getAllAppliedProfile [message #470441] |
Thu, 23 July 2009 10:35  |
I want to get the profile applied to my model with the function
"getAllAppliedProfiles" I obtain the list here under but when I use the
function "getOwnedStereotypes()" on these profiles I obtain an empty
list.I work with papyrus and my code to load my model is also here under.
getAllAppliedProfiles :
[org.eclipse.uml2.uml.internal.impl.ProfileImpl@2f0d54 (eProxyURI:
pathmap://UML_PROFILES/Standard.profile.uml#_0),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1961581 (eProxyURI:
resources/MARTE.profile.uml#_EIfnABJeEdy3Td9UhuLFPg),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@113beb5 (eProxyURI:
resources/MARTE.profile.uml#_5ZCOIAPMEdyuUt-4qHuVvQ),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@193f6e2 (eProxyURI:
resources/MARTE.profile.uml#_yNSZIAPMEdyuUt-4qHuVvQ),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1e13e07 (eProxyURI:
resources/MARTE.profile.uml#_A_vtYBJeEdy3Td9UhuLFPg)]
my code:
URI uri = URI.createURI("essai2/essai2.uml");
try {
ResourceSetImpl resourceSet = new ResourceSetImpl();
// Plug in UML model loader (package and file extension recognition)
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
UMLResource resource = (UMLResource) resourceSet.getResource(uri, true);
Model mod=(Model)EcoreUtil.getObjectByType(((Resource)
resource).getContents(), UMLPackage.eINSTANCE.getModel());
System.out.println(mod.getAllAppliedProfiles());
System.out.println(mod.getAllAppliedProfiles().get(0).getOwn edStereotypes());
} catch (WrappedException we) {
we.printStackTrace();
System.exit(1);
Aurélie
Re: getAllAppliedProfile [message #470444 is a reply to message #470441] |
Thu, 23 July 2009 12:17   |
Hi Aurélie,
I think your resource is not resolve and you can't access owned stereotypes.
Check if the profile is a proxy:
getAllAppliedProfiles().get(0).eIsProxy()
if true: EcoreUtil.resolveAll(resourceSet)
If is not represented by proxy, maybe your stereotypes are owned by a
subpackage of your profile. If I remember, getOwnedStereotypes() only
check the first level
Your question is about UML, not only papyrus project.
Be careful to post on the right newsgroup next time.
Emilien
guenin a écrit :
> my code:
> public static void main(String[] args) {
> try {
> System.exit(1);
> Aurélie
Re: getAllAppliedProfile [message #470447 is a reply to message #470444] |
Fri, 24 July 2009 04:32  |
HI,
To be more precise, when the profile is not a proxy, the result is good and
when the profile is a proxy the function getOwnedStereotype return an
empty list
Aurélie
Re: getAllAppliedProfile [message #590767 is a reply to message #470441] |
Hi Aurélie,
Emilien
guenin a écrit :
> my code:
> try {
> System.exit(1);
> Aurélie
Re: getAllAppliedProfile [message #590773 is a reply to message #470444] |
Fri, 24 July 2009 02:53  |
Hi Emilien,
Thank you for your answer but the profiles are proxy and the function
resolveAll(ResourceSet) changes nothing.
For the newsgroup, I first post my question in umltools news group and
someone tell me that my code seemed to be right and I could post my
question on papyrus newsgroup
Aurélie.
Re: getAllAppliedProfile [message #590782 is a reply to message #470444] |
HI,
empty list
Aurélie
FUDForum. Page generated in 0.54408 seconds
