Home » Modeling » UML2 » Questions to Sequence Diagram
Questions to Sequence Diagram [message #469721] Tue, 30 January 2007 18:49 Go to next message
Originally posted by: psentosa.yahoo.com
Hi all,
I tried to use the UML Editor to define a simple statemachine. Unfortunately
I can't confirm whether this is a correct usage of the different elements
If you have some time, could you please give a quick glance on the diagram
attached and its .uml file created with the UML Editor?
Many thanks in advance
Paul
ps: Unfortunately I still don't know how to define some methods within a
state. For the entry/.... statement I used an "entry activity"
I'll be thankful for every comments/correction
  • Attachment: mw.jpg
    (Size: 47.45KB, Downloaded 154 times)
  • Attachment: SM_MW.uml
    (Size: 4.51KB, Downloaded 241 times)
Re: Questions to Sequence Diagram [message #469722 is a reply to message #469721] Tue, 30 January 2007 18:57 Go to previous messageGo to next message
I tried to attach the .uml file but it didn't work. The content:
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_2EPR0LCkEduT5_CrhBdvpw" name="MW">
<packagedElement xmi:type="uml:Class" xmi:id="_hx9O8LClEduT5_CrhBdvpw"
name="MW" classifierBehavior="_PNqeQLCuEduT5_CrhBdvpw">
<ownedBehavior xmi:type="uml:StateMachine" xmi:id="_PNqeQLCuEduT5_CrhBdvpw"
name="States of MW">
<region xmi:id="_VXI98LCuEduT5_CrhBdvpw">
<subvertex xmi:type="uml:Pseudostate" xmi:id="_Z0mnwLCuEduT5_CrhBdvpw"
outgoing="_uU1xoLCuEduT5_CrhBdvpw"/>
<subvertex xmi:type="uml:State" xmi:id="_bojRoLCuEduT5_CrhBdvpw"
name="1_Ready to Cook" outgoing="_9DYCoLCuEduT5_CrhBdvpw
_GgxxMLCvEduT5_CrhBdvpw" incoming="_uU1xoLCuEduT5_CrhBdvpw
_9n9WYLCuEduT5_CrhBdvpw _EWx-0LCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_P2Z1ELC1EduT5_CrhBdvpw"
name="turnOffLight1"/>
</subvertex>
<subvertex xmi:type="uml:State" xmi:id="_cQFywLCuEduT5_CrhBdvpw"
name="2_Door Open" outgoing="_9n9WYLCuEduT5_CrhBdvpw"
incoming="_9DYCoLCuEduT5_CrhBdvpw _E2xGcLCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_ZcyggLC1EduT5_CrhBdvpw"
name="turnOnLight2"/>
</subvertex>
<subvertex xmi:type="uml:State" xmi:id="_cw8dELCuEduT5_CrhBdvpw"
name="3_Cooking" outgoing="_FSeLALCvEduT5_CrhBdvpw _HrkJULCvEduT5_CrhBdvpw
_mg4QoLCvEduT5_CrhBdvpw" incoming="_GgxxMLCvEduT5_CrhBdvpw
_HHjdULCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_exi-sLC1EduT5_CrhBdvpw"
name="turnOnLight3"/>
</subvertex>
<subvertex xmi:type="uml:State" xmi:id="_dMctULCuEduT5_CrhBdvpw"
name="4_Cooking Interrupted" outgoing="_EWx-0LCvEduT5_CrhBdvpw"
incoming="_FSeLALCvEduT5_CrhBdvpw _FxH14LCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_vm1g0LC1EduT5_CrhBdvpw"
name="turnOffLight4"/>
</subvertex>
<subvertex xmi:type="uml:State" xmi:id="_dt-GALCuEduT5_CrhBdvpw"
name="5_Cooking Complete" outgoing="_E2xGcLCvEduT5_CrhBdvpw
_HHjdULCvEduT5_CrhBdvpw" incoming="_IsyVwLCvEduT5_CrhBdvpw
_mg4QoLCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_aFGBMLC2EduT5_CrhBdvpw"
name="turnOffLight5"/>
</subvertex>
<subvertex xmi:type="uml:State" xmi:id="_eerKMLCuEduT5_CrhBdvpw"
name="6_Cooking Extended" outgoing="_FxH14LCvEduT5_CrhBdvpw
