OpenCOBOL what's needed [message #469668] |
Tue, 02 September 2008 16:16  |
I'm already using OpenCOBOL for some research work. I installed the
platform plugin, but I don't have a license to install the FUJITSU plugin.
I though that the platform plugin would work just as a COBOL editor, but
it seems to not work without the FUJITSU portion.
If I were to create a plugin to support OpenCOBOL and enable the COBOL
platform plugin to work with OpenCOBOL, what would I need to do? Is there
a particular set of interfaces I need to implement to make this work?
Re: OpenCOBOL what's needed [message #513925 is a reply to message #512977] |
Thu, 11 February 2010 12:00  |
Ibrahim wrote:
> Hello,
> I have problem by running Cobol's program. i have installed Cobol in
> Eclipse,when i click to run the program,it shows in the console that The
> system cannot find the file cobcrun.
> how can i fix this problem?
> Thank you Ibrahim.
Ibrahim, I can't answer your question, but did want to say that the
Eclipse COBOL Project is being terminated. Its downloads, etc., will
soon be archived and removed (including this news group!) so just didn't
want to have it disappear on you without at least responding to tell you
it will disappear.
FUDForum. Page generated in 0.12668 seconds
