a multi-threading issue. Certainly
ECrossReferenceAdapter is not designed for safe multi-threaded updates
and I don't think the CacheAdapter is specialized to support that
either. I didn't see your posting on the UML newsgroup, so I added it
to the "to" list.
Paul Kelly wrote:
> I get the following exception when I call ECoreUtil.resolveAll :
> java.util.ConcurrentModificationException: concurrent access to
> HashMap attempted by Thread[Worker-6,5,main]
> at java.util.HashMap.onExit(HashMap.java:217)
> at java.util.HashMap.transfer(HashMap.java:514)
> at java.util.HashMap.resize(HashMap.java:500)
> at java.util.HashMap.addEntry(HashMap.java:800)
> at java.util.HashMap.put(HashMap.java:441)
> at org.eclipse.uml2.common.util.CacheAdapter.put(CacheAdapter.j ava:420)
> at org.eclipse.uml2.common.util.CacheAdapter.put(CacheAdapter.j ava:393)
> at
> org.eclipse.uml2.uml.internal.impl.PropertyImpl.getDeployedE lements(PropertyImpl.java:635)
> at
> org.eclipse.uml2.uml.internal.impl.PropertyImpl.eIsSet(Prope rtyImpl.java:2551)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:818)
> at
> org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:414)
> at
> org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EContentsEList.java:549)
> at
> org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences( EcoreUtil.java:302)
> at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.ja va:296)
> Just wondering if anyone else has come across this issue?
> I wasn't sure whether to post to the uml2 or emf forum, decided on both.
> Its a hard one to recreate, but i've typically seen it when there are
> many background tasks running. I know there was a similar bug for
> getAppliedStereotypes(), just wondering if there is a fix or
> workaround for this issue? Any help appreciated.
> Cheers,
> Paul
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #470414 is a reply to message #470413] |
Wed, 14 February 2007 07:25   |
Originally posted by: pkelly03.gmail.com
Thanks for update Ed.
Paul
Ed Merks wrote:
> Paul,
> to the "to" list.
> Paul Kelly wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Paul
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #470415 is a reply to message #470413] |
Wed, 14 February 2007 09:32   |
Ed,
While it's true that the cross-referencing aspects of the cache adapter (as
extended from EMF) weren't designed to be thread-safe, the data caching
aspects were... This particular problem should have been fixed by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172040.
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:equtel$t30$1@utils.eclipse.org...
> Paul,
> ECrossReferenceAdapter is not designed for safe multi-threaded updates and
> I don't think the CacheAdapter is specialized to support that either. I
> didn't see your posting on the UML newsgroup, so I added it to the "to"
> list.
> Paul Kelly wrote:
>> Hi,
>> java.util.ConcurrentModificationException: concurrent access to HashMap
>> at
>> at
>> at
>> at
>> at
>> at
>> getAppliedStereotypes(), just wondering if there is a fix or workaround
>> Cheers,
>> Paul
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #470931 is a reply to message #470415] |
Wed, 14 February 2007 10:11   |
--------------010203090306090301060800
Kenn,
I thought I remembered something about this being fixed. I think this
stream will be released on Friday along with Eclipse 3.2.2, right?
Kenn Hussey wrote:
> Ed,
> Kenn
>> Paul,
>> list.
>> Paul Kelly wrote:
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Paul
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kenn,<br>
<br>
stream will be released on Friday along with Eclipse 3.2.2, right?<br>
<br>
<br>
Kenn Hussey wrote:
<blockquote cite="mideqv6h8$nvd$1@utils.eclipse.org" type="cite">
<pre wrap="">Ed,
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=172040">https://bugs.eclipse.org/bugs/show_bug.cgi?id=172040</a>.
Kenn
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:equtel$t30$1@utils.eclipse.org">news:equtel$t30$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Paul,
list.
Paul Kelly wrote:
</pre>
<pre wrap="">Hi,
at
at
at
at
at
at
Paul
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010203090306090301060800--
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #470934 is a reply to message #470931] |
Wed, 14 February 2007 10:14  |
------=_NextPart_000_074C_01C75020.FBD64E50
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Yes.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:eqv8qf$c02$2@utils.eclipse.org...