_IKHtkLCvEduT5_CrhBdvpw _IsyVwLCvEduT5_CrhBdvpw"
incoming="_HrkJULCvEduT5_CrhBdvpw _IKHtkLCvEduT5_CrhBdvpw">
<entry xmi:type="uml:Activity" xmi:id="_duUKoLC2EduT5_CrhBdvpw"
name="addOneMinuteToTimer"/>
</subvertex>
<transition xmi:id="_uU1xoLCuEduT5_CrhBdvpw" name="start"
target="_bojRoLCuEduT5_CrhBdvpw" source="_Z0mnwLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_9DYCoLCuEduT5_CrhBdvpw" name="doorOpened1_2"
target="_cQFywLCuEduT5_CrhBdvpw" source="_bojRoLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_9n9WYLCuEduT5_CrhBdvpw" name="doorClosed2_1"
target="_bojRoLCuEduT5_CrhBdvpw" source="_cQFywLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_EWx-0LCvEduT5_CrhBdvpw" name="doorClosed4_1"
target="_bojRoLCuEduT5_CrhBdvpw" source="_dMctULCuEduT5_CrhBdvpw"/>
<transition xmi:id="_E2xGcLCvEduT5_CrhBdvpw" name="doorOpened5_2"
target="_cQFywLCuEduT5_CrhBdvpw" source="_dt-GALCuEduT5_CrhBdvpw"/>
<transition xmi:id="_FSeLALCvEduT5_CrhBdvpw" name="doorOpened3_4"
target="_dMctULCuEduT5_CrhBdvpw" source="_cw8dELCuEduT5_CrhBdvpw"/>
<transition xmi:id="_FxH14LCvEduT5_CrhBdvpw" name="doorOpened6_4"
target="_dMctULCuEduT5_CrhBdvpw" source="_eerKMLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_GgxxMLCvEduT5_CrhBdvpw" name="buttonPressed1_3"
target="_cw8dELCuEduT5_CrhBdvpw" source="_bojRoLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_HHjdULCvEduT5_CrhBdvpw" name="buttonPressed5_3"
target="_cw8dELCuEduT5_CrhBdvpw" source="_dt-GALCuEduT5_CrhBdvpw"/>
<transition xmi:id="_HrkJULCvEduT5_CrhBdvpw" name="buttonPressed3_6"
target="_eerKMLCuEduT5_CrhBdvpw" source="_cw8dELCuEduT5_CrhBdvpw"/>
<transition xmi:id="_IKHtkLCvEduT5_CrhBdvpw" name="buttonPressed6_6"
kind="internal" target="_eerKMLCuEduT5_CrhBdvpw"
<transition xmi:id="_IsyVwLCvEduT5_CrhBdvpw" name="timerTimesOut6_5"
target="_dt-GALCuEduT5_CrhBdvpw" source="_eerKMLCuEduT5_CrhBdvpw"/>
<transition xmi:id="_mg4QoLCvEduT5_CrhBdvpw" name="timerTimesOut3_5"
target="_dt-GALCuEduT5_CrhBdvpw" source="_cw8dELCuEduT5_CrhBdvpw"/>
</region>
</ownedBehavior>
</packagedElement>
</uml:Model>
"Paul Sentosa" <psentosa@yahoo.com> schrieb im Newsbeitrag
news:epoli9$b5p$2@utils.eclipse.org...
> Hi all,
Unfortunately
> Regards
> Paul
    (Size: 4.51KB, Downloaded 191 times)
Re: Questions to Sequence Diagram [message #469815 is a reply to message #469722] Wed, 31 January 2007 10:31 Go to previous messageGo to next message
Hi Paul,
Just having a quick glance over this model, it looks like you are missing
Triggers and Events for the triggers on your transitions. Also, as you
mentioned, entry criteria is also missing.
Have a look at the superstructure spec for details
http://www.omg.org/docs/ptc/06-04-02.pdf of state chart diagrams. That
fully describes all the ins and outs of the UML metamodel. Watch out for
the constraints.
For situations like these, a good UML tool would come in handy :) If you
come across a good one for state charts let us know.
Also, try to run validation on your UML metamodel. Not all the validation
rules are implemented but it might be of some use.
- James.
"Paul Sentosa" <psentosa@yahoo.com> wrote in message
news:epom1h$c7u$1@utils.eclipse.org...
