Home » Modeling » UML2 » strange behavior when defining a profile
strange behavior when defining a profile [message #469706] |
Mon, 29 January 2007 02:21  |
When I define the following profile named 'sample_profile':
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_O3cisK9mEduaoJ8VsHbaPQ" name="sample_profile">
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_P7ic8K9mEduaoJ8VsHbaPQ" name="sample_stereotype">
<ownedAttribute xmi:id="_Xjqr8K9mEduaoJ8VsHbaPQ" name="myProperty">
<type xmi:type="uml:PrimitiveType"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Integer"/>
</ownedAttribute>
</packagedElement>
</uml:Profile>
It results in a EPackage instance that describes the UML metamodel.
Also, if I try to apply this profile to any models I build, the model is
persisted in a way that stereotype applications are lost. The reason
seems to be that the XMI for such a model refers to stereotypes coming
from 'sample_profile' as if they were coming from 'uml':
<xmi:XMI xmi:version="2.1" (...)>
<uml:Model xmi:id="_2YHtEK9lEdu8D5FNufO7zw" name="sample_model">
</uml:Model>
<uml:sample_stereotype (...) />
</xmi:XMI>
Instead, I would expect the stereotype applications to appear as:
<sample_profile:sample_stereotype (...) />
The trigger to this problem seems to be that I am referring to a type
from the uml package (integer). If I remove the reference, the problem
goes away.
Am I doing anything wrong to cause this, or is this a bug?
Rafael
Re: strange behavior when defining a profile [message #469714 is a reply to message #469712] |
Mon, 29 January 2007 13:44   |
Thanks, Kenn, I opened bug 172030:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172030
> The reason for this behavior is that you have directly referenced a
> primitive type (Integer) from the metamodel instead of from the
> primitive types library (only metaclasses from the metamodel
> should be directly referenced)
Is there a place where one can learn about rules like that?
In the specific case, should my profile be importing UMLPrimitiveTypes
instead (and references to uml::Integer be changed to
UMLPrimitiveTypes::Integer)?
Rafael
Kenn Hussey wrote:
> Rafael,
> primitive type (Integer) from the metamodel instead of from the primitive
> types library (only metaclasses from the metamodel should be directly
> referenced). With the current profile definition algorithm, metadata from
> packages other than the profile being defined are copied into the definition
> of the profile. This won't necessarily be the case once we fix
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=163556. Please update that bug
> or open a new one so that we'll remember to cover your use case. Thanks!
> Kenn
> "Rafael Chaves" <chaves@inf.ufsc.nospam.br> wrote in message
> news:epk79s$ith$1@utils.eclipse.org...
>> <?xml version="1.0" encoding="UTF-8"?>
>> </ownedAttribute>
>> </packagedElement>
>> </uml:Profile>
>> It results in a EPackage instance that describes the UML metamodel. Also,
>> persisted in a way that stereotype applications are lost. The reason seems
>> to be that the XMI for such a model refers to stereotypes coming from
>> </uml:Model>
>> </xmi:XMI>
>> The trigger to this problem seems to be that I am referring to a type from
>> the uml package (integer). If I remove the reference, the problem goes
>> away.
>> Thanks,
>> Rafael
Re: strange behavior when defining a profile [message #470059 is a reply to message #469714] |
Mon, 05 February 2007 14:54   |
Rafael,
The "expected" way to use primitive types is described in the articles
available at http://wiki.eclipse.org/index.php/MDT-UML2#Articles. Strictly
speaking, there's nothing wrong with a profile referencing a primitive type
defined in another model or profile...
Kenn
news:eplf98$bv0$1@utils.eclipse.org...
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> definition of the profile. This won't necessarily be the case once we fix
>> bug or open a new one so that we'll remember to cover your use case.
>> Thanks!
>> Kenn
>>> </ownedAttribute>
>>> </packagedElement>
>>> </uml:Profile>
>>> </uml:Model>
>>> </xmi:XMI>
>>> goes away.
>>> Thanks,
>>> Rafael
Re: strange behavior when defining a profile [message #470088 is a reply to message #470059] |
Mon, 05 February 2007 18:36  |
It seems I am doing it properly now.
> Strictly
> type defined in another model or profile...
Yes, I understand that. The problem in this specific case was that the
primitive types in "uml" were private and I hadn't noticed it.
Thanks!
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> Thanks,
>> Rafael
>> Kenn Hussey wrote:
>>> Rafael,
>>> Thanks!
>>> Kenn
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </uml:Profile>
>>>> </uml:Model>
>>>> </xmi:XMI>
>>>> goes away.
>>>> Thanks,
>>>> Rafael
Re: strange behavior when defining a profile [message #576673 is a reply to message #469706] |
Mon, 29 January 2007 11:46  |
Rafael,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163556 Please update that bug
Kenn
> </ownedAttribute>
> </packagedElement>
> </uml:Profile>
> </uml:Model>
> </xmi:XMI>
> away.
> Rafael
Re: strange behavior when defining a profile [message #576764 is a reply to message #469712] |
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> </ownedAttribute>
>> </packagedElement>
>> </uml:Profile>
>> </uml:Model>
>> </xmi:XMI>
>> away.
>> Thanks,
>> Rafael
Re: strange behavior when defining a profile [message #582027 is a reply to message #469714] |
Rafael,
available at http://wiki.eclipse.org/index.php/MDT-UML2#Articles Strictly
Kenn
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> Thanks!
>> Kenn
>>> </ownedAttribute>
>>> </packagedElement>
>>> </uml:Profile>
>>> </uml:Model>
>>> </xmi:XMI>
>>> goes away.
>>> Thanks,
>>> Rafael
Re: strange behavior when defining a profile [message #582231 is a reply to message #470059] |
> Strictly
Thanks!
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> Thanks,
>> Rafael
>> Kenn Hussey wrote:
>>> Rafael,
>>> Thanks!
>>> Kenn
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </uml:Profile>
>>>> </uml:Model>
>>>> </xmi:XMI>
>>>> goes away.
>>>> Thanks,
>>>> Rafael
Current Time: Sun Jul 20 03:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.07255 seconds