Kenn,
I thought I remembered something about this being fixed. I think this =
Kenn Hussey wrote:=20
Ed,
While it's true that the cross-referencing aspects of the cache adapter =
(as=20
extended from EMF) weren't designed to be thread-safe, the data caching=20
aspects were... This particular problem should have been fixed by=20
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D172040.
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Paul,
It sounds likely that this is a multi-threading issue. Certainly=20
ECrossReferenceAdapter is not designed for safe multi-threaded updates =
and=20
I don't think the CacheAdapter is specialized to support that either. I =
didn't see your posting on the UML newsgroup, so I added it to the "to"=20
list.
java.util.ConcurrentModificationException: concurrent access to HashMap=20
at=20
org.eclipse.uml2.uml.internal.impl.PropertyImpl.getDeployedE lements(Prope=
rtyImpl.java:635)
at=20
org.eclipse.uml2.uml.internal.impl.PropertyImpl.eIsSet(Prope rtyImpl.java:=
2551)
at=20
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:=
818)
at=20
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(ECo=
at=20
org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EConte=
ntsEList.java:549)
at=20
org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences( EcoreUtil.jav=
a:302)
Its a hard one to recreate, but i've typically seen it when there are=20
many background tasks running. I know there was a similar bug for=20
getAppliedStereotypes(), just wondering if there is a fix or workaround=20
Paul=20
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3020" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Yes.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:eqv8qf$c02$2@utils.eclipse.org">news:eqv8qf$c02$2@utils.ecli=
pse.org</A>...</DIV>Kenn,<BR><BR>I=20
thought I remembered something about this being fixed. I think =
this=20
stream will be released on Friday along with Eclipse 3.2.2,=20
right?<BR><BR><BR>Kenn Hussey wrote:=20
<BLOCKQUOTE cite=3Dmideqv6h8$nvd$1@utils.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Ed,
(as=20
<A class=3Dmoz-txt-link-freetext =
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D172040">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D172040</A>.
Kenn
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
href=3D"news:equtel$t30$1@utils.eclipse.org">news:equtel$t30$1@utils.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Paul,
and=20
list.
Paul Kelly wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
at=20
rtyImpl.java:635)
at=20
2551)
at=20
818)
at=20
at=20
ntsEList.java:549)
at=20
a:302)
Paul=20
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_074C_01C75020.FBD64E50--
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #588738 is a reply to message #470413] |
Paul
Ed Merks wrote:
> Paul,
> to the "to" list.
> Paul Kelly wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Paul
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #588749 is a reply to message #470413] |
Ed,
Kenn
> Paul,
> list.
> Paul Kelly wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Paul
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #588779 is a reply to message #470415] |
Kenn,
Kenn Hussey wrote:
> Ed,
> Kenn
>> Paul,
>> list.
>> Paul Kelly wrote:
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Paul
<html>
<head>
</head>
Kenn,<br>
<br>
<br>
<br>
<pre wrap="">Ed,
Kenn
</pre>
<pre wrap="">Paul,
list.
Paul Kelly wrote:
</pre>
<pre wrap="">Hi,
at
at
at
at
at
at
Paul
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: ConcurrentModificationExceptions with ECoreUtil.resolveAll [message #588788 is a reply to message #470931] |
Yes.
Kenn,
Ed,
(as=20
Kenn
Paul,
and=20
list.
at=20
rtyImpl.java:635)
at=20
2551)
at=20
818)
at=20
at=20
ntsEList.java:549)
at=20
a:302)
Paul=20
=20
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BLOCKQUOTE=20
this=20
(as=20
Kenn
message=20
pse.org</A>...
</PRE>
and=20
list.
Paul Kelly wrote:
</PRE>
at=20
rtyImpl.java:635)
at=20
2551)
at=20
818)
at=20
at=20
ntsEList.java:549)
at=20
a:302)
Paul=20
Current Time: Sun Jul 20 06:08:01 EDT 2025
Powered by FUDForum. Page generated in 0.04531 seconds