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </region>
> </ownedBehavior>
> </packagedElement>
> </uml:Model>
> > Hi all,
> Unfortunately
elements
diagram
> > Regards
> > Paul
Re: Questions to Sequence Diagram [message #469822 is a reply to message #469815] Wed, 31 January 2007 17:10 Go to previous messageGo to next message
Hi James,
thanks again for the tip.
Yes, a UML tool would be very helpful in this case, unfortunately I haven't
found any either.
I tried to find the information I needed from the spec, but somehow I'm
still not sure with what I got.
Just want to confirm what I made (referring to your comment before):
For behavior on the entry : New Child (of State) > Entry Activity (I made
this already on the example I sent)
For behavior within a state: New Child (of State) > Do Activity Activity
I also define a trigger for each transition and each of these is connected
to an event (defined outside the StateMachine, on the same "level" as
Class).
Sorry for the repeated questions but it's quite difficult for me to find out
everything from the spec
Many thanks
Paul
"James Bruck" <jbruck@ca.ibm.com> schrieb im Newsbeitrag
news:epqcp9$c2o$2@utils.eclipse.org...
> Hi Paul,
> the constraints.
> Regards,
> - James.
> > <?xml version="1.0" encoding="UTF-8"?>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </region>
> > </ownedBehavior>
> > </packagedElement>
> > </uml:Model>
> > > Hi all,
> > Unfortunately
> elements
> diagram
> > > Regards
> > > Paul
a
Re: Questions to Sequence Diagram [message #469829 is a reply to message #469822] Thu, 01 February 2007 16:17 Go to previous messageGo to next message
Sorry...one more question please to this topic:
how can I define more than one activities within a state? (as seen in the
example, there are more than one methods to define within one state).
The option "Do Activity Activity can be used only once, and also according
to the spec : doActivity::Behavior[0..1].
Or do we have to use something else to define the methods?
Paul
news:epr44q$hs4$1@utils.eclipse.org...
> Hi James,
haven't
> found any either.
> Class).
out
> Many thanks
> Regards
> Paul
> > Hi Paul,
missing
That
for
> > the constraints.
you
validation
> > Regards,
> > - James.
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </region>
> > > </ownedBehavior>
> > > </packagedElement>
> > > </uml:Model>
> > > > Hi all,
> > > Unfortunately
> > elements
> > diagram
> > > > Regards
> > > > Paul
within
> a
Re: Questions to Sequence Diagram [message #470081 is a reply to message #469829] Mon, 05 February 2007 18:12 Go to previous messageGo to next message
Hi Paul,
There are 3 special kinds of internal behavior. 'entry', 'do' and 'exit'.
The 'do' behavior is a behavior that is ongoing while the state is active.
The activity can make reference to BehavioralFeatures.... Operations are
Behavioral Features.
You might want to create an Activity Diagram to model the behavior of your
doActivity.
From the spec, there doesn't seem to be a way to add arbitrary number of
Activities to a State.
Hope this helps.
- James.
news:eptlcg$u50$1@utils.eclipse.org...
> Thanks
> Paul
> > Hi James,
> haven't
> > found any either.
made
connected
> > Class).
> out
> > Many thanks
> > Regards
> > Paul
> > > Hi Paul,
> missing
you
> That
> for
> > > the constraints.
> you
> validation
> > > Regards,
> > > - James.
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </region>
> > > > </ownedBehavior>
> > > > </packagedElement>
> > > > </uml:Model>
> > > > > Hi all,
> > > > Unfortunately
> > > elements
> > > diagram
> > > > > Regards
> > > > > Paul
> within
> > a
Re: Questions to Sequence Diagram [message #470143 is a reply to message #470081] Wed, 07 February 2007 12:31 Go to previous message
Once again, many thanks for the explanation.
Paul
news:eq8dkb$8u9$2@utils.eclipse.org...
> Hi Paul,
'exit'.
> doActivity.
> Hope this helps.
> - James.
the
according
> > Thanks
> > Paul
> > > Hi James,
> > haven't
> > > found any either.
I'm
> made
Activity
> connected
> > > Class).
find
> > out
> > > Many thanks
> > > Regards
> > > Paul
> > > > Hi Paul,
> > missing
> you
> > That
out
> > for
> > > > the constraints.
