Editor error [message #469673] |
Tue, 12 May 2009 15:15  |
I'm using the COBOL 3.4 plugin with OpenSUSE 11.1 and the provided Eclipse
(Ganymede, 3.4). It appears to integrate OK. When I try to edit a new
COBOL program or open an existing COBOL program (from the filesystem), I
get the following error:
Could not open the editor: The editor class could not be instantiated.
This usually indicates a missing no-arg constructor or that the editor's
class name was mistyped in plugin.xml.
When I click on Details>> I get the following:
java.lang.NoClassDefFoundError: org/eclipse/swt/custom/StyledText2
at org.eclipse.cobol.ui.editor.COBOLEditor.<init>(COBOLEditor.java:558)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:57)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 32)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:233)
at
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:846)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
at
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
at
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1361)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.swt.custom.StyledText2
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336 )
... 53 more
I've search many places for an error like this and have yet to find a
solution. Any help would be appreciated. Thanks.
Rich.
FUDForum. Page generated in 0.03654 seconds