If
> > you
> > validation
> > > > Regards,
> > > > - James.
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </region>
> > > > > </ownedBehavior>
> > > > > </packagedElement>
> > > > > </uml:Model>
> > > > > > Hi all,
> > > > > Unfortunately
> > > > elements
the
> > > > diagram
> > > > > > Regards
> > > > > > Paul
> > within
> > > a
Re: Questions to Sequence Diagram [message #576917 is a reply to message #469721] Tue, 30 January 2007 18:57 Go to previous message
</subvertex>
</subvertex>
</subvertex>
</subvertex>
</subvertex>
</subvertex>
</region>
</ownedBehavior>
</packagedElement>
</uml:Model>
> Hi all,
Unfortunately
> Regards
> Paul
    (Size: 4.51KB, Downloaded 161 times)
Re: Questions to Sequence Diagram [message #578832 is a reply to message #469722] Wed, 31 January 2007 10:31 Go to previous message
Hi Paul,
the constraints.
- James.
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </subvertex>
> </region>
> </ownedBehavior>
> </packagedElement>
> </uml:Model>
> > Hi all,
> Unfortunately
elements
diagram
> > Regards
> > Paul
Re: Questions to Sequence Diagram [message #579053 is a reply to message #469815] Wed, 31 January 2007 17:10 Go to previous message
Hi James,
found any either.
Class).
Many thanks
Paul
> Hi Paul,
> the constraints.
> Regards,
> - James.
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </subvertex>
> > </region>
> > </ownedBehavior>
> > </packagedElement>
> > </uml:Model>
> > > Hi all,
> > Unfortunately
> elements
> diagram
> > > Regards
> > > Paul
a
Re: Questions to Sequence Diagram [message #579252 is a reply to message #469822] Thu, 01 February 2007 16:17 Go to previous message
Paul
> Hi James,
haven't
> found any either.
> Class).
out
> Many thanks
> Regards
> Paul
> > Hi Paul,
missing
That
for
> > the constraints.
you
validation
> > Regards,
> > - James.
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </subvertex>
> > > </region>
> > > </ownedBehavior>
> > > </packagedElement>
> > > </uml:Model>
> > > > Hi all,
> > > Unfortunately
> > elements
> > diagram
> > > > Regards
> > > > Paul
within
> a
Re: Questions to Sequence Diagram [message #582187 is a reply to message #469829] Mon, 05 February 2007 18:12 Go to previous message
Hi Paul,
doActivity.
Hope this helps.
- James.
> Thanks
> Paul
> > Hi James,
> haven't
> > found any either.
made
connected
> > Class).
> out
> > Many thanks
> > Regards
> > Paul
> > > Hi Paul,
> missing
you
> That
> for
> > > the constraints.
> you
> validation
> > > Regards,
> > > - James.
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </subvertex>
> > > > </region>
> > > > </ownedBehavior>
> > > > </packagedElement>
> > > > </uml:Model>
> > > > > Hi all,
> > > > Unfortunately
> > > elements
> > > diagram
> > > > > Regards
> > > > > Paul
> within
> > a
Re: Questions to Sequence Diagram [message #583094 is a reply to message #470081] Wed, 07 February 2007 12:31 Go to previous message
Paul
> Hi Paul,
'exit'.
> doActivity.
> Hope this helps.
> - James.
the
according
> > Thanks
> > Paul
> > > Hi James,
> > haven't
> > > found any either.
I'm
> made
Activity
> connected
> > > Class).
find
> > out
> > > Many thanks
> > > Regards
> > > Paul
> > > > Hi Paul,
> > missing
> you
> > That
out
> > for
> > > > the constraints.
If
> > you
> > validation
> > > > Regards,
> > > > - James.
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </subvertex>
> > > > > </region>
> > > > > </ownedBehavior>
> > > > > </packagedElement>
> > > > > </uml:Model>
> > > > > > Hi all,
> > > > > Unfortunately
> > > > elements
the
> > > > diagram
> > > > > > Regards
> > > > > > Paul
> > within
> > > a
Previous Topic:UML Profile for extended metadata
Next Topic:A suggestion for user-friendly typing
Current Time: Sat Jul 19 23:25:11 EDT 2025
Powered by FUDForum. Page generated in 0.14567 seconds
